  2. Feature Requests
  3. Additional sleep methods with array of pins as parameters ?
Scheduled Pinned Locked Moved Feature Requests
24 Posts 5 Posters 6.0k Views 5 Watching
    So there would be a global variable called interrupt_cause? If that's the case, it should probably be renamed to latest_interrupt_cause since it may be updated at any time.
    Would there be a return value of sleep() that tells whether the user should check this global variable, or how would they know to check it?
    wrote on last edited by Nca78
    @mfalkvidd said in Additional sleep methods with array of pins as parameters ?:
    No that's just in my code for nrf51 that is just some kind of "proof of concept" that pin sense works with MySensors and that it solves the hardware bug creating a 1ma power consumption with other methods. Of course all of that must be wrapped into much more user friendly methods if included in MySensors.
    I think a "mySleepResult" structure like in my previous message (https://forum.mysensors.org/topic/9234/additional-sleep-methods-with-array-of-pins-as-parameters/8) is a better idea, with all information about the sleep summed up in one place, with some additional helper functions to check if a specific pin has changed (and in which direction) or not. If we don't do that it will be too complicated for the "non-programmer" user to retrieve information.
    For user the basic process to use it would be :
    • I declare the pins I want to watch (in theory as many pins as wanted)
    • I call the "advancedSleep" (or whatever name we give it) method
    • I get a simple return value (similar to now) telling me if there was an error, if it's the end of sleep duration or give me the (first) pin that triggered the wake up
    • If I want to get more detailed information (direction of pin change, check multiple pins, duration of sleep to restart sleeping only for remaining time in original delay, ...) then I can check the global instance of the structure (MySleepResult) or call the helper methods.
    • Nca78N Nca78
      @nca78 said in Additional sleep methods with array of pins as parameters ?:
      I'm glad you're working on this!
      For possible inspiration, there is precedent for calling a function/method for each pin that you want to set as an interrupt. For instance, for regular arduino's, the call might be:
        pciSetup(7);
        pciSetup(8);
        pciSetup(9);
        pciSetup(A0);
      as illustrated by the sketch at: https://playground.arduino.cc/Main/PinChangeInterrupt
      That said, I'm entirely neutral about how it gets done.
      Nca78N 1 Reply Last reply
          pciSetup(7);
          pciSetup(8);
          pciSetup(9);
          pciSetup(A0);
        @neverdie thank you for the link I didn't remember about that, I will have a look.
          @nca78 I think functionality like that would be nice. As you've already identified, there needs to be some user-friendly way to know which interrupt was triggered. I guess there also needs to be a way to specify the type of interrupt for each pin.
          Arduino's attachInterrupt is a pretty clean way. You call it as many times as you like, with the pins you want. So no need to handle arrays. The downside is that the user needs to write their own interrupt handler. There are lots of no-no's in interrupt handlers (don't print to serial, millis() wont increment, etc) so it would be nice if we can avoid forcing people to learn all that.
          Code could look like this maybe
            myAttachInterrupt(digitalPinToInterrupt(pin1), LOW));
            myAttachInterrupt(digitalPinToInterrupt(pin2), CHANGE));
            myAttachInterrupt(digitalPinToInterrupt(pin3), HIGH));
            Serial.println("Waiting for interrupt or sleep time expiring");
            int8_t result = sleep(SLEEP_TIME);
            switch (result) {
              case MY_WAKE_UP_BY_TIMER:
                // Woke up by timer
                // Do periodic stuff here
              case MY_SLEEP_NOT_POSSIBLE:
                // Unable to sleep
              case digitalPinToInterrupt(pin1):
                // pin1 was triggered
              case digitalPinToInterrupt(pin2):
                // pin2 was triggered
              case digitalPinToInterrupt(pin3):
                // pin3 was triggered
          sleep already returns the interrupt number that triggered the wakeup, so as long as all boards use interrupts between 0 and 127 there should be no need to change the return behavior.
          alexsh1A
          alexsh1A
          alexsh1
          Sorry to chip in, but what's myAttachInterrupt function please?
          Do you also have to do:
          pinMode(pin2, INPUT);
          • alexsh1A alexsh1
            @alexsh1 chipping in is great :) I don’t know what would be in it, I was just outlining how using the new feature could look like from a sketch developer’s perspective.
            I don’t think sketch developer should need to worry about setting the pin to input, except maybe if they want to activate a pullup/pulldown feature (if the mcu supports it).
            alexsh1A YveauxY 2 Replies Last reply
              alexsh1A
              alexsh1A
              alexsh1
              @mfalkvidd OK, I was concerned it was something already implemented and I did not know about it.
              I'd rather leave it as is. I know the idea is to avoid interrupt handlers, but we need to re-think and re-write the sketch code so that we only use volatile variables for true/false statements.
                Yes, they have to set it to input. There's no pin configuration in the (AVR) sleep code: https://github.com/mysensors/MySensors/blob/development/hal/architecture/AVR/MyHwAVR.cpp#L153
                Nca78N mfalkviddM 2 Replies Last reply
                • YveauxY Yveaux
                  @yveaux said in Additional sleep methods with array of pins as parameters ?:
                  But atmega pins default as inputs so it's not really mandatory with the default IC.
                  • Nca78N Nca78
                    #21
                    I like to make things explicit, especially if you decide to port to another architecture later on
                    • YveauxY Yveaux
                      I like to make things explicit, especially if you decide to port to another architecture layer on
                      I completely agree with you. Just stating that @mfalkvidd is not wrong when saying at the moment it's not necessary to declare pins as inputs
                      To go back to the main subject should I make a first version of this code (in post 9) to have a clearer basis for future discussions ? Or am I going a wrong way ?
                        Anything is always better than nothing.
                        • YveauxY Yveaux
                          @yveaux clarification: imho, if support for many interrupts is added in a future version of MySensors (which is what we're discussing in this thread), sketch developers should not need to manually call pinMode.
                          12.5k
