  3. Barometric Pressure Sensor Using MS5637
23 Posts 4 Posters 11.2k Views 1 Watching
    Myles L
    By adding those changes it went back to not outputting to the serial interface. I was able to get it to output again by removing the DEFINE DEVICE ID and the DEVICE ID section (not sure why that made a difference) but then it goes back to only adding a node to Vera.
    Really appreciate your determination to solve this and I am learning lots along the way!
    • M Myles L
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Myles-L
      you mind posting the code you tried last?
      Can you confirm that you have deleted the Vera devices that were created (I believe you said it was a relay)
        Myles L
        I have deleted the Vera devices and I have also tried removing and re-adding the MySensors plugin in Vera. When I add the pressure sensor now it still adds as a node. Code is below:
        #include <BaroSensor.h>
        #define BARO_CHILD 0
        #define TEMP_CHILD 1
        unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in seconds)
        float lastPressure = -1;
        float lastTemp = -1;
        int lastForecast = -1;
        int minutes;
        float pressureSamples[180];
        int minuteCount = 0;
        bool firstRound = true;
        float pressureAvg[7];
        float dP_dt;
        boolean metric;
        MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
        gw.begin(NULL, false);
        gw.sendSketchInfo("Pressure Sensor", "1.0");
        delay(1000);
        BaroSensor.begin();
        delay(1000);
        // Register sensors to gw (they will be created as child devices)
        gw.present(BARO_CHILD, S_BARO);
        delay(1000);
        gw.present(TEMP_CHILD, S_TEMP);
        delay(1000);
        if(!BaroSensor.isOK())
        Serial.print("Sensor not Found/OK. Error: ");
        Serial.println(BaroSensor.getError());
        BaroSensor.begin(); // Try to reinitialise the sensor if we can
        float pressure = BaroSensor.getPressure()/100;
        float temperature = BaroSensor.getTemperature();
        if (!metric)
        // Convert to fahrenheit
        temperature = temperature * 9.0 / 5.0 + 32.0;
        int forecast = sample(pressure);
        Serial.print("Temperature = ");
        Serial.print(temperature);
        Serial.println(metric?" *C":" *F");
        Serial.print("Pressure = ");
        Serial.print(pressure);
        Serial.println(" Pa");
        if (temperature != lastTemp) {
        gw.send(tempMsg.set(temperature,1));
        lastTemp = temperature;
        if (pressure != lastPressure) {
        gw.send(pressureMsg.set(pressure, 0));
        lastPressure = pressure;
        if (forecast != lastForecast)
        gw.send(forecastMsg.set(weather[forecast]));
        lastForecast = forecast;
        DP/Dt explanation
        0 = "Stable Weather Pattern"
        1 = "Slowly rising Good Weather", "Clear/Sunny "
        2 = "Slowly falling L-Pressure ", "Cloudy/Rain "
        3 = "Quickly rising H-Press", "Not Stable"
        4 = "Quickly falling L-Press", "Thunderstorm"
        5 = "Unknown (More Time needed)
        gw.sleep(SLEEP_TIME);
        int sample(float pressure) {
        // Algorithm found here
        if (minuteCount > 180)
        minuteCount = 6;
        pressureSamples[minuteCount] = pressure;
        minuteCount++;
        if (minuteCount == 5) {
            // Avg pressure in first 5 min, value averaged from 0 to 5 min.
            pressureAvg[0] = ((pressureSamples[1] + pressureSamples[2]
                    + pressureSamples[3] + pressureSamples[4] + pressureSamples[5])
                    / 5);
        } else if (minuteCount == 35) {
            // Avg pressure in 30 min, value averaged from 0 to 5 min.
            pressureAvg[1] = ((pressureSamples[30] + pressureSamples[31]
                    + pressureSamples[32] + pressureSamples[33]
                    + pressureSamples[34]) / 5);
            float change = (pressureAvg[1] - pressureAvg[0]);
                dP_dt = ((65.0 / 1023.0) * 2 * change); // note this is for t = 0.5hour
                dP_dt = (((65.0 / 1023.0) * change) / 1.5); // divide by 1.5 as this is the difference in time from 0 value.
        } else if (minuteCount == 60) {
            // Avg pressure at end of the hour, value averaged from 0 to 5 min.
            pressureAvg[2] = ((pressureSamples[55] + pressureSamples[56]
                    + pressureSamples[57] + pressureSamples[58]
                    + pressureSamples[59]) / 5);
            float change = (pressureAvg[2] - pressureAvg[0]);
                dP_dt = ((65.0 / 1023.0) * change); //note this is for t = 1 hour
                dP_dt = (((65.0 / 1023.0) * change) / 2); //divide by 2 as this is the difference in time from 0 value
        } else if (minuteCount == 95) {
            pressureAvg[3] = ((pressureSamples[90] + pressureSamples[91]
                    + pressureSamples[92] + pressureSamples[93]
                    + pressureSamples[94]) / 5);
            float change = (pressureAvg[3] - pressureAvg[0]);
                dP_dt = (((65.0 / 1023.0) * change) / 1.5); // note this is for t = 1.5 hour
                dP_dt = (((65.0 / 1023.0) * change) / 2.5); // divide by 2.5 as this is the difference in time from 0 value
        } else if (minuteCount == 120) {
            pressureAvg[4] = ((pressureSamples[115] + pressureSamples[116]
                    + pressureSamples[117] + pressureSamples[118]
                    + pressureSamples[119]) / 5);
            float change = (pressureAvg[4] - pressureAvg[0]);
                dP_dt = (((65.0 / 1023.0) * change) / 2); // note this is for t = 2 hour
                dP_dt = (((65.0 / 1023.0) * change) / 3); // divide by 3 as this is the difference in time from 0 value
        } else if (minuteCount == 155) {
            pressureAvg[5] = ((pressureSamples[150] + pressureSamples[151]
                    + pressureSamples[152] + pressureSamples[153]
                    + pressureSamples[154]) / 5);
            float change = (pressureAvg[5] - pressureAvg[0]);
                dP_dt = (((65.0 / 1023.0) * change) / 2.5); // note this is for t = 2.5 hour
                dP_dt = (((65.0 / 1023.0) * change) / 3.5); // divide by 3.5 as this is the difference in time from 0 value
        } else if (minuteCount == 180) {
            pressureAvg[6] = ((pressureSamples[175] + pressureSamples[176]
                    + pressureSamples[177] + pressureSamples[178]
                    + pressureSamples[179]) / 5);
            float change = (pressureAvg[6] - pressureAvg[0]);
                dP_dt = (((65.0 / 1023.0) * change) / 3); // note this is for t = 3 hour
                dP_dt = (((65.0 / 1023.0) * change) / 4); // divide by 4 as this is the difference in time from 0 value
            pressureAvg[0] = pressureAvg[5]; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
            return 5; // Unknown, more time needed
        else if (dP_dt < (-0.25))
            return 4; // Quickly falling LP, Thunderstorm, not stable
        else if (dP_dt > 0.25)
            return 3; // Quickly rising HP, not stable weather
            return 2; // Slowly falling Low Pressure System, stable rainy weather
            return 1; // Slowly rising HP stable good weather
        else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
            return 0; // Stable weather
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @BulldogLowell said:
          Try this, and tell me what the serial output looks like.
          Have you added a capacitor to the radio? It could be electronic...
          #define DEVICE_ID 99
          int minutes;
          float dP_dt;
          boolean metric;
            gw.begin(NULL, DEVICE_ID, false);
            delay(1000);
            Serial.println("Got to GW.Begin");
            Serial.println("Sketch data Presented");
            delay(1000);
            BaroSensor.begin();
            Serial.println("Brometer Sensor started...");
            delay(1000);
            Serial.println("presenting Barometer");
            delay(1000);
            Serial.println("presenting Thermometer");
            delay(1000);
            Serial.println("requesting Metric");
            delay(1000);
            Serial.println("Setup Complete");
            Myles L
            The Sensor and Ethernet gateway both have 4.7uf electrolytic capacitors across the power input of the radio's (I cant get much distance out of them, maybe <10 metres, but they do work for the relay sensor).
            The serial output looks like this: ��Ah���Y5����������i��`q!���J�����
              Myles L
              Using that sketch I was able to add it to Vera, it just does not report pressure or forecast (obviously as there is no data being presented to it)
              • BulldogLowellB
                BulldogLowellB
                BulldogLowell
                Great, now just plug the loop() back into the sketch, flash your arduino, and you should be good to go
                oh... and add a Serial.begin(yourDesiredBaudRate) to setup() ;)
                  Myles L
                  Ok, so close! Adding back the rest I get and endless string of � in the serial monitor and nothing adds to Vera.
                  I don't actually need the temp (tried commenting it out but could not get it to compile) if that makes it easier?
                  Here is what I have:
                  int minutes;
                  float dP_dt;
                  boolean metric;
                  Serial.begin(9600);
                  delay(1000);
                  delay(1000);
                  BaroSensor.begin();
                  delay(1000);
                  delay(1000);
                  delay(1000);
                  delay(1000);
                  if (!metric)
                  Serial.println(metric?" C":" F");
                  DP/Dt explanation
                  minuteCount = 6;
                  minuteCount++;
                  / 5);
                  • M Myles L
                    int minutes;
                    float dP_dt;
                    boolean metric;
                    Serial.begin(9600);
                    delay(1000);
                    delay(1000);
                    BaroSensor.begin();
                    delay(1000);
                    delay(1000);
                    delay(1000);
                    delay(1000);
                    if (!metric)
                    DP/Dt explanation
                    minuteCount = 6;
                    minuteCount++;
                    / 5);
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @Myles-L
                    hard to read your code like that...
                    indent your code 4 spaces or put it between three ` [backwards apostrophe just left of the 1 on your keyboard]
                    are you sure your serial monitor is set to the correct speed?
                    I'd leave compilable alone until you get the devices set up... you didn't delete the vera devices after you got them set with the correct device number before, right?
                      Myles L
                      I did delete it but understand now why I shouldn't have. I will re-add it (different device id) and let you know. It may take a little while as I am waiting for some radios with external antennas and an finding in the meantime that my radio reception is too limited to proceed.
