  3. Sonoff 433 bridge
Sonoff 433 bridge
13 Posts 4 Posters 6.9k Views 3 Watching
  • alowhumA
    alowhumA
    alowhum
    So Sonoff has this cure little hockey-puck device called the Sonoff 433 Bridge.
    https://www.aliexpress.com/item/Brand-Sonoff-RF-Bridge-433-Smart-Home-Automation-Module-Universal-Wifi-Wireless-Switch-Controller-Diy-433Mhz/32837854717.html
    Some people have hacked it to run as a MQTT gateway for 433 signals.
    https://github.com/1technophile/OpenMQTTGateway
    (and you can add IR too if you want)
    I know there is a ESP8266 gateway for MySensors. Perhaps for the 433Mhz crowd this could be a nice ready-to-go device? I don't know :-)
    Could this work with encryption/signing?
    alexsh1A 1 Reply Last reply
    • alowhumA alowhum
      alexsh1A
      alexsh1A
      alexsh1
      @alowhum I ditched almost all my 433Mhz devices. There is no ack. Why would want to have one? a simple esp-01 with let's control it firmware connected to your Wifi or Sonoff with the same firmware performs way much better in terms of reliability.
      • alowhumA
        alowhumA
        alowhum
        For security reasons I want to have the fewest ARM based Wifi connected devices in my home possible.
        • alowhumA alowhum
          alexsh1A
          alexsh1A
          alexsh1
          @alowhum I do not understand your issues with security. It does not have to be Wifi by the way.
          I may be mistaken, but I do not think you'd find a lot of support for 433Mhz around.
          • alowhumA
            alowhumA
            alowhum
            Cheap Wifi-based IOT chips are extremely dubious. The NSA and others even use the ARM chips inside harddrives to create unremovable trojans, so hacking these IOT devices is nothing compared to that.
            https://www.reddit.com/r/esp8266/comments/58q9wi/are_we_building_weapons_of_mass_destruction_our/
            https://github.com/esp8266/Arduino/issues/3725
            https://olimex.wordpress.com/2015/07/17/esp8266-has-now-lot-of-followers-but-they-do-not-offer-anything-better/
            • alexsh1A alexsh1
              zboblamontZ
              zboblamontZ
              zboblamont
              @alexsh1 I use 433MHz exclusively for local networks as it has proven completely reliable and resilient, and I am far from being alone..
              Your " I do not think you'd find a lot of support for 433Mhz around" may prove a flawed perspective. Frequencies and traffic are increasingly cramped, no more so in the burgeoning 2.4 and 5GHz environment, 433 etc are of increasing interest I suggest, not less..
              • alowhumA alowhum
                alexsh1A
                alexsh1A
                alexsh1
                @alowhum intereeting - I do not know about it, but my preference would be Wifi for a different reason. I’d like to make home automation independent and not dependent on WiFi
                • zboblamontZ zboblamont
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @zboblamont feel free to disagree. Firstly, I use 868Mhz and 2.4Ghz. 2.4Ghz has got many channel so if properly setup, congestion is completey irrelevant. And secondly, the major reason I ditched all my 433Mhz nodes was due to the fact that it does not have ack. I even considered buying RFXCOMM. I have used 433Mhz setup with remote water heating and once it did not work. It was enough for me to switch to a different technology.
                  I still have one LightwaveRF switch (433Mhz) which I’m controlling remotely, but i’ll get rid of that eventually too.
                  • alowhumA
                    alowhumA
                    alowhum
                    I think the confusion is that this thread is about using a protocol that DOES have ACK (MySensors) on the 433 frequency. So while a lot of cheap devices without ACK happen to use the 433 frequency, any problem lies not with the frequency, but with the protocol used.
                    • alowhumA alowhum
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @alowhum I did not mean MySensors as MySensors do have ack.
                      I meant any other 433Mhz technology without ACK.
                      Re your bridge, by chance I found the following link on the Domoticz Forum:
                      http://tinkerman.cat/hacking-sonoff-rf-bridge-433/#lightbox-gallery-c9PV/10/
                      • alowhumA
                        alowhumA
                        alowhum
                        Yes I've seen that link.
                        I started this thread to ask the question "could this hardware be used as a nice, cheap and powerful gateway for MySensors?".
                        Q 1 Reply Last reply
                        • alowhumA alowhum
                          Q
                          Q
                          quby
                          @alowhum As I see the topic is rather old, but I didn't find any other in this topic. So my question is the same: Can the sonoff RF bridge be used as a gateway for the mysensors 433 nodes?
                          • alowhumA
                            alowhumA
                            alowhum
                            @alexsh1 I've built something you might be interested in:
                            https://forum.mysensors.org/topic/10094/candle-433-hub-a-universal-433mhz-signal-cloner/1
