  3. 💬 MySensors Gateway for Raspberry PI
raspberrymysensors gateway
49 Posts 14 Posters 17.1k Views 12 Watching
  • pepsonP
    pepsonP
    pepson
    What you update info ?
    • llegoffL
      llegoffL
      llegoff
      edit file Makefile : replace the string mysgw by mysgwSecond (in nano use Ctrl + \ )
      copy file initscripts/mysgw.systemd and initscripts/mysgwSecond.sysvinit to initscripts/mysgwSecond.systemd and initscripts/mysgwSecond.sysvinit
      cp initscripts/mysgw.systemd initscripts/mysgwSecond.systemd
      cp initscripts/mysgwSecond.sysvinit initscripts/mysgwSecond.sysvinit
      edit file initscripts/mysgwSecond.systemd and initscripts/mysgwSecond.sysvinit : replace the string mysgw by mysgwSecond (in nano use Ctrl + \ ) and replace the string MySensors Gateway by MySensors Gateway 2
        sineverba
        Wonderful project... I did re-create on Eagle. First radio (RFM) works very well. Second instance, I got a wonderful... "Can't open SPI device: /dev/spidev1.0". After editing the boot/config.txt, need to reboot? Thank you very much
          sineverba
          Oh, also, need to re-write the instructions. In --development branch nowadays there is no option "-d" default start in debug mode... Just to help you wuth mantain instructions aligned
            You need reboot
            • S sineverba
              @sineverba instructions are aligned with the current stable version. We would confuse people mightily if the instructions did not work with stable.
              S 1 Reply Last reply
                sineverba
                @mfalkvidd said in 💬 MySensors Gateway for Raspberry PI:
                You write use development. ATM development doen't have anymore the -d flag ... But not a big problem at the end
                • S sineverba
                  @sineverba oh. I didn't know that. Sorry. where do we write to use development?
                    sineverba
                    @mfalkvidd I'm Sorry. For error I did confuse "official" page with OpenHardware project for double gateway. Sorry 😖
                    • S sineverba
                      @sineverba I see :) Thanks for clarifying.
                      12.5k
