  3. Vera
  4. S_RGB_LIGHT
S_RGB_LIGHT
2 Posts 1 Posters 1.8k Views 1 Watching
  • R
    R
    r-nox
    Using the code below I seem to be having trouble getting the control to show in the UI. When I include the device only the arduino node shows up.
    Where have I gone wrong?
    https://forum.mysensors.org/topic/7456/ws2812b-information-leds-blinking
    https://www.domoticz.com/forum/viewtopic.php?t=8039
    // Enable debug prints
     * @def MY_RF24_PA_LEVEL
     * - RF24_PA_MIN = -18dBm
     * - RF24_PA_LOW = -12dBm
     * - RF24_PA_HIGH = -6dBm
     * - RF24_PA_MAX = 0dBm
    // ENABLE REPEATER MODE
    //#define MY_REPEATER_FEATURE
    // ENABLE LOOP EVEN IF RADIO FAILS.
    #define MY_TRANSPORT_WAIT_READY_MS 15000
    #include <FastLED.h>
    const int stripPin = 4 ;                  // pin where 2812 LED strip is connected
    const int numPixel = 3 ;                  // set to number of pixels
    CRGB leds[numPixel];
    char actRGBvalue[] = "000000";               // Current RGB value
    uint16_t actRGBbrightness = 0xFF ;         // Controller Brightness
    int actRGBonoff=0;                        // OnOff flag
    #define CHILD_ID 0
    MyMessage lastColorStatusMsg(CHILD_ID,V_VAR1);
      FastLED.addLeds<NEOPIXEL, stripPin >(leds, numPixel); // initialize led strip
      // Flash the "hello" color sequence: R, G, B, black.
      colorBars();
     //begin(incomingMessage, NODE_ID, false);      // initialize MySensors
     sendSketchInfo("AWI RGB Light", "1.1");
     present(CHILD_ID, S_RGB_LIGHT, "RGB Strip");        // present to controller
      //Request the last stored colors settings
      request(CHILD_ID, V_VAR1);
      //gw.process();                       // wait for incoming messages
    void colorBars()
      SendColor2AllLEDs( CRGB::Red );   FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Green ); FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Blue );  FastLED.show(); delay(500);
      SendColor2AllLEDs( CRGB::Black ); FastLED.show(); delay(500);
    void SendColor2AllLEDs(const CRGB lcolor)
      for(int i = 0 ; i < numPixel ; i++) {
        leds[i] = lcolor;
    void SendLastColorStatus()
      String cStatus=actRGBvalue+String("&")+String(actRGBbrightness)+String("&")+String(actRGBonoff);
      send(lastColorStatusMsg.set(cStatus.c_str()));
    String getValue(String data, char separator, int index)
     int found = 0;
      int strIndex[] = {0, -1};
      int maxIndex = data.length()-1;
      for(int i=0; i<=maxIndex && found<=index; i++){
      if(data.charAt(i)==separator || i==maxIndex){
      found++;
      strIndex[0] = strIndex[1]+1;
      strIndex[1] = (i == maxIndex) ? i+1 : i;
      return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
    // ############################ INCOMING MESSAGE ###########################
      if (message.type == V_RGB) {            // check for RGB type
        actRGBonoff=1;
        strcpy(actRGBvalue, message.getString());    // get the payload
        SendColor2AllLEDs(strtol(actRGBvalue, NULL, 16));
        SendLastColorStatus();
      else if (message.type == V_DIMMER) {           // if DIMMER type, adjust brightness
        actRGBonoff=1;
        actRGBbrightness = map(message.getLong(), 0, 100, 0, 255);
        FastLED.setBrightness( actRGBbrightness );
      else if (message.type == V_STATUS) {           // if on/off type, toggle brightness
        actRGBonoff = message.getInt();
        FastLED.setBrightness((actRGBonoff == 1)?actRGBbrightness:0);
      else if (message.type==V_VAR1) {            // color status
        String szMessage=message.getString();
        strcpy(actRGBvalue, getValue(szMessage,'&',0).c_str());
        actRGBbrightness=atoi(getValue(szMessage,'&',1).c_str());
        actRGBonoff=atoi(getValue(szMessage,'&',2).c_str());
      FastLED.show();
    • R
      R
      r-nox
