  3. Singing 2.2.0
Singing 2.2.0
22 Posts 2 Posters 5.4k Views 2 Watching
  • AnticimexA Anticimex
    @alexsh1 looks like a textbook example where sender and receiver disagree on what hmac key to use.
    alexsh1A
    alexsh1A
    alexsh1
    @anticimex GW has got a lot of these:
    !SGN:NCE:GEN
    AnticimexA 1 Reply Last reply
    • alexsh1A alexsh1
      !SGN:NCE:GEN
      AnticimexA
      AnticimexA
      Anticimex
      @alexsh1 that indicate nonce generation fails. If you use soft signing it means the backend is not initialized.
      If it is not, it is indicating checksum failed. This should be visible in the early init messages.
      If you use atsha, it could indicate a dodgy device communication.
      alexsh1A 1 Reply Last reply
        alexsh1A
        alexsh1A
        alexsh1
        @anticimex Sensebender GW has got ATSHA204
        A few of my nodes do have ATSHA204 as well
        And a few others soft signing
        All of them fail after clearing eeprom and new personalisation with the same HMAC
        I understand the problem is the Sensebender
        Could it be a timing issue on Sensebender GW (SAMD21)?
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 if it is, it is new to me. SenseBender gw has been tested with signing. Perhaps @tbowmo might know if something changed in processor frequency on 2.2 that might affect timings in the atsha driver.
          alexsh1A 2 Replies Last reply
            alexsh1A
            alexsh1A
            alexsh1
            @anticimex
            This is the GW log:
            8858 TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            18868 TSF:MSG:BC
            18878 TSF:MSG:FPAR REQ,ID=15
            18888 TSF:PNG:SEND,TO=0
            18898 TSF:CKU:OK
            18908 TSF:MSG:GWL OK
            19394 SGN:SKP:MSG CMD=3,TYPE=8
            19406 TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            19416 TSF:MSG:READ,11-11-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            19426 TSF:MSG:PINGED,ID=11,HP=1
            19441 SGN:SGN:NREQ=11
            19453 TSF:MSG:SEND,0-0-11-11,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            24492 TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            24502 TSF:MSG:BC
            24512 TSF:MSG:FPAR REQ,ID=15
            24522 TSF:CKU:OK,FCTRL
            24532 TSF:MSG:GWL OK
            25522 SGN:SKP:MSG CMD=3,TYPE=8
            25534 TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
            26544 TSF:MSG:READ,15-15-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
            26554 TSF:MSG:PINGED,ID=15,HP=1
            26569 SGN:SKP:MSG CMD=3,TYPE=25
            26581 TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
            26591 TSF:MSG:READ,6-6-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
            26601 !SGN:NCE:GEN
            26611 TSF:MSG:READ,15-15-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
            26621 SGN:PRE:SGN REQ,FROM=15
            26663 SGN:PRE:SGN NREQ,TO=15
            26673 SGN:PRE:WHI NREQ,TO=15
            26683 SGN:SKP:MSG CMD=3,TYPE=15
            26695 TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
            26705 SGN:PRE:XMT,TO=15
            26715 TSF:MSG:READ,15-15-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.2.0
            26725 TSF:MSG:READ,15-15-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
            28734 TSF:MSG:READ,15-15-0,s=255,c=3,t=11,pt=0,l=22,sg=0:BMP280 Pressure Sensor
            28748 TSF:MSG:READ,15-15-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.1
            28760 TSF:MSG:READ,15-15-0,s=0,c=0,t=8,pt=0,l=0,sg=0:
            28771 TSF:MSG:READ,15-15-0,s=1,c=0,t=6,pt=0,l=0,sg=0:
            28782 TSF:MSG:READ,15-15-0,s=2,c=0,t=13,pt=0,l=0,sg=0:
            28795 TSF:MSG:READ,15-15-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
            28810 SGN:SKP:MSG CMD=3,TYPE=16
            28822 TSF:MSG:SEND,0-0-15-15,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
            28832 SGN:SGN:NCE REQ,TO=15
            28864 TSF:MSG:READ,15-15-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
            28874 SGN:NCE:FROM=15
            28884 SGN:BND:NONCE=0000000000000000000000000000000000000000000000000000000000000000
            29514 SGN:BND:HMAC=0000000000000000000000000000000000000000000000000000000000000000
            29524 SGN:SGN:SGN
            Something is just wrong - there are all zeros
            I'll check once again the sketch and schematic.
              alexsh1A
              alexsh1A
              alexsh1
              @anticimex
              I had to comment out this line
              #define MY_SIGNING_ATSHA204_PIN   17
              For SAMD21 it is connected to 20 (PA11) -> this corresponds to D0 arduino
              However, the node still gives me a pain:
               __  __       ____
                      |___/                      2.3.0-alpha
              18 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.3.0-alpha
              73 SGN:PER:OK
              106 SGN:INI:BND OK
              108 TSM:INIT
              108 TSF:WUR:MS=0
              116 TSM:INIT:TSP OK
              118 TSM:INIT:STATID=15
              120 TSF:SID:OK,ID=15
              122 TSM:FPAR
              124 SGN:SGN:NREQ=255
              161 TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              561 TSF:MSG:READ,11-11-15,s=255,c=3,t=8,pt=1,l=1,sg=0:1
              567 SGN:SKP:MSG CMD=3,TYPE=8
              571 TSF:MSG:FPAR OK,ID=11,D=2
              778 TSF:MSG:READ,0-0-15,s=255,c=3,t=8,pt=1,l=1,sg=0:0
              784 SGN:SKP:MSG CMD=3,TYPE=8
              788 TSF:MSG:FPAR OK,ID=0,D=1
              2170 TSM:FPAR:OK
              2170 TSM:ID
              2172 TSM:ID:OK
              2174 TSM:UPL
              2177 SGN:SGN:NREQ=0
              2181 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
              2215 TSF:MSG:READ,0-0-15,s=255,c=3,t=25,pt=1,l=1,sg=0:1
              2222 SGN:SKP:MSG CMD=3,TYPE=25
              2226 TSF:MSG:PONG RECV,HP=1
              2228 TSM:UPL:OK
              2230 TSM:READY:ID=15,PAR=0,DIS=1
              2234 SGN:PRE:SGN REQ
              2236 SGN:PRE:WHI NREQ
              2238 SGN:SGN:NREQ=0
              2252 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
              2260 SGN:PRE:XMT,TO=0
              2263 SGN:PRE:WAIT GW
              2342 TSF:MSG:READ,0-0-15,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              2349 SGN:SKP:MSG CMD=3,TYPE=15
              2353 SGN:SGN:NREQ=0
              2379 TSF:MSG:SEND,15-15-0-0,s=255,c=0,t=17,pt=0,l=11,sg=0,ft=0,st=OK:2.3.0-alpha
              2387 SGN:SGN:NREQ=0
              2392 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
              4401 SGN:SGN:NREQ=0
              4405 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=OK:BMP280 Pressure Sensor
              4415 SGN:SGN:NREQ=0
              4419 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
              4427 SGN:SGN:NREQ=0
              4431 TSF:MSG:SEND,15-15-0-0,s=0,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=OK:
              4438 SGN:SGN:NREQ=0
              4442 TSF:MSG:SEND,15-15-0-0,s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=OK:
              4450 SGN:SGN:NREQ=0
              4452 TSF:MSG:SEND,15-15-0-0,s=2,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
              4460 MCO:REG:REQ
              4462 SGN:SGN:NREQ=0
              4466 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              4493 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
              4499 SGN:SKP:MSG CMD=3,TYPE=16
              4530 SGN:SGN:NREQ=0
              4542 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
              4550 SGN:NCE:XMT,TO=15
              6475 SGN:SGN:NREQ=0
              6477 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              6506 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
              6512 SGN:SKP:MSG CMD=3,TYPE=16
              6543 SGN:SGN:NREQ=0
              6553 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
              6563 SGN:NCE:XMT,TO=15
              8486 SGN:SGN:NREQ=0
              8488 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              8515 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
              8521 SGN:SKP:MSG CMD=3,TYPE=16
              8554 SGN:SGN:NREQ=0
              8564 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
              8572 SGN:NCE:XMT,TO=15
              10498 SGN:SGN:NREQ=0
              10502 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
              10528 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
              10534 SGN:SKP:MSG CMD=3,TYPE=16
              10565 SGN:SGN:NREQ=0
              10577 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
              10586 SGN:NCE:XMT,TO=15
              11448 TSF:MSG:READ,0-0-15,s=255,c=3,t=16,pt=0,l=0,sg=1:
              11454 SGN:SKP:MSG CMD=3,TYPE=16
              11487 SGN:SGN:NREQ=0
              11501 TSF:MSG:SEND,15-15-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
              11509 SGN:NCE:XMT,TO=15
              12509 MCO:BGN:STP
              Pressure Sensor BMP280 1.1
              • alexsh1A
                alexsh1A
                alexsh1
                All other nodes are working fine with singing so the problem was incorrect reference to atsha204's pin on the GW. I'll debug the node above tomorrow
                • AnticimexA
                  AnticimexA
                  Anticimex
                  Alright. That is at least some progress. Just from the latest log I don't see anything going terribly wrong at the node side. But it perhaps hangs at that point? Could be a stack issue.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #21
                    @anticimex It is working now. It was one of those late night issues. In the morning it started working like a charm! (I bet it won't be able to replicate it). Thank you for your help.
                    Also a good lesson for me. A working sketch for an AVR may or may not work for ARM. Extra attention required for defining pins etc.
                    On a different note FYI, I was struggling to clear EEPROM on my Sensebender GW.
                    See this https://forum.mysensors.org/topic/8814/cleareprom-does-not-work-for-sensebender-gw/9
                    • alexsh1A alexsh1
                      AnticimexA
                      AnticimexA
                      Anticimex
                      #22
                      @alexsh1 nice to hear :)
