  3. 💬 RGB Led Strip Board (MysX)
leddimmerled stripmysx
16 Posts 5 Posters 4.9k Views 4 Watching
    https://www.openhardware.io/view/572/RGB-Led-Strip-Board-MysX
    sundberg84S
    sundberg84S
    This board uses MysX and connects to MysX 2.0.1 and above. MysX connector should be placed with pin 1 towards the corner of the motherboard. It means it will not align properly if you connect this to EasyPCB rev 9 and below. You need to connect this to EasyPCB Rev 10. If you are using any other Motherboard please check alignment before using.
    • A
      anovak
      EasyPCB rev 10. design files can be downloaded?
      • A anovak
        sundberg84S
        sundberg84S
        @anovak not yet. I have some final tests to do but if you Pm me your email I can send the current ones and you can order (on your own risk). I'm hoping I will have it all finished and published on openhardware in some weeks.
        vladimirV 1 Reply Last reply
        • sundberg84S sundberg84
          vladimirV
          vladimirV
          vladimir
          @sundberg84 you can write what capacitors and resistors should be placed on the board?
          • vladimirV vladimir
            sundberg84S
            sundberg84S
            @vladimir capacitors are only to smooth the DC supply. A 0.1uF and 10uF is what I just normally whack in there... But check the datasheet for the 5v voltage regulator you are using for recommendations. (LM2940CT = 0,47uF Input, 22uF Output)
            Resistors are optional and depend on if the gate needs some current limitations on the mosfet. If you are using the recommended mosfet you can just bridge these with wires. If not...check datasheet. (Does mostefs ever needs current limitations?)
              vladimirV
              vladimirV
              vladimir
              @sundberg84 Thank you for the clarification! Can you explain to me why you use a combination of 0.1 uF and 10 uF, instead of the recommended 0.47 uF and 22 uF?
                sundberg84S
                sundberg84S
                @vladimir because in lazy and sometimes doesn't check the datasheet. These values comes from the LE33 voltage regulator...
                vladimirV 3 Replies Last reply
                  vladimirV
                  vladimirV
                  vladimir
                  @sundberg84 :grin: many thanks!:raised_hands:
                    vladimirV
                    vladimirV
                    vladimir
                    @sundberg84 Is there a sketch for this device? Where can I find it?
                      vladimirV
                      vladimirV
                      vladimir
                      @sundberg84 And ... I do not use Easy/Newbie PCB. Will there be enough voltage at the conclusions of Arduino Pro Mini 3.3V for tape management?
                      I now experimented and accidentally burned the voltage regulator in Arduino Pro Mini 3.3V, applying 12 V to the RAW contact.:man-shrugging:
                      Today is clearly not my day...:man-facepalming: :smile:
                        sundberg84S
                        sundberg84S
                        @vladimir at the moment I do not have a sketch but there are plenty on the forum (Like this).
                        There will be more than enough current to run the normal Mysensors node.
                        If you use the recommended LM2940CT you will have about 5 times more than needed.
                          vladimirV
                          vladimirV
                          vladimir
                          wrote on last edited by vladimir
                          @sundberg84 The connected LED strip lights up, but for some reason the Atmega chip is heated very quickly and strongly. Have you encountered this?
                          My connection scheme:
                            sundberg84S
                            sundberg84S
                            @vladimir No but this indicates s short somewhere
                            • Y
                              Y
                              yoshida
                              Do you plan an RGBW version?
                              • Y yoshida
                                sundberg84S
                                sundberg84S
                                @yoshida I'm not sure... Maybe 😉
                                12.5k
