  3. 💬 RGB Led Strip Board (MysX)
leddimmerled stripmysx
16 Posts 5 Posters 4.9k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/572/RGB-Led-Strip-Board-MysX
      sundberg84S
      sundberg84S
      This board uses MysX and connects to MysX 2.0.1 and above. MysX connector should be placed with pin 1 towards the corner of the motherboard. It means it will not align properly if you connect this to EasyPCB rev 9 and below. You need to connect this to EasyPCB Rev 10. If you are using any other Motherboard please check alignment before using.
      • A
        anovak
        EasyPCB rev 10. design files can be downloaded?
        • A anovak
          sundberg84S
          sundberg84S
          @anovak not yet. I have some final tests to do but if you Pm me your email I can send the current ones and you can order (on your own risk). I'm hoping I will have it all finished and published on openhardware in some weeks.
          vladimirV 1 Reply Last reply
          • sundberg84S sundberg84
            vladimirV
            vladimirV
            vladimir
            @sundberg84 you can write what capacitors and resistors should be placed on the board?
            • vladimirV vladimir
              sundberg84S
              sundberg84S
              @vladimir capacitors are only to smooth the DC supply. A 0.1uF and 10uF is what I just normally whack in there... But check the datasheet for the 5v voltage regulator you are using for recommendations. (LM2940CT = 0,47uF Input, 22uF Output)
              Resistors are optional and depend on if the gate needs some current limitations on the mosfet. If you are using the recommended mosfet you can just bridge these with wires. If not...check datasheet. (Does mostefs ever needs current limitations?)
                vladimirV
                vladimirV
                vladimir
                @sundberg84 Thank you for the clarification! Can you explain to me why you use a combination of 0.1 uF and 10 uF, instead of the recommended 0.47 uF and 22 uF?
                  sundberg84S
                  sundberg84S
                  @vladimir because in lazy and sometimes doesn't check the datasheet. These values comes from the LE33 voltage regulator...
                  vladimirV 3 Replies Last reply
                    vladimirV
                    vladimirV
                    vladimir
                    @sundberg84 :grin: many thanks!:raised_hands:
                      vladimirV
                      vladimirV
                      vladimir
                      @sundberg84 Is there a sketch for this device? Where can I find it?
                        vladimirV
                        vladimirV
                        vladimir
                        @sundberg84 And ... I do not use Easy/Newbie PCB. Will there be enough voltage at the conclusions of Arduino Pro Mini 3.3V for tape management?
                        I now experimented and accidentally burned the voltage regulator in Arduino Pro Mini 3.3V, applying 12 V to the RAW contact.:man-shrugging:
                        Today is clearly not my day...:man-facepalming: :smile:
                          sundberg84S
                          sundberg84S
                          @vladimir at the moment I do not have a sketch but there are plenty on the forum (Like this).
                          There will be more than enough current to run the normal Mysensors node.
                          If you use the recommended LM2940CT you will have about 5 times more than needed.
                            vladimirV
                            vladimirV
                            vladimir
                            wrote on last edited by vladimir
                            @sundberg84 The connected LED strip lights up, but for some reason the Atmega chip is heated very quickly and strongly. Have you encountered this?
                            My connection scheme:
                              sundberg84S
                              sundberg84S
                              @vladimir No but this indicates s short somewhere
                              • Y
                                Y
                                yoshida
                                Do you plan an RGBW version?
                                • Y yoshida
                                  sundberg84S
                                  sundberg84S
                                  @yoshida I'm not sure... Maybe 😉
                                  12.5k
