  3. Ikea Molgan Hack with Wemos D1 mini or NodeMCU (WIFI, ESP8266)
17 Posts 4 Posters 5.1k Views 4 Watching
    Could be some interference from the wifi chip. Try to move the pir sensor 30/40cm away from the wemos and see if it works better. But why choosing an esp8266 solution for a pir sensor? Esp8266 is quite power hungry when it is transmitting and I suspect a pir sensor will be triggering quite often as people move around
    ehomeE
    ehomeE
    ehome
    @gohan thanks for your reply.
    Interesting idea. Moved the ESPBoard 90-100cm away from the PIR but still the same problem.
    Power consumption will be not a big deal because I don't want to use it with an battery. I will power all my sensors with an small USB power supply.
    The future plan is to integrate all my main sensors into this housing. Temperature, Humidity, Light and Motion. So in future this sensor will not just act like an PIR. And my sketch including the mysensors library is very big so that I had stability problems with ArduinoUNO, Pro mini, etc... because of insufficient memory.
    I found out:
    If I use a separate power supply for my ESPBoard then everything is working like expected. But to have two power supplies for every sensor is not very handy... Any ideas why it is not possible to power the ikea PIR and the ESPBoard from the same power supply? The specs from my power supply (5V/3A) are definitly good enough for both.
      The classic Arduino pir sensor gets triggered by very small power fluctuations. Look for Am612 sensors instead
      • ehomeE
        ehomeE
        ehome
        I do still have huge problems with PIR motion detector modules together with ESP8266 boards. (NodeMCU or Wemos D1)
        Problem:
        Sometimes the PIR do have false triggers or the state of the PIR output pin is always high.
        This as been tested with an HC-SR501 and AM312.
        Tried different voltages 3V/5V and power supplies.
        Everything is working as expexted if I'm using the same PIR with my ArduinoUno board.
        Any ideas how I could get this to work?
        My target goal is:
        I like to have a multi-sensor with the following minimum set of sensors:
        • Temperatur
        • Humidity
        • Motion
        • Sensor values via MQTT to my home automation central like openhab.
        • Board with more memory and ram like the ESP8266 boards
          Am312 shouldn't have false readings, quite some people used them. Can you try to run them on batteries an see if anything changes? Also keep pir sensor away from antenna
          • ehomeE
            ehomeE
            ehome
            wrote on last edited by ehome
            Thanks for your reply.
            I did some further tests. And I think it defenitly has something to do with the WIFI from the ESP8266 modules. (intereference problems?)
            I wrote a small sketch with much less WIFI activity. But as soon as the module sends the sensor data via WIFI to my home automation central then the PIR starts with false readings.
            Keeping the PIR away from the antenna could be a workaround but I really like to have all components in one small wall or ceiling mounted case.
            I also did a lot of research but was not really able to find a working solution for this.
            I'm wondering if no one else here also had this problem in the past? Maybe because the most people here don't use the ESP8266 modules? But I really need the space and speed from these modules.
            I'm also not so happy with the angle from 100° of the AM312 PIR.
            There are any other PIR solutions on the market? Or any other sensor (not to expensive) to get a working motion detection. (human motion)
              There is am612 sensor if you want to build your own. I also saw quite some people start using the xiaomi sensors.
              • ehomeE ehome
                @ehome said in Ikea Molgan Hack with Wemos D1 mini or NodeMCU (WIFI, ESP8266):
                Could still be related to power, as @gohan suggested, as power draw will increase significantly when wifi is transmitting.
                Try powering directly from batteries first.
                • electrikE
                  electrikE
                  electrik
                  Maybe this helps
                  http://www.letscontrolit.com/forum/viewtopic.php?f=5&t=671&start=20
                  There are more people with these issues, read through the entire post.
                  ehomeE 1 Reply Last reply
                  • electrikE electrik
                    Maybe this helps
                    ehomeE
                    ehomeE
                    ehome
                    @electrik thanks for your reply. I also already found and read this post.
                    And I already placed an order for the different required parts. They should arrive in the next 1-2 days.
                      What did you ordered?
                        ehomeE
                        ehomeE
                        ehome
                        @gohan Some people in the post (see link above) suggested to use some capacitors for the BISS0001 chip or between the power supply to act as rc filter.
                        So I've ordered different types of capacitors, resistors and some other electronic parts.
                        Few minutes ago I found some left overs of some 220nF ceramic capacitors.
                        It was a little bit tricky to solder because of the very, very small SMD size 0402. But was able to put it between PIN12 and PIN13 of the BISS0001 chip.
                        The first test run for one hour looks really good. Had no false triggers and also no triggers while WIFI is active for data transmission.
                        Negative: First impression is that also the sensitivity of the sensor is decreased by this capacitor.
                        Will make further tests an post the updates here.
                        • ehomeE
                          ehomeE
                          ehome
                          After some further tests over several hours I still had some false triggers.
                          But it is much better than without the capacitors.
                          The next step I did is that I put a peace of aluminium foil between my PIR PCB and ESP8266 board.
                          This combination capacitor + aluminium foil is now running since 2 hours without any false triggers.
                          Its really annoying that such simple requirement (motion detection) makes so huge problems :-(
                          Is there any other with similar specs and cheap micro controller that you could suggest?
                          I also thought about using an IR array like GRID-EYE for motion detection. But these electronic parts are quite expensive.
                          I would be happy over any suggestion for an replacement either the micro controller board or motion sensor.
                            Could you please post your code? I'd like to see why it is using so much memory
                              ehomeE
                              ehomeE
                              ehome
                              @gohan
                              If I am uploading the sketch below then I get the warning from the ArduinoIDE that only few ressources are left / its complaining about stability problems that my occur. (also with debugging disabled)
                              And if I run this on a ArduinoUNO or Micro then after a few hours the board doesn't respond anymore. I have to power off and on (or reset) to get it working again.
                              Code:
                               * Version 1.0 - Henrik Ekblad
                               * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
                               * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
                               * LED purposes:
                               * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                               * - ERR (red) - fast blink on error during transmission error or receive crc error
                               * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
                               * nRF24L01+  ESP8266
                               * VCC        VCC
                               * CE         GPIO4
                               * CSN/CS     GPIO15
                               * SCK        GPIO14
                               * MISO       GPIO12
                               * MOSI       GPIO13
                                * Inclusion mode button:
                              // ID of the current node
                              #define MY_NODE_ID 1
                              //#define MY_RADIO_NRF24
                              //#define MY_RADIO_RFM95
                              #define MY_MQTT_PUBLISH_TOPIC_PREFIX "ff-kitchen-gw1-out"
                              #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "ff-kitchen-gw1-in"
                              // Set MQTT client id
                              #define MY_MQTT_CLIENT_ID "ff-kitchen-1"
                              //#define MY_W5100_SPI_EN 4
                              // radio on the same spi bus.
                              #define MY_SOFTSPI
                              #ifndef MY_RF24_CE_PIN
                              #define MY_RF24_CE_PIN 5
                              #ifndef MY_RF24_CS_PIN
                              #define MY_RF24_CS_PIN 6
                              // Enable these if your MQTT broker requires username/password
                              #define MY_MQTT_USER "Username"
                              #define MY_MQTT_PASSWORD "Password"
                              #define MY_SENSOR_PASSWORD "Password"
                              #define MY_IP_ADDRESS xx,x,xx,xxx
                              #define MY_IP_GATEWAY_ADDRESS xx,x,xx,xxx
                              #define MY_IP_SUBNET_ADDRESS xxx,xxx,xxx,x
                              #define MY_CONTROLLER_IP_ADDRESS xx, x, xx, xxx
                              #define MY_PORT 1883
                              // Enable inclusion mode
                              // Set blinking period
                              // Flash leds on rx/tx/err
                              #include <Ethernet.h>
                              #include <BH1750.h>
                              // Pin configuration
                              // Interrupt pins: 2,3 (Arduino UNO)
                              #define PIR_DATA_PIN 2                                      // PIR Motion sensor
                              #define DHT_DATA_PIN 3                                      // Temperature and humidity sensor
                              #define WINDOW_TOP_REEDCONTACT_DATA_PIN 5                   // Reed contact sensor
                              #define WINDOW_BOTTOM_REEDCONTACT_DATA_PIN 6                // Reed contact sensor
                              const unsigned int RELAY_DATA_PINS[] = {4, 7, 8, 9};        // Relay module
                              char* RELAY_ANALOGDATA_PINS[] = { "A0", "A1", "A2", "A3"};  // Relay module
                              // Settings
                              #define RELEASE_VERSION "1.0"
                              bool enableSaveState = false;                  // Save states in local eeprom
                              bool metric = true;
                              const unsigned long WARMUP_TIME = 30000;       // Timer for initializing sensors like DHT, PIR, etc...
                              const unsigned long SENSOR_UPDATE_TIME = 3000; // Timer for periodic sensor readings
                              const unsigned long FAST_UPDATE_TIME = 250;    // Timer for special sensors like PIR
                              unsigned long lastSensorUpdateTime = 0;
                              unsigned long lastFastUpdateTime = 0;
                              // Sensor offsets
                              // SENSOR_TEMP_OFFSET: Set this offset if the sensor has a permanent small offset to the real temperatures
                              // SENSOR_MINCHANGE_OFFSET*: Set this offset for wheter sending mqtt updates or not
                              #define SENSOR_TEMP_OFFSET 0
                              #define SENSOR_MINCHANGE_OFFSET 0.2
                              #define SENSOR_MINCHANGE_OFFSET_LARGE 2
                              static const uint8_t FORCE_UPDATE_N_READS = 20;
                              // Set sensor child ids
                              #define CHILD_ID_MOTION 30
                              #define CHILD_ID_TEMP 40
                              #define CHILD_ID_HUM 50
                              #define CHILD_ID_LIGHT 60
                              #define CHILD_ID_WINDOW_TOP 5
                              #define CHILD_ID_WINDOW_BOTTOM 6
                              // States
                              // MotionSensor
                              unsigned long lastPirUpdate = 0;
                              long unsigned int lowIn;               // Save the time when the PIR sensor outputs a low impulse.
                              long unsigned int motionPause = 60000; // The amount of milliseconds the sensor has to be low, before we assume all motion has stopped.
                              bool lockLow = true;
                              bool takelowTime;
                              MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                              void initPirSensor()
                                  pinMode(PIR_DATA_PIN, INPUT); // Init PIR motion sensor
                              void updateMotionSensor(bool forceUpdate = false)
                                  bool tripped = digitalRead(PIR_DATA_PIN) == HIGH;
                              #ifdef MY_DEBUG
                                  Serial.print("M: ");
                                  Serial.println(tripped);
                                  if (tripped == HIGH)
                                      if (lockLow)
                                          // Make sure to wait for a transition to LOW before any further progress is made.
                                          lockLow = false;
                              #ifdef MY_DEBUG
                                          Serial.print("Motion detected at ");
                                          Serial.print(millis() / 1000);
                                          Serial.println(" sec.");
                                          send(msgMotion.set(tripped ? "1" : "0"));
                                      takelowTime = true;
                                  else if (tripped == LOW)
                                      if (takelowTime)
                                          lowIn = millis();    // Save the time of the transition from HIGH to LOW.
                                          takelowTime = false; // Make sure this is only done at the start of a new LOW ph.
                                      // If the sensor is low for more than the given pause,
                                      // then we assume that nor more motion (human presence) is going to happen.
                                      if (!lockLow && millis() - lowIn > motionPause)
                                          // Make sure this code block is only executed after a new motion sequence has been detected.
                                          lockLow = true;
                              #ifdef MY_DEBUG
                                          Serial.print("Motion ended at ");
                                          Serial.print((millis() - motionPause) / 1000);
                                          return;
                                  if (currentMillis - lastPirUpdate > WARMUP_TIME && lockLow)
                                      lastPirUpdate = currentMillis;
                              // TempSensor
                              float lastTemp;
                              float lastHum;
                              float lastHic;
                              uint8_t nNoUpdatesTemp;
                              uint8_t nNoUpdatesHum;
                              uint8_t nNoUpdatesHic;
                              MyMessage msgHic(CHILD_ID_TEMP, V_VAR1);
                              DHT dht;
                              void initTempSensor()
                                  if (SENSOR_UPDATE_TIME <= dht.getMinimumSamplingPeriod())
                              #ifdef MY_DEBUG
                                  wait(dht.getMinimumSamplingPeriod());
                              void updateTempSensor()
                                  // Source: https://gist.github.com/jamesabruce/382fe945d39cf41b29f9
                                  dht.readSensor(true);
                                  if (isnan(temperature))
                              #ifdef MY_DEBUG
                                  else if ((temperature != lastTemp && abs(temperature - lastTemp) > SENSOR_MINCHANGE_OFFSET) || nNoUpdatesTemp == FORCE_UPDATE_N_READS)
                                      lastTemp = temperature;
                                      if (!metric)
                                      // Reset no updates counter
                                      nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                                      Serial.print("T: ");
                                      nNoUpdatesTemp++;
                                  if (isnan(humidity))
                              #ifdef MY_DEBUG
                                  else if ((humidity != lastHum && abs(humidity - lastHum) > SENSOR_MINCHANGE_OFFSET) || nNoUpdatesHum == FORCE_UPDATE_N_READS)
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                      nNoUpdatesHum++;
                                  // Compute heat index in Celsius (isFahreheit = false)
                                  if (isnan(temperature) && isnan(humidity))
                                      float hic = dht.computeHeatIndex(temperature, humidity, false);
                              #ifdef MY_DEBUG
                                      Serial.print("Hic: ");
                                      if ((hic != lastHic && abs(hic - lastHic) > SENSOR_MINCHANGE_OFFSET) || nNoUpdatesHic == FORCE_UPDATE_N_READS)
                                          nNoUpdatesHic = 0;
                                          send(msgHic.set(hic, 1));
                                          lastHic = hic;
                                          nNoUpdatesHic++;
                              // LightSensor
                              // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
                              // If your controller supports the new V_LEVEL variable, use this instead for
                              // transmitting LUX light level.
                              MyMessage msgLux(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                              // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
                              uint16_t lastlux;
                              uint8_t nNoUpdatesLux;
                              BH1750 lightSensor;
                              void initLightSensor()
                                  // Initialize the I2C bus (BH1750 library doesn't do this automatically)
                                  // On esp8266 devices you can select SCL and SDA pins using Wire.begin(D4, D3);
                                  Wire.begin();
                                  lightSensor.begin();
                              void updateLightSensor()
                                  uint16_t lux = lightSensor.readLightLevel();
                              #ifdef MY_DEBUG
                                  Serial.print("L: ");
                                  Serial.println(lux);
                                  if ((lux != lastlux && abs(lux - lastlux) > SENSOR_MINCHANGE_OFFSET_LARGE) || nNoUpdatesLux == FORCE_UPDATE_N_READS)
                                      nNoUpdatesLux = 0;
                                      send(msgLux.set(lux));
                                      lastlux = lux;
                                      nNoUpdatesLux++;
                              // ReedContacts
                              int lastBounceWindowTop = -1;
                              int lastBounceWindowBottom = -1;
                              unsigned long lastBounceUpdate = 0;
                              MyMessage msgWindowTop(CHILD_ID_WINDOW_TOP, V_TRIPPED);
                              MyMessage msgWindowBottom(CHILD_ID_WINDOW_BOTTOM, V_TRIPPED);
                              void initReedContact(int pin)
                                  pinMode(pin, INPUT);
                                  digitalWrite(pin, HIGH); // Activate internal pull-up
                              void updateReedSensor(int pin, MyMessage &message, int &lastState, bool reset)
                                  int state = digitalRead(pin);
                              #ifdef MY_DEBUG
                                  Serial.print("R: ");
                                  Serial.println(state);
                                  if (state != lastState)
                                      send(message.set(state == HIGH ? 1 : 0));
                                      lastState = state;
                                      return;
                                  if (currentMillis - lastBounceUpdate > WARMUP_TIME)
                                      if (reset)
                                          lastBounceUpdate = currentMillis;
                              // Relays Module
                              void initRelayModules()
                                  for (size_t sensor = 0; sensor < (sizeof(RELAY_DATA_PINS) / sizeof(int)); sensor++)
                                      pinMode(RELAY_DATA_PINS[sensor], OUTPUT);                                        // Then set relay pins in output mode
                                      digitalWrite(RELAY_DATA_PINS[sensor], loadState(RELAY_DATA_PINS[sensor]) ? RELAY_ON : RELAY_OFF); // Set relay to last known state (using eeprom storage)
                                  for (size_t sensor = 0; sensor < (sizeof(RELAY_ANALOGDATA_PINS) / sizeof(int)); sensor++)
                                      pinMode(RELAY_ANALOGDATA_PINS[sensor], OUTPUT);
                                      digitalWrite(RELAY_ANALOGDATA_PINS[sensor], RELAY_OFF);
                              void presentRelays()
                                      present(RELAY_DATA_PINS[sensor], S_LIGHT);
                                      present(RELAY_ANALOGDATA_PINS[sensor], S_LIGHT);
                                  initTempSensor();                                    // Init temperature and humidity sensor. (DHT22)
                                  initLightSensor();                                   // Init one wire light sensor. (BH1750)
                                  initPirSensor();                                     // Init PIR sensor
                                  initRelayModules();                                  // Init relay modules
                                  initReedContact(WINDOW_TOP_REEDCONTACT_DATA_PIN);    // Init read contact
                                  initReedContact(WINDOW_BOTTOM_REEDCONTACT_DATA_PIN); // Init read contact
                                  wait(WARMUP_TIME);
                                  // Optional: Send the sketch version information to the gateway
                                  sendSketchInfo("Multi room sensor", RELEASE_VERSION);
                                  present(CHILD_ID_HUM, S_HUM);
                                  present(CHILD_ID_MOTION, S_MOTION);
                                  presentRelays();
                                  present(CHILD_ID_WINDOW_TOP, S_DOOR);
                                  present(CHILD_ID_WINDOW_BOTTOM, S_DOOR);
                                  if (currentMillis - lastSensorUpdateTime > SENSOR_UPDATE_TIME)
                                      lastSensorUpdateTime = currentMillis;
                                      updateTempSensor();
                                      updateLightSensor();
                                  else if (currentMillis - lastFastUpdateTime > FAST_UPDATE_TIME)
                                      lastFastUpdateTime = currentMillis;
                                      updateMotionSensor();
                                      updateReedSensor(WINDOW_TOP_REEDCONTACT_DATA_PIN, msgWindowTop, lastBounceWindowTop, false);
                                      updateReedSensor(WINDOW_BOTTOM_REEDCONTACT_DATA_PIN, msgWindowBottom, lastBounceWindowBottom, true);
                              #ifdef MY_DEBUG
                                  Serial.print("Incoming message received. Type: ");
                                  Serial.println(message.type);
                                  Serial.print("Destination: ");
                                  Serial.println(message.destination);
                                  if (message.type == V_LIGHT)
                              #ifdef MY_DEBUG
                                      Serial.print("Incoming change for sensor: ");
                                      Serial.print("New status: ");
                                      digitalWrite(message.sensor, message.getBool() ? RELAY_ON : RELAY_OFF);
                                      // Store state in eeprom
                                      // if(enableSaveState) {
                                      //     saveState(message.sensor, message.getBool());
                                but that is a mqtt gateway sketch. That is not a normal node. Have you tried making a normal node with nrf24 radio only, no gw functions?
