  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 46.7k Views 19 Watching
  • pepsonP pepson
    @sineverba
    Ok summary
    When i have setup on Raspberry Gateway , generate keys.
    When i write in node all keys with sketches.... Node connect ok.
    But when write to node only sketches without keys.,... node connect to gateway or not connect to gateway ?
    sineverba
    @pepson you need to setup gateway with weak security.
    You need generate keyes and set in gateway.
    You need to personalize nodes with the sketch and set keyes on Arduino EEPROM.
    From now, you have two ways: Your node need security? Set use security bla-bla on top with other define(s).
    Don't Need security? Don't define use security.
    Simpler than ever.
    • pepsonP pepson
      @sineverba
      Ok summary
      AnticimexA
      AnticimexA
      Anticimex
      @pepson if you find the security setup to be too complicated, I highly recommend sticking with the simple password flags. The documentation has it all.
      pepsonP 1 Reply Last reply
      • pepsonP
        pepsonP
        pepson
        @sineverba said in 💬 Security & Signing:
        But when configure my gateway without flag setup gateway with weak security i can only use nodes with setup in sketches keys. yes ?
        S 2 Replies Last reply
        • AnticimexA Anticimex
          pepsonP
          pepsonP
          pepson
          @anticimex
          Can you share me this document when is describe how define only pass ? I want also read this.
          • pepsonP pepson
            sineverba
            @pepson
            Let's summarize. Last time.
            1. compile gateway with weak security (make your research, also in my github guide, there is ;) )
            2. create the 3 keyes for gateway
            3. set the 3 keyes for gateway.
            4. clean your EEPROM arduinos with the sketch present in my guide and in examples of library
            5. set the keyes in EEPROM arduinos.
            Stop. End. Fin. Fine. These steps are MANDATARY. You NEED to do.
            You will have in EEPROM the keyes (arduino) and in gateway.
            From now, you select:
            a) Do I need security? Perfect, in sketch arduino add #define bla bla bla on top with security and other stuff.
            b) Do I NOT need security? Perfect, in sketch arduino DON'T ADD #define bla bla related to security.
            • pepsonP pepson
              sineverba
              @pepson And, last all, you can use the mysensors debug options. Try. Try. Try! This is the best option offered to you to learn. Try!
              At max, nothing works ;)
              • S sineverba
                @pepson
                pepsonP
                pepsonP
                pepson
                @sineverba
                ok all is very good.
                But what give me this if i can connect nodes also with defines bla bla bla in skethc and also without define bla bla bla in sketch?
                But Do I think right ? In each of these accidents in the eeprom I need to have the keys loaded?
                S 1 Reply Last reply
                • pepsonP pepson
                  @sineverba
                  sineverba
                  @pepson only one word. Try. Really, you are lost in 1 cm of water. Try. And if it doesn't work, open your topic, showing exactly your sketches and what have you done.
                  • pepsonP
                    pepsonP
                    pepson
                    ok thanks
                    • pepsonP pepson
                      ok thanks
                      pepsonP
                      pepsonP
                      pepson
                      Ok i build my gateway on RPI on MySensors 2.2.0 with this configuration:
                      ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=ethernet --my-port=5003 --my-signing=software --my-signing-request-signatures
                      Then generate 3 key and setup it on gateway.
                      Then clear_epprom on Arduino MIni Pro, and then send sketch security with add serial, HMAC, and AES. Then put sketch with add this on top sketch with my SERIAL generated on gateway RPI.
                      #define MY_SIGNING_SOFT
                      #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0X2C,0X61,0X17,0X2E,0XEE,0XDD,0XCC,0XBB,0XAA}}} // got from gateway setup
                      After that i run HA and he not found my nodes...
                      WHat is wrondg ?
                      AnticimexA 1 Reply Last reply
                      • pepsonP pepson
                        WHat is wrondg ?
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @pepson well for starters, don't start out with whitelisting unless you know exactly what you are doing. First you have to verify that your network is stable enough to handle the security protocol. The simplest option is to only enable encryption, or use the simple password flag options. Once you have established that your gw and nodes are capable of communicating securely you can move on to personalization and whitelisting.
                          pepsonP
                          pepsonP
                          pepson
                          @anticimex
                          What you mean white list?
                          Before adding all security my nodes and gateway works perfect.
                          • pepsonP pepson
                            @anticimex
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @pepson you define whitelisting so I presume you use it. But I don't see your gw flags specifying it so of course it does not work. So get rid of that flag from your config unless you know what it mean so that you set it up properly.
                              pepsonP
                              pepsonP
                              pepson
                              @anticimex
                              What flag i must remove ?
                              This :
                              But on GW i setup this:
                              sudo mysgw --set-soft-serial-key=2C61172EEEDDCCBBAA && sudo mysgw --set-aes-key=9D2AD43CF909875C4C77111111111111 && sudo mysgw --set-soft-hmac-key=A2A64C48EA6765C5DAEFA12A1E41E2F038515A9CAED9FED73D11111111111111
                              • pepsonP pepson
                                @anticimex
                                This :
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @pepson please just read the documentation. And more importantly, follow it.
                                Isn't it obvious that it is the flag that mention whitelisting that is supposed to be removed unless you intend to use whitelisting, in which case you ought to know how to set it up properly at both ends?
                                  pepsonP
                                  pepsonP
                                  pepson
                                  wrote on last edited by pepson
                                  #84
                                  @anticimex
                                  Sorry i dont undestand
                                  • pepsonP pepson
                                    @anticimex
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @pepson https://www.mysensors.org/apidocs/group__MySigninggrpPub.html
                                    Note that it is the documentation for the latest release (simple password flags work differently compared to previous releases, see release notes for the latest release).
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      HI
                                      i don as describe...
                                      1. install gateway on raspberry with this configuration:
                                        ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=ethernet --my-port=5003 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-signing=software --my-signing-request-signatures --my-signing-weak_security --my-signing-debug
                                      and then generate serial, aes and hmac
                                      pi@raspberrypi:~/MySensors $ sudo mysgw --gen-soft-serial-key
                                      SOFT_SERIAL | 8FC828503E6EB14C5D
                                      The next line is intended to be used in SecurityPersonalizer.ino:
                                      #define MY_SOFT_SERIAL 0X8F,0XC8,0X28,0X50,0X3E,0X6E,0XB1,0X4C,0X5D
                                      To use this key, run mysgw with:
                                      --set-soft-serial-key=8FC828503E6EB14C5D
                                      pi@raspberrypi:~/MySensors $ sudo mysgw --gen-soft-hmac-key
                                      SOFT_HMAC_KEY | 0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
                                      #define MY_SOFT_HMAC_KEY 0XD,0X68,0X2E,0XD0,0X51,0X6,0XE5,0XF3,0X61,0XC6,0X42,0X88,0XD6,0X8A,0XAE,0X1B,0X34,0XF5,0XFF,0XB6,0X2B,0X4E,0X39,0X77,0X3C,0X9D,0X92,0XDE,0XD0,0X4B,0X65,0X14
                                      --set-soft-hmac-key=0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
                                      pi@raspberrypi:~/MySensors $ sudo mysgw --gen-aes-key
                                      AES_KEY | 8FDB1EE8D0351CFF874D337731BF37AE
                                      #define MY_AES_KEY 0X8F,0XDB,0X1E,0XE8,0XD0,0X35,0X1C,0XFF,0X87,0X4D,0X33,0X77,0X31,0XBF,0X37,0XAE
                                      --set-aes-key=8FDB1EE8D0351CFF874D337731BF37AE
                                      and setup it on my gateway
                                      sudo mysgw --set-soft-serial-key=8FC828503E6EB14C5D && sudo mysgw --set-aes-key=8FDB1EE8D0351CFF874D337731BF37AE && sudo mysgw --set-soft-hmac-key=0D682ED05106E5F361C64288D68AAE1B34F5FFB62B4E39773C9D92DED04B6514
                                      all is ok to this moment
                                      Then
                                      1. clear eeprom in node Arduino pro mini with this sketch:
                                        https://github.com/sineverba/domoraspi/tree/master/utils/sketches
                                      2. write sketch security with setup my serial, aes and hmac
                                      at the top setup...
                                      /************************************ User defined key data ***************************************/
                                      /** @brief The user-defined HMAC key to use unless @ref GENERATE_HMAC_KEY is set */
                                      //#define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
                                      #define MY_HMAC_KEY 0XD,0X68,0X2E,0XD0,0X51,0X6,0XE5,0XF3,0X61,0XC6,0X42,0X88,0XD6,0X8A,0XAE,0X1B,0X34,0XF5,0XFF,0XB6,0X2B,0X4E,0X39,0X77,0X3C,0X9D,0X92,0XDE,0XD0,0X4B,0X65,0X14
                                      /** @brief The user-defined AES key to store in EEPROM unless @ref GENERATE_AES_KEY is set */
                                      //#define MY_AES_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
                                      /** @brief The user-defined soft serial to use for soft signing unless @ref GENERATE_SOFT_SERIAL is set */
                                      /***************************** Flags for guided personalization flow ******************************/
                                      1. then write my sketch relay with added at the top this info:
                                      #define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0X8F,0XC8,0X28,0X50,0X3E,0X6E,0XB1,0X4C,0X5D}}} // got from gateway setup
                                      and now on my Home assistant in file
                                      /home/homeassistant/.homeassistant/mysensors.json
                                      found my node but wthout full information like name....
                                      "0": {
                                      "battery_level": 0,
                                      "sketch_name": null,
                                      "sketch_version": null,
                                      "children": {},
                                      "type": 18,
                                      "protocol_version": "2.2.0",
                                      "sensor_id": 0
                                      "33": {
                                      "battery_level": 0,
                                      "sketch_version": "1.0",
                                      "children": {
                                      "1": {
                                      "type": 3,
                                      "id": 1,
                                      "values": {
                                      "2": "1"
                                      "description": ""
                                      "type": 17,
                                      "sensor_id": 33
                                      and in Home Assistant is not show in devices this node. Not found it.
                                      What i done wrong ?
                                      AnticimexA S 2 Replies Last reply
                                      • pepsonP pepson
                                        HI
                                        Then
                                        at the top setup...
                                        "0": {
                                        "battery_level": 0,
                                        "children": {},
                                        "type": 18,
                                        "sensor_id": 0
                                        "33": {
                                        "battery_level": 0,
                                        "children": {
                                        "1": {
                                        "type": 3,
                                        "id": 1,
                                        "values": {
                                        "2": "1"
                                        "description": ""
                                        "type": 17,
                                        "sensor_id": 33
                                        What i done wrong ?
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @pepson said in 💬 Security & Signing:
                                        How many times do I need to tell you to get rid of the whitelisting flag?
                                          pepsonP
                                          pepsonP
                                          pepson
                                          @anticimex
                                          Ok read... but...
                                          when i use MY_SIGNING_NODE_WHITELISTING i must on node in sketch add serial number my gateway and also serial number for node. But from where i can get serial number for my arduino pro mini ? I dont know...becasue i don use ATSHA204 but i use only soft signing....
