  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 22.5k Views 11 Watching
  • L lis610
    Thank you. Did you upload the file for download?
    petewillP
    petewillP
    petewill
    @lis610 yes, I uploaded it to the page in the link at the top of this page.
    • L
      L
      lis610
      Cannot locate file "WholeHouseFan2.0.ino"
      petewillP 1 Reply Last reply
      • L lis610
        petewillP
        petewillP
        petewill
        wrote on last edited by petewill
        #37
        @lis610 Strange. It disappeared. I added it again and just downloaded it so you should be good. Sorry for all the issues!
        • L
          L
          lis610
          Thank you. The box is ready. Next step connect all hardware. So far no luck with the display (KMR-1.8 SPI). What kind of display model you used in this project.
          • L lis610
            petewillP
            petewillP
            petewill
            @lis610 This is the display I used.
            http://www.ebay.com/itm/331443126874?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
            • L
              L
              lis610
              Got the same display. It is working with Adafruit graphicstest example. I did not connect any components just display. If I ran the FAN sketch should be something showing on the display?
              Or need to connect everything?
              • L lis610
                petewillP
                petewillP
                petewill
                @lis610 is #define TFT_DISPLAY_ON uncommented? Also, you will at least need the radio attached so the MySensors code can fully load (you can also setup defines to proceed without connecting to gateway but I don't remember them off the top of my head). I don't remember if there are any other dependencies since it as been so long since I built this.
                • L
                  L
                  lis610
                  Please help
                  Display is working with Adafruit graphicstest example pins:
                  #define TFT_CS 10 #define TFT_RST 9 #define TFT_DC 8# define TFT_SCLK 13 #define TFT_MOSI 11
                  I did try the same pins in FAN sketch -nothing on display
                  Tryed pin# from FAN sketch on Adafruit graphicstest- nothing on display.
                  Nothing come up
                  I did connect to the radio. Got something from MY_DUBUG not sure is it good or bad:
                  624893 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                  626903 !TSM:FPAR:NO REPLY
                  626905 TSM:FPAR
                  626941 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  628951 !TSM:FPAR:NO REPLY
                  628953 TSM:FPAR
                  628989 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  630999 !TSM:FPAR:NO REPLY
                  631001 TSM:FPAR
                  631037 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  633047 !TSM:FPAR:FAIL
                  633049 TSM:FAIL:CNT=7
                  633051 TSM:FAIL:DIS
                  633053 TSF:TDI:TSL
                  693057 TSM:FAIL:RE-INIT
                  693059 TSM:INIT
                  693067 TSM:INIT:TSP OK
                  693069 TSF:SID:OK,ID=5
                  693071 TSM:FPAR
                  693108 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  693432 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  693438 TSF:MSG:FPAR OK,ID=0,D=1
                  695117 TSM:FPAR:OK
                  695119 TSM:ID
                  695119 TSM:ID:OK
                  695121 TSM:UPL
                  695160 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  697171 TSM:UPL
                  697178 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                  699187 TSM:UPL
                  699224 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                  701233 TSM:UPL
                  • L lis610
                    Please help
                    Nothing come up
                    626905 TSM:FPAR
                    628953 TSM:FPAR
                    631001 TSM:FPAR
                    633051 TSM:FAIL:DIS
                    633053 TSF:TDI:TSL
                    693059 TSM:INIT
                    693071 TSM:FPAR
                    695117 TSM:FPAR:OK
                    695119 TSM:ID
                    695119 TSM:ID:OK
                    695121 TSM:UPL
                    697171 TSM:UPL
                    699187 TSM:UPL
                    701233 TSM:UPL
                    petewillP
                    petewillP
                    petewill
                    @lis610 It looks like it's having issues communicating with your gateway. Here is a link to the log parser. You can use this in the future to check out your logs.
                    https://www.mysensors.org/build/parser?log=624893 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A 626903 !TSM%3AFPAR%3ANO REPLY 626905 TSM%3AFPAR 626941 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 628951 !TSM%3AFPAR%3ANO REPLY 628953 TSM%3AFPAR 628989 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 630999 !TSM%3AFPAR%3ANO REPLY 631001 TSM%3AFPAR 631037 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 633047 !TSM%3AFPAR%3AFAIL 633049 TSM%3AFAIL%3ACNT%3D7 633051 TSM%3AFAIL%3ADIS 633053 TSF%3ATDI%3ATSL 693057 TSM%3AFAIL%3ARE-INIT 693059 TSM%3AINIT 693067 TSM%3AINIT%3ATSP OK 693069 TSF%3ASID%3AOK%2CID%3D5 693071 TSM%3AFPAR 693108 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 693432 TSF%3AMSG%3AREAD%2C0-0-5%2Cs%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A0 693438 TSF%3AMSG%3AFPAR OK%2CID%3D0%2CD%3D1 695117 TSM%3AFPAR%3AOK 695119 TSM%3AID 695119 TSM%3AID%3AOK 695121 TSM%3AUPL 695160 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 697171 TSM%3AUPL 697178 TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A1 699187 TSM%3AUPL 699224 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 701233 TSM%3AUPL
                    Also, did you comment/uncomment the proper defines as noted above and in the code comments?
                    Try adding this line before #include <MySensors.h>
                    #define MY_TRANSPORT_WAIT_READY_MS 4000 //This will allow the sensor to function if it can't find the gateway when it first starts up
                    • L
                      L
                      lis610
                      This my node:
                      • L
                        L
                        lis610
                        Gateway :
                        https://www.mysensors.org/build/parser?log=0%3B0%3B3%3B0%3B9%3Bgateway started%2C id%3D0%2C parent%3D0%2C distance%3D0 0%3B0%3B3%3B0%3B14%3BGateway startup complete. 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dok%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dok%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1
                        • L
                          L
                          lis610
                          VeraEdge:
                          • L
                            L
                            lis610
                            Hi Pete,
                            Do you see anything wrong with gateway, node and vera
                            • L lis610
                              Hi Pete,
                              petewillP
                              petewillP
                              petewill
                              @lis610 sorry, I'm not a place where I can look in depth. It looks like your code isn't communicating with the gateway though. Did you try the line of code above? The device should work with the push button even if it can't communicate with the gateway (with that code).
                              • L
                                L
                                lis610
                                I will come back to the communication issue later.
                                In your resent code SPI is comment out " //#include <SPI.h> " what is the reason you comment SPI?
                                The display is not showing anything even with: #define TFT_DISPLAY_ON. and #include <SPI.h>
                                petewillP H 2 Replies Last reply
                                • L lis610
                                  petewillP
                                  petewillP
                                  petewill
                                  @lis610 if it can't communicate with the gateway and controller the node will never get to the loop which could be why the display isn't working. The SPI include used to be required for MySensors.
                                  • L lis610
                                    H
                                    H
                                    hard-shovel
                                    wrote on last edited by hard-shovel
                                    #51
                                    @lis610 It seems you have two problems.
                                    1 The radio is not connecting reliably with the gateway and may blocking the display from starting.
                                    There are lots of other messages on troubleshooting radio problems.
                                    2 The Graphic Display is not operating correctly.
                                    For Item one, You eventually need to resolve the radio problem, However as pete stated in his message if you add the following define it will allow the sketch to run, I can confirm this as i have just tested with just a arduino and just a graphics display.
                                    So if you add this and the display still does not display then you need to test the display connections.
                                    You stated
                                    "Display is working with Adafruit graphicstest example pins:
                                    Tryed pin# from FAN sketch on Adafruit graphicstest- nothing on display."
                                    So with standard connections the display is working.
                                    So you need to test and get the display working with the adafruit test program using the correct pins required for the house fan program.
                                    Add the following info the adafruit test sketch as option 3 and comment out the options 1 and 2. Wire the graphic display as per the house fan requirements and it should work.
                                    // Option 3: testing pins used in Whole House Fan Node
                                    #define TFT_CS     3
                                    #define TFT_DC     6
                                    #define TFT_MOSI   7
                                    #define TFT_SCLK   8
                                    #define TFT_RST    0  // you can also connect this to the Arduino reset
                                                          // in which case, set this #define pin to 0
                                    Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
                                    If it does not work the same as when connected to the standard connections , then your wiring is in error and need to be changed to make it work before proceeding to the other sketch.
                                    • L
                                      L
                                      lis610
                                      Thank you very much. Star Over. Rewire display and change the code. Never thought I would be excited to see the word ”Error” on display :).
                                      I got five NRF24L01+. Two of them are not working at all. Looks like the one on the gateway working ok, but the node is unstable.
                                      Do I need to create an additional device for Fan in Vera or, it will be displayed within the MySensors serial gateway?
                                      • L lis610
                                        petewillP
                                        petewillP
                                        petewill
                                        @hard-shovel Thanks for the help.
                                        @lis610 You are picking a very advanced project to start with. If you have the time I'd suggest an easier project like a motion sensor to get started. If you want to keep going I'd suggest doing some additional reading/watching on how this all works. Not trying to be critical but rather save you frustration.
                                        I'm not running UI7 on my Vera so I haven't tested but it should automatically create your device as long as you are including it when first starting the node. For me I press the "Start" button then power up my node (the fan in this case).
                                        However, if you don't have good communication it may not add correctly.
                                        • L
                                          L
                                          lis610
                                          .......Thanks
