  3. 💬 Insulated Whole House Fan
mysensorswhole house fan
72 Posts 11 Posters 23.4k Views 11 Watching
  • L lis610
    @petewill Hi Pete
    Just Start building the system and got an error at sketch verify.
    "exit status 1
    'class Adafruit_ST7735' has no member named 'setFont'"
    petewillP
    petewillP
    petewill
    @lis610 Sorry for the delay. Work has been very busy. I have attached the libraries I'm using. I was able to get it to compile when I just tested. https://drive.google.com/file/d/1wauxHRf5pyqLnBGsfCP8UPJQR1wNdkoF/view?usp=sharing
    Let me know if you have issues with this.
    • L
      L
      lis610
      THANK YOU so much for sharing. Most of the errors gone, but one left (using Arduino v.1.8.5; MySensors v 2.3.0):
      [C:\Users\BEAST\Documents\Arduino\Whole-House-Fan\code\New folder\WholeHouseFan2.0\WholeHouseFan2.0.ino: In function 'void presentation()':
      WholeHouseFan2.0:197: error: 'TEMP_CHILD_NAME' was not declared in this scope present(TEMP_ID, S_TEMP, TEMP_CHILD_NAME);
      exit status 1]
      petewillP 1 Reply Last reply
      • L lis610
        exit status 1]
        petewillP
        petewillP
        petewill
        @lis610 Sorry about that. I just fixed the code on the build page. Hopefully that will get you up and running :)
        • L
          L
          lis610
          Thank you. Did you upload the file for download?
          • L lis610
            petewillP
            petewillP
            petewill
            @lis610 yes, I uploaded it to the page in the link at the top of this page.
            • L
              L
              lis610
              Cannot locate file "WholeHouseFan2.0.ino"
              • L lis610
                petewillP
                petewillP
                petewill
                wrote on last edited by petewill
                #37
                @lis610 Strange. It disappeared. I added it again and just downloaded it so you should be good. Sorry for all the issues!
                • L
                  L
                  lis610
                  Thank you. The box is ready. Next step connect all hardware. So far no luck with the display (KMR-1.8 SPI). What kind of display model you used in this project.
                  • L lis610
                    petewillP
                    petewillP
                    petewill
                    @lis610 This is the display I used.
                    http://www.ebay.com/itm/331443126874?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                    • L
                      L
                      lis610
                      Got the same display. It is working with Adafruit graphicstest example. I did not connect any components just display. If I ran the FAN sketch should be something showing on the display?
                      Or need to connect everything?
                      • L lis610
                        petewillP
                        petewillP
                        petewill
                        @lis610 is #define TFT_DISPLAY_ON uncommented? Also, you will at least need the radio attached so the MySensors code can fully load (you can also setup defines to proceed without connecting to gateway but I don't remember them off the top of my head). I don't remember if there are any other dependencies since it as been so long since I built this.
                        • L
                          L
                          lis610
                          Please help
                          Display is working with Adafruit graphicstest example pins:
                          #define TFT_CS 10 #define TFT_RST 9 #define TFT_DC 8# define TFT_SCLK 13 #define TFT_MOSI 11
                          I did try the same pins in FAN sketch -nothing on display
                          Tryed pin# from FAN sketch on Adafruit graphicstest- nothing on display.
                          Nothing come up
                          I did connect to the radio. Got something from MY_DUBUG not sure is it good or bad:
                          624893 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=1,st=OK:
                          626903 !TSM:FPAR:NO REPLY
                          626905 TSM:FPAR
                          626941 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          628951 !TSM:FPAR:NO REPLY
                          628953 TSM:FPAR
                          628989 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          630999 !TSM:FPAR:NO REPLY
                          631001 TSM:FPAR
                          631037 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          633047 !TSM:FPAR:FAIL
                          633049 TSM:FAIL:CNT=7
                          633051 TSM:FAIL:DIS
                          633053 TSF:TDI:TSL
                          693057 TSM:FAIL:RE-INIT
                          693059 TSM:INIT
                          693067 TSM:INIT:TSP OK
                          693069 TSF:SID:OK,ID=5
                          693071 TSM:FPAR
                          693108 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                          693432 TSF:MSG:READ,0-0-5,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          693438 TSF:MSG:FPAR OK,ID=0,D=1
                          695117 TSM:FPAR:OK
                          695119 TSM:ID
                          695119 TSM:ID:OK
                          695121 TSM:UPL
                          695160 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          697171 TSM:UPL
                          697178 TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=1,st=OK:1
                          699187 TSM:UPL
                          699224 !TSF:MSG:SEND,5-5-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
                          701233 TSM:UPL
                          • L lis610
                            Please help
                            Nothing come up
                            626905 TSM:FPAR
                            628953 TSM:FPAR
                            631001 TSM:FPAR
                            633051 TSM:FAIL:DIS
                            633053 TSF:TDI:TSL
                            693059 TSM:INIT
                            693071 TSM:FPAR
                            695117 TSM:FPAR:OK
                            695119 TSM:ID
                            695119 TSM:ID:OK
                            695121 TSM:UPL
                            697171 TSM:UPL
                            699187 TSM:UPL
                            701233 TSM:UPL
                            petewillP
                            petewillP
                            petewill
                            @lis610 It looks like it's having issues communicating with your gateway. Here is a link to the log parser. You can use this in the future to check out your logs.
                            https://www.mysensors.org/build/parser?log=624893 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A 626903 !TSM%3AFPAR%3ANO REPLY 626905 TSM%3AFPAR 626941 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 628951 !TSM%3AFPAR%3ANO REPLY 628953 TSM%3AFPAR 628989 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 630999 !TSM%3AFPAR%3ANO REPLY 631001 TSM%3AFPAR 631037 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 633047 !TSM%3AFPAR%3AFAIL 633049 TSM%3AFAIL%3ACNT%3D7 633051 TSM%3AFAIL%3ADIS 633053 TSF%3ATDI%3ATSL 693057 TSM%3AFAIL%3ARE-INIT 693059 TSM%3AINIT 693067 TSM%3AINIT%3ATSP OK 693069 TSF%3ASID%3AOK%2CID%3D5 693071 TSM%3AFPAR 693108 TSF%3AMSG%3ASEND%2C5-5-255-255%2Cs%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%2Cft%3D0%2Cst%3DOK%3A 693432 TSF%3AMSG%3AREAD%2C0-0-5%2Cs%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A0 693438 TSF%3AMSG%3AFPAR OK%2CID%3D0%2CD%3D1 695117 TSM%3AFPAR%3AOK 695119 TSM%3AID 695119 TSM%3AID%3AOK 695121 TSM%3AUPL 695160 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 697171 TSM%3AUPL 697178 TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D1%2Cst%3DOK%3A1 699187 TSM%3AUPL 699224 !TSF%3AMSG%3ASEND%2C5-5-0-0%2Cs%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cft%3D0%2Cst%3DNACK%3A1 701233 TSM%3AUPL
                            Also, did you comment/uncomment the proper defines as noted above and in the code comments?
                            Try adding this line before #include <MySensors.h>
                            #define MY_TRANSPORT_WAIT_READY_MS 4000 //This will allow the sensor to function if it can't find the gateway when it first starts up
                            • L
                              L
                              lis610
                              This my node:
                              • L
                                L
                                lis610
                                Gateway :
                                https://www.mysensors.org/build/parser?log=0%3B0%3B3%3B0%3B9%3Bgateway started%2C id%3D0%2C parent%3D0%2C distance%3D0 0%3B0%3B3%3B0%3B14%3BGateway startup complete. 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dok%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dok%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1 0%3B0%3B3%3B0%3B9%3Bread and forward%3A 3-3-255 s%3D255%2Cc%3D3%2Ct%3D7%2Cpt%3D0%2Cl%3D0%2Csg%3D0%3A 0%3B0%3B3%3B0%3B9%3Bsend%3A 0-0-3-3 s%3D255%2Cc%3D3%2Ct%3D8%2Cpt%3D1%2Cl%3D1%2Csg%3D0%2Cst%3Dfail%3A0 0%3B0%3B3%3B0%3B9%3Bread%3A 3-3-0 s%3D255%2Cc%3D3%2Ct%3D24%2Cpt%3D1%2Cl%3D1%2Csg%3D0%3A1 3%3B255%3B3%3B0%3B24%3B1
                                • L
                                  L
                                  lis610
                                  VeraEdge:
                                  • L
                                    L
                                    lis610
                                    Hi Pete,
                                    Do you see anything wrong with gateway, node and vera
                                    • L lis610
                                      Hi Pete,
                                      petewillP
                                      petewillP
                                      petewill
                                      @lis610 sorry, I'm not a place where I can look in depth. It looks like your code isn't communicating with the gateway though. Did you try the line of code above? The device should work with the push button even if it can't communicate with the gateway (with that code).
                                      • L
                                        L
                                        lis610
                                        I will come back to the communication issue later.
                                        In your resent code SPI is comment out " //#include <SPI.h> " what is the reason you comment SPI?
                                        The display is not showing anything even with: #define TFT_DISPLAY_ON. and #include <SPI.h>
                                        petewillP H 2 Replies Last reply
                                        • L lis610
                                          petewillP
                                          petewillP
                                          petewill
                                          @lis610 if it can't communicate with the gateway and controller the node will never get to the loop which could be why the display isn't working. The SPI include used to be required for MySensors.
