  3. Changing a node not captured by gateway
8 Posts 5 Posters 2.3k Views 5 Watching
  • hakha4H
    hakha4H
    hakha4
    I'm new to Mysensors but must say that I'm impressed sofar! Great job from the developers. I've made a gateway with ESP8266 that work's just fine. Now to my issue. Made a node with two relays and it show's up as expected in Domoticz and seems to work perfect. When upgrading the node by adding another relay it don't shows the added relay. What do I have to do for gateway to see that a node has changed ?
    Any help appreciated
    Regards
    K 1 Reply Last reply
    • rejoe2R
      rejoe2R
      rejoe2
      Can you please give more background info?
      I don't think it's a development issue but either related to domoticz or to the code on your node. Would you mind posting your sketch?
      • hakha4H hakha4
        Regards
        K
        K
        kimot
        @hakha4
        What mean "don't shows the added relay" .
        Sometimes you do not see your node in "Hardware",
        but in "Devices" child sensors from that node are normally presented.
        No node 254 in list:
        But its sensors are in devices:
        • hakha4H
          hakha4H
          hakha4
          Thankäs for answer. I've find code on internet with two relay's 'A and B'. Just added a third relay 'C'. When first using two relays everything worked ok with two child's registered in Domoticz but when updating the node with relay 'C it don't shows up in Domoticz. So my main question is if gateway recognize changes in an earlier reg. node or if you have to delete some info for a fresh reg. ? I've checked code for typo error but can't see any obvious errors. See code below:
           * NANO:
           * Radio occupies pin 2,9-13
          #define MY_REPEATER_FEATURE
          #define RELAY_ON 1
          #define RELAY_OFF 0
          #define SSR_A_ID 1   // Id of the sensor child pump filter
          #define SSR_B_ID 2   // Id of the sensor child pump waterfall
          #define SSR_C_ID 3   // Id of the sensor child pump waterfall
          const int buttonPinA = 3;
          const int buttonPinB = 7;
          const int buttonPinC = 8;
          const int relayPinA = 4;
          const int relayPinB = 5;
          const int relayPinC = 6;
          int oldValueA = 0;
          int oldValueB = 0;
          int oldValueC = 0;
          bool stateA = false;
          bool stateB = false;
          bool stateC = false;
          Bounce debouncerA = Bounce();
          Bounce debouncerB = Bounce();
          Bounce debouncerC = Bounce();
          MyMessage msgA(SSR_A_ID, V_STATUS);
          MyMessage msgB(SSR_B_ID, V_STATUS);
          MyMessage msgC(SSR_B_ID, V_STATUS);
            pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(buttonPinC, INPUT_PULLUP); // Setup the button Activate internal pull-up
            pinMode(relayPinA, OUTPUT);
            pinMode(relayPinB, OUTPUT);
           pinMode(relayPinC, OUTPUT);
            // After setting up the buttons, setup debouncer
            debouncerA.attach(buttonPinA);
            debouncerA.interval(5);
            debouncerB.attach(buttonPinB);
            debouncerB.interval(5);
            debouncerC.attach(buttonPinC);
            debouncerC.interval(5);
            digitalWrite(relayPinA, RELAY_OFF);
            digitalWrite(relayPinB, RELAY_OFF);
             digitalWrite(relayPinC, RELAY_OFF);
              /*--------------------- Added these lines for toggle switch-------------------------*/
            oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
            oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
            oldValueC = digitalRead(buttonPinC);  // set oldValueB to the current status of the toggle switch
            send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
            send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
            send(msgC.set(false)); // Send off state for relayB to ensure controller knows the switch is off
          void presentation()  {
            sendSketchInfo("Pond Controller", "1.0");
            present(SSR_A_ID, S_LIGHT);
            present(SSR_B_ID, S_LIGHT);
            present(SSR_C_ID, S_LIGHT);
            debouncerA.update();
            // Get the update value
            int valueA = debouncerA.read();
            if (valueA != oldValueA) {
              send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
            oldValueA = valueA;
            debouncerB.update();
            int valueB = debouncerB.read();
            if (valueB != oldValueB) {
              send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
            oldValueB = valueB;
            debouncerC.update();
            int valueC = debouncerC.read();
            if (valueC != oldValueC) {
              send(msgC.set(stateC ? false : true), true); // Send new state and request ack back
            oldValueC = valueC;
              switch (message.sensor) {
                case 1:
                  stateA = message.getBool();
                  digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
                case 2:
                  stateB = message.getBool();
                  digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
                  case 3:
                  stateC = message.getBool();
                  digitalWrite(message.sensor + 4, stateC ? RELAY_ON : RELAY_OFF);
              Serial.print("from node:");
              Serial.println(message.sender);
          Regards
          • hakha4H hakha4
             * NANO:
            #define RELAY_ON 1
            #define RELAY_OFF 0
            int oldValueA = 0;
            int oldValueB = 0;
            int oldValueC = 0;
              oldValueA = valueA;
              oldValueB = valueB;
              oldValueC = valueC;
                  case 1:
                  case 2:
                    case 3:
            Regards
            @hakha4 the code looks good to me. What does the device page in Domoticz look like? What do the node and gateway debug logs say?
            Maybe the presentations are putting too much strain on the power supply or radio (the debug output will show whether that is the case). Try adding wait(100) after each presentation statement.
            • hakha4H
              hakha4H
              hakha4
              I'll try put in a delay and get back if not solved. Thank's
              • GizMoCuzG
                GizMoCuzG
                GizMoCuz
                The code looks wrong to me
                this
                should probably be
                MyMessage msgC(SSR_C_ID, V_STATUS);
                • hakha4H
                  hakha4H
                  hakha4
                  You're absolutely right. Should be MyMessage msgC(SSR_C_ID, V_STATUS);
                  Sometimes you get blind when looking for typos. Thank's
