  3. ESP32 gateway pinout
5 Posts 3 Posters 3.6k Views 3 Watching
  • hakha4H
    hakha4H
    hakha4
    Hi
    I'm trying to get a gateway with ESP32 devkit V1.0 to work. I have an ESP8266 GW working but want some extra pins for traffic light to work and perhaps better speed etc.
    I found a pinout in 'MyHWESP32.h' as below but I always get confused refeering to pin number. I assume the numbers refeers to GPIO number ?. I use an adapter for the radio to get extra juice and power the adapter from the Vin pin (5V from USB) but I can't get radio to work.
    Checked and rechecked wiring.
    Output from serial port :
    10040 TSM:FAIL:RE-INIT
    10041 TSM:INIT
    10048 !TSM:INIT:TSP FAIL
    10050 TSM:FAIL:CNT=2
    10052 TSM:FAIL:DIS
    10053 TSF:TDI:TSL
    20056 TSM:FAIL:RE-INIT
    20057 TSM:INIT
    20064 !TSM:INIT:TSP FAIL
    20066 TSM:FAIL:CNT=3
    20068 TSM:FAIL:DIS
    20069 TSF:TDI:TSL
    Adapter used :
    Code :
     * Copyright (C) 2013-2018 Sensnology AB
     * Version 1.0 - tekka
     * The ESP32 gateway sends data received from sensors to the WiFi link.
     * ----------- PINOUT --------------
     * | IO   | RF24 | RFM69 | RFM95 |
      | MOSI | 23   | 23    | 23    |
      | MISO | 19   | 19    | 19    |
      | SCK  | 18   | 18    | 18    |
      | CSN  | 5    | 5     | 5     |
      | CE   | 17   | -     | -     |
      | RST  | -    | 17    | 17    |
      | IRQ  | 16*  | 16    | 16    |
     * Make sure to fill in your ssid and WiFi password below.
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP32
    #define MY_WIFI_SSID "xxxxxxx"
    #define MY_WIFI_PASSWORD "xxxxxxxx"
    #define MY_HOSTNAME "ESP32_GW"
    #define MY_IP_ADDRESS 192,168,1,10
    #define MY_PORT 5003
    Anyone succesfully get the ESP32 to work ? Any idea what could be the problem ? Can someone confirm that pin numbers are correct ?
    Any help appreciated
    berkseoB 1 Reply Last reply
    • H
      H
      heinzv
      @hakha4 I can tell you at least, that ESP32 boards with RFM95 work. I have tried at least two boards successfully. A Heltec ESP32 LoRa board and another one with RFM95 on board.
      In your code, you use the RF24. So what kind of gateway are you building here? The ESP32 has WiFI and you use another RF24 WiFi radio? I have never used the nRF24 Chip.
      So I guess it's just a matter of the proper pin assignments. You can use the physical pins or the logical pin names as described in your ESP32 dev board. If you have selected your board in your project it should also know the logical names of the pins or use a ESP32 spec to map it to the phyicals pin numbers.
      https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=14&cad=rja&uact=8&ved=0ahUKEwi3ivfY86jcAhVMsKQKHSPnDr8QFghYMA0&url=https%3A%2F%2Fespressif.com%2Fsites%2Fdefault%2Ffiles%2Fdocumentation%2Fesp32_datasheet_en.pdf&usg=AOvVaw36NvMsK4MvrPdxjJU_rLR3
      • hakha4H
        hakha4H
        hakha4
        Hi
        Thank's for answer. RF24 isn't a wifi radio, work's like RFM I believe.
        I'm building a Mysensors gateway with lan for Domoticz and as I said with Esp8266 it works and I've used the example sketch for Esp32 GW so I must made some fault. I'll try and error but if someone have tips I appreciate comment's
        • hakha4H hakha4
          Hi
          10041 TSM:INIT
          10052 TSM:FAIL:DIS
          10053 TSF:TDI:TSL
          20057 TSM:INIT
          20068 TSM:FAIL:DIS
          20069 TSF:TDI:TSL
          Adapter used :
          Code :
            | CSN  | 5    | 5     | 5     |
            | CE   | 17   | -     | -     |
            | RST  | -    | 17    | 17    |
          berkseoB
          berkseoB
          berkseo
          @hakha4
          Checked, I confirm sketches in examples do not work in a sheaf of ESP-RF24
          Board downloaded from git hub Expessif
          Tested on NODE MCU32S
          • hakha4H hakha4
            Hi
            berkseoB
            berkseoB
            berkseo
            @hakha4
            I take it back, the sketches work. The problem was solved as follows: connected the radio to the output of nodemcu 3.3 V. before that, the radio was on a separate power line. I think the esp32 is very power sensitive, I think it was a level mismatch on the SPI pins.
            Try it, I think you have the same problem.
