  3. 💬 Simple compact RF24 node (ATmega328 + NRF24)
5 Posts 3 Posters 1.7k Views 3 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/594/Simple-compact-RF24-node-ATmega328-NRF24
    • C
      C
      cabat
      Update status "Work in progress" (add info about tested in hardware configuration, add example of usage).
      • YveauxY
        There are copper traces located under the nrf antenna, which is regarded 'sub optimal'.
        What is the range of the nodes?
        C 1 Reply Last reply
        • YveauxY Yveaux
          C
          C
          cabat
          @yveaux Sorry, i don't test the range of nodes - plan to use in the 2 floor house of 60 meters.
          But you opinion is correct, this design is compromise of size, pins count and range degradate.
          This is prototype, work good about 1 year:
          • C
            C
            cabat
            Update: PCB with NRF24 standart version tested in hardware.
