  3. Serial Gateway w/ MQTT using nodeJS
6 Posts 4 Posters 4.6k Views 7 Watching
  • barduinoB Offline
    barduinoB Offline
    barduino
    Hi Folks
    While adding mqtt feature to my controller and inspired by @cranky and his node-red controller, I've created a simple nodejs app to do 2 things:
    • Get the information from the serial gateway and publish it to a broker
    • Subscribe from the broker and send it to the serial gateway.
    Here is the app.js
    // LIBS
    var com = require("serialport");
    var mqtt = require('mqtt');
    // SERIAL PORT SETTINGS
    var serial_port = '/dev/ttyACM0';
    // var serial_port = 'COM3'; // windows
    // MQTT SETTINGS
    var mqtt_host     = 'mqtts://m10.cloudmqtt.com';
    var mqtt_port     =  8883;
    var mqtt_username =  'user name';
    var mqtt_password =  'password';
    var KEY = 'yourkey';
    // publications will be made into /haall/yourkey/out/x/x/x/x
    // subcriptions will come from /haall/yourkey/in/x/x/x/
    // adjust as necessary
    // MQTT CLIENT OPTIONS
    var mqtt_Options = {
         port:              mqtt_port
        ,keepalive:         10                  //seconds, set to 0 to disable
        ,clientId:          'haall_' + KEY
        ,protocolId:        'MQTT'
        //,protocolVersion: 4
        ,clean:             false               //set to false to receive QoS 1 and 2 messages while offline
        ,reconnectPeriod:   1000                // milliseconds, interval between two reconnections
        ,connectTimeout:    30 * 1000           //milliseconds, time to wait before a CONNACK is received
        ,username:          mqtt_username       //the username required by your broker, if any
        ,password:          mqtt_password       //the password required by your broker, if any
        ,incomingStore: , // a Store for the incoming packets
        ,outgoingStore: , // a Store for the outgoing packets
        //a message that will sent by the broker automatically when the client disconnect badly. The format is:
        ,will: {topic:  '/haall/'+KEY+'/out',                           // the topic to publish
                payload:'Client haall_' + KEY +'has lost connection',   // the message to publish
                qos:    1,                                              // the QoS
                retain: false                                           // the retain flag
    // SERIAL PORT
    var serialPort = new com.SerialPort(serial_port, {
        baudrate: 115200,
    	parser: com.parsers.readline('\n')
    // START SERIAL PORT
    console.log('Opening Serial port...');
    serialPort.open(function (error) {
      if ( error ) {
        console.log('failed to open: '+error);
        console.log('Serial port opened!');
    // START MQTT
    console.log('Starting MQTT...');
    var mqtt_client  = mqtt.connect(mqtt_host,mqtt_Options);
    console.log('Subscribing MQTT...');
    mqtt_client.subscribe('/haall/'+KEY+'/in/#');
    console.log('Publish MQTT...');
    mqtt_client.publish('/haall/'+KEY+'/out', 'HAALL mqtt client started at '+ new Date());
    // SERIAL PORT OUTGOING
    serialPort.on('data', function(data) {
    	if (data.indexOf('0;0;3;0;9;') == 0) {
    		console.log('        I_LOG: '+data);
            mqttPublish(data);
    	else{
    		console.log(data);
    		mqttPublish(data);
    // MQTT INCOMING
    mqtt_client.on('message', function (topic, message) {
    	var m = topic.toString();
    	m = m.replace('/haall/'+KEY+'/in/','');
    	m = m.split('/').join(';');
    	m = m + ';' + message.toString();
    	serialPort.write('' + m + '\n');
      	console.log('INCOMING MQTT: ' + topic + ':' + message.toString());
    // MQTT OUTGOING
    function mqttPublish(data){
    	var topic = '/haall/'+KEY+'/out/';
    	var params = data.split(';');
    	topic = topic + params[0] + '/';
    	topic = topic + params[1] + '/';
    	topic = topic + params[2] + '/';
    	topic = topic + params[3] + '/';
    	topic = topic + params[4] + '';
    	var payload = params[5];
    	mqtt_client.publish(topic,payload);
    	console.log('OUTGOING MQTT: ' + topic + ' Payload: ' + payload);
    and the package.json
      "name": "gw",
      "version": "0.0.2",
      "description": "Gateway Module for MySensors",
      "dependencies": {
        "serialport": "^1.4.5",
        "mqtt": "^1.7.0"
      "main": "gw.js",
      "devDependencies": {},
      "scripts": {
        "test": "echo \"Error: no test specified\" && exit 1"
      "author": "",
      "license": "ISC"
    ร 1 Reply Last reply
    • icebobI Offline
      icebobI Offline
      icebob
      @barduino Thx, good job!
      • barduinoB barduino
        Hi Folks
        Here is the app.js
        // LIBS
        // MQTT SETTINGS
             port:              mqtt_port
            ,protocolId:        'MQTT'
                    qos:    1,                                              // the QoS
        // SERIAL PORT
            baudrate: 115200,
          if ( error ) {
        // START MQTT
                mqttPublish(data);
        	else{
        		console.log(data);
        		mqttPublish(data);
        // MQTT INCOMING
        // MQTT OUTGOING
          "name": "gw",
          "version": "0.0.2",
          "dependencies": {
            "mqtt": "^1.7.0"
          "main": "gw.js",
          "scripts": {
          "author": "",
          "license": "ISC"
        ร Offline
        ร Offline
        รอเรือ
        @barduino said in Serial Gateway w/ MQTT using nodeJS:
        Hi Folks
        Here is the app.js
        // LIBS
        // MQTT SETTINGS
             port:              mqtt_port
            ,protocolId:        'MQTT'
                    qos:    1,                                              // the QoS
        // SERIAL PORT
            baudrate: 115200,
          if ( error ) {
        // START MQTT
                mqttPublish(data);
        	else{
        		console.log(data);
        		mqttPublish(data);
        // MQTT INCOMING
        // MQTT OUTGOING
          "name": "gw",
          "version": "0.0.2",
          "dependencies": {
            "mqtt": "^1.7.0"
          "main": "gw.js",
          "scripts": {
          "author": "",
          "license": "ISC"
        @barduino, this is great stuff, any chance that there is an updated version of app.js? I've been trying hard to get this working.
        Cheers!
        • ร รอเรือ
          Hi Folks
          Here is the app.js
          // LIBS
          // MQTT SETTINGS
               port:              mqtt_port
              ,protocolId:        'MQTT'
                      qos:    1,                                              // the QoS
          // SERIAL PORT
              baudrate: 115200,
            if ( error ) {
          // START MQTT
                  mqttPublish(data);
          	else{
          		console.log(data);
          		mqttPublish(data);
          // MQTT INCOMING
          // MQTT OUTGOING
            "name": "gw",
            "version": "0.0.2",
            "dependencies": {
              "mqtt": "^1.7.0"
            "main": "gw.js",
            "scripts": {
            "author": "",
            "license": "ISC"
          Cheers!
          ร Offline
          ร Offline
          รอเรือ
          wrote on last edited by รอเรือ
          Anyway, I put some effort in this because I think that the Serial-to-MQTT gateway is actually the ultimate gateway for MySensors. It's very easy to build and it's versatile because it uses MQTT which in many cases will eliminate the use of more or less buggy add-ons for different home automation systems. It's my hope that the team would like to consider to add it as a new gateway type.
          I used the code from @barduino as a starting point but there has been many changes to it. Here it goes:
          /* Serial Gateway w/ MQTT using nodeJS, originally written by barduino https://forum.mysensors.org/user/barduino
           * Rewritten by รอเรือ
           * Copyright: Unknown
           * MySensors forum topic: https://forum.mysensors.org/topic/3042/serial-gateway-w-mqtt-using-nodejs
           * Using:
           *		serialport -npm: https://www.npmjs.com/package/serialport
           *		mqtt -npm: https://www.npmjs.com/package/mqtt#client
          // Custom settings
          var serial_port = '/dev/ttyUSBmys';
          var serial_baud_rate = 115200;
          var mqtt_host     = 'XXXXXXXX';
          var mqtt_port     =  1883;
          var mqtt_subscribe_topic = 'mysensors-in';
          var mqtt_publish_topic = 'mysensors-out';
          var mqtt_username =  '';
          var mqtt_password =  '';
          var mqtt_client_id = 'mysensors_' + Math.random().toString(16).substr(2, 8);
          const DEBUG = false;
          // LIBS
          const SerialPort = require('serialport');
          const Readline = require('@serialport/parser-readline')
          const mqtt = require('mqtt');
          	port: mqtt_port,
          	keepalive: 60, //seconds, set to 0 to disable
          	clientId: mqtt_client_id,
          	protocolId: 'MQTT', //'MQTT', 'mqtts', 'tcp', 'tls', 'ws', 'wss'.
          	//protocolVersion: 4,
          	clean: true, //set to false to receive QoS 1 and 2 messages while offline
          	reconnectPeriod: 5000, // milliseconds, interval between two reconnections
          	connectTimeout: 30 * 1000, //milliseconds, time to wait before a CONNACK is received
          	//username: mqtt_username, //the username required by your broker, if any
          	//password: mqtt_password, //the password required by your broker, if any
          	will: {topic: mqtt_publish_topic, payload: mqtt_client_id +' disconnected', qos: 1, retain: false }
          // Define the port and a parser
          const port = new SerialPort(serial_port, { baudRate: serial_baud_rate });
          const parser = port.pipe(new Readline({ delimiter: '\n' }))
          // START MQTT
          if (DEBUG) console.log('Starting MQTT...');
          var mqtt_client = mqtt.connect('mqtt://'+mqtt_host, mqtt_Options);
          mqtt_client.on('connect', function () {
          	if (DEBUG) console.log('Subscribing MQTT...');
          	mqtt_client.subscribe(mqtt_subscribe_topic+'/#');
          	if (DEBUG) console.log('Publish MQTT...');
          	mqtt_client.publish(mqtt_publish_topic, 'mqtt client '+mqtt_client_id+' started at '+ new Date());
          parser.on('data', function (data) {
          	if (DEBUG) console.log('Data:', data);
          	mqttPublish(data);
          // MQTT INCOMING
          	m = m.replace(mqtt_subscribe_topic, '');
          	port.write('' + m + '\n', function(err) {
          		if (err) {
          		  return console.log('Error on write: ', err.message);
          		if (DEBUG) console.log('INCOMING MQTT: ' + topic + ':' + message.toString());
          // MQTT OUTGOING
          	var topic = mqtt_publish_topic+'/';
          	if (DEBUG) console.log('OUTGOING MQTT: ' + topic + ' ' + payload);
          Use pm2 to keep it running!
          Cheers!!
          Very simple hardware:
          • electrikE Offline
            electrikE Offline
            electrik
            nice, thanks for sharing
            Could you also explain how to install / run this?
            • electrikE electrik
              ร Offline
              ร Offline
              รอเรือ
              @electrik
              There are already plenty of instructions on how you install Node.js and it would be beyond the scope of this topic to do so here. There are so many variables such as operating systems and so on to take into account.
              After installing Node.js you need to install the Node serialport and Node mqtt.
              pm2 is a very nice process manager for Node.js that you can use to make sure that your node scripts always is running. It's highly recommended and will make your life easier.
              In my own installation, I created a sub directory ~/node_modules/serialgwmqtt/ where I saved the app.js script file. Then cd ~/node_modules/serialgwmqtt/ followed by node app.js to make sure that everything works fine.
              When it does (works fine) you should make it autostart. I added my script to pm2 with the following command: pm2 start app.js --name "serialgwmqtt" (while still in the same directory). check hat it's working by issuing pm2 list
              I might have been running npm installor something similar also. I'm actually not so clever with these things and I'm sure my instructions can be simplified. The script should also be uploaded so some place to make it available for installing with a simple command. Maybe someone else more node.js-talented person want's to help here.
              I hope I have't forgotten anything, it's quite straight forward.
              Things are running rock solid here.
