  3. Arduino Mega 2560 Ethernet Gateway - Cant get it going.
4 Posts 3 Posters 1.9k Views 3 Watching
  • DbagioniD
    DbagioniD
    Dbagioni
    wrote on last edited by Dbagioni
    Hello all
    I am in the process of moving my gateway over to an Arduino Mega 2560 R3.....presently it is running on an UNO R3 but that is my template device and I kinda want it back for that. Im using a W5100 Ethernet Shield, found here
    My base gateway code comes from this post.
    And my wiring is; (power is just off the Mega for testing only)
    NRF - MEGA
    Vcc - 3.3V
    Gnd - Gnd
    CE - 49 with change made in code
    CSN - 53 with change made in code
    SCK - 52
    MOSI - 51
    MISO - 50
     * Version 1.0 - Henrik EKblad
     * LED purposes:
     * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
     * - ERR (red) - fast blink on error during transmission error or receive crc error
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 49
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 53
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
    #define MY_PORT 5003
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    But no matter what I do I get the following error.  Ive read through every post I can find here and nothing seems to get me going.
    0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.3.0
    3 TSM:INIT
    4 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    12 TSM:FAIL:CNT=1
    14 TSM:FAIL:DIS
    15 TSF:TDI:TSL```
    Any ideas? If I load any other gateway sketch it fires up without a problem.
    Thanks a bunch.
    Dave
    H 1 Reply Last reply
    • DbagioniD Dbagioni
      Hello all
      NRF - MEGA
      Vcc - 3.3V
      Gnd - Gnd
      SCK - 52
      MOSI - 51
      MISO - 50
       * LED purposes:
      #define MY_SOFTSPI
      3 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:FAIL:CNT=1
      14 TSM:FAIL:DIS
      15 TSF:TDI:TSL```
      Thanks a bunch.
      Dave
      H
      H
      hard-shovel
      @dbagioni did you have a reason to change the CE and CSN pins?
      Look at the link text message that was tested earlier today for connections with example sketches included with MySensors library.
      Try with standard connections and then change to your new pin numbers.
      • DbagioniD
        DbagioniD
        Dbagioni
        I hadn't seen that, as it appears it was posted after I had written my post.
        I had changed the CE/CSN pins based on the tutorial written on the Site and numerous other posters had states they had to make those changes to get the Mega and W5100 Shiled to work.
        I will give this a try and see what happens.
        Thanks you for the point in this directions.....Y'All rock
        DB
        pepsonP 1 Reply Last reply
          DB
          pepsonP
          pepsonP
          pepson
          @dbagioni
          Any news in this thread ?
