  3. Node-RED
  4. node-red-contrib-mysensors release thread
Scheduled Pinned Locked Moved Node-RED
36 Posts 6 Posters 10.2k Views 8 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    Released 2.1.0 today,
    Improved debug node, where I ported the parser from https://mysensors.org/build/parser.
    The controller node now also logs the last repeater a given node has used, to reach the gateway.
    Some minor details here and ther in the ui have been updated as well.
    Linting of the typescript files have been added using tslint.
    • tbowmoT
      tbowmoT
      tbowmo
      Released 2.2.0 today
      the mysdecode node now also decodes messageType and sensorType to string values, in the node message it emits.
      The emitted message now contains the following propperties:
      topicRoot: string; // Only used if it is decoding from a mqtt topic
      nodeId: number;
      childSensorId: number;
      messageType: mysensor_command;
      messageTypeStr: string;
      ack: 0|1;
      subType: mysensor_data| mysensor_internal| mysensor_sensor| mysensor_stream;
      subTypeStr: string;
      origin: MsgOrigin; // This is an indicator for where the message was received from (mqtt, serial or "undefined")
      Also did a lot of cleanup, set stricter rules in the typescript compiler etc. to avoid common mistakes.
      • tbowmoT
        tbowmoT
        tbowmo
        Released 3.0.0
        Breaking change is in the controller node, which now use a migration feature in the sqlite lilbrary that I use. It makes it easier to update database schema later on, as I can now create "patches" for the schema, that is included in the library. The database needs to be re-created from scratch, as the migration part has some extra tables to keep track of the schema version.
        Also documentation has been received an overhaul, correcting a few spelling errors, and a lot of formatting.
        • ThucarT
          ThucarT
          Thucar
          Awesome work! I was trying to create a bridge between a MQTT gateway and a Serial gateway (over TCP) so I could use firmware upload function of the MySController. However for some reason it seems to only work one way. I can send commands from the MySController to MQTTGateway but nothing is being received on the MySController side when data is sent from MQTT
          This is my flow, would be awesome if someone would spot the issue...
          [{"id":"e6a66581.c16ec8","type":"mysdecode","z":"229ed636.c3ff2a","name":"","mqtt":false,"x":450,"y":460,"wires":[["58ac0291.04974c","a3ba801.a63be8"]]},{"id":"eb5b52a1.29566","type":"tcp in","z":"229ed636.c3ff2a","name":"","server":"server","host":"","port":"5003","datamode":"stream","datatype":"utf8","newline":"\\n","topic":"","base64":false,"x":270,"y":460,"wires":[["e6a66581.c16ec8","ab0f8982.8a9588","78954899.688c28"]]},{"id":"58ac0291.04974c","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":510,"y":560,"wires":[]},{"id":"a3ba801.a63be8","type":"mysencode","z":"229ed636.c3ff2a","name":"","mqtt":true,"mqtttopic":"myGreenhouse-in","x":1040,"y":200,"wires":[["8d64662e.fbada8","595543a3.f537cc"]]},{"id":"ab0f8982.8a9588","type":"globalGetSet","z":"229ed636.c3ff2a","name":"Save Session","topic":"","context":"msg","variable":"_session","outContext":"global","outVar":"_session","x":440,"y":420,"wires":[[]]},{"id":"78954899.688c28","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":500,"y":720,"wires":[]},{"id":"cdf94190.9fb8e","type":"myscontroler","z":"229ed636.c3ff2a","database":"5fdbb924.88fb48","name":"","handleid":true,"x":770,"y":200,"wires":[["a3ba801.a63be8"]]},{"id":"8d64662e.fbada8","type":"mqtt out","z":"229ed636.c3ff2a","name":"","topic":"","qos":"","retain":"","broker":"1920bc44.5c3304","x":1270,"y":200,"wires":[]},{"id":"595543a3.f537cc","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1270,"y":260,"wires":[]},{"id":"c800320f.2a2b","type":"mysdecode","z":"229ed636.c3ff2a","name":"","mqtt":true,"x":560,"y":200,"wires":[["cdf94190.9fb8e","aa22f275.cc8ec"]]},{"id":"2222f84e.56c4e8","type":"mqtt in","z":"229ed636.c3ff2a","name":"","topic":"myGreenhouse-out/#","qos":"2","broker":"1920bc44.5c3304","x":320,"y":200,"wires":[["41588b7e.b61114","c800320f.2a2b"]]},{"id":"aa22f275.cc8ec","type":"switch","z":"229ed636.c3ff2a","name":"","property":"nodeId","propertyType":"msg","rules":[{"t":"eq","v":"203","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":570,"y":360,"wires":[[],["ea8a0d53.8140b"]]},{"id":"41588b7e.b61114","type":"debug","z":"229ed636.c3ff2a","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":530,"y":260,"wires":[]},{"id":"ea8a0d53.8140b","type":"mysencode","z":"229ed636.c3ff2a","name":"","mqtt":false,"mqtttopic":"","x":870,"y":420,"wires":[["2036eda1.dd8bf2","ad5ca8e4.1c4f68"]]},{"id":"2036eda1.dd8bf2","type":"debug","z":"229ed636.c3ff2a","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1030,"y":460,"wires":[]},{"id":"ad5ca8e4.1c4f68","type":"globalGetSet","z":"229ed636.c3ff2a","name":"Load Session","topic":"","context":"global","variable":"_session","outContext":"msg","outVar":"_session","x":1060,"y":420,"wires":[["cb6d084b.432238","f99fd97d.5f73c8"]]},{"id":"cb6d084b.432238","type":"tcp out","z":"229ed636.c3ff2a","host":"localhost","port":"5003","beserver":"reply","base64":true,"end":false,"name":"","x":1250,"y":420,"wires":[]},{"id":"f99fd97d.5f73c8","type":"debug","z":"229ed636.c3ff2a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1240,"y":480,"wires":[]},{"id":"5fdbb924.88fb48","type":"mysensorsdb","z":"","name":"Device DB","file":"sqlite"},{"id":"1920bc44.5c3304","type":"mqtt-broker","z":"","name":"LocalNew","broker":"localhost","port":"8883","tls":"","clientid":"Node-RedHome","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":""}]```
          Controller: Node-Red
          Gateway: SerialGateway & GSMMQTTGateway
          MySensors: 2.2.0
          • tbowmoT
            tbowmoT
            tbowmo
            @Thucar
            The MysController node doesn't pass any messages through it, it only emits messages if it receives a node ID request.
            Also, (depending on your version) then it is not needed to pass messages through mysdecode / mysencode before / after the myscontroller node. It understands mqtt / serial protocol directly. (this has been a feature since 2.2.0)
            / Thomas
            • tbowmoT
              tbowmoT
              tbowmo
              New release : 3.1.0
              Added features:
              Controller now supports the following messages:
              • I_TIME is replied with a unix timestamp corrected with local timezone offset
              • I_CONFIG, responds with Metric / Imperial setting
              Minor documentation updates to other nodes as well.
              • tbowmoT
                tbowmoT
                tbowmo
                Bugfix release is out: 3.1.1
                @mirodin found an issue with assigning node ID's with the controller node, which should be addressed with this release.
                Basically I tried to assign nodeid 0 to nodes, and it never went out to the nodes. At the same time, the controller never got node ID 0 marked as used, as it filtered away all packages where the nodeId was 0, null or undefined, due to a missing nullcheck.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  New release: 3.2.0
                  I added the possibility to do database lookups in the decode node, which is used to add info about sensor type to the mysensors messages in node-red. The info is gathered during node presentations
                  An example, from a node that report door state from the chicken coop:
                  topic: "mys-in/21/5/1/0/16"
                  payload: "1"
                  qos: 2
                  retain: false
                  _msgid: "ddf9aef9.9a21a"
                  topicRoot: "mys-in"
                  nodeId: 21
                  childSensorId: 5
                  messageType: 1
                  ack: 0
                  subType: 16
                  origin: 2
                  messageTypeStr: "C_SET"
                  subTypeStr: "V_TRIPPED"
                  sensorTypeStr: "S_DOOR"
                  As seen above, the sensorTypeStr is added.
                    Maschler
                    great work. I tried to install it, without success. First I installed node-red und npm. As operation system I use openHABian v1.4.1.
                    This is the output:
                    npm install node-red-contrib-mysensors
                    (node:4359) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    npm WARN package.json node-red-project@0.0.1 No repository field.
                    npm WARN package.json node-red-project@0.0.1 No README data
                    npm WARN package.json node-red-project@0.0.1 No license field.
                    npm WARN package.json copy-descriptor@0.1.1 No README data
                    npm WARN package.json log-ok@0.1.1 No README data
                    npm WARN package.json log-utils@0.2.1 No README data
                    npm WARN package.json object-copy@0.1.0 No README data
                    npm WARN package.json static-extend@0.1.2 No README data
                    npm WARN package.json ansi-wrap@0.1.0 license should be a valid SPDX license expression
                    npm WARN package.json events@1.1.1 events is also the name of a node core module.
                    npm WARN package.json format@0.2.2 No license field.
                    npm WARN package.json jsonify@0.0.0 license should be a valid SPDX license expression
                    npm WARN package.json string_decoder@1.1.1 string_decoder is also the name of a node core module.
                    npm ERR! Error: Method Not Allowed
                    npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
                    npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
                    npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
                    npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
                    npm ERR! If you need help, you may report this *entire* log,
                    npm ERR! including the npm and node versions, at:
                    npm ERR!     <http://github.com/npm/npm/issues>
                    npm ERR! System Linux 4.14.52+
                    npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "node-red-contrib-mysensors"
                    npm ERR! cwd /home/openhabian/.node-red
                    npm ERR! node -v v8.11.1
                    npm ERR! npm -v 1.4.21
                    npm ERR! code E405
                    npm ERR!
                    npm ERR! Additional logging details can be found in:
                    npm ERR!     /home/openhabian/.node-red/npm-debug.log
                    npm ERR! not ok code 0
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @Maschler
                      Which version of node-red, nodejs and npm are you using?
                      And what does /home/openhabian/.node-red/npm-debug.log tell you?
                        Maschler
                        wrote on last edited by Maschler
                        hey @tbowmo
                        I found my mistake in /home/openhabian/.npm/_logs
                        I had to use sudo ....
                        But I have another Question. Do I need an Arduino in-between or can I connect the modul directly to the Raspberry pi like it is done here.
                        Thank you very much for your help!! :)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Maschler
                          It's not necessary to have an arduino to make the gateway. You can configure the linux variant as a MQTT gateway (which I recommend), and then have mosquitto as a broker and nodered listening for mqtt messages.
                          https://www.mysensors.org/build/raspberry#configure
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            New release: 3.2.1
                            It's a minor update, as @pansen discovered that node IDs wasn't shown correctly in the controller view.
                            Also behind the scenes a couple of module dependencies have been updated to mitigate a couple of (low-risk) security issues that has been reported against some of the npm packages that was used.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              Today I have released version 3.3.0
                              New in this release is that battery level messages is now stored in the database by myscontroller, and are also shown in the table of mysensors nodes, when you open the myscontroller node.
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                Version 3.3.1 is now released
                                A bug with the Encapsulate node was reported, where child sensor types didn't have the correct IDs. Also updated dependencies as a few where reported to have security vulnerabilities.
                                • magpernM
                                  magpernM
                                  magpern
                                  @tbowmo I feel a little confused on how to use this node-red plugin. Is this something like "a node-red plug-in framework", but you have to invent the wheel yourself kind of solution?
                                  I have just opted for the Home assistant (hass.io) system as the hub for my home automation.
                                  Home assistant, according to documentation, is mysensors enabled, but compared to other add-ons, like zigbee2mqtt, zwave2mqtt, the mysensors implementaton is like a child's tricycle, while the others are sports cars.
                                  The zigbee2mqtt, you just turn on and off the IKEA light buld six times and it is added, whereas the mysensors you have to type configuration files and have limited graphical administration possibilities.
                                  So I thought, what if the mysensors could talk to mqtt and get into home assistant that way (my gateway is serial).
                                  I understand the node-red implementation enables you to decode the messages as you like, but do I really need to invent how it should decode it and send it to mqtt?
                                  Are there any ready to use implementations of the plug.in?
                                  Could it support "auto discovery"? So you just have to turn the device on, and voila, it appears in home assistant (if mqtt auto discovery is turned on)?
                                  tbowmoT 1 Reply Last reply
                                  • magpernM magpern
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @magpern this module is more if you want to only use nodered for your home automation, without Hass.io or the likes.
                                    Most of the standard controllers (domoticz, openhab, home assistant etc) are all able to handle the mysensors network directly (more or less), and handle the device registration for you.
                                    My module for nodered is implementing a crude controller, that only handles out node id's to the mysensors network, when asked for, and then leaves everything else up to your imagination, for how to wire things together behind the scenes.
                                    That being said, if you only need to convert your serial mysensors gateway into mqtt, I do have a small python script that I use for that particular case, as my nodered instance can't access the serial Ports from my docker swarm setup. So this script is running besides everything else. I can post it tomorrow if interested, as my pc is closed for the night now.
                                    / Thomas
                                    magpernM 1 Reply Last reply
                                    • tbowmoT tbowmo
                                      / Thomas
                                      magpernM
                                      magpernM
                                      magpern
                                      @tbowmo said in node-red-contrib-mysensors release thread:
                                      / Thomas
                                      I'd love to try the script! /Magnus
                                      • magpernM magpern
                                        / Thomas
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @magpern
                                        It's more or less the script below, I removed some stuff from my utility meter, that I also handles in my script (but isn't needed for just mysensors).
                                        #!/usr/bin/python3
                                        import serial
                                        import paho.mqtt.client as mqtt
                                        import time
                                        mysensors = serial.serial_for_url('/dev/ttyNRF24', 115200, rtscts=0, timeout=1000)
                                        mysensors.isOpen()
                                        mqtt_connect = False
                                        def mqtt_reception(client, userdata, msg):
                                            payload = msg.payload.decode("ascii")
                                            topic = msg.topic.split('/')
                                            topic.remove('mys-out')
                                            mymsg = ';'.join(topic) + ';' + payload + '\n'
                                            print("out <- ", mymsg)
                                            mysensors.write(str.encode(mymsg))
                                        def mqtt_connect(client, userdata, flags, rc):
                                            print('Connected')
                                            mqtt_connect = True
                                            client.subscribe('mys-out/#')
                                        def mqtt_disconnect(client, userdata, rc):
                                            print(rc)
                                        client = mqtt.Client('mys')
                                        client.on_connect = mqtt_connect
                                        client.on_message = mqtt_reception
                                        client.on_disconnect = mqtt_disconnect
                                        client.connect('192.168.1.64')
                                        def handle_data(data):
                                            print("in -> ", data)
                                            s = data.split(';')
                                            payload = s[-1]
                                            s.remove(payload)
                                            topic = 'mys-in/' + '/'.join(s)
                                            if mqtt_connect:
                                                client.publish(topic, payload.rstrip())
                                        if __name__ == "__main__":
                                            client.loop_start()
                                            mys_data_str = '';
                                            util_data_str = '';
                                            while (True):
                                                if (mysensors.inWaiting()>0):
                                                    char = mysensors.read(1).decode('ascii')
                                                    mys_data_str += char
                                                    if (char == '\n'):
                                                        handle_data(mys_data_str)
                                                        mys_data_str = ''
                                                time.sleep(0.01)
                                        • D
                                          DenisJ
                                          Hi there all,
                                          I just try to install the node in my Node-Red (Home Assistant)
                                          and I got error:
                                          2021-04-30T07:18:09.293Z Install : node-red-contrib-mysensors 3.3.1
                                          2021-04-30T07:18:07.624Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-contrib-mysensors@3.3.1
                                          2021-04-30T07:18:11.638Z [err] npm WARN deprecated @types/moment-timezone@0.5.30: This is a stub types definition. moment-timezone provides its own type definitions, so you do not need this installed.
                                          2021-04-30T07:18:14.813Z [err] npm WARN
                                          2021-04-30T07:18:14.813Z [err]  deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
                                          2021-04-30T07:18:19.176Z [out]
                                          2021-04-30T07:18:19.176Z [out] > sqlite3@4.2.0 install /config/node-red/node_modules/sqlite3
                                          2021-04-30T07:18:19.176Z [out] > node-pre-gyp install --fallback-to-build
                                          2021-04-30T07:18:19.551Z [err] node-pre-gyp
                                          2021-04-30T07:18:19.552Z [err]  WARN Using request for node-pre-gyp https download
                                          2021-04-30T07:18:20.511Z [err] node-pre-gyp
                                          2021-04-30T07:18:20.512Z [err]  WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v83-linux-x64.tar.gz
                                          2021-04-30T07:18:20.512Z [err] node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.16.1 (node-v83 ABI, musl) (falling back to source compile with node-gyp)
                                          2021-04-30T07:18:21.714Z [err] gyp
                                          2021-04-30T07:18:21.715Z [err]
                                          2021-04-30T07:18:21.715Z [err] ERR!
                                          2021-04-30T07:18:21.716Z [err] build error
                                          2021-04-30T07:18:21.716Z [err] gyp
                                          2021-04-30T07:18:21.717Z [err]
                                          2021-04-30T07:18:21.717Z [err] ERR!
                                          2021-04-30T07:18:21.717Z [err] stack
                                          2021-04-30T07:18:21.717Z [err]  Error: not found: make
                                          2021-04-30T07:18:21.717Z [err] gyp
                                          2021-04-30T07:18:21.717Z [err]      at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
                                          2021-04-30T07:18:21.718Z [err] gyp
                                          2021-04-30T07:18:21.718Z [err] ERR!
                                          2021-04-30T07:18:21.718Z [err] stack
                                          2021-04-30T07:18:21.718Z [err]      at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
                                          2021-04-30T07:18:21.719Z [err]      at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
                                          2021-04-30T07:18:21.719Z [err] gyp
                                          2021-04-30T07:18:21.719Z [err] ERR!
                                          2021-04-30T07:18:21.719Z [err] stack
                                          2021-04-30T07:18:21.719Z [err]      at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
                                          2021-04-30T07:18:21.720Z [err]
                                          2021-04-30T07:18:21.720Z [err] stack
                                          2021-04-30T07:18:21.720Z [err]      at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
                                          2021-04-30T07:18:21.720Z [err] gyp
                                          2021-04-30T07:18:21.720Z [err] ERR!
                                          2021-04-30T07:18:21.720Z [err]      at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
                                          2021-04-30T07:18:21.721Z [err] ERR!
                                          2021-04-30T07:18:21.721Z [err] stack
                                          2021-04-30T07:18:21.721Z [err]      at FSReqCallback.oncomplete (fs.js:183:21)
                                          2021-04-30T07:18:21.721Z [err] gyp
                                          2021-04-30T07:18:21.721Z [err] System
                                          2021-04-30T07:18:21.722Z [err]  Linux 5.0.0-27-generic
                                          2021-04-30T07:18:21.722Z [err] gyp
                                          2021-04-30T07:18:21.722Z [err] ERR!
                                          2021-04-30T07:18:21.722Z [err] command
                                          2021-04-30T07:18:21.722Z [err]  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
                                          2021-04-30T07:18:21.723Z [err]
                                          2021-04-30T07:18:21.723Z [err] cwd
                                          2021-04-30T07:18:21.723Z [err]  /config/node-red/node_modules/sqlite3
                                          2021-04-30T07:18:21.723Z [err] gyp
                                          2021-04-30T07:18:21.723Z [err] ERR!
                                          2021-04-30T07:18:21.723Z [err] node -v
                                          2021-04-30T07:18:21.724Z [err]  v14.16.1
                                          2021-04-30T07:18:21.724Z [err] gyp
                                          2021-04-30T07:18:21.724Z [err] ERR!
                                          2021-04-30T07:18:21.724Z [err] node-gyp -v
                                          2021-04-30T07:18:21.725Z [err]  v5.1.0
                                          2021-04-30T07:18:21.725Z [err] gyp
                                          2021-04-30T07:18:21.725Z [err] ERR!
                                          2021-04-30T07:18:21.725Z [err] not ok
                                          2021-04-30T07:18:21.730Z [err] node-pre-gyp
                                          2021-04-30T07:18:21.730Z [err]  ERR! build error
                                          2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR!
                                          2021-04-30T07:18:21.731Z [err] stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                                          2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/config/node-red/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          2021-04-30T07:18:21.731Z [err] ERR! stack     at ChildProcess.emit (events.js:315:20)
                                          2021-04-30T07:18:21.731Z [err] stack     at maybeClose (internal/child_process.js:1048:16)
                                          2021-04-30T07:18:21.731Z [err] node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
                                          2021-04-30T07:18:21.731Z [err] System Linux 5.0.0-27-generic
                                          2021-04-30T07:18:21.731Z [err]  ERR! command "/usr/bin/node" "/config/node-red/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          2021-04-30T07:18:21.731Z [err]  ERR! cwd /config/node-red/node_modules/sqlite3
                                          2021-04-30T07:18:21.731Z [err]  ERR! node -v v14.16.1
                                          2021-04-30T07:18:21.732Z [err] node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                          2021-04-30T07:18:21.732Z [err] node-pre-gyp ERR! not ok
                                          2021-04-30T07:18:21.732Z [out] Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64/node_sqlite3.node --module_name=node_sqlite3 --module_path=/config/node-red/node_modules/sqlite3/lib/binding/node-v83-linux-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
                                          2021-04-30T07:18:22.158Z [err] npm ERR!
                                          2021-04-30T07:18:22.158Z [err]  code ELIFECYCLE
                                          2021-04-30T07:18:22.158Z [err] npm ERR! errno 1
                                          2021-04-30T07:18:22.164Z [err] npm ERR!
                                          2021-04-30T07:18:22.164Z [err]  sqlite3@4.2.0 install: `node-pre-gyp install --fallback-to-build`
                                          2021-04-30T07:18:22.164Z [err] npm ERR! Exit status 1
                                          2021-04-30T07:18:22.164Z [err] ERR! Failed at the sqlite3@4.2.0 install script.
                                          2021-04-30T07:18:22.164Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                          2021-04-30T07:18:22.178Z [err]
                                          2021-04-30T07:18:22.178Z [err] npm ERR! A complete log of this run can be found in:
                                          2021-04-30T07:18:22.178Z [err] npm ERR!     /root/.npm/_logs/2021-04-30T07_18_22_169Z-debug.log
                                          2021-04-30T07:18:22.201Z rc=1
                                          Is there still possibility to install it please ?
                                          Thanks a lot
                                          Denis
