  3. AC -DC transformer sourcing
19 Posts 7 Posters 5.6k Views 5 Watching
  • axillentA axillent
    @jeremushka am i got it correctly that you need 5v without having neutral wire?
    I never saw solutions for that type of power source using transformers, regular 50hz or even switching
    There are a few different types of schematics i saw, but all are transgormer less
    jeremushkaJ
    jeremushkaJ
    jeremushka
    @axillent i have bought one livolo light switch which has an transformer and the system is working without neutral wire.
    Also here is a specific design from AC power integrations website:
    https://ac-dc.power.com/design-support/reference-designs/design-examples/der-622-two-wire-no-neutral-wide-range/
    However, it works with a non isolated flyback transformer. The specs are defined but it is necessary to produce this transformer to have a try.
    monteM axillentA 2 Replies Last reply
    • jeremushkaJ jeremushka
      monteM
      monteM
      monte
      @jeremushka is livolo's transformer isolated?
      jeremushkaJ 1 Reply Last reply
        @jeremushka
        I saw this design a while ago, it's a nice sch, I made a design for it too (I simplified a bit the BOM to reduce board size). but not found the time to test for the moment. and livolo with enclosure are so cheap .. but lacks of power supply agree, that said for nrf/ble that's ok.
        yes you'll have to make the transformer by yourself for proto. simply sources parts and if you follow their specs, it should be fine. and be careful with thermal dissipation :)
        • monteM monte
          jeremushkaJ
          jeremushkaJ
          jeremushka
          @monte i do not think their is isolation as well.
          • scalzS scalz
            @jeremushka
            jeremushkaJ
            jeremushkaJ
            jeremushka
            @scalz how did you reduce the BOM? I have sourced most of the components, my only problem is the transformer. Do you have any suggestions where we can produce it with the specs which are provided with the schematic above?
              axillentA
              axillentA
              axillent
              @jeremushka if you will check datasheet on lnk3002 you will find that it is a regular none isolated acdc
              The know how of this design for 2wire installation not in transformer, it is in disconnecting load on positive wave in case of voltage drop
              A saw similar desing without transformer, it was a re engineering of radio switch
              sense and drive
              • axillentA
                axillentA
                axillent
                a few examples without transformer
                sense and drive
                  For a specific project of wall switch light without Neutral wire, i need to design a specific AC-DC tranformer.
                  I have the specifications for the conception of the bobin... However, i do not find any good supplier to produce it at a affordable price.
                  Or need to produce in big quantity. Without to know if it is working well, i would like to produce few samples only.
                  Does anyone design his own transformer 220V - 5V ? any suggestions of supplier at good price?
                  APL2017
                  wrote on last edited by APL2017
                  @jeremushka Before helping you out here are a few thoughts to share:
                  1. I have to disappoint you, AC-DC transformer does not exist. By definition, transformer is an AC to AC device, so most likely you are looking for a power supply (PS) to convert 220VAC to 5VDC.
                  2. How do you expect to power PS without neutral wire? Use ground wire instead? in USA and most likely in other countries, ground wire must not be load carrying wire. There are few designs with very low power consumption, I believe less than 2-3mA, designed & FM certified to eliminate shock in case of failures. I guesstimated 2-3mA because typical GFCI trip point is 4-5mA, so GFCI allows ground current leak of less that 4mA.
                  If you don't care about 2) at risk of electrical shock, lawsuit, etc. advise:
                  1. What is expected power consumption
                  2. What form factor required (PCB module, panel module, wall plug, etc.)
                  monteM 1 Reply Last reply
                  • poordomP
                    poordomP
                    poordom
                    Good Morning Jeremushka,
                    I was looking at purchasing an AC/DC transformer, I found one, see the following: https://www.aliexpress.com/item/AC-DC-110V-220V-to-3-3V-700mA-2-3W-Switching-Switch-Power-Supply-Buck-Converter/32829978591.html?spm=a2g0s.8937460.0.0.1d582e0ecZHxyR
                    I understand you may want to build your own, but I figured for the price of the above unit, could be a viable alternative.
                    Dom
                    • A APL2017
                      monteM
                      monteM
                      monte
                      @apl2017 said in AC -DC transformer sourcing:
                      Obviously he expects to power PS like it is powered in schematics he provided and like it is powered without neutral wire in every retro-fitting smart switches and dimmers that are present on the market and, apparently are certified. For example mentioned above Livolo switch. How do you expect to retro-fit those into the wall if there is no neutral wire, because mechanical switch that were installed there before didn't need it?
                      A 1 Reply Last reply
                      • monteM monte
                        APL2017
                        @monte Well, yes there are few designs with very low power consumption, I believe less than 2-3mA, designed & FM certified to eliminate shock in case of failures. I guesstimated 2-3mA because typical GFCI trip point is 4-5mA, so GFCI allows ground current leak of less that 4mA. That is why it is important to specify expected power consumption.
                        • T
                          TSD
                          Hi Jeremushka,
                          Are you designing your own AC/DC power supply? For low power levels (<20W), typically flyback converters are used.
                          If you want to build your own flyback converter, you could use this controller IC:
                          https://ac-dc.power.com/products/tinyswitch-family/tinyswitch-4/
                          And this transformer: https://www.soselectronic.com/products/myrra/74010-48847
                          If you're looking for a complete solution, the Aliexpress converter suggested by @poordom looks good, the 5V version can be found here and is even cheaper:
                          https://www.aliexpress.com/item/5V-700mA-3-5W-AC-DC-Precision-Buck-Converter-AC-220v-to-5v-DC-step-down/32677330307.html?gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.99734.0&scm_id=1007.13339.99734.0&scm-url=1007.13339.99734.0&pvid=a8341147-314f-4c36-aec2-aa63ad557688
                          It's dirt cheap, I don't have any clue about its quality. I'm sure it'll work, I just don't know about its safety level.
                            jeremushkaJ
                            jeremushkaJ
                            jeremushka
                            @axillent Thanks. The dfirst diagram is interesting. I do not understand the idea of having a buzzer here (grey part). But the violet schematic is good. Seems it used a divider to compare the value of the voltage in order to determine when we can disconnect the load on positive wave.
                            • poordomP poordom
                              Dom
                              jeremushkaJ
                              jeremushkaJ
                              jeremushka
                              @poordom Thanks. I will check about that
                              • T TSD
                                Hi Jeremushka,
                                jeremushkaJ
                                jeremushkaJ
                                jeremushka
                                @tsd Perfect! It is what i was looking for. For the moment, i am using using this IC controller (iW1700-01) https://www.dialog-semiconductor.com/sites/default/files/EBC10010_Reference_Design.pdf. I have a transformer that i can use for flyback typology.
                                Now, i need to know think how to switch the load without Neutral Wire.
                                Here in France the standard is that we do not have Neutral wire connected to the light switch. We have only the Live wire (Phase L) and the second wire connected the light and the Neutral wire is connected to the Light to the main electrical board.
                                Neutral wire is used for the wall socket. It is why, it is a little bit complex to design it.
                                Then, the second issue is that in our installation most of the time we have the concept of "va et vient" where 2/3 buttons are connected together at different places of the room to switch off/on the same light.
                                Today in the market LIVOLO can do that, with "push button". or i have found FIBARO company where you can install the module directly behind the switch without to change any buttons. but it is very expensive about 50 euros per wall switch.
                                • A APL2017
                                  monteM
                                  monteM
                                  monte
                                  wrote on last edited by monte
                                  @apl2017 well, in Europe we have 30ma and 10ma GFCI's for use in home networks, didn't see lower. Does Z-wave have such low power consumption?
                                  @jeremushka really interesting question. How doesn't GFCI trip with those switches installed? Or where current leaks? Could you measure your livolo's switch consumption? I am curious.
                                  EDIT: Ok, so I've got my thoughts together. Let's take the lowest leakage consumer GFCI - 10ma, 220v (Europe). That's 2,2Watts of power available to leak without tripping the cut-off. 2,2W for 3.3V that is needed for typical mysensors sensor is 0,66A. And typical board will consume not more than 25mA during transmission if I am correct. So we can have around of 25 mysensors smart switches sitting on one 10ma GFCI without tripping it. I'm not sure if we have to divide it by 2 for the only one half of syn wave?
                                  • T
                                    TSD
                                    @jeremushka
                                    Indeed, it is a complex way to switch on a lamp, but if you only want to change the switch, I guess it's what you need to do. It would be much easier to insert something at the light bulb, as your neutral is available there.
                                    My French is not that good, but I think you can solve your "va et vient" by changing the NO relay in your reference schematic with a NO/NC relay (SPDT switch).
