  3. 💬 EFEKTA Temp&Hum sensor(ver. nRF52 )+E-Ink display
nrf52832e-ink displaye-papernrf52nrf52810nrf52811nrf52840temperature & humidity sensor
105 Posts 11 Posters 33.5k Views 12 Watching
  • O Offline
    O Offline
    openhardware.io
    https://www.openhardware.io/view/629/EFEKTA-TempandHum-sensorver-nRF52-E-Ink-display
    • H Offline
      H Offline
      heinzv
      I like that project because it uses the energy efficient nRF52 and it uses ePaper which connects it directly without an adiitional HAT (cheaper).
      I would lie to join that project but it would be grat if you could share the BOM, the PCB files (Eagle and Gerber) and also the code (github)?
      Where do/dis you order the PCB's?
      berkseoB 1 Reply Last reply
      • ranseyerR Offline
        ranseyerR Offline
        ranseyer
        I watch this too...
        • H heinzv
          berkseoB Offline
          berkseoB Offline
          berkseo
          @heinzv
          I think I need two more weeks for all the tests. Now waiting for the PCB for the tests. Of course there are huge opportunities. An old sketch which occupied 99% on atmega328 here is 5%. The possibilities are great. After the successful test will be available: to order the PCB, ready device, BOM and test the software. Now spread unverified gerber files or code does not see the point, something else will probably be changed. At the moment I'm generally looking at the concept of the device itself. I would like to add a few more sensors ... but let's see, maybe I'll implement the ideas on another device.
          • ranseyerR ranseyer
            I watch this too...
            berkseoB Offline
            berkseoB Offline
            berkseo
            @ranseyer
            On the basis of tests of a homemade PCB may say that energy efficiency is extremely good
            • berkseoB Offline
              berkseoB Offline
              berkseo
              ... and it seems that this project is less interesting than its predecessor on atmega328 ... (if it estimate by the number of likes)
              Apparently a new chip causes misunderstanding.
              • H Offline
                H Offline
                heinzv
                @berkseo I gave it at least one more like. Fo me it is one of the most interesting projects! With the Atmega328, we are on a dead end and this is the next step we have to go.
                I'm not just interested in the PCB and the code but also how you integrate/mount the "plain" epaper with the "foil-connector" which is much cheaper such as 5.99us$ (see below)
                So I'm looking forward when the stuff is available. That is exactly what I'm trying to achive since a long time!
                https://www.aliexpress.com/item/WFC0000CZ07-1-54-200x200-e-ink/32814074862.html?spm=2114.search0104.3.151.42736564L6Hvwq&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10547_10059_10884_10548_10887_10696_100031_10084_10083_10103_10618_10304_10307_10820_10821_10302,searchweb201603_60,ppcSwitch_4&algo_expid=be678964-275d-4b20-a162-2a7ef1e8ba04-23&algo_pvid=be678964-275d-4b20-a162-2a7ef1e8ba04&transAbTest=ae803_2&priceBeautifyAB=0.
                • H Offline
                  H Offline
                  heinzv
                  you might consider even the nRF52840 instead of the 832 as it supports BLE 5 with long range (the 832 does not) and ZigBee.
                  • H Offline
                    H Offline
                    heinzv
                    are you satisfied with the nRF52xx and does it work properly? I hope sometime we get the project infos to make some sensors too :-)
                    • H heinzv
                      berkseoB Offline
                      berkseoB Offline
                      berkseo
                      @heinzv
                      I'm satisfied, it work perfectly. I found ready-made modules that can be used by every user without learning, in the Arduino IDE, this was my main task. Now the self-made prototype is on testing, PCB ordered in production. After some time, the development will be available.
                      • H Offline
                        H Offline
                        heinzv
                        @berkseo That looks awsome, great work. One of the best projects (HW and SW) I have seen. Exactly what I need!!! I can't wait to get your PCB layout and the project code.
                        • H Offline
                          H Offline
                          heinzv
                          @berkseo once I got it/use it I will make a donation (I think you deserve it)
                          • berkseoB Offline
                            berkseoB Offline
                            berkseo
                            Received printed circuit boards. Soldering tomorrow :))
                            J 1 Reply Last reply
                            • J Offline
                              J Offline
                              jeti
                              Looking good! Please keep up the awesome work.
                              • berkseoB berkseo
                                J Offline
                                J Offline
                                jeti
                                @berkseo any chance you can provide a brief feedback?
                                What is your status on the software side?
                                • J jeti
                                  berkseoB Offline
                                  berkseoB Offline
                                  berkseo
                                  @jeti said in 💬 Temperature and humidity sensor(ver.NRF52832)+E-Ink display:
                                  For nrf52832 was tested software developed for the atmega328. Need to alter the fonts and graphics, to improve, because this chip have more opportunities. This is not difficult. There will be an update soon.
                                  • berkseoB berkseo
                                    J Offline
                                    J Offline
                                    jeti
                                    @berkseo thanks!
                                    • berkseoB Offline
                                      berkseoB Offline
                                      berkseo
                                      update,
                                      https://www.youtube.com/watch?v=FNdqroZxFR0
                                      It remains a bit to fix the program(improve graphics), as the demo uses software from the version on atmega328
                                      • berkseoB berkseo
                                        update,
                                        J Offline
                                        J Offline
                                        jeti
                                        @berkseo awesome! Great work!
                                        One question: the high temperature is a result of testing? So with a long enough sleep time the temp will be accurate?
                                        • J jeti
                                          berkseoB Offline
                                          berkseoB Offline
                                          berkseo
                                          @jeti said in 💬 EFEKTA Temp&Hum sensor(ver. nRF52832 )+E-Ink display:
                                          Don't quite understand the question. The chip is not heated. No matter how much the device sleeps, the temperature sensor also sleeps. A digital temperature and humidity sensor is used.
