  3. Vera Helper with Arduino
13 Posts 6 Posters 9.6k Views 1 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    Nice, I like it.
    RJ_Make
    • RJ_MakeR RJ_Make
      Nice, I like it.
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @ServiceXp
      So I've updated this for a four line display and gave it the ability to send a message to the device from its own website:
      the Display shows lots of data points from Vera:
      Video Here
      Anyone interested I'm making one... I'll post the code... or show some more video.
      • D
        dayve218
        @ServiceXp im keen, post away
        RJ_MakeR BulldogLowellB 3 Replies Last reply
        • D dayve218
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @dayve218 I think you mean @BulldogLowell ... ;-)
          RJ_Make
          • D dayve218
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @dayve218
            well, having some free time I've expanded it quite a bit, and I am not 100% sure it will run on an UNO... It works on a mega. I added a bunch of stuff:
            • tells you how many unread emails you have using a BASH script on a server to send updates every so often (I'll post that too).
            • control the brightness of the LCD with a dimmer.
            • uses Vera dimmer and switch to control relay and brightness (uses standard xml files to upload to Vera)
            • more weather
            I don't have a display demo right now, been testing in my Serial Monitor
            I can help you with any of it:
             Vera Auxilliary Controller a.k.a. Arduino/Vera Ethernet Device
             December, 2014
             Version .91
             * With the device's own website it allows you to send the device a message along with a visual or sound indicator
             * Control LCD backlight
             * Control led (relay)
             * Control your alarm state or lights or execute scenes...
             * Control attached Relay
             * Processes and displays "Vital" data from Vera like the Weather, Alarm State
             * Reliably runs on an UNO but very expandable if you want to use a Mega instead
             * Displays Indoor Temp and Humidity using DHT sensor
             INSTRUCTIONS:
             * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
             * Add virtual switches to your Vera by following instructions here:http://faq.mios.com/content/2/40/en/how-to-create-virtual-device.html
             * and create a scene and add luup (lua) code like this:
               local state = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 3)
               luup.inet.wget("192.168.1.50//?ledState=“..state..”&”)
             copyright (c) by Jim Brower (BulldogLowell@gmail.com)
            #include <EEPROM.h>
            //#include <SD.h>  // you will need a MEGA for this, if you want to really expand the web UI
            #include <Ethernet.h>
            #include <EthernetUdp.h>
            #include <utility/w5100.h>
            #include <Time.h>
            #include <Timezone.h>
            #include "DHT.h"
            //#define DEBUG_ON   // comment out getNTPtime(); in loop to get this to fit on an UNO for debug, otherwise debug on a MEGA
            //#define USE_DHCP   // uncomment here for DHCP but uses more than 3kBytes, so warm up your MEGA it is too big for your UNO
            #define DIMMER_PIN 6                // available PWM capable pin
            #define DHT_SENSOR_PIN 7            // Thermometer-Hygrometer
            #define RELAY_PIN 13//8                 // Relay control output
            #define DISPLAY_UPDATE_TIME 3000UL  // 3.5 seconds seems OK
            #define NUMBER_OF_MESSAGE_TYPES 17  // Kinds of transmissions from Vera/Internet
            #define TONE_PIN 6                  // If you want Audio alerts
            #define NUMBER_OF_ACTION_BUTTONS 5  // your device can control scenes, devices, etc Vera-side
            #ifdef  DEBUG_ON
            typedef enum{
              LCD_WIND, LCD_TIME, LCD_ALARM_STATUS, LCD_GARAGE, LCD_GUEST_GARAGE, LCD_IP_ADDRESS, LCD_TEMPERATURE, LCD_AC_SETPOINT, LCD_OUTSIDE_TEMP, LCD_WEATHER, LCD_FORECAST, LCD_MESSAGE, LCD_HI_LOW, LCD_EMAIL}
            lcdState;
            lcdState state = LCD_TIME;  // display start on Time
            //File webFile;
            char *messagePtr;
            const char *messageType[NUMBER_OF_MESSAGE_TYPES] = {
              "?ledStatus=", "?alarmState=", "?garageState=", "?guestGarageState=", "?weatherCondition=", "?outsideTemp=", "?outsideHumid=", "?airconSetpoint=", "?weatherForecast=", "?messageData=", "?todayHigh=", "?todayLow=", "?windSpeed=", "?windDirection=", "?relayState=", "?brightLevel=", "?emailCount="};
            boolean messageFlag = false;
            unsigned long timerStart;
            unsigned long timerDuration;
            int signal = 0;
            boolean lightOn;
            boolean relayState;
            boolean garageOpen = false;
            boolean guestGarageOpen = false;
            char customMessage [30];
            char weatherCondition[30] = {
              "  Not Yet Reported"};
            char weatherForecast[30] = {
            int outdoorTemp = -99;
            int outdoorHumid = -99;
            int todayHigh = -99;
            int todayLow = -99;
            int airconSetpoint = 78;
            int alarmArmed = -1;
            int windSpeed = 99;
            char windDirection[6] = {"ZZZ"};
            char myCharBuffer[30];
            byte brightLevel = 0;
            byte oldBrightLevel;
            int emailCount = -1;
            byte buttonPin[NUMBER_OF_ACTION_BUTTONS] = {
              4, 5, A0, A1, A2};
            byte lastButtonState[4];
            DHT dht;
            LiquidCrystal_I2C lcd(0x27, 20,4);
            uint8_t clock[8] = {
              0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // I'm-fetching-time-indicator for LCD display
            EthernetUDP Udp;
            EthernetServer server(80);
            uint8_t mac[] = {
              0xDE, 0xDE, 0xDE, 0xDE, 0xDE, 0xDE };
            IPAddress ip(192,168,1,50);
            unsigned int localPort = 8888;
            IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
            const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
            byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
            byte socketStat[MAX_SOCK_NUM];
            char myString[100];
            byte locator = 0;
            EthernetClient client;
            const byte veraServer[] = {
              192,168,1,59 };
            const char *dayOfWeek[] = {
              "NULL","       Sunday","       Monday", "      Tuesday", "     Wednesday", "      Thursday", "       Friday", "      Saturday"};
            const char *monthString[] = {
              "NULL", "January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
            TimeChangeRule usEDT = {
              "EDT", Second, Sun, Mar, 2, -240};  //Eastern Daylight Time = UTC - 4 hours
            TimeChangeRule usEST = {
              "EST", First, Sun, Nov, 2, -300};   //Eastern Standard Time = UTC - 5 hours
            Timezone usET(usEDT, usEST);
            TimeChangeRule *tcr;
              SERIAL_START(9600);
              lightOn = EEPROM.read(0);
              relayState = EEPROM.read(1);
              pinMode(RELAY_PIN, OUTPUT);
              pinMode(DIMMER_PIN, OUTPUT);
              digitalWrite(RELAY_PIN, relayState? HIGH : LOW);
              for (byte i = 0; i < 4; i++)
                pinMode(buttonPin[i], INPUT_PULLUP);
              dht.setup(DHT_SENSOR_PIN);
            #ifdef USE_DHCP
               DEBUG_PRINTLN(F("configuring e-net"));
               if (Ethernet.begin(mac) == 0) // start Ethernet and UDP
               DEBUG_PRINTLN(F("Fail Ethernet DHCP"));
               while(true){
              Ethernet.begin(mac, ip);
              server.begin();
              Udp.begin(localPort);
              lcd.init();
              lcd.clear();
              lightOn? lcd.backlight() : lcd.noBacklight();
              lcd.createChar(0, clock);
              updateLCD();
              getNTPtime();
              webControl();
              messageTimer();
              updateBriteness();
              for (byte i = 0; i < NUMBER_OF_ACTION_BUTTONS; i++)
                byte buttonState = digitalRead(buttonPin[i]);
                if (buttonState == LOW && lastButtonState[i] == HIGH)
                  buttonPress(i);
                lastButtonState[i] = buttonState;
            void updateLCD()
              static unsigned long lastDisplayChangeTime;
              if (millis() - lastDisplayChangeTime >= DISPLAY_UPDATE_TIME)
                switch (state)
                case LCD_TIME:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  DEBUG_PRINT(F("Time: "));
                  DEBUG_PRINT(hourFormat12());
                  DEBUG_PRINT(F(":"));
                  DEBUG_PRINT(minute());
                  DEBUG_PRINTLN(isAM() ? "a" : "p");
                  lcd.print(dayOfWeek[weekday()]);
                  displayStatus();
                  if (emailCount != -1)
                    state = LCD_EMAIL;
                    state = LCD_ALARM_STATUS;
                case LCD_EMAIL:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("    Email Count"));
                  DEBUG_PRINT(F("emails: "));
                  lcd.setCursor(0,2);
                  lcd.print(F("         "));
                  lcd.print(emailCount);
                  DEBUG_PRINTLN(emailCount);
                  displayStatus();
                case LCD_ALARM_STATUS:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("    Alarm Status"));
                  DEBUG_PRINT(F("Alm: "));
                  lcd.setCursor(0,2);
                  if (alarmArmed == 0)
                    lcd.print(F("     Not  Armed"));
                  else if (alarmArmed == 1)
                    lcd.print(F("        Armed"));
                    lcd.print(F("  Not Yet Reported"));
                  DEBUG_PRINTLN(alarmArmed ? F("Yes") : F("NO"));
                  displayStatus();
                  state = LCD_GARAGE;
                case LCD_GARAGE:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("    Main  Garage"));
                  DEBUG_PRINT(F("Garage: "));
                  lcd.setCursor(0,2);
                  if (garageOpen == 0)
                    lcd.print(F("       Closed"));
                  else if (garageOpen == 1)
                    lcd.print(F("        Open"));
                  DEBUG_PRINTLN(garageOpen ? F("OPEN") : F("CLOSE"));
                  displayStatus();
                  state = LCD_GUEST_GARAGE;
                case LCD_GUEST_GARAGE:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("    Guest Garage"));
                  DEBUG_PRINT(F("Guest: "));
                  lcd.setCursor(0,2);
                  if (guestGarageOpen == 0)
                  else if (guestGarageOpen == 1)
                  DEBUG_PRINTLN(guestGarageOpen ? F("OPEN") : F("CLOSE"));
                  displayStatus();
                  state = LCD_TEMPERATURE;
                case LCD_TEMPERATURE:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("  Temperture:"));
                  DEBUG_PRINT(F("Inside Temp:"));
                  lcd.print(dht.toFahrenheit(dht.getTemperature()), 0);
                  lcd.print(char(223));
                  lcd.print(F("F"));
                  lcd.setCursor(0,2);
                  lcd.print(F("    Humidity:"));
                  lcd.print(dht.getHumidity(), 0);
                  DEBUG_PRINT(F("Humidity:"));
                  DEBUG_PRINTLN(dht.getHumidity());
                  lcd.print(F("%"));
                  displayStatus();
                  state = LCD_AC_SETPOINT;
                case LCD_AC_SETPOINT:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("    A/C Setpoint"));
                  lcd.setCursor(0,2);
                  lcd.print(F("        "));
                  lcd.print(airconSetpoint);
                  lcd.print(F("F"));
                  DEBUG_PRINT(F("A/C setpoint:"));
                  DEBUG_PRINTLN(airconSetpoint);
                  displayStatus();
                  state = LCD_OUTSIDE_TEMP;
                case LCD_OUTSIDE_TEMP:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F(" Outdoor Temp:"));
                  DEBUG_PRINT(F("Ext. Temp:"));
                  lcd.print(outdoorTemp);
                  lcd.print(F("F"));
                  DEBUG_PRINTLN(outdoorTemp);
                  lcd.setCursor(0,2);
                  lcd.print (outdoorHumid);
                  lcd.print(F("%"));
                  DEBUG_PRINTLN(outdoorHumid);
                  displayStatus();
                  state = LCD_WEATHER;
                case LCD_WEATHER:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("  Today's  Weather"));
                  DEBUG_PRINT(F("Weather: "));
                  lcd.setCursor(0,2);
                  lcd.print(weatherCondition);
                  DEBUG_PRINTLN(weatherCondition);
                  displayStatus();
                  state = LCD_HI_LOW;
                case LCD_HI_LOW:
                  fastClearLCD();
                  DEBUG_PRINTLN(F("Weather Hi/Lows"));
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("Today's High: "));
                  lcd.print(todayHigh);
                  lcd.print(F("F"));
                  lcd.setCursor(0,2);
                  lcd.print(F("         Low: "));
                  lcd.print (todayLow);
                  lcd.print(F("F"));
                  displayStatus();
                  if (windSpeed > 2)
                    state = LCD_WIND;
                    state = LCD_FORECAST;
                    DEBUG_PRINTLN(F("wind too light to report..."));
                case LCD_WIND:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("   Winds  Gusting"));
                  DEBUG_PRINT(F("Winds: "));
                  DEBUG_PRINTLN(windSpeed);
                  lcd.print(F(" "));
                  lcd.setCursor(1,2);
                  if (windSpeed < 10) lcd.print(F(" "));
                  lcd.print(windSpeed);
                  lcd.print(F("mph from the "));
                  lcd.print(windDirection);
                  displayStatus();
                case LCD_FORECAST:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("      Tomorrow"));
                  DEBUG_PRINT(F("Forecast: "));
                  lcd.setCursor(0,2);
                  lcd.print(weatherForecast);
                  DEBUG_PRINTLN(weatherForecast);
                  displayStatus();
                  if (messageFlag)
                    state = LCD_MESSAGE;
                    state = LCD_IP_ADDRESS;
                case LCD_MESSAGE:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  if (signal == 2 && lightOn == 1)
                    for (int i = 0; i < 20; i++)
                      lcd.noBacklight();
                      delay(50);
                      lcd.backlight();
                      delay(50);
                  else if (signal == 1 && lightOn == 1)
                    beepTone();
                  if (signal != 0)
                    lastDisplayChangeTime - millis();  // give the message back the time lost in the flash/blinking
                  lcd.setCursor(0,1);
                  lcd.print(F("  *** Message ***"));
                  DEBUG_PRINT(F("Message: "));
                  lcd.setCursor(0,2);
                  lcd.print(customMessage);
                  DEBUG_PRINTLN(customMessage);
                  displayStatus();
                case LCD_IP_ADDRESS:
                  fastClearLCD();
                  lcd.setCursor(0,0);
                  timeDate();
                  lcd.setCursor(0,1);
                  lcd.print(F("     IP Address"));
                  DEBUG_PRINT(F("IP Address: "));
                  lcd.setCursor(0,2);
                  lcd.print("    ");
                  for (byte thisByte = 0; thisByte < 4; thisByte++) // print the value of each byte of the IP address:
                    lcd.print(Ethernet.localIP()[thisByte], DEC);
                    if (thisByte < 3) lcd.print(".");
            #ifdef DEBUG_ON
                    Serial.print(Ethernet.localIP()[thisByte], DEC);
                    if (thisByte < 3) DEBUG_PRINT(".");
                    else DEBUG_PRINTLN(F(" "));
                  lcd.print(F(" "));
                  displayStatus();
                  state = LCD_TIME;
                lastDisplayChangeTime = millis();
                DEBUG_PRINT(F("free ram:"));
                DEBUG_PRINTLN(freeRam());
            void sendNTPpacket(IPAddress& address) // Send an NTP request to the time server at the given address
              memset(packetBuffer, 0, NTP_PACKET_SIZE);
              packetBuffer[0]  = 0b11100011;   // LI, Version, Mode
              packetBuffer[1]  = 0;            // Stratum, or type of clock
              packetBuffer[2]  = 6;            // Polling Interval
              packetBuffer[3]  = 0xEC;         // Peer Clock Precision
              packetBuffer[12] = 49;
              packetBuffer[13] = 0x4E;
              packetBuffer[14] = 49;
              packetBuffer[15] = 52;
              Udp.beginPacket(address, 123);  //NTP requests are to port 123
              Udp.write(packetBuffer,NTP_PACKET_SIZE);
              Udp.endPacket();
            void receiveTime(unsigned long newTime)
              DEBUG_PRINT(F("Time value received: "));
              int lastSecond = second();
              int lastMinute = minute();
              int lastHour = hour();
              setTime(newTime);
              if ((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour))
                DEBUG_PRINT(hourFormat12() < 10? F(" 0") : F(" "));
                DEBUG_PRINT(minute() < 10? F(":0") : F(":"));
                DEBUG_PRINTLN(isAM()? F("am") : F("pm"));
                DEBUG_PRINT(month());
                DEBUG_PRINT(F("/"));
                DEBUG_PRINT(day());
                DEBUG_PRINTLN(year());
              lcd.setCursor(19,0);
              lcd.print(F(" "));
            void getNTPtime()
              const unsigned long interval = 60000UL;
              if ((millis() - lastUpdateTime >= interval))
                lcd.write(0);
                sendNTPpacket(timeServer); // send an NTP packet to a time server
                delay(1000);
                if (Udp.parsePacket())
                  Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
                  unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
                  unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
                  unsigned long secsSince1900 = highWord << 16 | lowWord;
                  DEBUG_PRINT(F("Seconds since Jan 1 1900 = "));
                  DEBUG_PRINTLN(secsSince1900);
                  DEBUG_PRINT(F("Unix time = "));
                  time_t utcEpoch = secsSince1900 - 2208988800UL;  //seventyYears = 2208988800UL
                  DEBUG_PRINTLN(utcEpoch);
                  receiveTime(usET.toLocal(utcEpoch, &tcr) + 2);   //about 2 seconds to call for time
                  lastUpdateTime += interval;
            void webControl()
              EthernetClient client = server.available();
              if (client)
                while (client.connected())
                  if (client.available())
                    char c = client.read();
                    if (locator < 100)
                      myString[locator] = c;
                      locator++;
                      myString[locator] = '\0';
                    if (c == '\n') //if HTTP request has ended
                      DEBUG_PRINTLN(F("MyString ="));
                      DEBUG_PRINTLN(myString);
                      // Send a full website with controls functions and handles message input...
                      client.println(F(
                        "<html>"
                        "<head>"
                        "<title>Vera Helper</title>"
                        "</head>"
                        "<body>"
                        "<div align=\"center\">"
                        "<H2>Arduino Auxilliary Controller</H2>"
                        "<H3>for Vera</H3>"
                        "<hr>"
                        "<H2><font color=\"green\">Comfort Settings</H2>"
                        "<H4><font color=\"blue\">Temperature</font>"
                        "<font color=\"red\">"));
                      client.println(dht.toFahrenheit(dht.getTemperature()), 1);
                      client.println(F("</font>"
                        "<font color=\"blue\">F</font>"
                        "<br />"
                        "<H4><font color=\"blue\">Humidity</font>"
                      client.println(dht.getHumidity(), 1);
                        "<font color=\"blue\">%</font>"
                        "<H4><font color=\"midnightBlue\">AirConditioning Setpoint</font>"
                      client.println(airconSetpoint);
                        "<br />"
                        "<hr>"
                        "<h2>"
                        "Send Message<br>"
                        "<form>"
                        "<input type=\"text\" size=\"20\" name= \"messageData\" value=\"Enter message here\">"
                        "<select name=\"time\">"
                        "<option value=\"5\">5min</option>"
                        "<option value=\"15\">15min</option>"
                        "<option selected value=\"30\">30min</option>"
                        "<option value=\"60\">60min</option>"
                        "<option value=\"720\">12hrs</option>"
                        "<option value=\"1440\">24hrs</option>"
                        "</select>"
                        "<h4>"
                        "<input type=\"radio\" name=\"signal\" value=\"2\"> Flash<br>"
                        "<input type=\"radio\" name=\"signal\" value=\"1\"> Tone <br>"
                        "<input type=\"radio\" name=\"signal\" value=\"0\" checked> None</h4>"
                        "<input type=\"submit\" onclick=\"alert('Message Sent!')\" value=\"Send\"> <input type=\"reset\" value=\"Reset\"></h2>"
                        "</form>"
                        "<hr>"
                        "<a href=\"/?ledStatus=1?\"\">Turn On LED Backlight</a>    "
                        "<a href=\"/?ledStatus=0?\"\">Turn Off LED Backlight</a>"
                        "<br />"
                        "<a href=\"/?relayState=1?\"\">Turn On Outlet</a>    "
                        "<a href=\"/?relayState=0?\"\">Turn Off Outlet</a><br /> "
                        "<br />"
                        "<a href=\"/?airconSetpoint="));
                      if (airconSetpoint > 70) client.println(airconSetpoint - 1);
                      else client.println(airconSetpoint);
                      client.println(F("?\"\">Lower Air Conditioning Setpoint</a><br /> "
                        "<br />"
                        "<div style=\"background-color:LightSlateGray; color:black; margin:20px; padding:20px;\">"
                        "<h3>Jim Brower</h3>"
                        "<h5>&copy; copyright 2014</h5>"
                        "<h5><a href=\"mailto:bulldoglowell@gmail.com?subject=Arduino/Vera Home Controller\">"
                        "Send Email</a><h5>"
                        "</div>"
                        "</body>"
                        "</html>"));
                      delay(1);
                      client.stop();
                      // let's sort out that HTTP request...
                      for (byte i = 0; i < NUMBER_OF_MESSAGE_TYPES; i++)
                        messagePtr = strstr(myString, messageType[i]); // we need a global variable here
                        if (messagePtr)
                          DEBUG_PRINT(F("network msg..."));
                          DEBUG_PRINTLN(messageType[i]);
                          processMessage(i);
                      myString[0] = '\0'; //clearing string for next read
                      locator = 0;
            #ifdef DEBUG_ON
            int freeRam ()
              extern int __heap_start, *__brkval;
              int v;
              return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
            void ShowSockStatus()
              for (int i = 0; i < MAX_SOCK_NUM; i++)
                DEBUG_PRINT(F("Socket#"));
                DEBUG_PRINT(i);
                uint8_t s = W5100.readSnSR(i);
                socketStat[i] = s;
                DEBUG_PRINT(F(":0x"));
            #ifdef DEBUG_ON
                Serial.print(s,16);
                DEBUG_PRINT(F(" "));
                DEBUG_PRINT(W5100.readSnPORT(i));
                DEBUG_PRINT(F(" D:"));
                uint8_t dip[4];
                W5100.readSnDIPR(i, dip);
            #ifdef DEBUG_ON
                for (int j=0; j<4; j++)
                  Serial.print(dip[j],10);
                  if (j<3) Serial.print(".");
                DEBUG_PRINT(F("("));
                DEBUG_PRINT(W5100.readSnDPORT(i));
                DEBUG_PRINT(F(")"));
            void processMessage(byte httpMessage)
              switch (httpMessage)
              case 0: // "?ledStatus="
                lightOn = parseNumber(httpMessage) ? 1 : 0;
                //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? lightOn = 0 : lightOn = 1;
                EEPROM.write(0, lightOn? 0xFF : 0x00);
                if (lightOn) lcd.backlight();
                else lcd.noBacklight();
                DEBUG_PRINT(F("LCD Backlight: "));
                DEBUG_PRINTLN(lightOn ? F("ON") : F("OFF"));
              case 1: // "?alarmState="
                alarmArmed = parseNumber(httpMessage) ? 1 : 0;
                DEBUG_PRINTLN(alarmArmed ? F("Alarm is ON") : F("Alarm is OFF"));
              case 2: // "?garageState="
                garageOpen = parseNumber(httpMessage) ? 1 : 0;
                DEBUG_PRINTLN(garageOpen ? F("Garage is Open") : F("garage is Closed"));
              case 3: // "?guestGarageState="
                guestGarageOpen = parseNumber(httpMessage) ? 1 : 0;
                DEBUG_PRINTLN(guestGarageOpen ? F("Guest garage is Open") : F("Guest garage is Closed"));
              case 4: // "?weatherCondition="  // Parse Weather
                  strncpy(weatherCondition, parseString(httpMessage), sizeof weatherCondition);
                  if (strstr(weatherCondition, "%20"))
                    strncpy(weatherCondition, cleanString(weatherCondition, "%20"), sizeof weatherCondition);
                  if (strlen(weatherCondition) < 19)
                    strncpy(weatherCondition, centerString(weatherCondition), sizeof weatherCondition);
              case 5: // "?outsideTemp="  // Parse Outside Temperature
                outdoorTemp = parseNumber(httpMessage);
              case 6: // "?outsideHumid=" // Parse Outside Humidity
                outdoorHumid = parseNumber(httpMessage);
              case 7: // "?airconSetpoint="  // Parse A/C Setpoint
                airconSetpoint = parseNumber(httpMessage);
              case 8: // "?weatherForecast="  // Parse the weather forecast
                  strncpy(weatherForecast, parseString(httpMessage), sizeof weatherForecast);
                  if (strstr(weatherForecast, "+"))
                    strncpy(weatherForecast, cleanString(weatherForecast, "+"), sizeof weatherForecast);
                  if (strlen(weatherForecast) < 19)
                    strncpy(weatherForecast, centerString(weatherForecast), sizeof weatherForecast);
              case 9: //"?messageData="  // Parse display message
                  strncpy(customMessage, parseString(httpMessage), sizeof customMessage);
                  if (strstr(customMessage, "+"))
                    strncpy(customMessage, cleanString(customMessage, "+"), sizeof customMessage);
                  if (strlen(customMessage) < 19)
                    strncpy(customMessage, centerString(customMessage), sizeof customMessage);
                  Serial.println(myString);
                  if (strstr(myString, "&time="))
                    DEBUG_PRINTLN(F("Got length marker..."));
                    char *timePointer = (strstr(myString, "&time="));
                    timerDuration = atoi(timePointer + 6);
                    timerStart = millis();
                    DEBUG_PRINT(F("message length:"));
                    DEBUG_PRINTLN(timerDuration);
                    DEBUG_PRINTLN(F("No length marker..."));
                    timerDuration = 5;
                  if (strstr(myString, "&signal="))
                    DEBUG_PRINTLN(F("Got signal..."));
                    char *signalPointer = (strstr(myString, "&signal="));
                    signal = atoi(signalPointer + 8);
                    DEBUG_PRINT(F("Signal ="));
                    DEBUG_PRINTLN(signal);
                    DEBUG_PRINTLN(F("No signal..."));
                    timerDuration = 5;
                  messageFlag = true;
              case 10: // "?todayHigh="  // Parse Outside High Temperature
                todayHigh = parseNumber(httpMessage);
              case 11: // "?todayLow="  // Parse Outside Low Temperature
                todayLow = parseNumber(httpMessage);
              case 12: // "?windSpeed="  // Parse Outside Low Temperature
                windSpeed = parseNumber(httpMessage);
              case 13: // "?windDirection"  // Parse Outside Low Temperature
                strncpy(windDirection, parseString(httpMessage), sizeof windDirection);
              case 14:  //  "?relayState=" // Get the state of the relay
                relayState = parseNumber(httpMessage) ? 1 : 0;
                //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? relayState = 0 : relayState = 1;
                EEPROM.write(1, relayState ? 0xFF : 0x00);
                digitalWrite(RELAY_PIN, relayState ? HIGH : LOW);
                DEBUG_PRINT(F("Relay Status: "));
                DEBUG_PRINTLN(relayState ? F("ON") : F("OFF"));
              case 15:  //  "?brightLevel=" // Get the brightness of the LED
                brightLevel = parseNumber(httpMessage);
                brightLevel = map(brightLevel, 0, 100, 0, 255);
                DEBUG_PRINT(F("Brite:"));
                DEBUG_PRINTLN(brightLevel);
              case 16: // "?emailCount"  // Parse email count
                emailCount = parseNumber(httpMessage);
              default:
                  //Nothing to do here...
            void buttonPress(int buttonID)
              DEBUG_PRINTLN(F("buttonPress"));
              ShowSockStatus();
              if (client.connect(veraServer, 3480)) //starts client connection, checks for connection
                DEBUG_PRINTLN(F("connected"));
                switch (buttonID)
                  case 0:  // Toggle LED backlight (?ledStatus=)
                    client.print(F("GET /data_request?"
                      "id=action&output_format=xml"
                      "&DeviceNum=111" // <<<<< Set Vera Device Number for LCD backlight
                      "&serviceId=urn:upnp-org:"
                      "serviceId:SwitchPower1"
                      "&action=SetTarget"
                      "&newTargetValue="));
                    client.println(lightOn ? F("0") : F("1"));
                    client.println(F(" HTTP/1.1"
                      "Connection: close"));  //close 1.1 persistent connection
                    client.println(); //end of get request
                    delay(1);
                    client.stop();
                  case 1:  // Toggle Relay (relayState)
                      "&DeviceNum=116" // <<<<< Set Vera Device Number for Relay
                      "&action=SetTarget"
                    client.print(relayState ? F("0") : F("1"));
                    delay(1);
                    client.stop();
                  case 2:  // Toggle Alarm
                      "&DeviceNum=112" /* <<<<< Set Vera Device Number for Alarm */
                      "&action=SetTarget"
                    delay(1);
                    client.stop();
                  case 3:  // run lights out scene  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                      "&action=SetTarget"
                    delay(1);
                    client.stop();
                  case 4:  // Lower Air Conditioning //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                      "&DeviceNum=112" /* <<<<< Set Vera Device Number for A/C Control */
                      "&action=SetTarget"
                    if (airconSetpoint > 72) client.print(airconSetpoint - 1);
                    else client.print(airconSetpoint - 1);
                    delay(1);
                    client.stop();
                  default:
                    //nothing to do here...
            char *parseString(byte messageNumber)
              int textLocation = (messagePtr - myString + strlen(messageType[messageNumber]));
              myCharBuffer[0] = '\0';
              for (byte i = 0; i < 30; i++) // we have room to display only 20 chars, but lets parse 30.
                if (myString[textLocation + i] != '&')
                  myCharBuffer[i] = myString[textLocation + i];
                  DEBUG_PRINTLN(myCharBuffer[i]);
                  DEBUG_PRINTLN(F("got & marker"));
                  myCharBuffer[i] = '\0';
              DEBUG_PRINTLN(myCharBuffer);
              return myCharBuffer;
            char *cleanString(char *targetString, char *searchString)
              while(strstr(targetString, searchString))
                char* stringChunk;
                stringChunk = strstr(targetString, searchString);
                targetString[stringChunk - targetString] = '\0';
                strncpy(myCharBuffer, targetString, sizeof myCharBuffer);
                strncat(myCharBuffer, " ", sizeof myCharBuffer);
                strncat(myCharBuffer, stringChunk + strlen(searchString), sizeof myCharBuffer);
                strncpy(targetString, myCharBuffer, sizeof myCharBuffer);
            int parseNumber(byte msgNum)
              if (strstr(myString, messageType[msgNum]))
                char *messagePointer;
                messagePointer = strtok(myString, "=");
                messagePointer = strtok(NULL, "?");
                int extractedNumber = atoi(messagePointer);
                return extractedNumber;
                DEBUG_PRINTLN(F("Fail parseNumber..."));
                return -99;
            char *centerString(char *stringToCenter)
              char centerSpacing[30];
              for (byte i = 0; i < ((20 - strlen(myCharBuffer)) / 2); i++)
                centerSpacing[i] = ' ';
                centerSpacing[i+1] = '\0';
              strncat(centerSpacing, myCharBuffer, sizeof centerSpacing);
              strncpy(myCharBuffer, centerSpacing, sizeof myCharBuffer);
            void messageTimer()
              if (millis() - timerStart >= timerDuration * 60000UL)
                signal = 0;
            void fastClearLCD()
              for (int i = 1; i < 3; i++)
                lcd.setCursor(0,i);
                for (int j = 0; j < 20; j++)
                  lcd.print(F(" "));
            void timeDate()
              if (hourFormat12() < 10) lcd.print(F(" "));
              lcd.print(hourFormat12());
              lcd.print(minute());
              lcd.print(isAM() ? "am" : "pm");
              lcd.setCursor(11,0);
              if (month() < 10) lcd.print(F(" "));
              lcd.print(month());
              lcd.print(day());
              lcd.print(F("/"));
              lcd.print(year());
            void displayStatus()
              lcd.setCursor(0,3);
              lcd.print(F("A/C:"));
              lcd.print(airconSetpoint);  //lcd.print(dht.toFahrenheit(dht.getTemperature()), 1);
              lcd.print(F("F "));
              lcd.setCursor(11,3);
              if (alarmArmed != 1)
                lcd.print(F("Not Armed"));
            void beepTone()
              tone(TONE_PIN, 440, 200);
              noTone(TONE_PIN);
            void updateBriteness()
              if (brightLevel != oldBrightLevel)
                analogWrite(DIMMER_PIN, brightLevel);
              oldBrightLevel = brightLevel;
            • D dayve218
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @dayve218
              BASH script to transmit unread emails to the arduino:
              #!/bin/bash
              #SCRIPT_NAME="Arduino Gmail Checker"
              #SCRIPT_VERSION="0.1"
              #figlet $SCRIPT_NAME $SCRIPT_VERSION
              # Modified for use with Vera Tool #
              #    Jim Brower  January 2015     #
              # Description: Check Gmail for unread email and switch RGB LED on Arduino in accordance #
              # Dependencies: sed, curl,                                                              #
              # Author: Virtualmix        #
              # http://blog.trollmaker.com/article10/arduino-led-notification-for-gmail-on-linux      #
              # License: CC BY        #
              # Enter Gmail username and password below (Warning: Unsafe storage):
              USERID="username"
              PASSWORD="password"
              # Enter number of seconds between email verification:
              WAIT=60
              #set -xv
              # Loop to check for new mail every X minutes
              while [ "1" -eq "1" ]; do
                  # Command line to fetch the number of unread emails:
                  MAILCOUNTER=`curl -u $USERID:$PASSWORD --silent "https://mail.google.com/mail/feed/atom" \ | xmllint --format - \ | sed -n 's#<fullcount>\(.*\)</fullcount>#\1#p'`
                  if [[ "$MAILCOUNTER" = "" ]]; then
                      echo "ERROR: The program coulndn't fetch the account for user \"$USERID\"."
                      echo "- Are you connected to the Internet?"
                      echo -e "- Is the userid and password correct for \"$USERID\"?\n"
                      curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=-1\&
                  elif [[ "$MAILCOUNTER" -eq "0" ]]; then
                      echo "* There is 0 new email for user $USERID."
                      curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=0&
                      # you can do other curl here....
                  elif [[ "$MAILCOUNTER" -gt "0" ]]; then
                      echo "* There is $MAILCOUNTER new email for user $USERID."
                      curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount="$MAILCOUNTER"&
                  fi
                  echo "* Waiting $WAIT seconds before checking for emails again."
                  echo "* (^C to quit the program)"
                  sleep $WAIT
              #set +xv
              done
              C 1 Reply Last reply
              • D
                dayve218
                @BulldogLowell thanks!!! ill have a play later on!!
                  @dayve218
                  #!/bin/bash
                  # License: CC BY        #
                  USERID="username"
                  PASSWORD="password"
                  WAIT=60
                  #set -xv
                      fi
                      sleep $WAIT
                  #set +xv
                  done
                  C
                  C
                  cleight
                  @BulldogLowell Would it be possible to use your example without the webserver portion on a Nano and still pull information from Vera?
                  • C cleight
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @cleight
                    do you mean without ethernet using the MySensors configuration?
                    look at this example, and be sure to check out @korttoma example down the page...
                    • korttomaK
                      korttomaK
                      korttoma
                      I just had an idea @BulldogLowell .
                      Do you think it would be possible for your Vera Helper to write variables directly to Plot.ly using http.request?
                      How cool would that be?
                      • Tomas
                      • korttomaK korttoma
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @korttoma
                        Sure... you could retrieve data from vera and transmit to plot.ly by making an http request to vera and passing it on to plot.ly.
                        I guess it is possible also to make a MySensors ethenet node and other MySensors sensors could transmit values to the Ethernet Enabled Sensor too.
                        • mntlvrM
                          mntlvrM
                          mntlvr
                          Hello @BulldogLowell
                          I am brand new to this site but have built a few of my own project that monitored batteries and controlled the charging rate as well as the voltage all through a web page but I am Interested in this project, Have you a complete project details with BOM and full working code, as of yet? I am looking to control the fill of a 275 gallon water tank by sonic means. I wish to have the Ultra-Sonic device measure the water level and when certain depth conditions are met the unit will open a valve and allow water in , then when the proper level is met it will close the valve and transmit all this info back to my Vera and or a web page. Please keep up the great idea.
