  3. Vera Helper with Arduino
13 Posts 6 Posters 9.6k Views 1 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    I've been interested in augmenting my network with Ethernet and WiFi devices for some time. So, just messing around with an Uno and an Ethernet Shield, I built a device that can (without the RF integration)
    • Control any Vera device through HTTP Commands
    • Can be controlled by VERA luup or any wget style command
    • be a sensor on my network
    • be an independant/agnostic layer with equal footing with My Sensors
    • be dependable
    I'm not all the way there yet, but i built a sensor that can talk to my Vera, controlling vera devices and can be controlled by vera.
    This is the web page it creates:
    this sketch allow you to turn on/off a relay via a webpage or Vera, and control a vera device.
    take a look:
    https://www.youtube.com/watch?v=d1kxQCuZEJI
    #include <EEPROM.h>
    #include <Ethernet.h>
    #include <EthernetUdp.h>
    #include <utility/w5100.h>
    #include <Time.h>
    #include <Timezone.h>
    #include "DHT.h"
    //#define DEBUG_ON
    #define LED_PIN 8
    #define DHT_SENSOR_PIN 7
    #ifdef DEBUG_ON
    boolean lightOn;
    DHT dht;
    LiquidCrystal_I2C lcd(0x27, 16, 2);
    uint8_t clock[8] = {0x0,0xe,0x15,0x17,0x11,0xe,0x0}; // I'm-fetching-time-indicator for LCD display
    EthernetUDP Udp;
    EthernetServer server(80);
    uint8_t mac[] = { 0xDE, 0xDE, 0xDE, 0xDE, 0xDE, 0xDE };
    unsigned int localPort = 8888;
    IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 102); // time-b.timefreq.bldrdoc.gov NTP server  // IPAddress timeServer(132, 163, 4, 103); // time-c.timefreq.bldrdoc.gov NTP server
    const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
    byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
    byte socketStat[MAX_SOCK_NUM];
    char myString[100];
    byte locator = 0;
    EthernetClient client;
    const byte myserver[] = { 192,168,1,59 };
    const char *dayOfWeek[] = {"Null","Sunday ","Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "};
    const char *monthString[] = {"NULL", "January", "February", "March", "April", "May", "June", "July", "August","September", "October", "November", "December"};
    TimeChangeRule usEDT = {"EDT", Second, Sun, Mar, 2, -240};  //Eastern Daylight Time = UTC - 4 hours
    TimeChangeRule usEST = {"EST", First, Sun, Nov, 2, -300};   //Eastern Standard Time = UTC - 5 hours
    Timezone usET(usEDT, usEST);
    TimeChangeRule *tcr;
    boolean forceClockUpdate = true;
      SERIAL_START(9600);
      lightOn = EEPROM.read(0);
      pinMode(LED_PIN, OUTPUT);
      dht.setup(DHT_SENSOR_PIN);
      digitalWrite(LED_PIN, lightOn);
      DEBUG_PRINTLN(F("configuring ethernet"));
      if (Ethernet.begin(mac) == 0) // start Ethernet and UDP
        DEBUG_PRINTLN(F("Failed to configure Ethernet using DHCP"));
        while(true){}
      server.begin();
      Udp.begin(localPort);
      lcd.init();
      lcd.clear();
      lightOn? lcd.backlight() : lcd.noBacklight();
      lcd.createChar(0, clock);
      updateLCD();
      getNTPtime();
      webControl();
    void updateLCD()
      static int lastSecond;
      time_t rightNow = now();
      if (second(rightNow) != lastSecond)
        lcd.setCursor(0,0);
        lcd.print(F("Time:"));
        DEBUG_PRINT(F("Time:"));
        lcd.print(hourFormat12(rightNow) < 10 ? F(" ") : F(""));
        DEBUG_PRINT(hourFormat12(rightNow) < 10 ? F(" ") : F(""));
        lcd.print(hourFormat12(rightNow));
        DEBUG_PRINT(hourFormat12(rightNow));
        lcd.print(minute(rightNow) < 10 ? F(":0") : F(":"));
        DEBUG_PRINT(minute(rightNow) < 10 ? F(":0") : F(":"));
        lcd.print(minute(rightNow));
        DEBUG_PRINT(minute(rightNow));
        lcd.print(second(rightNow) < 10 ? F(":0") : F(":"));
        DEBUG_PRINT(second(rightNow) < 10 ? F(":0") : F(":"));
        lcd.print(second(rightNow));
        DEBUG_PRINT(second(rightNow));
        lcd.print(isAM() ? "am" : "pm");
        DEBUG_PRINT(isAM() ? " am " : " pm ");
        lcd.setCursor(0,1);
        lcd.print(dayOfWeek[weekday(rightNow)]);
        DEBUG_PRINTLN(dayOfWeek[weekday(rightNow)]);
        lcd.print(F("      "));
        lcd.setCursor(11,1);
        lcd.print(month(rightNow) < 10 ? F(" ") : F(""));
        lcd.print(month(rightNow));
        lcd.print(day(rightNow) < 10 ? F("/0") : F("/"));
        lcd.print(day(rightNow));
      lastSecond = second(rightNow);
    //unsigned long
    void sendNTPpacket(IPAddress& address) // Send an NTP request to the time server at the given address
      memset(packetBuffer, 0, NTP_PACKET_SIZE);
      packetBuffer[0] = 0b11100011;   // LI, Version, Mode
      packetBuffer[1] = 0;            // Stratum, or type of clock
      packetBuffer[2] = 6;            // Polling Interval
      packetBuffer[3] = 0xEC;         // Peer Clock Precision
      packetBuffer[12]  = 49;
      packetBuffer[13]  = 0x4E;
      packetBuffer[14]  = 49;
      packetBuffer[15]  = 52;
      Udp.beginPacket(address, 123); //NTP requests are to port 123
      Udp.write(packetBuffer,NTP_PACKET_SIZE);
      Udp.endPacket();
    void receiveTime(unsigned long newTime)
      DEBUG_PRINT(F("Time value received: "));
      int lastSecond = second();
      int lastMinute = minute();
      int lastHour = hour();
      setTime(newTime);
      if ((second() != lastSecond) || (minute() != lastMinute) || (hour() != lastHour))
        DEBUG_PRINT(hourFormat12() < 10? F(" 0") : F(" "));
        DEBUG_PRINT(hourFormat12());
        DEBUG_PRINT(minute() < 10? F(":0") : F(":"));
        DEBUG_PRINT(minute());
        DEBUG_PRINTLN(isAM()? F("am") : F("pm"));
        DEBUG_PRINT(month());
        DEBUG_PRINT(F("/"));
        DEBUG_PRINT(day());
        DEBUG_PRINTLN(year());
      lcd.setCursor(15,0);
      lcd.print(F(" "));
    void getNTPtime()
      const unsigned long interval = 60000UL;
      if ((millis() - lastUpdateTime >= interval) || forceClockUpdate)
        lcd.write(0);
        sendNTPpacket(timeServer); // send an NTP packet to a time server
        delay(1000);
        if (Udp.parsePacket())
          Udp.read(packetBuffer,NTP_PACKET_SIZE);  // read the packet into the buffer
          unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
          unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
          unsigned long secsSince1900 = highWord << 16 | lowWord;
          DEBUG_PRINT(F("Seconds since Jan 1 1900 = "));
          DEBUG_PRINTLN(secsSince1900);
          DEBUG_PRINT(F("Unix time = "));
          time_t utcEpoch = secsSince1900 - 2208988800UL;//seventyYears = 2208988800UL
          DEBUG_PRINTLN(utcEpoch);
          receiveTime(usET.toLocal(utcEpoch, &tcr) + 2);  //about 2 seconds to call for time
        if (!forceClockUpdate)
          lastUpdateTime += interval;
        forceClockUpdate = false;
    void webControl()
      EthernetClient client = server.available();
      if (client)
        while (client.connected())
          if (client.available())
            char c = client.read();
            if (locator < 100)
              myString[locator] = c;
              locator++;
              myString[locator] = '\0';
            if (c == '\n') //if HTTP request has ended
              DEBUG_PRINTLN(F("MyString ="));
              DEBUG_PRINTLN(myString);
              client.println(F("HTTP/1.1 200 OK")); //new page
              client.println(F("Content-Type: text/html"));
              client.println();
              client.println(F("<HTML>"));
              client.println(F("<HEAD>"));
              client.println(F("<meta name='apple-mobile-web-app-capable' content='yes' />"));
              client.println(F("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />"));
              client.println(F("<link rel='stylesheet' type='text/css' href='http://homeautocss.net84.net/a.css' />"));
              client.println(F("<TITLE>Jim's Home Automation</TITLE>"));
              client.println(F("</HEAD>"));
              client.println(F("<BODY>"));
              client.println(F("<H1>NTP Clock/Light</H1>"));
              client.println(F("<hr />"));
              client.println(F("<br />"));
              client.println(F("<a href=\"/?ledOn\"\">Light On</a>"));
              client.println(F("<a href=\"/?ledOff\"\">Light Off</a><br />"));
              client.println(F("<a href=\"/?phoneyOn\"\">PhoneyTV On</a>"));
              client.println(F("<a href=\"/?phoneyOff\"\">PhoneyTV Off</a><br />"));
              client.println(F("<a href=\"/?syncClock\"\">Force Synchronize Clock</a>"));
              client.println(F("<H2>Current Conditions</H2>"));
              client.println(F("<H3>"));
              client.println(dayOfWeek[weekday()]);
              client.println(F(","));
              client.println(monthString[month()]);
              client.println(F(" "));
              client.println(day());
              client.println(year());
              client.println(F("<font color=\"blue\">Temperature</font>"));
              client.println(F("<font color=\"red\">"));
              client.println((int)floor(dht.toFahrenheit(dht.getTemperature()) + 0.5), 1);
              client.println(F("</font>"));
              client.println(F("<font color=\"blue\">F</font>"));
              client.println(F("<H3><font color=\"blue\">Humidity</font>"));
              client.println((int)floor(dht.getHumidity() + 0.5), 1);
              client.println(F("<font color=\"blue\">%</font>"));
              client.println(F("<div style=\"background-color:grey;"));
              client.print(F(" color:black; margin:20px; padding:20px;\">"));
              client.println(F("<h3>Jim Brower</h3>"));
              client.println(F("<p>"));
              client.println("&#169");
              client.println(F(" 2014"));
              client.println(F("</p>"));
              client.println(F("</div>"));
              client.println(F("</BODY>"));
              client.println(F("</HTML>"));
              delay(1);
              client.stop();
              if(strstr(myString, "?ledOn")) // control arduino pin and LCD backlight //checks for 'on'
                lightOn = true;
                EEPROM.write(0,0xFF);
                digitalWrite(LED_PIN, HIGH);
                lcd.backlight();
                DEBUG_PRINTLN(F("Led On"));
              if(strstr(myString, "?ledOff")) // compliment to above
                lightOn = false;
                EEPROM.write(0,0x00);
                digitalWrite(LED_PIN, LOW);
                lcd.noBacklight();
                DEBUG_PRINTLN(F("Led Off"));
              else if (strstr(myString, "?syncClock"))
                DEBUG_PRINTLN(F("Sync Set"));
              else if (strstr(myString, "?phoneyOn"))
                phoneyTV(true);
                DEBUG_PRINTLN(F("PhoneyTV On"));
              else if (strstr(myString, "?phoneyOff"))
                phoneyTV(false);
                DEBUG_PRINTLN(F("PhoneyTV Off"));
              myString[0] = '\0'; //clearing string for next read
              locator = 0;
    void phoneyTV(boolean status)
      ShowSockStatus();
      if (client.connect(myserver, 3480)) //starts client connection, checks for connection
        DEBUG_PRINTLN(F("connected"));
        client.print(F("GET /data_request?"));
        client.print(F("id=action&output_format=xml"));
        client.print(F("&DeviceNum=88"));
        client.print(F("&serviceId=urn:upnp-org:"));
        client.print(F("serviceId:SwitchPower1"));
        client.print(F("&action=SetTarget"));
        client.print(F("&newTargetValue="));
        client.print(status ? F("1") : F("0"));
        client.println(F(" HTTP/1.1"));
        client.println(F("Connection: close"));  //close 1.1 persistent connection
        client.println(); //end of get request
        delay(1);
        client.stop();
    void ShowSockStatus()
      for (int i = 0; i < MAX_SOCK_NUM; i++) {
        DEBUG_PRINT(F("Socket#"));
        DEBUG_PRINT(i);
        uint8_t s = W5100.readSnSR(i);
        socketStat[i] = s;
        DEBUG_PRINT(F(":0x"));
        #ifdef DEBUG_ON
        Serial.print(s,16);
        DEBUG_PRINT(F(" "));
        DEBUG_PRINT(W5100.readSnPORT(i));
        DEBUG_PRINT(F(" D:"));
        uint8_t dip[4];
        W5100.readSnDIPR(i, dip);
        for (int j=0; j<4; j++) {
          Serial.print(dip[j],10);
          if (j<3) Serial.print(".");
        DEBUG_PRINT(F("("));
        DEBUG_PRINT(W5100.readSnDPORT(i));
        DEBUG_PRINT(F(")"));
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Nice, I like it.
      RJ_Make
      • RJ_MakeR RJ_Make
        Nice, I like it.
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @ServiceXp
        So I've updated this for a four line display and gave it the ability to send a message to the device from its own website:
        the Display shows lots of data points from Vera:
        Video Here
        Anyone interested I'm making one... I'll post the code... or show some more video.
        • D
          dayve218
          @ServiceXp im keen, post away
          RJ_MakeR BulldogLowellB 3 Replies Last reply
          • D dayve218
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @dayve218 I think you mean @BulldogLowell ... ;-)
            RJ_Make
            • D dayve218
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @dayve218
              well, having some free time I've expanded it quite a bit, and I am not 100% sure it will run on an UNO... It works on a mega. I added a bunch of stuff:
              • tells you how many unread emails you have using a BASH script on a server to send updates every so often (I'll post that too).
              • control the brightness of the LCD with a dimmer.
              • uses Vera dimmer and switch to control relay and brightness (uses standard xml files to upload to Vera)
              • more weather
              I don't have a display demo right now, been testing in my Serial Monitor
              I can help you with any of it:
               Vera Auxilliary Controller a.k.a. Arduino/Vera Ethernet Device
               December, 2014
               Version .91
               * With the device's own website it allows you to send the device a message along with a visual or sound indicator
               * Control LCD backlight
               * Control led (relay)
               * Control your alarm state or lights or execute scenes...
               * Control attached Relay
               * Processes and displays "Vital" data from Vera like the Weather, Alarm State
               * Reliably runs on an UNO but very expandable if you want to use a Mega instead
               * Displays Indoor Temp and Humidity using DHT sensor
               INSTRUCTIONS:
               * https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads for the I2C library, or use yours
               * Add virtual switches to your Vera by following instructions here:http://faq.mios.com/content/2/40/en/how-to-create-virtual-device.html
               * and create a scene and add luup (lua) code like this:
                 local state = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 3)
                 luup.inet.wget("192.168.1.50//?ledState=“..state..”&”)
               copyright (c) by Jim Brower (BulldogLowell@gmail.com)
              #include <EEPROM.h>
              //#include <SD.h>  // you will need a MEGA for this, if you want to really expand the web UI
              #include <Time.h>
              #include "DHT.h"
              //#define DEBUG_ON   // comment out getNTPtime(); in loop to get this to fit on an UNO for debug, otherwise debug on a MEGA
              //#define USE_DHCP   // uncomment here for DHCP but uses more than 3kBytes, so warm up your MEGA it is too big for your UNO
              #define DIMMER_PIN 6                // available PWM capable pin
              #define DHT_SENSOR_PIN 7            // Thermometer-Hygrometer
              #define RELAY_PIN 13//8                 // Relay control output
              #define DISPLAY_UPDATE_TIME 3000UL  // 3.5 seconds seems OK
              #define NUMBER_OF_MESSAGE_TYPES 17  // Kinds of transmissions from Vera/Internet
              #define TONE_PIN 6                  // If you want Audio alerts
              #define NUMBER_OF_ACTION_BUTTONS 5  // your device can control scenes, devices, etc Vera-side
              #ifdef  DEBUG_ON
              typedef enum{
                LCD_WIND, LCD_TIME, LCD_ALARM_STATUS, LCD_GARAGE, LCD_GUEST_GARAGE, LCD_IP_ADDRESS, LCD_TEMPERATURE, LCD_AC_SETPOINT, LCD_OUTSIDE_TEMP, LCD_WEATHER, LCD_FORECAST, LCD_MESSAGE, LCD_HI_LOW, LCD_EMAIL}
              lcdState;
              lcdState state = LCD_TIME;  // display start on Time
              //File webFile;
              char *messagePtr;
              const char *messageType[NUMBER_OF_MESSAGE_TYPES] = {
                "?ledStatus=", "?alarmState=", "?garageState=", "?guestGarageState=", "?weatherCondition=", "?outsideTemp=", "?outsideHumid=", "?airconSetpoint=", "?weatherForecast=", "?messageData=", "?todayHigh=", "?todayLow=", "?windSpeed=", "?windDirection=", "?relayState=", "?brightLevel=", "?emailCount="};
              boolean messageFlag = false;
              unsigned long timerStart;
              unsigned long timerDuration;
              int signal = 0;
              boolean lightOn;
              boolean relayState;
              boolean garageOpen = false;
              boolean guestGarageOpen = false;
              char customMessage [30];
              char weatherCondition[30] = {
                "  Not Yet Reported"};
              char weatherForecast[30] = {
              int outdoorTemp = -99;
              int outdoorHumid = -99;
              int todayHigh = -99;
              int todayLow = -99;
              int airconSetpoint = 78;
              int alarmArmed = -1;
              int windSpeed = 99;
              char windDirection[6] = {"ZZZ"};
              char myCharBuffer[30];
              byte brightLevel = 0;
              byte oldBrightLevel;
              int emailCount = -1;
              byte buttonPin[NUMBER_OF_ACTION_BUTTONS] = {
                4, 5, A0, A1, A2};
              byte lastButtonState[4];
              DHT dht;
              LiquidCrystal_I2C lcd(0x27, 20,4);
              EthernetUDP Udp;
              uint8_t mac[] = {
              IPAddress ip(192,168,1,50);
              char myString[100];
              byte locator = 0;
              const byte veraServer[] = {
                192,168,1,59 };
                "NULL","       Sunday","       Monday", "      Tuesday", "     Wednesday", "      Thursday", "       Friday", "      Saturday"};
                SERIAL_START(9600);
                relayState = EEPROM.read(1);
                pinMode(RELAY_PIN, OUTPUT);
                pinMode(DIMMER_PIN, OUTPUT);
                digitalWrite(RELAY_PIN, relayState? HIGH : LOW);
                for (byte i = 0; i < 4; i++)
                  pinMode(buttonPin[i], INPUT_PULLUP);
              #ifdef USE_DHCP
                 DEBUG_PRINTLN(F("configuring e-net"));
                 DEBUG_PRINTLN(F("Fail Ethernet DHCP"));
                 while(true){
                Ethernet.begin(mac, ip);
                server.begin();
                lcd.init();
                lcd.clear();
                updateLCD();
                getNTPtime();
                webControl();
                messageTimer();
                updateBriteness();
                for (byte i = 0; i < NUMBER_OF_ACTION_BUTTONS; i++)
                  byte buttonState = digitalRead(buttonPin[i]);
                  if (buttonState == LOW && lastButtonState[i] == HIGH)
                    buttonPress(i);
                  lastButtonState[i] = buttonState;
              void updateLCD()
                static unsigned long lastDisplayChangeTime;
                if (millis() - lastDisplayChangeTime >= DISPLAY_UPDATE_TIME)
                  switch (state)
                  case LCD_TIME:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    DEBUG_PRINT(F("Time: "));
                    DEBUG_PRINT(F(":"));
                    DEBUG_PRINTLN(isAM() ? "a" : "p");
                    lcd.print(dayOfWeek[weekday()]);
                    displayStatus();
                    if (emailCount != -1)
                      state = LCD_EMAIL;
                      state = LCD_ALARM_STATUS;
                  case LCD_EMAIL:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Email Count"));
                    DEBUG_PRINT(F("emails: "));
                    lcd.setCursor(0,2);
                    lcd.print(F("         "));
                    lcd.print(emailCount);
                    DEBUG_PRINTLN(emailCount);
                    displayStatus();
                  case LCD_ALARM_STATUS:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Alarm Status"));
                    DEBUG_PRINT(F("Alm: "));
                    lcd.setCursor(0,2);
                    if (alarmArmed == 0)
                      lcd.print(F("     Not  Armed"));
                    else if (alarmArmed == 1)
                      lcd.print(F("        Armed"));
                      lcd.print(F("  Not Yet Reported"));
                    DEBUG_PRINTLN(alarmArmed ? F("Yes") : F("NO"));
                    displayStatus();
                    state = LCD_GARAGE;
                  case LCD_GARAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Main  Garage"));
                    DEBUG_PRINT(F("Garage: "));
                    lcd.setCursor(0,2);
                    if (garageOpen == 0)
                      lcd.print(F("       Closed"));
                    else if (garageOpen == 1)
                      lcd.print(F("        Open"));
                    DEBUG_PRINTLN(garageOpen ? F("OPEN") : F("CLOSE"));
                    displayStatus();
                    state = LCD_GUEST_GARAGE;
                  case LCD_GUEST_GARAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    Guest Garage"));
                    DEBUG_PRINT(F("Guest: "));
                    lcd.setCursor(0,2);
                    if (guestGarageOpen == 0)
                    else if (guestGarageOpen == 1)
                    DEBUG_PRINTLN(guestGarageOpen ? F("OPEN") : F("CLOSE"));
                    displayStatus();
                    state = LCD_TEMPERATURE;
                  case LCD_TEMPERATURE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("  Temperture:"));
                    DEBUG_PRINT(F("Inside Temp:"));
                    lcd.print(dht.toFahrenheit(dht.getTemperature()), 0);
                    lcd.print(char(223));
                    lcd.print(F("F"));
                    lcd.setCursor(0,2);
                    lcd.print(F("    Humidity:"));
                    lcd.print(dht.getHumidity(), 0);
                    DEBUG_PRINT(F("Humidity:"));
                    DEBUG_PRINTLN(dht.getHumidity());
                    lcd.print(F("%"));
                    displayStatus();
                    state = LCD_AC_SETPOINT;
                  case LCD_AC_SETPOINT:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("    A/C Setpoint"));
                    lcd.setCursor(0,2);
                    lcd.print(F("        "));
                    lcd.print(airconSetpoint);
                    lcd.print(F("F"));
                    DEBUG_PRINT(F("A/C setpoint:"));
                    DEBUG_PRINTLN(airconSetpoint);
                    displayStatus();
                    state = LCD_OUTSIDE_TEMP;
                  case LCD_OUTSIDE_TEMP:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F(" Outdoor Temp:"));
                    DEBUG_PRINT(F("Ext. Temp:"));
                    lcd.print(outdoorTemp);
                    lcd.print(F("F"));
                    DEBUG_PRINTLN(outdoorTemp);
                    lcd.setCursor(0,2);
                    lcd.print (outdoorHumid);
                    lcd.print(F("%"));
                    DEBUG_PRINTLN(outdoorHumid);
                    displayStatus();
                    state = LCD_WEATHER;
                  case LCD_WEATHER:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("  Today's  Weather"));
                    DEBUG_PRINT(F("Weather: "));
                    lcd.setCursor(0,2);
                    lcd.print(weatherCondition);
                    DEBUG_PRINTLN(weatherCondition);
                    displayStatus();
                    state = LCD_HI_LOW;
                  case LCD_HI_LOW:
                    fastClearLCD();
                    DEBUG_PRINTLN(F("Weather Hi/Lows"));
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("Today's High: "));
                    lcd.print(todayHigh);
                    lcd.print(F("F"));
                    lcd.setCursor(0,2);
                    lcd.print(F("         Low: "));
                    lcd.print (todayLow);
                    lcd.print(F("F"));
                    displayStatus();
                    if (windSpeed > 2)
                      state = LCD_WIND;
                      state = LCD_FORECAST;
                      DEBUG_PRINTLN(F("wind too light to report..."));
                  case LCD_WIND:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("   Winds  Gusting"));
                    DEBUG_PRINT(F("Winds: "));
                    DEBUG_PRINTLN(windSpeed);
                    lcd.print(F(" "));
                    lcd.setCursor(1,2);
                    if (windSpeed < 10) lcd.print(F(" "));
                    lcd.print(windSpeed);
                    lcd.print(F("mph from the "));
                    lcd.print(windDirection);
                    displayStatus();
                  case LCD_FORECAST:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("      Tomorrow"));
                    DEBUG_PRINT(F("Forecast: "));
                    lcd.setCursor(0,2);
                    lcd.print(weatherForecast);
                    DEBUG_PRINTLN(weatherForecast);
                    displayStatus();
                    if (messageFlag)
                      state = LCD_MESSAGE;
                      state = LCD_IP_ADDRESS;
                  case LCD_MESSAGE:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    if (signal == 2 && lightOn == 1)
                      for (int i = 0; i < 20; i++)
                        lcd.noBacklight();
                        delay(50);
                        lcd.backlight();
                        delay(50);
                    else if (signal == 1 && lightOn == 1)
                      beepTone();
                    if (signal != 0)
                      lastDisplayChangeTime - millis();  // give the message back the time lost in the flash/blinking
                    lcd.setCursor(0,1);
                    lcd.print(F("  *** Message ***"));
                    DEBUG_PRINT(F("Message: "));
                    lcd.setCursor(0,2);
                    lcd.print(customMessage);
                    DEBUG_PRINTLN(customMessage);
                    displayStatus();
                  case LCD_IP_ADDRESS:
                    fastClearLCD();
                    lcd.setCursor(0,0);
                    timeDate();
                    lcd.setCursor(0,1);
                    lcd.print(F("     IP Address"));
                    DEBUG_PRINT(F("IP Address: "));
                    lcd.setCursor(0,2);
                    lcd.print("    ");
                    for (byte thisByte = 0; thisByte < 4; thisByte++) // print the value of each byte of the IP address:
                      lcd.print(Ethernet.localIP()[thisByte], DEC);
                      if (thisByte < 3) lcd.print(".");
              #ifdef DEBUG_ON
                      Serial.print(Ethernet.localIP()[thisByte], DEC);
                      if (thisByte < 3) DEBUG_PRINT(".");
                      else DEBUG_PRINTLN(F(" "));
                    lcd.print(F(" "));
                    displayStatus();
                    state = LCD_TIME;
                  lastDisplayChangeTime = millis();
                  DEBUG_PRINT(F("free ram:"));
                  DEBUG_PRINTLN(freeRam());
                Udp.endPacket();
                setTime(newTime);
                  DEBUG_PRINT(day());
                lcd.setCursor(19,0);
                lcd.print(F(" "));
              void getNTPtime()
                if ((millis() - lastUpdateTime >= interval))
                  lcd.write(0);
                  delay(1000);
                    time_t utcEpoch = secsSince1900 - 2208988800UL;  //seventyYears = 2208988800UL
              void webControl()
                if (client)
                      if (locator < 100)
                        locator++;
                        // Send a full website with controls functions and handles message input...
                        client.println(F(
                          "<html>"
                          "<head>"
                          "<title>Vera Helper</title>"
                          "</head>"
                          "<body>"
                          "<div align=\"center\">"
                          "<H2>Arduino Auxilliary Controller</H2>"
                          "<H3>for Vera</H3>"
                          "<hr>"
                          "<H2><font color=\"green\">Comfort Settings</H2>"
                          "<H4><font color=\"blue\">Temperature</font>"
                        client.println(dht.toFahrenheit(dht.getTemperature()), 1);
                          "<br />"
                          "<H4><font color=\"blue\">Humidity</font>"
                        client.println(dht.getHumidity(), 1);
                          "<H4><font color=\"midnightBlue\">AirConditioning Setpoint</font>"
                        client.println(airconSetpoint);
                          "<br />"
                          "<hr>"
                          "<h2>"
                          "Send Message<br>"
                          "<form>"
                          "<input type=\"text\" size=\"20\" name= \"messageData\" value=\"Enter message here\">"
                          "<select name=\"time\">"
                          "<option value=\"5\">5min</option>"
                          "<option value=\"15\">15min</option>"
                          "<option selected value=\"30\">30min</option>"
                          "<option value=\"60\">60min</option>"
                          "<option value=\"720\">12hrs</option>"
                          "<option value=\"1440\">24hrs</option>"
                          "</select>"
                          "<h4>"
                          "<input type=\"radio\" name=\"signal\" value=\"2\"> Flash<br>"
                          "<input type=\"radio\" name=\"signal\" value=\"1\"> Tone <br>"
                          "<input type=\"radio\" name=\"signal\" value=\"0\" checked> None</h4>"
                          "<input type=\"submit\" onclick=\"alert('Message Sent!')\" value=\"Send\"> <input type=\"reset\" value=\"Reset\"></h2>"
                          "</form>"
                          "<hr>"
                          "<a href=\"/?ledStatus=1?\"\">Turn On LED Backlight</a>    "
                          "<a href=\"/?ledStatus=0?\"\">Turn Off LED Backlight</a>"
                          "<br />"
                          "<a href=\"/?relayState=1?\"\">Turn On Outlet</a>    "
                          "<a href=\"/?relayState=0?\"\">Turn Off Outlet</a><br /> "
                          "<br />"
                          "<a href=\"/?airconSetpoint="));
                        if (airconSetpoint > 70) client.println(airconSetpoint - 1);
                        else client.println(airconSetpoint);
                        client.println(F("?\"\">Lower Air Conditioning Setpoint</a><br /> "
                          "<br />"
                          "<div style=\"background-color:LightSlateGray; color:black; margin:20px; padding:20px;\">"
                          "<h5>&copy; copyright 2014</h5>"
                          "<h5><a href=\"mailto:bulldoglowell@gmail.com?subject=Arduino/Vera Home Controller\">"
                          "Send Email</a><h5>"
                          "</div>"
                          "</body>"
                          "</html>"));
                        delay(1);
                        client.stop();
                        // let's sort out that HTTP request...
                        for (byte i = 0; i < NUMBER_OF_MESSAGE_TYPES; i++)
                          messagePtr = strstr(myString, messageType[i]); // we need a global variable here
                          if (messagePtr)
                            DEBUG_PRINT(F("network msg..."));
                            DEBUG_PRINTLN(messageType[i]);
                            processMessage(i);
                        locator = 0;
              #ifdef DEBUG_ON
              int freeRam ()
                extern int __heap_start, *__brkval;
                int v;
                return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
                  DEBUG_PRINT(i);
                  socketStat[i] = s;
              #ifdef DEBUG_ON
                  Serial.print(s,16);
                  uint8_t dip[4];
              #ifdef DEBUG_ON
              void processMessage(byte httpMessage)
                switch (httpMessage)
                case 0: // "?ledStatus="
                  lightOn = parseNumber(httpMessage) ? 1 : 0;
                  //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? lightOn = 0 : lightOn = 1;
                  EEPROM.write(0, lightOn? 0xFF : 0x00);
                  if (lightOn) lcd.backlight();
                  else lcd.noBacklight();
                  DEBUG_PRINT(F("LCD Backlight: "));
                  DEBUG_PRINTLN(lightOn ? F("ON") : F("OFF"));
                case 1: // "?alarmState="
                  alarmArmed = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(alarmArmed ? F("Alarm is ON") : F("Alarm is OFF"));
                case 2: // "?garageState="
                  garageOpen = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(garageOpen ? F("Garage is Open") : F("garage is Closed"));
                case 3: // "?guestGarageState="
                  guestGarageOpen = parseNumber(httpMessage) ? 1 : 0;
                  DEBUG_PRINTLN(guestGarageOpen ? F("Guest garage is Open") : F("Guest garage is Closed"));
                case 4: // "?weatherCondition="  // Parse Weather
                    strncpy(weatherCondition, parseString(httpMessage), sizeof weatherCondition);
                    if (strstr(weatherCondition, "%20"))
                      strncpy(weatherCondition, cleanString(weatherCondition, "%20"), sizeof weatherCondition);
                    if (strlen(weatherCondition) < 19)
                      strncpy(weatherCondition, centerString(weatherCondition), sizeof weatherCondition);
                case 5: // "?outsideTemp="  // Parse Outside Temperature
                  outdoorTemp = parseNumber(httpMessage);
                case 6: // "?outsideHumid=" // Parse Outside Humidity
                  outdoorHumid = parseNumber(httpMessage);
                case 7: // "?airconSetpoint="  // Parse A/C Setpoint
                  airconSetpoint = parseNumber(httpMessage);
                case 8: // "?weatherForecast="  // Parse the weather forecast
                    strncpy(weatherForecast, parseString(httpMessage), sizeof weatherForecast);
                    if (strstr(weatherForecast, "+"))
                      strncpy(weatherForecast, cleanString(weatherForecast, "+"), sizeof weatherForecast);
                    if (strlen(weatherForecast) < 19)
                      strncpy(weatherForecast, centerString(weatherForecast), sizeof weatherForecast);
                case 9: //"?messageData="  // Parse display message
                    strncpy(customMessage, parseString(httpMessage), sizeof customMessage);
                    if (strstr(customMessage, "+"))
                      strncpy(customMessage, cleanString(customMessage, "+"), sizeof customMessage);
                    if (strlen(customMessage) < 19)
                      strncpy(customMessage, centerString(customMessage), sizeof customMessage);
                    Serial.println(myString);
                    if (strstr(myString, "&time="))
                      DEBUG_PRINTLN(F("Got length marker..."));
                      char *timePointer = (strstr(myString, "&time="));
                      timerDuration = atoi(timePointer + 6);
                      timerStart = millis();
                      DEBUG_PRINT(F("message length:"));
                      DEBUG_PRINTLN(timerDuration);
                      DEBUG_PRINTLN(F("No length marker..."));
                      timerDuration = 5;
                    if (strstr(myString, "&signal="))
                      DEBUG_PRINTLN(F("Got signal..."));
                      char *signalPointer = (strstr(myString, "&signal="));
                      signal = atoi(signalPointer + 8);
                      DEBUG_PRINT(F("Signal ="));
                      DEBUG_PRINTLN(signal);
                      DEBUG_PRINTLN(F("No signal..."));
                      timerDuration = 5;
                    messageFlag = true;
                case 10: // "?todayHigh="  // Parse Outside High Temperature
                  todayHigh = parseNumber(httpMessage);
                case 11: // "?todayLow="  // Parse Outside Low Temperature
                  todayLow = parseNumber(httpMessage);
                case 12: // "?windSpeed="  // Parse Outside Low Temperature
                  windSpeed = parseNumber(httpMessage);
                case 13: // "?windDirection"  // Parse Outside Low Temperature
                  strncpy(windDirection, parseString(httpMessage), sizeof windDirection);
                case 14:  //  "?relayState=" // Get the state of the relay
                  relayState = parseNumber(httpMessage) ? 1 : 0;
                  //(myString[messagePtr - myString + strlen(messageType[httpMessage])]) == '0' ? relayState = 0 : relayState = 1;
                  EEPROM.write(1, relayState ? 0xFF : 0x00);
                  digitalWrite(RELAY_PIN, relayState ? HIGH : LOW);
                  DEBUG_PRINT(F("Relay Status: "));
                  DEBUG_PRINTLN(relayState ? F("ON") : F("OFF"));
                case 15:  //  "?brightLevel=" // Get the brightness of the LED
                  brightLevel = parseNumber(httpMessage);
                  brightLevel = map(brightLevel, 0, 100, 0, 255);
                  DEBUG_PRINT(F("Brite:"));
                  DEBUG_PRINTLN(brightLevel);
                case 16: // "?emailCount"  // Parse email count
                  emailCount = parseNumber(httpMessage);
                default:
                    //Nothing to do here...
              void buttonPress(int buttonID)
                DEBUG_PRINTLN(F("buttonPress"));
                ShowSockStatus();
                if (client.connect(veraServer, 3480)) //starts client connection, checks for connection
                  switch (buttonID)
                    case 0:  // Toggle LED backlight (?ledStatus=)
                        "&DeviceNum=111" // <<<<< Set Vera Device Number for LCD backlight
                        "&action=SetTarget"
                      client.println(lightOn ? F("0") : F("1"));
                      delay(1);
                      client.stop();
                    case 1:  // Toggle Relay (relayState)
                        "&DeviceNum=116" // <<<<< Set Vera Device Number for Relay
                        "&action=SetTarget"
                      client.print(relayState ? F("0") : F("1"));
                      delay(1);
                      client.stop();
                    case 2:  // Toggle Alarm
                        "&DeviceNum=112" /* <<<<< Set Vera Device Number for Alarm */
                        "&action=SetTarget"
                      delay(1);
                      client.stop();
                    case 3:  // run lights out scene  //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                        "&action=SetTarget"
                      delay(1);
                      client.stop();
                    case 4:  // Lower Air Conditioning //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                        "&DeviceNum=112" /* <<<<< Set Vera Device Number for A/C Control */
                        "&action=SetTarget"
                      if (airconSetpoint > 72) client.print(airconSetpoint - 1);
                      else client.print(airconSetpoint - 1);
                      delay(1);
                      client.stop();
                    default:
                      //nothing to do here...
              char *parseString(byte messageNumber)
                int textLocation = (messagePtr - myString + strlen(messageType[messageNumber]));
                myCharBuffer[0] = '\0';
                for (byte i = 0; i < 30; i++) // we have room to display only 20 chars, but lets parse 30.
                  if (myString[textLocation + i] != '&')
                    myCharBuffer[i] = myString[textLocation + i];
                    DEBUG_PRINTLN(myCharBuffer[i]);
                    DEBUG_PRINTLN(F("got & marker"));
                    myCharBuffer[i] = '\0';
                DEBUG_PRINTLN(myCharBuffer);
                return myCharBuffer;
              char *cleanString(char *targetString, char *searchString)
                while(strstr(targetString, searchString))
                  char* stringChunk;
                  stringChunk = strstr(targetString, searchString);
                  targetString[stringChunk - targetString] = '\0';
                  strncpy(myCharBuffer, targetString, sizeof myCharBuffer);
                  strncat(myCharBuffer, " ", sizeof myCharBuffer);
                  strncat(myCharBuffer, stringChunk + strlen(searchString), sizeof myCharBuffer);
                  strncpy(targetString, myCharBuffer, sizeof myCharBuffer);
              int parseNumber(byte msgNum)
                if (strstr(myString, messageType[msgNum]))
                  char *messagePointer;
                  messagePointer = strtok(myString, "=");
                  messagePointer = strtok(NULL, "?");
                  int extractedNumber = atoi(messagePointer);
                  return extractedNumber;
                  DEBUG_PRINTLN(F("Fail parseNumber..."));
                  return -99;
              char *centerString(char *stringToCenter)
                char centerSpacing[30];
                for (byte i = 0; i < ((20 - strlen(myCharBuffer)) / 2); i++)
                  centerSpacing[i] = ' ';
                  centerSpacing[i+1] = '\0';
                strncat(centerSpacing, myCharBuffer, sizeof centerSpacing);
                strncpy(myCharBuffer, centerSpacing, sizeof myCharBuffer);
              void messageTimer()
                if (millis() - timerStart >= timerDuration * 60000UL)
                  signal = 0;
              void fastClearLCD()
                for (int i = 1; i < 3; i++)
                  lcd.setCursor(0,i);
                  for (int j = 0; j < 20; j++)
                    lcd.print(F(" "));
              void timeDate()
                if (hourFormat12() < 10) lcd.print(F(" "));
                lcd.print(hourFormat12());
                lcd.print(minute());
                lcd.setCursor(11,0);
                if (month() < 10) lcd.print(F(" "));
                lcd.print(month());
                lcd.print(day());
                lcd.print(F("/"));
                lcd.print(year());
              void displayStatus()
                lcd.setCursor(0,3);
                lcd.print(F("A/C:"));
                lcd.print(airconSetpoint);  //lcd.print(dht.toFahrenheit(dht.getTemperature()), 1);
                lcd.print(F("F "));
                lcd.setCursor(11,3);
                if (alarmArmed != 1)
                  lcd.print(F("Not Armed"));
              void beepTone()
                tone(TONE_PIN, 440, 200);
                noTone(TONE_PIN);
              void updateBriteness()
                if (brightLevel != oldBrightLevel)
                  analogWrite(DIMMER_PIN, brightLevel);
                oldBrightLevel = brightLevel;
              • D dayve218
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @dayve218
                BASH script to transmit unread emails to the arduino:
                #!/bin/bash
                #SCRIPT_NAME="Arduino Gmail Checker"
                #SCRIPT_VERSION="0.1"
                #figlet $SCRIPT_NAME $SCRIPT_VERSION
                # Modified for use with Vera Tool #
                #    Jim Brower  January 2015     #
                # Description: Check Gmail for unread email and switch RGB LED on Arduino in accordance #
                # Dependencies: sed, curl,                                                              #
                # Author: Virtualmix        #
                # http://blog.trollmaker.com/article10/arduino-led-notification-for-gmail-on-linux      #
                # License: CC BY        #
                # Enter Gmail username and password below (Warning: Unsafe storage):
                USERID="username"
                PASSWORD="password"
                # Enter number of seconds between email verification:
                WAIT=60
                #set -xv
                # Loop to check for new mail every X minutes
                while [ "1" -eq "1" ]; do
                    # Command line to fetch the number of unread emails:
                    MAILCOUNTER=`curl -u $USERID:$PASSWORD --silent "https://mail.google.com/mail/feed/atom" \ | xmllint --format - \ | sed -n 's#<fullcount>\(.*\)</fullcount>#\1#p'`
                    if [[ "$MAILCOUNTER" = "" ]]; then
                        echo "ERROR: The program coulndn't fetch the account for user \"$USERID\"."
                        echo "- Are you connected to the Internet?"
                        echo -e "- Is the userid and password correct for \"$USERID\"?\n"
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=-1\&
                    elif [[ "$MAILCOUNTER" -eq "0" ]]; then
                        echo "* There is 0 new email for user $USERID."
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount=0&
                        # you can do other curl here....
                    elif [[ "$MAILCOUNTER" -gt "0" ]]; then
                        echo "* There is $MAILCOUNTER new email for user $USERID."
                        curl -H "Accept: application/xml" -H "Content-Type: application/xml" -X GET 192.168.1.50/?emailCount="$MAILCOUNTER"&
                    fi
                    echo "* Waiting $WAIT seconds before checking for emails again."
                    echo "* (^C to quit the program)"
                    sleep $WAIT
                #set +xv
                done
                C 1 Reply Last reply
                • D
                  dayve218
                  @BulldogLowell thanks!!! ill have a play later on!!
                    @dayve218
                    #!/bin/bash
                    # License: CC BY        #
                    USERID="username"
                    PASSWORD="password"
                    WAIT=60
                    #set -xv
                        fi
                        sleep $WAIT
                    #set +xv
                    done
                    C
                    C
                    cleight
                    @BulldogLowell Would it be possible to use your example without the webserver portion on a Nano and still pull information from Vera?
                    • C cleight
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @cleight
                      do you mean without ethernet using the MySensors configuration?
                      look at this example, and be sure to check out @korttoma example down the page...
                      • korttomaK
                        korttomaK
                        korttoma
                        I just had an idea @BulldogLowell .
                        Do you think it would be possible for your Vera Helper to write variables directly to Plot.ly using http.request?
                        How cool would that be?
                        • Tomas
                        • korttomaK korttoma
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @korttoma
                          Sure... you could retrieve data from vera and transmit to plot.ly by making an http request to vera and passing it on to plot.ly.
                          I guess it is possible also to make a MySensors ethenet node and other MySensors sensors could transmit values to the Ethernet Enabled Sensor too.
                          • mntlvrM
                            mntlvrM
                            mntlvr
                            Hello @BulldogLowell
                            I am brand new to this site but have built a few of my own project that monitored batteries and controlled the charging rate as well as the voltage all through a web page but I am Interested in this project, Have you a complete project details with BOM and full working code, as of yet? I am looking to control the fill of a 275 gallon water tank by sonic means. I wish to have the Ultra-Sonic device measure the water level and when certain depth conditions are met the unit will open a valve and allow water in , then when the proper level is met it will close the valve and transmit all this info back to my Vera and or a web page. Please keep up the great idea.
