  3. RFM69 ATC not working?
39 Posts 6 Posters 7.9k Views 7 Watching
    @tsd
     present(1,S_SOUND);
    should be
    present(2,S_SOUND);
    and you don’t need MyMessage msgTemp(1,V_TEMP);
    I am not sure about the error. Are you using the rpi gw as serial, mqtt or ethernet gw? (What was your configure command?)
    TSD
    @mfalkvidd
    I improved the power supply of the RFM (added linear regulator) on the gateway and the error is gone.
    The code doesn't compile if I don't declare msgTemp, as I use msgTemp in the main loop.
    Where should I see the message the GW is sending? On the node? I'm using a custom node without a serial connection, so I can't see incoming messages on the node. Is there a way to have the GW send the RSSI to its own log?
      @tsd
       present(1,S_SOUND);
      should be
      present(2,S_SOUND);
      TSD
      @mfalkvidd
      I was using serial gateway by the way.
      • T TSD
        @mfalkvidd
        @tsd I don’t know. I've always connected the gateways to my controller where I get logs and graphs.
        Maybe you can use GATEWAY_DEBUG(text)
          TSD
          @mfalkvidd
          #define GATEWAY_DEBUG(text)
          or
          doesn't show any additional messages in the log, besides the node messages.
          In the mean time I installed Domoticz to try it your way, but don't see the USB port that I tried to make by installing the serial gateway (ttyUSB020, which is not in /dev yet, so should be free).
          This command should take care of that, right?
          ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
          Sorry to be such a pain, but I would really like to get this sorted out.
          • T TSD
            @mfalkvidd
            or
            @tsd sorry for being unclear. This is how to use GATEWAY_DEBUG:
            GATEWAY_DEBUG("This message will be sent to the debug log")
            But I am not sure it is available in sketches and I don't have access to a computer at the moment.
            The configure command looks good. After running configure, did you continue with make, etc?
              TSD
              @mfalkvidd
              Do you mean
              #define MY_DEBUG_VERBOSE_GATEWAY
              That uses the GATEWAY_DEBUG("text") macro that you are referring to. I tried that, but it doesn't give any additional output in the log.
              Yes, this is the complete code I run:
              sudo ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
              sudo make install
              But ttyUSB020 doesn't appear in /dev afterwards, nor does Domoticz list it.
              • T TSD
                @mfalkvidd
                Do you mean
                sudo make install
                @tsd I think you'll need to run make before make install.
                configure prepares the settings for make
                make compiles the code into an executable file called mysgw, including changes to the cpp file and the settings from the configure command
                make install copies the mysgw executable to /etc/init.d/
                • T
                  TSD
                  If I run "make install" while the code has not compiled yet, it will compile before installing. If you first run "make" seperately, "make install" will only install.
                  I'm almost there. I configured an Ethernet gateway (couldn't get serial gateway to work) and can now see the temperature, receive RSSI and sending RSSI from the node in Domoticz.
                  The gateway receive function shows up as "S_ARDUINO_REPEATER_NODE", but there's no data yet.
                  What data should I pass on to your receive function? My gateway code is now as follows:
                  MyMessage msgRSSI(2,V_LEVEL);
                  #define ARDUINO 100
                  // This space is intended to be used to include arduino libraries
                  #undef ARDUINO
                  present(2,S_SOUND);
                  receive(msgTemp);
                    int16_t rssiReceive = RFM69_getReceivingRSSI();
                    if (message.sender == 1 ) {
                      send(msgRSSI.set(rssiReceive,0));
                  • T TSD
                    #define ARDUINO 100
                    #undef ARDUINO
                    present(2,S_SOUND);
                    receive(msgTemp);
                    @tsd MySensors will automatically call receive() when the node receives a message. It should not be called manually.
                      This is how I monitor RSSI and power % from the node: sending RSSI should be close to the RSSI target value set in the config file. I left atc enabled and if I move the node away from the gateway I see the power % going up while RSSI value stays more or less the same.
                      #ifdef MY_RADIO_RFM69
                      	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
                      	send(msgRSSI1.set(rssi));                  // send RSSI level
                      	wait(500);                                 // wait to get idle
                      	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
                      	send(msgRSSI2.set(rssi));                  // send RSSI level
                      	wait(200);                                 // wait for next send
                      	PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
                      	send(msgPWR.set(PwrPcnt));				  // send TX Power
                      • T
                        TSD
                        @mfalkvidd
                        My code now looks pretty much the same as yours, except for the OTA stuff. But I don't see gateway messages in Domoticz. The node shows up with all its measurements.
                        MyMessage msgRSSI(1,V_LEVEL);
                        #define ARDUINO 100
                        #undef ARDUINO
                        present(1,S_SOUND);
                        Is the gateway supposed to show up as a measurement? Any idea why that doesn't happen?
                          TSD
                          @gohan
                          I added your code to my node. It gives exactly the same results as my own code. What kind of node are you using? Are you using the HW or W version of the RFM69?
                            it works the same, of course if you have a HW version you will see TX power % lower compared to a W module. I am not using those functions on the gateway because they are actually more node related
                              TSD
                              wrote on last edited by TSD
                              #25
                              @gohan @mfalkvidd
                              I think it is related to the Raspberry Pi implementation of MySensors. If I use an Arduino/RFM69 gateway, the RSSI is as expected. At close range, the power drops to the minimum possible level and the RSSI is strong. I noticed that the interrupt pin is toggled during communication, see picture below (orange is node current, blue is gateway interrupt).
                              If I use the Raspberry gateway (with origin/development-3.0.0 MySensors), I get the following result (orange is node current, yellow is gateway interrupt). The same result is obtained with MySensors 2.3.0 (origin/master). I couldn't get the origin/development version to compile. It gives an error about MY_DEBUGDEVICE.
                              Apart from the much higher node current (and worse RSSI), the interrupt pin is always high and not toggled.
                              Are you guys using a Raspberry gateway, or an Arduino gateway?
                              I haven't had time to dig into to the MySensors code further, but does any of you know if this could be the problem?
                              • T TSD
                                @gohan @mfalkvidd
                                @tsd nice work. I'm using an esp8266 gateway but I don't use atc.
                                  I am using raspberry with both nrf24 and rfm69 gateway on it, but I am still version 2.2.0
                                  • D
                                    diogoc
                                    I have problems too with the linux gateway
                                    link text
                                      TSD
                                      @gohan
                                      I just tried with the node on MySensors 2.2.0, but I get the same result. I cannot get the gateway to compile with 2.2.0, I get the following errors:
                                      In file included from ./MySensors.h:49:0,
                                                       from examples_linux/mysgw.cpp:83:
                                      ./drivers/RFM69/new/RFM69_new.cpp: In function ‘bool RFM69_initialise(uint32_t)’:
                                      ./MyConfig.h:716:26: error: ‘DEFAULT_RFM69_IRQ_NUM’ was not declared in this scope
                                       #define MY_RFM69_IRQ_NUM DEFAULT_RFM69_IRQ_NUM
                                      ./drivers/RFM69/new/RFM69_new.cpp:230:18: note: in expansion of macro ‘MY_RFM69_IRQ_NUM’
                                        attachInterrupt(MY_RFM69_IRQ_NUM, RFM69_interruptHandler, RISING);
                                      In file included from ./MySensors.h:347:0,
                                      ./hal/transport/MyTransportRFM69.cpp: In function ‘uint8_t transportReceive(void*)’:
                                      ./hal/transport/MyTransportRFM69.cpp:80:54: error: ‘RFM69_recv’ was not declared in this scope
                                        return RFM69_recv((uint8_t*)data, MAX_MESSAGE_LENGTH);
                                      In file included from ./MySensors.h:343:0,
                                      ./drivers/RFM69/new/RFM69_new.cpp: At global scope:
                                      ./drivers/RFM69/new/RFM69_new.cpp:749:12: warning: ‘void RFM69_encrypt(const char*)’ defined but not used [-Wunused-function]
                                       LOCAL void RFM69_encrypt(const char *key)
                                      ./drivers/RFM69/new/RFM69_new.cpp:599:12: warning: ‘void RFM69_ATCmode(bool, int16_t)’ defined but not used [-Wunused-function]
                                       LOCAL void RFM69_ATCmode(const bool onOff, const int16_t targetRSSI)
                                      ./drivers/RFM69/new/RFM69_new.cpp:340:15: warning: ‘uint8_t RFM69_receive(uint8_t*, uint8_t)’ defined but not used [-Wunused-function]
                                       LOCAL uint8_t RFM69_receive(uint8_t *buf, const uint8_t maxBufSize)
                                      Do you have the gateway running with 2.2.0? And ATC works for the RFM69?
                                        TSD
                                        @mfalkvidd
                                        And if you turn on ATC? Does that work? Are you on 2.3.0?
                                        • T TSD
                                          @mfalkvidd
                                          #31
                                          @tsd I don't know which version I am using. I'm currently travelling so I can't check easily.
