  3. RFM69 ATC not working?
39 Posts 6 Posters 7.8k Views 7 Watching
  • mfalkviddM
    Maybe measuring rssi at the gateway gives a better result? See https://github.com/mfalkvidd/Arduino-MySensors-ESP8266-RFM69-Gateway/blob/master/Arduino-MySensors-ESP8266-RFM69-Gateway.ino#L105 for how I’ve done that.
    • mfalkviddM
      also, getReceivingRSSI will return the RSSI from the last received message. It shouldn't be affected by the TX power of the node, and it is probably only updated when a message is sent to the node.
        TSD
        @mfalkvidd
        I added a sending a temperature measurement before RFM69_getReceivingRSSI and enabled ATC, but get a similar result. The code is now as follows (I cleaned up the comments):
        txPower = RFM69_getTxPowerLevel();       // Get TX power
        float temperature = readTemp705x();      // Read temperature
        send(msgTemp.set(temperature, 1),0);    // Send temperature
        rssiSend    = RFM69_getSendingRSSI();
        rssiReceive = RFM69_getReceivingRSSI();
        send(msgRSSI.set(txPower,2));		// Send TX power
        send(msgRSSI.set(rssiSend,3));		// Send sending RSSI
        send(msgRSSI.set(rssiReceive,3));	// Send receiving RSSI
        The gateway log shows that the power is increased until the maximum allowed (20 dBm), but no change in RSSI.
        TSF:MSG:READ,12-12-0,s=1,c=1,t=0,pt=7,l=5,sg=0:23.8
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:11.00
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-79.000
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-42.000
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:13.00
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-96.000
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:17.00
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-97.000
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:20.00
        TSF:MSG:READ,12-12-0,s=3,c=1,t=24,pt=7,l=5,sg=0:-43.000
        Any idea why this doesn't work?
        I'm using a Raspberry Pi gateway now, is it easy to measure RSSI on that as well? I can switch to an Arduino gateway if required.
        • T TSD
          @mfalkvidd
          @tsd sorry, no idea at the moment.
          For the rpi gw, just edit https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp (add the receive function from my sketch and start from the make step)
          T 2 Replies Last reply
            TSD
            @mfalkvidd
            OK, tnx for now. I'll look at gateway rssi tomorrow evening
              TSD
              @mfalkvidd
              I modified my code to include your receive function, but I wasn't sure how to use it in the main loop.
              MyMessage msgTemp(1,V_TEMP);
              MyMessage msgRSSI(2,V_LEVEL);
              #define ARDUINO 100
              // This space is intended to be used to include arduino libraries
              #undef ARDUINO
              present(1,S_SOUND);
              receive(msgTemp);
                int16_t rssiReceive = RFM69_getReceivingRSSI();
                if (message.sender == 1 ) {
                  send(msgRSSI.set(rssiReceive,0));
              I figured that you have to use your receive function to capture a message from the node and then do an RSSI measurement. Since I have a msgTemp coming from the node, I used that.
              After compiling the code and running the SGW, I get the following error in the logs:
              Serial - write failed: Resource temporarily unavailable
              Do you know what I did wrong?
              • T TSD
                @mfalkvidd
                #define ARDUINO 100
                #undef ARDUINO
                present(1,S_SOUND);
                receive(msgTemp);
                @tsd
                 present(1,S_SOUND);
                should be
                present(2,S_SOUND);
                and you don’t need MyMessage msgTemp(1,V_TEMP);
                I am not sure about the error. Are you using the rpi gw as serial, mqtt or ethernet gw? (What was your configure command?)
                  @tsd
                   present(1,S_SOUND);
                  should be
                  present(2,S_SOUND);
                  TSD
                  @mfalkvidd
                  I improved the power supply of the RFM (added linear regulator) on the gateway and the error is gone.
                  The code doesn't compile if I don't declare msgTemp, as I use msgTemp in the main loop.
                  Where should I see the message the GW is sending? On the node? I'm using a custom node without a serial connection, so I can't see incoming messages on the node. Is there a way to have the GW send the RSSI to its own log?
                    @tsd
                     present(1,S_SOUND);
                    should be
                    present(2,S_SOUND);
                    TSD
                    @mfalkvidd
                    I was using serial gateway by the way.
                    • T TSD
                      @mfalkvidd
                      @tsd I don’t know. I've always connected the gateways to my controller where I get logs and graphs.
                      Maybe you can use GATEWAY_DEBUG(text)
                        TSD
                        @mfalkvidd
                        #define GATEWAY_DEBUG(text)
                        or
                        doesn't show any additional messages in the log, besides the node messages.
                        In the mean time I installed Domoticz to try it your way, but don't see the USB port that I tried to make by installing the serial gateway (ttyUSB020, which is not in /dev yet, so should be free).
                        This command should take care of that, right?
                        ./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                        Sorry to be such a pain, but I would really like to get this sorted out.
                        • T TSD
                          @mfalkvidd
                          or
                          @tsd sorry for being unclear. This is how to use GATEWAY_DEBUG:
                          GATEWAY_DEBUG("This message will be sent to the debug log")
                          But I am not sure it is available in sketches and I don't have access to a computer at the moment.
                          The configure command looks good. After running configure, did you continue with make, etc?
                            TSD
                            @mfalkvidd
                            Do you mean
                            #define MY_DEBUG_VERBOSE_GATEWAY
                            That uses the GATEWAY_DEBUG("text") macro that you are referring to. I tried that, but it doesn't give any additional output in the log.
                            Yes, this is the complete code I run:
                            sudo ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB020
                            sudo make install
                            But ttyUSB020 doesn't appear in /dev afterwards, nor does Domoticz list it.
                            • T TSD
                              @mfalkvidd
                              Do you mean
                              sudo make install
                              @tsd I think you'll need to run make before make install.
                              configure prepares the settings for make
                              make compiles the code into an executable file called mysgw, including changes to the cpp file and the settings from the configure command
                              make install copies the mysgw executable to /etc/init.d/
                              • T
                                TSD
                                If I run "make install" while the code has not compiled yet, it will compile before installing. If you first run "make" seperately, "make install" will only install.
                                I'm almost there. I configured an Ethernet gateway (couldn't get serial gateway to work) and can now see the temperature, receive RSSI and sending RSSI from the node in Domoticz.
                                The gateway receive function shows up as "S_ARDUINO_REPEATER_NODE", but there's no data yet.
                                What data should I pass on to your receive function? My gateway code is now as follows:
                                #define ARDUINO 100
                                #undef ARDUINO
                                present(2,S_SOUND);
                                receive(msgTemp);
                                • T TSD
                                  #define ARDUINO 100
                                  #undef ARDUINO
                                  present(2,S_SOUND);
                                  receive(msgTemp);
                                  @tsd MySensors will automatically call receive() when the node receives a message. It should not be called manually.
                                    This is how I monitor RSSI and power % from the node: sending RSSI should be close to the RSSI target value set in the config file. I left atc enabled and if I move the node away from the gateway I see the power % going up while RSSI value stays more or less the same.
                                    #ifdef MY_RADIO_RFM69
                                    	rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
                                    	send(msgRSSI1.set(rssi));                  // send RSSI level
                                    	wait(500);                                 // wait to get idle
                                    	rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
                                    	send(msgRSSI2.set(rssi));                  // send RSSI level
                                    	wait(200);                                 // wait for next send
                                    	PwrPcnt = RFM69_getTxPowerPercent();      // read TX Power in RFM69
                                    	send(msgPWR.set(PwrPcnt));				  // send TX Power
                                    • T
                                      TSD
                                      @mfalkvidd
                                      My code now looks pretty much the same as yours, except for the OTA stuff. But I don't see gateway messages in Domoticz. The node shows up with all its measurements.
                                      MyMessage msgRSSI(1,V_LEVEL);
                                      #define ARDUINO 100
                                      #undef ARDUINO
                                      present(1,S_SOUND);
                                      Is the gateway supposed to show up as a measurement? Any idea why that doesn't happen?
                                        TSD
                                        @gohan
                                        I added your code to my node. It gives exactly the same results as my own code. What kind of node are you using? Are you using the HW or W version of the RFM69?
                                          it works the same, of course if you have a HW version you will see TX power % lower compared to a W module. I am not using those functions on the gateway because they are actually more node related
