  3. NodeManager
  4. cant get setSafeguard to work with NodeManager 1.8dev
momentaryrelaynode managersafeguard
3 Posts 2 Posters 1.7k Views 2 Watching
  • T
    tomlund
    Hi
    First of all, since this is my first post. Thank you all who have made this possible and so easy for us to use, especially NodeManager.
    I'm currently working on a garage sensor. Everything is working except this safeguard.
    I'm using a relay to open my garage door, but I only need a puls so I want to de-energize the relay as soon as possible. I tried to use;
    // [108] when switching on, turns the output off after the given number of milliseconds. For latching relay controls the pulse width (default: 0)
        void setPulseWidth(int value);
    It worked, but with power loss it would send one puls at startup, I tried using EEPROM, but still the same problem.
    So I thought it would be possible to use it as a normal relay and then use setSafeguard to be sure to cut the signal to the relay within a short time. Nothing happens when I try to use setSafeguard.
    Here is my code. If anyone can see where my mistake is, or have another solution how to make a momentary relay with nodeManager. I would be very happy :-)
    * Copyright (C) 2013-2017 Sensnology AB
     * MySensors node configuration
    // General settings
    #define SKETCH_NAME "Relay"
    #define SKETCH_VERSION "1.0"
    #define MY_NODE_ID 3
    // RFM69 radio settings
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    #define MY_RFM69_NETWORKID 100  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
    #define MY_RFM69_NEW_DRIVER
    // Advanced settings
    #define MY_BAUD_RATE 9600
     * NodeManager configuration
    #define NODEMANAGER_DEBUG ON
    #define NODEMANAGER_INTERRUPTS ON
    #define NODEMANAGER_SLEEP OFF
    #define NODEMANAGER_RECEIVE ON
    #define NODEMANAGER_DEBUG_VERBOSE ON
    #define NODEMANAGER_POWER_MANAGER OFF
    #define NODEMANAGER_CONDITIONAL_REPORT ON
    #define NODEMANAGER_EEPROM OFF
    #define NODEMANAGER_TIME ON
    #define NODEMANAGER_RTC OFF
    #define NODEMANAGER_SD OFF
    #define NODEMANAGER_HOOKING OFF
    #define NODEMANAGER_OTA_CONFIGURATION OFF
    #define NODEMANAGER_SERIAL_INPUT OFF
    // import NodeManager library (a nodeManager object will be then made available)
    #include <MySensors_NodeManager.h>
     * Add your sensors
    //#include <sensors/SensorConfiguration.h>
    //SensorConfiguration configuration;
    #include <sensors/SensorSignal.h>
    SensorSignal signal;
    #include <sensors/SensorLDR.h>
    SensorLDR ldr(A0);
    #include <sensors/SensorRelay.h>
    SensorRelay relay(6);
    #include <sensors/SensorDHT22.h>
    SensorDHT22 dht22(4);
    #include <sensors/SensorDoor.h>
    SensorDoor door(3);
     * Main Sketch
    // before
    void before() {
       * Configure your sensors
      // report measures of every attached sensors every 10 minutes
      nodeManager.setReportIntervalMinutes(10);
      // [105] automatically turn the output off after the given number of minutes
      relay.setSafeguard(1);
      // call NodeManager before routine
      nodeManager.before();
    // presentation
      nodeManager.presentation();
    // setup
      nodeManager.setup();
    // loop
      nodeManager.loop();
    #if NODEMANAGER_RECEIVE == ON
    // receive
      nodeManager.receive(message);
    #if NODEMANAGER_TIME == ON
    // receiveTime
      nodeManager.receiveTime(ts);
    • T tomlund
      Hi
      // General settings
       * Add your sensors
      SensorLDR ldr(A0);
      SensorDoor door(3);
       * Main Sketch
      // before
      void before() {
      // presentation
      // setup
      // loop
        nodeManager.loop();
      // receive
      // receiveTime
      tomlund
      It Looks like I can somewhat answer my own question.
      I got Safeguard to work, even if I have set it to 1minute, it doesn't update before next
      So it takes 10minutes, even if I have sent it to 1min. Is it supposed to be like this or is it a bug?
      • U
        U
        user2684
        Sorry for the delay first of all, unfortunately I didn't get the notification of this thread :-/ If you are using a latching relay I'd recommend using SensorLatchingRelay1Pin or SensorLatchingRelay2Pins which should take better all the aspects of a latching relay. Then you can still use the safeguard for closing the door after a given timeframe. And yes you have to set a reporting interval even if not intuitive at all. This is because the safeguard is checked in the loop cycle which is called only if a reporting interval is set. So if you have a safeguard set to 1 minute, the report interval should be 1 minute or less. Thanks!
