  3. OpenHAB Mysensors binding 2.4: cant get mqtt gateway online
mqttmysensors-bindingopenhab
49 Posts 6 Posters 11.6k Views 7 Watching
  • J jimmy loyens
    @guillermo-schimmel Hi guilleromo, thanks for staying with me.
    I have a broker setup and online,
    mqtt:broker:mosquito
        [ host="192.168.1.2",
          port=1883,
          qos=1,
          clientID="openHAB2",
          reconnectTime=20000,
          keepAlive=60000,
          secure=false,
          username="openhabian",
          password="xxxx"
    If i create a thing for the gateway i can see the gateway in paperUI but i cant managet to get it online
    Bridge mysensors:bridge-mqtt:gateway2 [ brokerName="mosquitto", username="openhabian", password="xxxx", topicPublish="mygateway1-in", topicSubscribe="mygateway1-out", startupCheckEnabled=false ]
    (This line probably looks formilliar, its the same you use with addition of username & password)
    In the log it says: "No connection to broker: mosquitto" and i think this is the whole problem since i can see the messages from the gateway appearing on mosquitto when i do:
    "mosquitto_sub -u openhabian -P y -p 1883 -v -t 'mygateway1-out/#'"
    i can allso see the messages on my phone using an mqtt client perscribing to the same topic. But i'm downloading mqtt.fx as i type
    G
    G
    Guillermo Schimmel
    @jimmy-loyens You have some mosquito/mosquitto mismatch. Have you noticed?
    J 1 Reply Last reply
    • G Guillermo Schimmel
      J
      J
      jimmy loyens
      wrote on last edited by jimmy loyens
      @guillermo-schimmel No I had not noticed thanks. Corrected it but so far GW stays offline. I have deleted and restarted these files so often over the past coupple of days, this was a fresh file from today:grin:
      just did a global search in my files, this was the only occurrence of the misspelling
      G 1 Reply Last reply
      • J jimmy loyens
        G
        G
        Guillermo Schimmel
        @jimmy-loyens This binding is a little raw. Perhaps you would like to restart the whole OpenHAB.
        Also you should enable more debugging in openhab-cli console. Specificaly to mysensors binding and mqtt.
          J
          J
          jimmy loyens
          @guillermo-schimmel I allready have TRACE on for mysensors binding, i will turn it on for mqtt to (if i can find bundle name). Do you mean reboot openhab server? No problem that will be reboot nr167 for today :grin: :stuck_out_tongue_winking_eye:
          • J jimmy loyens
            J
            J
            jimmy loyens
            @jimmy-loyens turned on TRACE logging for mqtt transport, mqtt binding & mqtt thing binding. TRACE logging was allready on for mysensors binding.
            Openhab server rebooted.
            But gateway doesnt come online
            This is everything logged about mqtt:
            2019-01-22 15:39:26.350 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - BundleEvent STARTING - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:39:26.420 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=482, service.bundleid=270, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.internal.discovery.MqttServiceDiscoveryService, component.id=321} - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:39:26.457 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory, org.eclipse.smarthome.binding.mqtt.discovery.MQTTTopicDiscoveryService}={service.id=483, service.bundleid=270, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.internal.MqttBrokerHandlerFactory, component.id=322} - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:39:26.483 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingActions}={service.id=484, service.bundleid=270, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.action.MQTTActions, component.id=323} - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:39:26.494 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - BundleEvent STARTED - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:39:26.514 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - BundleEvent STARTING - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.598 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=485, service.bundleid=271, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.generic.internal.discovery.HomeAssistantDiscovery, component.id=324} - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.626 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.type.ChannelTypeProvider, org.eclipse.smarthome.core.thing.type.ChannelGroupTypeProvider, org.eclipse.smarthome.binding.mqtt.generic.internal.generic.MqttChannelTypeProvider}={service.id=486, service.bundleid=271, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.generic.internal.generic.MqttChannelTypeProvider, component.id=325} - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.643 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=487, service.bundleid=271, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.generic.internal.discovery.Homie300Discovery, component.id=326} - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.665 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.type.DynamicStateDescriptionProvider, org.eclipse.smarthome.binding.mqtt.generic.internal.generic.MqttChannelStateDescriptionProvider}={service.id=488, service.bundleid=271, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.generic.internal.generic.MqttChannelStateDescriptionProvider, component.id=327} - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.700 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=489, service.bundleid=271, service.scope=bundle, component.name=org.eclipse.smarthome.binding.mqtt.generic.internal.MqttThingHandlerFactory, component.id=328} - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:39:26.722 [DEBUG] [lipse.smarthome.binding.mqtt.generic] - BundleEvent STARTED - org.eclipse.smarthome.binding.mqtt.generic
            2019-01-22 15:40:38.064 [TRACE] [sors.factory.MySensorsHandlerFactory] - Creating handler for thing: mysensors:bridge-mqtt:gateway2
            2019-01-22 15:40:38.090 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:gateway2' changed from UNINITIALIZED to INITIALIZING
            2019-01-22 15:40:38.115 [DEBUG] [org.eclipse.smarthome.binding.mqtt  ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingActions}={service.id=510, service.bundleid=270, service.scope=singleton} - org.eclipse.smarthome.binding.mqtt
            2019-01-22 15:40:38.130 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from UNINITIALIZED to INITIALIZING
            2019-01-22 15:40:38.194 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
            2019-01-22 15:40:38.197 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from INITIALIZING to OFFLINE
            2019-01-22 15:40:38.222 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - No connection to broker: mosquitto
            2019-01-22 15:40:38.245 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection@c41f03 to: org.openhab.binding.mysensors.internal.gateway.MySensorsGateway@16ae66
            2019-01-22 15:40:38.266 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event org.openhab.binding.mysensors.internal.protocol.mqtt.MySensorsMqttConnection@c41f03 to: org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@86c4a7
            2019-01-22 15:40:38.274 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:gateway2' changed from INITIALIZING to OFFLINE
            2019-01-22 15:40:38.281 [ERROR] [rotocol.mqtt.MySensorsMqttConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
            2019-01-22 15:40:38.368 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.2' with clientid openHAB2 and file store '/var/lib/openhab2/mqtt/192.168.1.2'
            2019-01-22 15:40:38.386 [TRACE] [ternal.TopicSubscribeMultiConnection] - Found suitable bridge mqtt:broker:mosquitto for listing to topic homie/+/$homie
            2019-01-22 15:40:38.388 [TRACE] [ternal.TopicSubscribeMultiConnection] - Found suitable bridge mqtt:broker:mosquitto for listing to topic homeassistant/#
            2019-01-22 15:40:38.407 [TRACE] [.transport.mqtt.MqttBrokerConnection] - subscribeRaw message consumer for topic 'homeassistant/#' from broker '192.168.1.2'
            2019-01-22 15:40:38.413 [TRACE] [.transport.mqtt.MqttBrokerConnection] - subscribeRaw message consumer for topic 'homie/+/$homie' from broker '192.168.1.2'
            2019-01-22 15:40:38.424 [hingStatusInfoChangedEvent] - 'mqtt:broker:mosquitto' changed from OFFLINE to ONLINE```
            • J jimmy loyens
              J
              J
              jimmy loyens
              @jimmy-loyens And everything logged for mysensors binding:
              2019-01-22 15:39:45.027 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
              2019-01-22 15:39:45.130 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=507, service.bundleid=263, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=341} - org.openhab.binding.mysensors
              2019-01-22 15:39:45.143 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
              2019-01-22 15:40:38.106 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
              2019-01-22 15:40:38.158 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
              2019-01-22 15:40:38.163 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0, 11, 107]
              2019-01-22 15:40:38.197 [TRACE] [sensors.internal.event.EventRegister] - Adding listener org.openhab.binding.mysensors.internal.gateway.MySensorsGateway@16ae66 to org.openhab.binding.mysensors.internal.event.EventRegister@c0307f
              2019-01-22 15:40:38.199 [TRACE] [sensors.internal.event.EventRegister] - Adding listener org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@86c4a7 to org.openhab.binding.mysensors.internal.event.EventRegister@c0307f
              2019-01-22 15:40:38.204 [TRACE] [nsors.handler.MySensorsBridgeHandler] - Registering MySensorsDiscoveryService for bridge 'gateway2'
              2019-01-22 15:40:38.220 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=511, service.bundleid=263, service.scope=singleton} - org.openhab.binding.mysensors
              2019-01-22 15:40:38.233 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
              2019-01-22 15:40:38.252 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=0, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.internal.gateway.MySensorsGateway@16ae66
              2019-01-22 15:40:38.254 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=0, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@86c4a7
              2019-01-22 15:40:38.256 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=11, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.internal.gateway.MySensorsGateway@16ae66
              2019-01-22 15:40:38.258 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=11, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@86c4a7
              2019-01-22 15:40:38.261 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=107, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.internal.gateway.MySensorsGateway@16ae66
              2019-01-22 15:40:38.263 [TRACE] [nternal.event.MySensorsEventRegister] - Broadcasting event MySensorsNode [nodeId=107, childNumber=0, chidldList={}] to: org.openhab.binding.mysensors.handler.MySensorsBridgeHandler@86c4a7
              2019-01-22 15:40:38.277 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,11,107]
              2019-01-22 15:40:38.280 [TRACE] [sensors.internal.event.EventRegister] - Adding listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@10bffbb to org.openhab.binding.mysensors.internal.event.EventRegister@c0307f
              2019-01-22 15:40:38.282 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
              It says "Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)" but no retry is ever done to reconnect.
              • J jimmy loyens
                J
                J
                jimmy loyens
                @jimmy-loyens I allso have no problem publishing messages to the broker from MQTT.fx.
                I currently have no actuator nodes, only sensor nodes so i cant see if gateway sends message on to nodes.
                If i just send message: "mygateway1-in/170/4/1/0/16 0" to a node that has a door contact on child 4, should this message show up in the serial monitor?
                otherwise i can reflash the node with a relay sketch
                • J jimmy loyens
                  G
                  G
                  Guillermo Schimmel
                  wrote on last edited by Guillermo Schimmel
                  @jimmy-loyens Sorry man. I'm lost. we should try to contact the author of mysensors-binding.
                  The only advice that I have right now. What I would do: Delete all mysensors-mqtt config. Delete openhab caches (a very big json file).
                  Start again very simple.
                    J
                    J
                    jimmy loyens
                    @guillermo-schimmel Dont worry about it you tried! Do you know who that is?
                    Where can i find "openhab caches"
                    • J jimmy loyens
                      G
                      G
                      Guillermo Schimmel
                      @jimmy-loyens https://forum.mysensors.org/topic/7176/openhab-2-2-binding
                      he is usually at that thread. very nice guy.
                      Lots of info on that thread also.
                      • G
                        G
                        Guillermo Schimmel
                        Is this ok in your installation?
                        openhab> bundle:list|grep My
                        191 │ Active   │  80 │ 2.4.0.201812040738     │ MySensors Binding
                          J
                          J
                          jimmy loyens
                          @guillermo-schimmel I will give it a try, thank you very much for all your efford. I think i will be needing a little brake right now so since its snowing over here i'll go sleeing with my doughter then start over fresh.:sweat_smile: :snowflake:
                          Thanks again
                            J
                            J
                            jimmy loyens
                            @guillermo-schimmel said in OpenHAB Mysensors binding 2.4: cant get mqtt gateway online:
                            bundle:list|grep My
                            263 x Active   x  80 x 2.4.0.201812040738     x MySensors Binding
                            openhab>
                            yes, its active. but for some reason it looks different
                            • T
                              TimO
                              Hey @jimmy-loyens !
                              I needed some time to investigate the problem and after looking into it, I've no clue why this is working for you @Guillermo-Schimmel . :flushed:
                              With version 2.4.0 and the changes to the mqtt binding I'm not able to connect the MySensors binding to the MQTT broker connection configured in OpenHAB. The MySensors binding uses the MQTT implementation and connection of OpenHAB, it does not connect to the broker itself.
                              And now the funny part: my development system works fine, so I need to find a way to debug this problem.
                              @Guillermo-Schimmel Did you configure broker and things in PaperUI or in textual files?
                              • T TimO
                                Hey @jimmy-loyens !
                                G
                                G
                                Guillermo Schimmel
                                @timo said in OpenHAB Mysensors binding 2.4: cant get mqtt gateway online:
                                Hey @jimmy-loyens !
                                Some in files, some in Paper UI.
                                I think I have a mess, but don't want to touch it because it's working so nicely...
                                • G
                                  G
                                  Guillermo Schimmel
                                  @guillermo-schimmel @TimO
                                  have a look
                                  Bridge mqtt:broker:mosquittotexto [ host="localhost",
        port="8884",
        secure=false,
        brokername="mosquitto",
        topicPublish="mysensors1-in",
        topicSuscribe="mysensors1-out",
                                      Thing mqtt:topic:miscosas {
                                          Channels:
                                              Type number : ecovacs_1_battery_level     "Ecovacs 01 Battery Level"         [ stateTopic="ecovacs/E0000693817701104736/battery_level" ]
                                              Type string : ecovacs_1_charge_status     "Ecovacs 01 Charge Status"         [ stateTopic="ecovacs/E0000693817701104736/charge_status" ]
                                              Type string : ecovacs_1_clean_status      "Ecovacs 01 Clean Status"          [ stateTopic="ecovacs/E0000693817701104736/clean_status" ]
                                              Type string : ecovacs_1_vacuum_status     "Ecovacs 01 Vacuum Status"         [ stateTopic="ecovacs/E0000693817701104736/vacuum_status" ]
                                              Type string : ecovacs_1_fan_speed         "Ecovacs 01 Fan Speed"             [ stateTopic="ecovacs/E0000693817701104736/fan_speed" ]
                                              Type number : ecovacs_1_main_brush        "Ecovacs 01 Main Brush"            [ stateTopic="ecovacs/E0000693817701104736/components/main_brush" ]
                                              Type number : ecovacs_1_side_brush        "Ecovacs 01 Side Brush"            [ stateTopic="ecovacs/E0000693817701104736/components/side_brush" ]
                                              Type number : ecovacs_1_filter            "Ecovacs 01 Filter"                [    stateTopic="ecovacs/E0000693817701104736/components/filter" ]
                                              Type number : ecovacs_1_ncommand          "Ecovacs 01 Number Command"        [ commandTopic="ecovacs/E0000693817701104736/command" ]
                                              Type string : porton_a_mano               "Garage Porton a Mano"             [ stateTopic="mygateway1-out/11/3/1/0/16" ]
                                              Type number : server_nextcloud_disk_root  "Server Nextloud Root Partition"   [ stateTopic="servers/nextcloud/disk/root" ]
                                              Type number : server_bluecherry_disk_root "Server Bluecherry Root Partition" [ stateTopic="servers/bluecherry/disk/root" ]
                                    have a look
        port="8884",
        secure=false,
                                            Channels:
                                    TimO
                                    @guillermo-schimmel You've mixed up attributes from the MySensors binding and the MQTT binding in the bridge definition. brokerName, topicSubscribe and so on are attributes from the MySensors binding. But this won't do any harm.
                                    How is the MySensors gateway defined?
                                    G 2 Replies Last reply
                                    • T TimO
                                      G
                                      G
                                      Guillermo Schimmel
                                      @timo Mysensors gateway is defined via Paper UI:
                                      1_1548344263093_gw2019-01-24_12-37-09.jpg 0_1548344263092_gw2019-01-24_12-36-42.jpg
                                      • T TimO
                                        G
                                        G
                                        Guillermo Schimmel
                                        Thanks, cleaned up config file:
        port="8884",
        secure=false,
                                                Channels:
                                        Restarted all, still all working fine.
        port="8884",
        secure=false,
                                                  Channels:
                                          TimO
                                          @guillermo-schimmel OK, next question: how did you define the system broker named mosquitto? Because that's the one the MySensors binding seems to use. In a service (cfg) file? I've had no success defining one and maybe that's the key.
                                          12.5k
