  3. 💬 In Wall AC/DC Pcb for MySensors
pcbmysx1.4inwallacdc
62 Posts 17 Posters 31.1k Views 20 Watching
  • J
    J
    johmei
    Looking at the images and schematics(V4.1) it looks like the 18B20 and LE33 are soldered in the wrong way?! old images or am I looking at this wrong?
    Still waiting for slow blow fuses so not ready to test yet.
    • J johmei
      sundberg84S
      sundberg84S
      @johmei - some parts was supposed to be soldered from the bottom side, so it depends :)
      Keep it in mind when you are building. I might have to make this more clear somehow on the PCB as well.
      • J
        J
        johmei
        Ok, I was reffering to the pictures of the assembled board. My half done Node (no AC) works well with the two components "the other way". confised Traced the PCB connections before testing with 5VDC. =) As long as everyone double checks what they are doing it is no problem.
        • J johmei
          sundberg84S
          sundberg84S
          @johmei - "everyone doublecheck what they are doing" = that is a problem ;)
          I will make a note on the page and change whats needed for next rev, thanks for notising!
          • J
            J
            johmei
            After quite a bit of abuse from resoldering components as I completely screwed up the order of things to get soldered I got the first couple of AC nodes running. These will be discarded once I get new Mini Pros to make fresh nodes without messing them up too much with my hot soldering iron. Been running them for 12 hours yesterday and everything seems fine. Great work on designing the PCBs @Sundberg84!
            One tip is to cool the thermal cutoffs well while soldering. I broke the first one cooling it with pliers + aligator clip. Next I used water soaked paper around components and legs with great results. Just be mindful not to soak "the wrong components".
            <blockquote class="imgur-embed-pub" lang="en" data-id="a/DBln7"><a href="//imgur.com/DBln7"></a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
            • J johmei
              sundberg84S
              sundberg84S
              @johmei - thank you! All tips for future revisions are appreciated! Let me know if I can do anything better and good luck with your nodes!
              • J
                J
                johmei
                I think the nodes seem to run really well with minimal produced heat. Do you think there will be a 3D case design for the latest version PCB? Unfortunately I have no knowledge in 3D design to contribute.
                • J johmei
                  sundberg84S
                  sundberg84S
                  @johmei - sorry, its been on my list as you probably see above.
                  I will try to make one asap!
                  • sundberg84S
                    sundberg84S
                    Finally I made the changes to the silk-screen so the orientation of the LE33 and Dallas temp sensor is right.
                    Project updated and sent new revision to PCB manufacturer. The right revision if you want to buy should be Rev 4 which is the latest files (PCB Rev 4.1)
                    • T
                      The-Holgi
                      wrote on last edited by The-Holgi
                      #58
                      i´have purchased the in wall pcb rev.3.1.
                      Now i´m want to cut up the right part of the pcb and powering the pcb with 5V power adapter.
                      Why is the VCC pin (lower arrow) with the arduino GND pin (upper arrow) connectet?
                      The GND pin lower side is connectet to arduino VCC pin, is that a mistake?
                      I´m think the print vcc and ground are reversed.
                      • T The-Holgi
                        sundberg84S
                        sundberg84S
                        @the-holgi Hi - hmm, this is an old revision and there might be misstakes as you describe. The current version is 4.1. Im traveling with work and dont have the documentation with me - but it should be quite easy to figure out if vcc and gnd are reversed by probing it with a multimeter. This PCB was not made to cut like this, but it might work - you have to try.
                        • Y
                          Y
                          yoshida
                          Just FYI: I have ordered 20pcb in January, and even though they are 4.1rev (pcbway), the le33a voltage regulator's silk screen still points to the wrong direction (flat side outwards). Also the second picture here mentions 4.1 rev, but I think this is an older rev. flat side outwards will connect the le33a Vin 5V leg to the Vin for the NRF2.4 in the 4.1 rev. Or the other way is that the orientation is good, but then it should be on the other side of the board :) So if it would be on the same side like the capacitors, it would be ok. (I have realized this after the third node built up wrongly.. :) )
                          Do you know if the le33a gets 5V to the 3v3 leg, will it survive? Other components?
                          • Y yoshida
                            sundberg84S
                            sundberg84S
                            @yoshida - sorry, I will have a check. Either its the wrong files or it not been update at the factory.
                            Im sorry, I dont know if it will survive. You have to test it.
                            Y 1 Reply Last reply
                            • sundberg84S sundberg84
                              Y
                              Y
                              yoshida
                              @sundberg84 alt text
                              I was able to do a photo, so the dallas temp, and le33 "mask" is on the opposite side, I think this is the problem. (in your example pictures they are on the good side)
                              No worries, I use currently the newbie pcbs for light switching,
