  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.6k Views 37 Watching
  • P
    P
    patrikr76
    wrote on last edited by patrikr76
    #152
    @mfalkvidd , you are absolutely right. Let me clarify.
    I am using the example code that is under build and power meter pulse sensor, updated may 1st, 2018.
    Running it with "sleep mode = false" it works fine with both usb and battery power, just drains the battery quite fast.
    Setting it to "sleep mode = true" it doesn't work either on usb or battery power.
    Here's how the serial monitor looks for the startup phase with sleep mode as true.
    23:21:24.219 ->  __  __       ____
    23:21:24.219 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
    23:21:24.219 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
    23:21:24.219 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
    23:21:24.219 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
    23:21:24.219 ->         |___/                      2.3.0
    23:21:24.219 ->
    23:21:24.219 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
    23:21:24.254 -> 25 TSM:INIT
    23:21:24.254 -> 26 TSF:WUR:MS=0
    23:21:24.254 -> 33 TSM:INIT:TSP OK
    23:21:24.254 -> 35 TSF:SID:OK,ID=2
    23:21:24.254 -> 37 TSM:FPAR
    73 TSF:MSG:SEND,2-2-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    201 TSF:MSG:READ,0-0-2,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    23:21:24.428 -> 205 TSF:MSG:FPAR OK,ID=0,D=1
    2080 TSM:FPAR:OK
    23:21:26.306 -> 2081 TSM:ID
    23:21:26.306 -> 2082 TSM:ID:OK
    23:21:26.306 -> 2084 TSM:UPL
    23:21:26.306 -> 2087 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    23:21:26.306 -> 2095 TSF:MSG:READ,0-0-2,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    23:21:26.306 -> 2100 TSF:MSG:PONG RECV,HP=1
    23:21:26.306 -> 2103 TSM:UPL:OK
    23:21:26.306 -> 2104 TSM:READY:ID=2,PAR=0,DIS=1
    23:21:26.306 -> 2109 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    23:21:26.341 -> 2118 TSF:MSG:READ,0-0-2,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    23:21:26.341 -> 2125 TSF:MSG:SEND,2-2-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
    23:21:26.341 -> 2134 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2203 TSF:MSG:READ,0-0-2,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    23:21:26.410 -> 2210 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Energy Meter
    23:21:26.445 -> 2220 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    23:21:26.445 -> 2228 TSF:MSG:SEND,2-2-0-0,s=1,c=0,t=13,pt=0,l=0,sg=0,ft=0,st=OK:
    23:21:26.445 -> 2234 MCO:REG:REQ
    23:21:26.445 -> 2237 TSF:MSG:SEND,2-2-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2252 TSF:MSG:READ,0-0-2,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    23:21:26.480 -> 2257 MCO:PIM:NODE REG=1
    23:21:26.480 -> 2259 MCO:BGN:STP
    23:21:26.480 -> 2263 TSF:MSG:SEND,2-2-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
    23:21:26.480 -> 2269 MCO:BGN:INIT OK,TSP=1
    23:21:26.480 -> 2272 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:21:26.480 -> 2277 TSF:TDI:TSL
    As far as i can see it seems fine and also shows up in myscontroller.
    And here is an example how it looks after 20 seconds sleep.
    2414 MCO:SLP:WUP=-1
    23:26:36.346 -> 2416 TSF:TRI:TSB
    23:26:36.346 -> 2418 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:26:36.346 -> 2423 TSF:TDI:TSL
    I don't see any connection attempts with my gateway, or shouldn't there by any if the sensor is not triggered?
    Here i can show how it looks when tricking the sensor with the ir on the mouse.
    2456 MCO:SLP:WUP=-1
    23:27:48.785 -> 2458 TSF:TRI:TSB
    23:27:48.785 -> 2460 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:48.785 -> 2465 TSF:TDI:TSL
    2467 MCO:SLP:WUP=-1
    23:27:48.924 -> 2468 TSF:TRI:TSB
    23:27:48.959 -> 2470 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:48.959 -> 2476 TSF:TDI:TSL
    2478 MCO:SLP:WUP=-1
    23:27:49.098 -> 2480 TSF:TRI:TSB
    23:27:49.098 -> 2481 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:49.098 -> 2486 TSF:TDI:TSL
    2488 MCO:SLP:WUP=-1
    23:27:49.235 -> 2490 TSF:TRI:TSB
    23:27:49.235 -> 2492 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:49.270 -> 2497 TSF:TDI:TSL
    2498 MCO:SLP:WUP=-1
    23:27:49.408 -> 2500 TSF:TRI:TSB
    23:27:49.408 -> 2502 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:49.408 -> 2507 TSF:TDI:TSL
    2509 MCO:SLP:WUP=-1
    23:27:49.546 -> 2510 TSF:TRI:TSB
    23:27:49.546 -> 2512 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
    23:27:49.546 -> 2518 TSF:TDI:TSL
    Interrupt is triggered and it wakes up, but nothing is sent to the gateway.
    Have i missed something?
    • P patrikr76
      23:21:24.219 ->
      2080 TSM:FPAR:OK
      2414 MCO:SLP:WUP=-1
      2456 MCO:SLP:WUP=-1
      2467 MCO:SLP:WUP=-1
      2478 MCO:SLP:WUP=-1
      2488 MCO:SLP:WUP=-1
      2498 MCO:SLP:WUP=-1
      2509 MCO:SLP:WUP=-1
      @patrikr76 great info, thanks!
      The -1 in Wup=-1 indicates that the node was waken up by timer and not by interrupt. That’s very strange, since the time stamps clearly show that 20 seconds has not passed.
      Could you add
      Serial.println(pulseCount);
      after
      sleep(SEND_FREQUENCY);
      to see if pulseCount is increased?
      • P
        P
        patrikr76
        #154
        @mfalkvidd , Here's the serial monitor after adding the serial print.
        2269 MCO:SLP:WUP=-1
        14:15:15.125 -> 2270 TSF:TRI:TSB
        14:15:15.125 -> 0
        14:15:15.125 -> 2272 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
        14:15:15.125 -> 2277 TSF:TDI:TSL
        2279 MCO:SLP:WUP=-1
        14:15:37.264 -> 2281 TSF:TRI:TSB
        14:15:37.264 -> 0
        14:15:37.264 -> 2282 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
        14:15:37.264 -> 2287 TSF:TDI:TSL
        2289 MCO:SLP:WUP=-1
        14:15:59.354 -> 2291 TSF:TRI:TSB
        14:15:59.354 -> 0
        14:15:59.354 -> 2293 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
        14:15:59.389 -> 2298 TSF:TDI:TSL
        As you see, it sleeps about 22 secs with no pulse on it.
        Moving the mouse over it gives this.
        2353 MCO:SLP:WUP=-1
        14:18:09.982 -> 2355 TSF:TRI:TSB
        14:18:09.982 -> 4
        14:18:09.982 -> 2357 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
        14:18:09.982 -> 2362 TSF:TDI:TSL
        2363 MCO:SLP:WUP=-1
        14:18:23.059 -> 2365 TSF:TRI:TSB
        14:18:23.059 -> 5
        14:18:23.059 -> 2367 MCO:SLP:MS=20000,SMS=0,I1=255,M1=255,I2=255,M2=255
        14:18:23.059 -> 2372 TSF:TDI:TSL
        Looking through the code, this one raises a flag.
        if (pcReceived && (SLEEP_MODE || sendTime))
        The pulseCount send is within that if statement which is not fullfilled because it doesn't receive pcReceived.
        Or am i wrong?
        • P
          P
          patrikr76
          Found a solution, which is not ideal.
          I was having similar problem with a motion sensor not being able to send, adding a delay after sleep helped on that one, but it was just a 5ms delay needed.
          On this one i had to add a 1 sec delay in the begining of the loop. I tried smaller but then it didn't work.
          I am starting to think it is the nano clone that has crappy components.
          • P patrikr76
            @patrikr76 nice work.
            Sounds very similar to https://forum.mysensors.org/topic/9655/delay-after-tsf-tri-tsb/14
              StKilda
              I have two meters I would like to measure: One that the LED is off most of the time and briefly pulses on per increment (at 3200 pulses per Kwh - so I adjusted the pulse factor accordingly). This works fine. The second meter, the LED pulses off (meaning the led it lit most of the time, and pulses off briefly). Do I need to adjust the code in any way to deal with this meter? Thanks. Really impressed it works virtually out of the box.
              • S StKilda
                Great work @stkilda
                I think the sketch will work without modification. The easiest way to find out is probably to try it.
                  you may need to change the interrupt behavior, but try it first
                  • bjornhallbergB
                    bjornhallbergB
                    bjornhallberg
                    Is there a suggested replacement for the TSL250? While it can still be found, it seems to be discontinued for the most part.
                    I've had no luck with the LM393 solution for my new power meter. Just can't tune it to pick up the led impulses. What sort of diode solution is everyone else using? I'm aware of the possibility of IR communication (https://wiki.hal9k.dk/projects/kamstrup) but it seems a little over the top.
                      I used these https://www.aliexpress.com/item/5-pcs-LM393-Light-Sensor-Photosensitive-Sensitivity-light-Sensor-Module-For-Arduino-Smart-Car/1729424221.html
                      • F
                        F
                        FullMetal
                        Hello
                        my skectch works very well, only I have a double pricing, I manage to recover the information. but I have to modify the code in order to have my exact consumption.
                        but my code sends me information always on the same IDs.
                        thank you
                        • F FullMetal
                          Hello
                          thank you
                          #163
                          Hi @fullmetal, welcome to the forum :-)
                          Could you explain what double pricing means?
                          • F
                            F
                            FullMetal
                            Thank you for your welcome @mfalkvidd
                            Our electricity provider offers several rates.
                            HP: Full time
                            HC: off-peak time
                            usually the HP/HC rate is programmed at night by the provider.
                            As the consumption is saved by the arduino, I need two different IDs to trace the information to domotics
                            • F
                              F
                              FullMetal
                              Here is the modified code:
                              #define MY_PARENT_NODE_ID 0                   // define if fixed parent
                              #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
                              #define MY_NODE_ID 2                     // fixed node number
                              // Enable debug prints
                              // Enable RS485 transport layer
                              #define MY_RS485
                              // Define this to enables DE-pin management on defined pin
                              #define MY_RS485_DE_PIN 2
                              // Set RS485 baud rate to use
                              // Set blinking period
                              // Flash leds on rx/tx/err
                              #define MY_DEFAULT_ERR_LED_PIN 13  // Error led pin
                              #define MY_DEFAULT_RX_LED_PIN  7  // Receive led pin
                              #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
                              //#define MY_RADIO_NRF24
                              #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
                              #define DIGITAL_INPUT_HCHP 5
                              #define PULSE_FACTOR 250       // Nummber of blinks per KWH of your meeter
                              #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
                              //#define CHILD_ID 2              // Id of the sensor child
                              unsigned long SEND_FREQUENCY =
                                 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
                              double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
                              bool pcReceived = false;
                              volatile unsigned long pulseHpCount = 0;
                              volatile unsigned long pulseHcCount = 0;
                              unsigned long oldPulseHpCount = 0;
                              unsigned long oldWatt = 0;
                              double oldKwhHp;
                              unsigned long oldPulseHcCount = 0;
                              double oldKwhHc;
                              unsigned long lastSend;
                              Bounce debouncer = Bounce();
                              int oldValue=-1;
                              MyMessage wattMsg(1,V_WATT);
                              MyMessage kwhHpMsg(3,V_KWH);
                              MyMessage pcHpMsg(2,V_VAR1);
                              MyMessage kwhHcMsg(5,V_KWH);
                              MyMessage pcHcMsg(6,V_VAR1);
                              MyMessage hchpMsg(7,V_VAR2);
                              const int ledPin =  13;      // sortie digitale
                                 request(2, V_VAR1);
                                 request(6, V_VAR1);
                                 pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                                 pinMode(DIGITAL_INPUT_HCHP,INPUT_PULLUP);
                                 pinMode(ledPin, OUTPUT);
                                 attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                                 lastSend=millis();
                                 debouncer.attach(DIGITAL_INPUT_HCHP);
                                 debouncer.interval(5);
                                 sendSketchInfo("Energy Meter", "2.0");
                                 present(1, S_POWER);
                                 present(2, S_POWER);
                                 present(3, S_POWER);
                                 present(5, S_POWER);
                                 present(6, S_POWER);
                                 present(7, S_POWER);
                                 unsigned long now = millis();
                                 if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
                                 // LED Power On
                                 digitalWrite(ledPin, HIGH);
                                 // LED Power Off
                                 digitalWrite(ledPin, LOW);
                               debouncer.update();
                               // Get the update value
                               int value = debouncer.read();
                               Serial.println("");
                               if (value != oldValue) {
                                  // Send in the new value
                                  send(hchpMsg.set(value==HIGH ? 1 : 0));
                                  oldValue = value;
                                 if (pcReceived && (SLEEP_MODE || sendTime)) {
                                     if (!SLEEP_MODE && watt != oldWatt) {
                                         if (watt<((unsigned long)MAX_WATT)) {
                                         Serial.print("Watt:");
                                         Serial.println(watt);
                                         oldWatt = watt;
                                 /////HP
                                       if (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH ) {
                                     // Pulse cout has changed
                                        if (pulseHpCount != oldPulseHpCount) {
                                         send(pcHpMsg.set(pulseHpCount));  // Send pulse count value to gw
                                         double kwhHp = ((double)pulseHpCount/((double)PULSE_FACTOR));
                                         oldPulseHpCount = pulseHpCount;
                                         if (kwhHp != oldKwhHp) {
                                             send(kwhHpMsg.set(kwhHp, 4));  // Send kwh value to gw
                                             oldKwhHp = kwhHp;
                                     lastSend = now;
                                    }else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ){
                                    if (pulseHcCount != oldPulseHcCount) {
                                         send(pcHcMsg.set(pulseHcCount));  // Send pulse count value to gw
                                         double kwhHc = ((double)pulseHcCount/((double)PULSE_FACTOR));
                                         oldPulseHcCount = pulseHcCount;
                                         if (kwhHc != oldKwhHc) {
                                             send(kwhHcMsg.set(kwhHc, 4));  // Send kwh value to gw
                                             oldKwhHc = kwhHc;
                                     lastSend = now;
                                 }else if (sendTime && !pcReceived) {
                                     // No count received. Try requesting it again
                                     request(2, V_VAR1);
                                     request(6, V_VAR1);
                                     lastSend=now;
                                 if (SLEEP_MODE) {
                                /////HP
                                 if (message.type==V_VAR1) {
                                     pulseHpCount = oldPulseHpCount = message.getLong();
                                     Serial.print("Received last pulse count from gw:");
                                     Serial.println(pulseHpCount);
                                     pcReceived = true;
                                 /////HC
                                     pulseHcCount = oldPulseHcCount = message.getLong();
                                     Serial.println(pulseHcCount);
                                     pcReceived = true;
                              void onPulse()
                                 /////HP
                                 if (!SLEEP_MODE) {
                                     unsigned long interval = newBlink-lastBlink;
                                     if (interval<10000L) { // Sometimes we get interrupt on RISING
                                         return;
                                     watt = (3600000000.0 /interval) / ppwh;
                                     lastBlink = newBlink;
                                 pulseHpCount++;
                                 /////HC
                                 else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
                                   if (!SLEEP_MODE) {
                                         return;
                                 pulseHcCount++;
                              • F FullMetal
                                #define MY_RS485
                                double oldKwhHp;
                                double oldKwhHc;
                                int oldValue=-1;
                                   request(2, V_VAR1);
                                   request(6, V_VAR1);
                                   lastSend=millis();
                                   // LED Power On
                                   // LED Power Off
                                 debouncer.update();
                                 Serial.println("");
                                    oldValue = value;
                                           oldWatt = watt;
                                   /////HP
                                               oldKwhHp = kwhHp;
                                       lastSend = now;
                                               oldKwhHc = kwhHc;
                                       lastSend = now;
                                       request(2, V_VAR1);
                                       request(6, V_VAR1);
                                       lastSend=now;
                                   if (SLEEP_MODE) {
                                  /////HP
                                       pcReceived = true;
                                   /////HC
                                       pcReceived = true;
                                void onPulse()
                                   /////HP
                                   if (!SLEEP_MODE) {
                                           return;
                                   pulseHpCount++;
                                   /////HC
                                     if (!SLEEP_MODE) {
                                           return;
                                   pulseHcCount++;
                                @fullmetal cool. Thanks for explaining, and for sharing your sketch.
                                F 1 Reply Last reply
                                  F
                                  F
                                  FullMetal
                                  In fact, my code does not work as I would like, HC information systematically go back to the HP ID.
                                  Can you help me
                                  • C
                                    C
                                    cstewy
                                    Update: Running for over 12 months on 2 regular AA batteries using the method I described above. Basically rather than powering the tsl257 constantly, I wake up every 125ms then send power to the tsl257, check if there has been a state change in the power meter light then go back to sleep.
                                      This thread contains comments for the article "Power Meter Pulse Sensor" posted on MySensors.org.
                                      I
                                      I
                                      it-slav
                                      wrote on last edited by it-slav
                                      #169
                                      Hi
                                      My heat exchanger does only give one pulse / kWh which results in that there can be hours between the pulses. When doing the watt calculation micros are used and that counter overflow after 70minutes. See: https://www.arduino.cc/reference/en/language/functions/time/micros/
                                      I have modified the sketch to use millis instead of micros when the time between the pulses are above one hour and micros if it is less than an hour.
                                      I hope I did it correct ;-)
                                      Best regards
                                      Peter Andersson
                                       * Copyright (C) 2013-2019 Sensnology AB
                                       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                                       * Version 1.0 - Henrik Ekblad
                                       * Version 1.1 - Peter Andersson added millis watt calculation if time between pulses > 1h
                                       * This sketch provides an example how to implement a LM393 PCB
                                       * Use this sensor to measure kWh and Watt of your house meter
                                       * You need to set the correct pulsefactor of your meter (blinks per kWh).
                                       * The sensor starts by fetching current kWh value from gateway.
                                       * Reports both kWh and Watt back to gateway.
                                       * Unfortunately millis() won't increment when the Arduino is in
                                       * sleepmode. So we cannot make this sensor sleep if we also want
                                       * to calculate/report watt value.
                                       * http://www.mysensors.org/build/pulse_power
                                      #define MY_REPEATER_FEATURE    //Added
                                      #define MY_RADIO_RF24
                                      //#define MY_RADIO_NRF5_ESB
                                      //#define MY_RADIO_RFM95
                                      #define PULSE_FACTOR 1       // Number of blinks per of your meter. Normally 1000
                                      #define SLEEP_MODE false        // Watt value can only be reported when sleep mode is false.
                                      #define MAX_WATT 100000          // Max watt value to report. This filters outliers. Normally 10000
                                      uint32_t SEND_FREQUENCY =
                                          20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                                      volatile uint32_t pulseCount = 0;
                                      volatile uint32_t lastBlinkmicros = 0;
                                      volatile uint32_t lastBlinkmillis = 0;
                                      volatile uint32_t watt = 0;
                                      uint32_t oldPulseCount = 0;
                                      uint32_t oldWatt = 0;
                                      double oldkWh;
                                      uint32_t lastSend;
                                      MyMessage wattMsg(CHILD_ID,V_WATT);
                                      MyMessage kWhMsg(CHILD_ID,V_KWH);
                                      MyMessage pcMsg(CHILD_ID,V_VAR1);
                                          request(CHILD_ID, V_VAR1);
                                          lastSend=millis();
                                          present(CHILD_ID, S_POWER);
                                          uint32_t now = millis();
                                                  // Check that we don't get unreasonable large watt value.
                                                  // could happen when long wraps or false interrupt triggered
                                                  if (watt<((uint32_t)MAX_WATT)) {
                                                  oldWatt = watt;
                                              // Pulse count value has changed
                                              if (pulseCount != oldPulseCount) {
                                                  send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                                  double kWh = ((double)pulseCount/((double)PULSE_FACTOR));
                                                  oldPulseCount = pulseCount;
                                                  if (kWh != oldkWh) {
                                                      send(kWhMsg.set(kWh, 4));  // Send kWh value to gw
                                                      oldkWh = kWh;
                                              lastSend = now;
                                          } else if (sendTime && !pcReceived) {
                                              // No pulse count value received. Try requesting it again
                                              lastSend=now;
                                          if (SLEEP_MODE) {
                                              pulseCount = oldPulseCount = message.getLong();
                                              Serial.print("Received last pulse count value from gw:");
                                              pcReceived = true;
                                      void onPulse()
                                          if (!SLEEP_MODE) {
                                              uint32_t newBlinkmicros = micros();
                                              uint32_t newBlinkmillis = millis();
                                              uint32_t intervalmicros = newBlinkmicros-lastBlinkmicros;
                                              uint32_t intervalmillis = newBlinkmillis-lastBlinkmillis;
                                              if (intervalmicros<10000L && intervalmillis<10L) { // Sometimes we get interrupt on RISING
                                                  return;
                                              if (intervalmillis<360000) { //Less then an hour since last pulse, use microseconds
                                                 watt = (3600000000.0 /intervalmicros) / ppwh;
                                                 watt = (3600000.0 /intervalmillis) / ppwh; //more then an hour since last pulse, use milliseconds as micros will overflow after 70min
                                              lastBlinkmicros = newBlinkmicros;
                                              lastBlinkmillis = newBlinkmillis;
                                          pulseCount++;
                                      • I it-slav
                                        Hi
                                        Best regards
                                        Peter Andersson
                                        double oldkWh;
                                        uint32_t lastSend;
                                            lastSend=millis();
                                                    oldWatt = watt;
                                                        oldkWh = kWh;
                                                lastSend = now;
                                                lastSend=now;
                                            if (SLEEP_MODE) {
                                                pcReceived = true;
                                        void onPulse()
                                            if (!SLEEP_MODE) {
                                                    return;
                                            pulseCount++;
                                        #170
                                        Thanks @it-slav
                                        I have created a pull request based on your sketch.
                                        https://github.com/mysensors/MySensors/pull/1306
                                        There were some merge problems, but I think I got them all ironed out.
                                        • butalukB
                                          butalukB
                                          butaluk
                                          Hello everyone.
                                          Is it possible to evaluate two electricity meter signals with one sensor?
                                          Thank you!
