  2. Announcements
  3. 💬 Power Meter Pulse Sensor
183 Posts 40 Posters 93.6k Views 37 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Is there a suggested replacement for the TSL250? While it can still be found, it seems to be discontinued for the most part.
    I've had no luck with the LM393 solution for my new power meter. Just can't tune it to pick up the led impulses. What sort of diode solution is everyone else using? I'm aware of the possibility of IR communication (https://wiki.hal9k.dk/projects/kamstrup) but it seems a little over the top.
      I used these https://www.aliexpress.com/item/5-pcs-LM393-Light-Sensor-Photosensitive-Sensitivity-light-Sensor-Module-For-Arduino-Smart-Car/1729424221.html
      • F
        F
        FullMetal
        Hello
        my skectch works very well, only I have a double pricing, I manage to recover the information. but I have to modify the code in order to have my exact consumption.
        but my code sends me information always on the same IDs.
        thank you
        • F FullMetal
          Hello
          thank you
          #163
          Hi @fullmetal, welcome to the forum :-)
          Could you explain what double pricing means?
          • F
            F
            FullMetal
            Thank you for your welcome @mfalkvidd
            Our electricity provider offers several rates.
            HP: Full time
            HC: off-peak time
            usually the HP/HC rate is programmed at night by the provider.
            As the consumption is saved by the arduino, I need two different IDs to trace the information to domotics
            • F
              F
              FullMetal
              Here is the modified code:
              #define MY_PARENT_NODE_ID 0                   // define if fixed parent
              #undef MY_REGISTRATION_FEATURE                  // sketch moves on if no registration
              #define MY_NODE_ID 2                     // fixed node number
              // Enable debug prints
              // Enable RS485 transport layer
              #define MY_RS485
              // Define this to enables DE-pin management on defined pin
              #define MY_RS485_DE_PIN 2
              // Set RS485 baud rate to use
              // Set blinking period
              // Flash leds on rx/tx/err
              #define MY_DEFAULT_ERR_LED_PIN 13  // Error led pin
              #define MY_DEFAULT_RX_LED_PIN  7  // Receive led pin
              #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
              //#define MY_RADIO_NRF24
              #define DIGITAL_INPUT_SENSOR 3  // The digital input you attached your light sensor.  (Only 2 and 3 generates interrupt!)
              #define DIGITAL_INPUT_HCHP 5
              #define PULSE_FACTOR 250       // Nummber of blinks per KWH of your meeter
              #define SLEEP_MODE false        // Watt-value can only be reported when sleep mode is false.
              //#define CHILD_ID 2              // Id of the sensor child
              unsigned long SEND_FREQUENCY =
                 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
              double ppwh = ((double)PULSE_FACTOR)/1000; // Pulses per watt hour
              bool pcReceived = false;
              volatile unsigned long pulseHpCount = 0;
              volatile unsigned long pulseHcCount = 0;
              unsigned long oldPulseHpCount = 0;
              unsigned long oldWatt = 0;
              double oldKwhHp;
              unsigned long oldPulseHcCount = 0;
              double oldKwhHc;
              unsigned long lastSend;
              Bounce debouncer = Bounce();
              int oldValue=-1;
              MyMessage wattMsg(1,V_WATT);
              MyMessage kwhHpMsg(3,V_KWH);
              MyMessage pcHpMsg(2,V_VAR1);
              MyMessage kwhHcMsg(5,V_KWH);
              MyMessage pcHcMsg(6,V_VAR1);
              MyMessage hchpMsg(7,V_VAR2);
              const int ledPin =  13;      // sortie digitale
                 request(2, V_VAR1);
                 request(6, V_VAR1);
                 pinMode(DIGITAL_INPUT_SENSOR,INPUT_PULLUP);
                 pinMode(DIGITAL_INPUT_HCHP,INPUT_PULLUP);
                 pinMode(ledPin, OUTPUT);
                 attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, RISING);
                 lastSend=millis();
                 debouncer.attach(DIGITAL_INPUT_HCHP);
                 debouncer.interval(5);
                 sendSketchInfo("Energy Meter", "2.0");
                 present(1, S_POWER);
                 present(2, S_POWER);
                 present(3, S_POWER);
                 present(5, S_POWER);
                 present(6, S_POWER);
                 present(7, S_POWER);
                 unsigned long now = millis();
                 if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
                 // LED Power On
                 digitalWrite(ledPin, HIGH);
                 // LED Power Off
                 digitalWrite(ledPin, LOW);
               debouncer.update();
               // Get the update value
               int value = debouncer.read();
               Serial.println("");
               if (value != oldValue) {
                  // Send in the new value
                  send(hchpMsg.set(value==HIGH ? 1 : 0));
                  oldValue = value;
                 if (pcReceived && (SLEEP_MODE || sendTime)) {
                     if (!SLEEP_MODE && watt != oldWatt) {
                         if (watt<((unsigned long)MAX_WATT)) {
                         Serial.print("Watt:");
                         Serial.println(watt);
                         oldWatt = watt;
                 /////HP
                       if (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH ) {
                     // Pulse cout has changed
                        if (pulseHpCount != oldPulseHpCount) {
                         send(pcHpMsg.set(pulseHpCount));  // Send pulse count value to gw
                         double kwhHp = ((double)pulseHpCount/((double)PULSE_FACTOR));
                         oldPulseHpCount = pulseHpCount;
                         if (kwhHp != oldKwhHp) {
                             send(kwhHpMsg.set(kwhHp, 4));  // Send kwh value to gw
                             oldKwhHp = kwhHp;
                     lastSend = now;
                    }else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ){
                    if (pulseHcCount != oldPulseHcCount) {
                         send(pcHcMsg.set(pulseHcCount));  // Send pulse count value to gw
                         double kwhHc = ((double)pulseHcCount/((double)PULSE_FACTOR));
                         oldPulseHcCount = pulseHcCount;
                         if (kwhHc != oldKwhHc) {
                             send(kwhHcMsg.set(kwhHc, 4));  // Send kwh value to gw
                             oldKwhHc = kwhHc;
                     lastSend = now;
                 }else if (sendTime && !pcReceived) {
                     // No count received. Try requesting it again
                     request(2, V_VAR1);
                     request(6, V_VAR1);
                     lastSend=now;
                 if (SLEEP_MODE) {
                     sleep(SEND_FREQUENCY);
                /////HP
                 if (message.type==V_VAR1) {
                     pulseHpCount = oldPulseHpCount = message.getLong();
                     Serial.print("Received last pulse count from gw:");
                     Serial.println(pulseHpCount);
                     pcReceived = true;
                 /////HC
                     pulseHcCount = oldPulseHcCount = message.getLong();
                     Serial.println(pulseHcCount);
                     pcReceived = true;
              void onPulse()
                 /////HP
                 if (!SLEEP_MODE) {
                     unsigned long interval = newBlink-lastBlink;
                     if (interval<10000L) { // Sometimes we get interrupt on RISING
                         return;
                     watt = (3600000000.0 /interval) / ppwh;
                     lastBlink = newBlink;
                 pulseHpCount++;
                 /////HC
                 else if (digitalRead(DIGITAL_INPUT_SENSOR) == LOW ) {
                   if (!SLEEP_MODE) {
                         return;
                 pulseHcCount++;
              • F FullMetal
                #define MY_RS485
                double oldKwhHp;
                double oldKwhHc;
                int oldValue=-1;
                   request(2, V_VAR1);
                   request(6, V_VAR1);
                   lastSend=millis();
                   // LED Power On
                   // LED Power Off
                 debouncer.update();
                 Serial.println("");
                    oldValue = value;
                           oldWatt = watt;
                   /////HP
                               oldKwhHp = kwhHp;
                       lastSend = now;
                               oldKwhHc = kwhHc;
                       lastSend = now;
                       request(2, V_VAR1);
                       request(6, V_VAR1);
                       lastSend=now;
                   if (SLEEP_MODE) {
                  /////HP
                       pcReceived = true;
                   /////HC
                       pcReceived = true;
                void onPulse()
                   /////HP
                   if (!SLEEP_MODE) {
                           return;
                   pulseHpCount++;
                   /////HC
                     if (!SLEEP_MODE) {
                           return;
                   pulseHcCount++;
                @fullmetal cool. Thanks for explaining, and for sharing your sketch.
                F 1 Reply Last reply
                  F
                  F
                  FullMetal
                  In fact, my code does not work as I would like, HC information systematically go back to the HP ID.
                  Can you help me
                  • C
                    C
                    cstewy
                    Update: Running for over 12 months on 2 regular AA batteries using the method I described above. Basically rather than powering the tsl257 constantly, I wake up every 125ms then send power to the tsl257, check if there has been a state change in the power meter light then go back to sleep.
                      This thread contains comments for the article "Power Meter Pulse Sensor" posted on MySensors.org.
                      I
                      I
                      it-slav
                      wrote on last edited by it-slav
                      #169
                      Hi
                      My heat exchanger does only give one pulse / kWh which results in that there can be hours between the pulses. When doing the watt calculation micros are used and that counter overflow after 70minutes. See: https://www.arduino.cc/reference/en/language/functions/time/micros/
                      I have modified the sketch to use millis instead of micros when the time between the pulses are above one hour and micros if it is less than an hour.
                      I hope I did it correct ;-)
                      Best regards
                      Peter Andersson
                       * Copyright (C) 2013-2019 Sensnology AB
                       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                       * Version 1.0 - Henrik Ekblad
                       * Version 1.1 - Peter Andersson added millis watt calculation if time between pulses > 1h
                       * This sketch provides an example how to implement a LM393 PCB
                       * Use this sensor to measure kWh and Watt of your house meter
                       * You need to set the correct pulsefactor of your meter (blinks per kWh).
                       * The sensor starts by fetching current kWh value from gateway.
                       * Reports both kWh and Watt back to gateway.
                       * Unfortunately millis() won't increment when the Arduino is in
                       * sleepmode. So we cannot make this sensor sleep if we also want
                       * to calculate/report watt value.
                       * http://www.mysensors.org/build/pulse_power
                      #define MY_REPEATER_FEATURE    //Added
                      #define MY_RADIO_RF24
                      //#define MY_RADIO_NRF5_ESB
                      //#define MY_RADIO_RFM95
                      #define PULSE_FACTOR 1       // Number of blinks per of your meter. Normally 1000
                      #define SLEEP_MODE false        // Watt value can only be reported when sleep mode is false.
                      #define MAX_WATT 100000          // Max watt value to report. This filters outliers. Normally 10000
                      uint32_t SEND_FREQUENCY =
                          20000; // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                      volatile uint32_t pulseCount = 0;
                      volatile uint32_t lastBlinkmicros = 0;
                      volatile uint32_t lastBlinkmillis = 0;
                      volatile uint32_t watt = 0;
                      uint32_t oldPulseCount = 0;
                      uint32_t oldWatt = 0;
                      double oldkWh;
                      uint32_t lastSend;
                      MyMessage wattMsg(CHILD_ID,V_WATT);
                      MyMessage kWhMsg(CHILD_ID,V_KWH);
                      MyMessage pcMsg(CHILD_ID,V_VAR1);
                          request(CHILD_ID, V_VAR1);
                          lastSend=millis();
                          present(CHILD_ID, S_POWER);
                          uint32_t now = millis();
                                  // Check that we don't get unreasonable large watt value.
                                  // could happen when long wraps or false interrupt triggered
                                  if (watt<((uint32_t)MAX_WATT)) {
                                  oldWatt = watt;
                              // Pulse count value has changed
                              if (pulseCount != oldPulseCount) {
                                  send(pcMsg.set(pulseCount));  // Send pulse count value to gw
                                  double kWh = ((double)pulseCount/((double)PULSE_FACTOR));
                                  oldPulseCount = pulseCount;
                                  if (kWh != oldkWh) {
                                      send(kWhMsg.set(kWh, 4));  // Send kWh value to gw
                                      oldkWh = kWh;
                              lastSend = now;
                          } else if (sendTime && !pcReceived) {
                              // No pulse count value received. Try requesting it again
                              lastSend=now;
                          if (SLEEP_MODE) {
                              pulseCount = oldPulseCount = message.getLong();
                              Serial.print("Received last pulse count value from gw:");
                              Serial.println(pulseCount);
                              pcReceived = true;
                      void onPulse()
                          if (!SLEEP_MODE) {
                              uint32_t newBlinkmicros = micros();
                              uint32_t newBlinkmillis = millis();
                              uint32_t intervalmicros = newBlinkmicros-lastBlinkmicros;
                              uint32_t intervalmillis = newBlinkmillis-lastBlinkmillis;
                              if (intervalmicros<10000L && intervalmillis<10L) { // Sometimes we get interrupt on RISING
                                  return;
                              if (intervalmillis<360000) { //Less then an hour since last pulse, use microseconds
                                 watt = (3600000000.0 /intervalmicros) / ppwh;
                                 watt = (3600000.0 /intervalmillis) / ppwh; //more then an hour since last pulse, use milliseconds as micros will overflow after 70min
                              lastBlinkmicros = newBlinkmicros;
                              lastBlinkmillis = newBlinkmillis;
                          pulseCount++;
                      • I it-slav
                        Hi
                        Best regards
                        Peter Andersson
                        double oldkWh;
                        uint32_t lastSend;
                            lastSend=millis();
                                    oldWatt = watt;
                                        oldkWh = kWh;
                                lastSend = now;
                                lastSend=now;
                            if (SLEEP_MODE) {
                                pcReceived = true;
                        void onPulse()
                            if (!SLEEP_MODE) {
                                    return;
                            pulseCount++;
                        #170
                        Thanks @it-slav
                        I have created a pull request based on your sketch.
                        https://github.com/mysensors/MySensors/pull/1306
                        There were some merge problems, but I think I got them all ironed out.
                        • butalukB
                          butalukB
                          butaluk
                          Hello everyone.
                          Is it possible to evaluate two electricity meter signals with one sensor?
                          Thank you!
                          • butalukB butaluk
                            Hello everyone.
                            Thank you!
                            @butaluk yes, as long as they are not too far apart to run the cables
                            butalukB 1 Reply Last reply
                              butalukB
                              butalukB
                              butaluk
                              @mfalkvidd Thank you. no, the counters are in one place. Do you have an example code for me?
                              • sundberg84S
                                sundberg84S
                                #174
                                Hi! I have just revised my pulse sensor and have a few suggestions to the code. I have mentioned this before but there can be issues when requesting V_VAR1.
                                In current code we request V_VAR1 one time and then goes to sleep, and if you like me have a 10 minute sleep period it can take along time to get V_VAR1 if you have a radio on the outside of your GW range.
                                I would suggest adding:
                                } else if (now - lastSend > 5000 && !pcReceived) {
                                    // No pulse count value received from controller. Try requesting it again.
                                    recrequestcount = recrequestcount + 1;
                                #ifdef MY_DEBUG
                                    Serial.println("Req p-cnt");
                                    lastSend = now;
                                    return;
                                and before sleep:
                                else if (!pcReceived) {
                                    //We dont want to sleep if !pcRecieved. Return and wait 5 sec to request a new value.
                                    return;
                                In HomeAssisant you also have the specific problem that if V_VAR1 isnt stored, the controller will not answer - so you can keep asking for a pulsecount forever without an reply. To avoid this the first time I have added:
                                else if (recrequestcount == 5 && !pcReceived) {
                                    //For some controllers, if you dont have any V_VAR1 stored node will not get an answer.
                                    //Try 5 times, then set V_VAR1 to 0 and update controller
                                #ifdef MY_DEBUG
                                    Serial.println("Set p-cnt and update controller");
                                    pcReceived = true;
                                    recrequestcount = 0;
                                    send(pcMsg.set(pulseCount));  // Send pulse count 0 value to gw
                                    double kWh = ((double)pulseCount / ((double)PULSE_FACTOR));
                                    send(kWhMsg.set(kWh, 4));  // Send kWh value 0 to gw
                                    lastSend = now;
                                This setup works great for me, but I dont have the bigger picture - might break something else.
                                I can add a pull request if you think this should fit.
                                Here is my full code (but It includes battery measurments)
                                https://github.com/sundberg84/HomeAutomation/blob/master/Ver 2.X/2.3/EnergyMeterPulseSensor_Feb2020/EnergyMeterPulseSensor_Feb2020.ino
                                Also there is a strange error with SEND_FREQUENCY / timer when you have this interrupt. Works great if you dont have any interrupts but as soon as you get pulses the timer gets about 4 times as fast as it should be - I have added a correction to this, but I dont know whats causing this.
                                uint32_t SEND_FREQUENCY = 4*60000*15; // Minimum time between send (in milliseconds). We don't want to spam the gateway. (Corr * 60sek * minutes)
                                K 1 Reply Last reply
                                  snady
                                  Hi
                                  I have done search of this thread and no one seems to have mentioned latency.
                                  I have a test setup using a LM393 running on a particle photon with a sketch that also runs a flashing led. I have tested this with various led flash lengths and intervals, the highest rate being a 10ms flash with 10ms interval . I have a consistent precise reading of pulse interval and number but have identified that there is a 1ms delay between the flash and the start of the interrupt function. This latency is consistent, whatever the interval between and I can only assume it is a result of latency caused by LM393 and interrupt, though I find it strange that the latency is exactly 1millisecond even when measured in micros. Under low meter loads this discrepancy would most likely go unnoticed but with high loads of 72kWs it results in a significant error when calculating the instant power.
                                  Has anyone else noticed this or can give another reason for this that I am missing?
                                  A subtraction of the identified latency from the pulse interval reading, calibrates the setup and produces exact readings
                                  • F
                                    F
                                    frydrik
                                    Hello, this sensor can be adapted for 2-4 meters ?
                                    • K
                                      K
                                      keithellis
                                      I've been building one of these pulse meters up, it seems to be working on the bench very nice. Just got to build a case and get a power supply of the Arduino. But I have designed a case to hold the LM393 sensor onto the meter. I removed the light sensor and re-soldered it flush to the board making it easier to mount on the meter. Its a simple box but works quite well.
                                      The files are on thingiverse here
                                      Hope this is useful.
                                      • sundberg84S sundberg84
                                        #ifdef MY_DEBUG
                                            lastSend = now;
                                            return;
                                        and before sleep:
                                            return;
                                        #ifdef MY_DEBUG
                                            pcReceived = true;
                                            lastSend = now;
                                        K
                                        K
                                        keithellis
                                        @sundberg84 Thanks very much for this post. I was struggling to get the sensor appear in Home-Assistant. Your note on the fact that HA never returns V_VAR1 on first use was very useful and pointed me in the right direction.
                                        My modifications looked like this:
                                            retryCount++;
                                        		lastSend = now;
                                        	} else if (retryCount >= 5 && !pcReceived) {
                                            pcReceived = true;
                                            retryCount = 0;
                                            lastSend = now;
                                        The whole sketch is here:
                                           REVISION HISTORY
                                           DESCRIPTION
                                        #define PULSE_FACTOR 1000       // Number of blinks per kWh of your meter. Normally 1000.
                                        #define MAX_WATT 10000          // Max watt value to report. This filters outliers.
                                        double ppwh = ((double)PULSE_FACTOR) / 1000; // Pulses per watt hour
                                        uint32_t retryCount = 0;  //If value not being returned from controller, increment this counter
                                        double oldkWh;
                                        uint32_t lastSend;
                                        MyMessage wattMsg(CHILD_ID, V_WATT);
                                        MyMessage kWhMsg(CHILD_ID, V_KWH);
                                        MyMessage pcMsg(CHILD_ID, V_VAR1);
                                        #if defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
                                        #define IRQ_HANDLER_ATTR ICACHE_RAM_ATTR
                                        void IRQ_HANDLER_ATTR onPulse()
                                        	if (!SLEEP_MODE) {
                                        		uint32_t intervalmicros = newBlinkmicros - lastBlinkmicros;
                                        		uint32_t intervalmillis = newBlinkmillis - lastBlinkmillis;
                                        		if (intervalmicros < 10000L && intervalmillis < 10L) { // Sometimes we get interrupt on RISING
                                        			return;
                                        		if (intervalmillis < 360000) { // Less than an hour since last pulse, use microseconds
                                        			watt = (3600000000.0 / intervalmicros) / ppwh;
                                        			watt = (3600000.0 / intervalmillis) /
                                        			       ppwh; // more thAn an hour since last pulse, use milliseconds as micros will overflow after 70min
                                        	pulseCount++;
                                        	pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
                                        	lastSend = millis();
                                        	sendSketchInfo(F("Energy Meter"), F("1.1"));
                                        			// Check that we don't get unreasonable large watt value, which
                                        			if (watt < ((uint32_t)MAX_WATT)) {
                                        			oldWatt = watt;
                                        				oldkWh = kWh;
                                        		lastSend = now;
                                            retryCount++;
                                        		lastSend = now;
                                            pcReceived = true;
                                            retryCount = 0;
                                            lastSend = now;
                                        	if (SLEEP_MODE) {
                                        		sleep(SEND_FREQUENCY, false);
                                        	if (message.getType()==V_VAR1) {
                                        		pcReceived = true;
                                        • K
                                          K
                                          keithellis
                                          Got this sensor up and running now. Comparing it to my old clamp meter the kWh reading was reading 2-3 times higher, the Watts was about right. I added a 0.1uF capacity across the ground and data pins of the sensor and it is working well now.
                                          The graph below shows the comparison of my two sensors. the old clamp meter is Energy previous hour, the new pulse sensor is Temp energy previous hour
                                          You can see they are not aligned, until about 20:00 when I added the capacitor and they drop in line.Screenshot 2021-09-25 at 22.18.27.png
