  3. Combine several scetches to 1 node
4 Posts 2 Posters 1.2k Views 2 Watching
  • X
    X
    xypzo
    Hi
    I am having trouble combining multiple scetches into one node since the last mysensors library update.
    I have combined the DHT and RELAY scetches and they work great. I just want to add an interrupt sensor (door, motion, whatever) to pin 3.
    I think the problem is the sleep function. it is different in all 3 scetches, i am an absolute NOOB with programming, but simply cut/paste is not working anymore.
    Can somebody please be of any assistance? You would save the day! thanks!
    #define MY_REPEATER_FEATURE
    static const uint64_t UPDATE_INTERVAL = 60000;
    #define CHILD_ID_HUM 3
    #define CHILD_ID_TEMP 4
    #define DHT_DATA_PIN 8
    #define SENSOR_TEMP_OFFSET 0
    #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    void before()
      for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
      sendSketchInfo("DHT & Relays", "2.0");
      present(CHILD_ID_HUM, S_HUM);
        present(sensor, S_BINARY);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
    #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
    #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
    skywatchS 1 Reply Last reply
    • X xypzo
      Hi
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
          if (!metric) {
          nNoUpdatesTemp = 0;
      #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
      #ifdef MY_DEBUG
          nNoUpdatesHum++;
      skywatchS
      skywatchS
      skywatch
      @xypzo said in Combine several scetches to 1 node:
      This should do it - It compiles but I cannot test it, so that is down to you!
      #define DIGITAL_INPUT_SENSOR 3
      #define CHILD_ID 1
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      void before()
          pinMode(DIGITAL_INPUT_SENSOR, INPUT);
         digitalWrite(DIGITAL_INPUT_SENSOR, HIGH);
        present(CHILD_ID, S_DOOR);
          if (!metric) {
          nNoUpdatesTemp = 0;
      #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
      #ifdef MY_DEBUG
          nNoUpdatesHum++;
      bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
          sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, UPDATE_INTERVAL);
        //sleep(UPDATE_INTERVAL);
      I am not sure it is possible for the node to receive a message when it is asleep?
      X 1 Reply Last reply
      • skywatchS skywatch
        #define CHILD_ID 1
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
        void before()
            if (!metric) {
            nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
            nNoUpdatesHum++;
        X
        X
        xypzo
        wrote on last edited by xypzo
        IT WORKS, thank you very much!
        One thing, the interrupt (motion) status is only sent when the other data (temp hum) is being send. So once a minute it jumps from "on" to "off" in stead of every time the Sensor goes HI/LO.
        Is there a way to fix that?
        Thanks again, you are a HERO
        • X xypzo
          skywatchS
          skywatchS
          skywatch
          @xypzo > One thing, the interrupt (motion) status is only sent when the other data (temp hum) is being send. So once a minute it jumps from "on" to "off" in stead of every time the Sensor goes HI/LO.
          Don't sleep the node. It won't be able to receive messages during it's sleep anyway so incomming messages will be lost as well.
