  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 24.2k Views 23 Watching
    A Former User
    java.lang.NoClassDefFoundError: org/eclipse/smarthome/io/transport/mqtt/MqttActionCallback
    The new MQTT binding requires parts of the new automation engine. This is missing from your system for some reason. Should be automatically installed when MQTT or the MySensors binding are installed.
    I'd love to have a simple working binding but it isn't there yet. Use plain mqtt elements and it'll work great.
    This statement is not correct. The OH 2.4 release officially supports the new binding and if any errors are reported, they are getting fixed. The new binding allows Paper UI and textual configuration so there is no reason to start with mqtt1 nowadays.
    Cheers,
    David
    G 1 Reply Last reply
    • ? A Former User
      Cheers,
      David
      G
      G
      Guillermo Schimmel
      @davidgraeff Yes David, you are correct. The new binding works. I'm in fact using it and with the corresponding changes on the items files its ok.
      I would love some kind of auto discovery though. In order to create each thing you have to manually enter the topic (which on mysensors is very complex)
      Anyways, I will try to edit previous message which is in fact wrong.
      • MasMatM MasMat
        @jogant Finally had time to double check this:
        Paper UI:
        Broker Name
        mosquitto
        Subscription Topic
        mygateway1-out
        Publish Topic
        mygateway1-in
        Send Delay 100
        Startup check enabled
        Metric answer enabled
        Network sanity check enabled
        Interval to launch network sanity check 3
        Attempts before disconnecting the bridge 3
        Heartbeat disabled
        Attempts before disconnecting nodes 10
        EDIT: I noticed I have different topics in MQTT, corrected AND I did:
        cd /usr/share/openhab2/addons/
        wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar   <== THIS probably  fixed it!
        chown for the same file
        rm org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
        Now my MQTT Gw is ONLINE, in Paper UI I just selected the bridge for every individual Thing and now it works.
        Hope this helps people strugling with this.
        G
        G
        Guillermo Schimmel
        @masmat Yes!!!! Thank you man. I found 2.4.0 thanks to your message and now it's working!
        Love
        • J
          J
          jimmy loyens
          wrote on last edited by jimmy loyens
          #52
          • R
            R
            Rene Mullie
            wrote on last edited by Rene Mullie
            #53
            Hi all, I am a Newbie an trying to get OH2.4 to work with MySensors nodes.
            I have a MYS Mqtt ethernet GW up&running (seems to work, can talk to other sensors)
            Now I can't get MQTT thing/broker/binding to work in OH2.4. I first tries the manual above, then I read that Musquitto is not needed any more....right??
            I have to use MQTT 2.4 Ting binding and MQTT broker right? -> I have installed this and have MQTT broker running on localhost (online) (no channels addes in MQTT broker)
            I have added in Things: MysensorsMQTT gateway: broker name: "MQTT Broker" and 'startup check' and 'sanity check' ON
            Then I checked from the CLI the file "org.eclipse.smarthome.mqtt.cfg" ->there was still the musquitto entries I made... Also in mqtt-eventbus.cfg was still broker=musquitto. What do I do with this??
            In OH log I get errors:
            ****2019-02-10 21:52:35.274 [me.event.ThingUpdatedEvent] - Thing 'mysensors:bridge-mqtt:9954d183' has been updated.
            2019-02-10 21:52:35.682 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:9954d183' changed from UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/openhab/binding/mysensors/internal/protocol/mqtt/MySensorsMqttConnection$MySensorsMqttPublishCallback to INITIALIZING
            2019-02-10 21:52:35.685 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:9954d183' changed from INITIALIZING to UNINITIALIZED (HANDLER_INITIALIZING_ERROR): org/openhab/binding/mysensors/internal/protocol/mqtt/MySensorsMqttConnection$MySensorsMqttPublishCallback****
            Next problem:
            I installed the MySensors Ethernet gateway thing in OH, configged it with IP of Arduino running the Mys GW. -> This Thing will NOT come 'online'. I can Ping the GW board, all looks OK in GW log:
            0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
            4 TSM:INIT
            5 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSM:INIT:GW MODE
            15 TSM:READY:ID=0,PAR=0,DIS=0
            17 MCO:REG:NOT NEEDED
            580 GWT:TPC:IP=192.168.178.87
            1583 MCO:BGN:STP
            1585 MCO:BGN:INIT OK,TSP=1
            1588 GWT:TPC:IP=192.168.178.87
            2590 GWT:RMQ:MQTT RECONNECT
            2798 GWT:RMQ:MQTT CONNECTED
            2801 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
            2807 TSM:READY:NWD REQ
            2844 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            4 TSM:INIT
            5 TSF:WUR:MS=0
            11 TSM:INIT:TSP OK
            13 TSM:INIT:GW MODE
            1583 MCO:BGN:STP
            2800 GWT:TPS:TOPIC=mygateway1-out/0/255/0/0/18,MSG SENT
            3810 TSF:MSG:READ,254-254-0,s=255,c=3,t=21,pt=1,l=1,sg=0:0
            3815 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/21,MSG SENT
            636790 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
            636795 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/0,MSG SENT
            637304 TSF:MSG:READ,254-254-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
            637309 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/1,MSG SENT
            637815 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:0
            637820 GWT:TPS:TOPIC=mygateway1-out/254/1/1/0/16,MSG SENT
            637827 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1
            637832 GWT:TPS:TOPIC=mygateway1-out/254/1/1/0/15,MSG SENT
            637838 TSF:MSG:READ,254-254-0,s=7,c=1,t=0,pt=4,l=4,sg=0:44
            637844 GWT:TPS:TOPIC=mygateway1-out/254/7/1/0/0,MSG SENT
            637850 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:99
            637855 GWT:TPS:TOPIC=mygateway1-out/254/255/3/0/0,MSG SENT
            900006 TSF:SAN:OK
            How do I proceed? Ive tried to find more posts on getting MySensors to work under OH24 but I think it is sooo simple that nobody has any problems to post....right?!
            Hope you guys can get this Newbie back on track.... thx a lot!
            J 1 Reply Last reply
            • R Rene Mullie
              Next problem:
              4 TSM:INIT
              5 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSM:INIT:GW MODE
              1583 MCO:BGN:STP
              4 TSM:INIT
              5 TSF:WUR:MS=0
              11 TSM:INIT:TSP OK
              13 TSM:INIT:GW MODE
              1583 MCO:BGN:STP
              900006 TSF:SAN:OK
              J
              J
              jimmy loyens
              Hi @rene-mullie,
              Seems like the mysensors binding mqtt gw doesnt play nice with the mosquitto broker. You can try running the embedded broker of openhab (paperUi->addons->misc->embedded broker i beleive). Dont forget to configure it under services->misc (not shure since im on my phone right now). And connect your mqtt gateway to this broker. I was not succesful in this because i need the embedded broker on port 1884 since i allready have mosquitto on port 1883 for other stuff. And i <think> mysensors mqtt gateway doesnt want to connect to 1884 but 1883. But you can give it a try. If you have ethernet gateway going and dont have plans to use different controllers (for example to do FOTA updates) i would stick to the ethernet gw for now. Greets
              • R
                R
                Rene Mullie
                I have configged the embedded broker in right way, broker is online on localhost.
                I tried to connect Mys mqtt gateway to Embedded mqtt broker in paper UI:
                Broker Name
                MQTT Broker (-> not sure about this name....??)
                name of the MQTT broker as defined in the org.eclipse.smarthome.mqtt.cfg file``` (-> if I check this cfg file there is NOTHING about the embedded broker, only old Musquitto stuf...)
                All is on default port 1883 on both sides...
                I get fault in OH log file:
                2019-02-10 23:40:56.626 [ERROR] [al.protocol.ip.MySensorsIpConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:15)
                • W
                  W
                  waspie
                  broker name is "embedded-mqtt-broker"
                  R 1 Reply Last reply
                  • W waspie
                    R
                    R
                    Rene Mullie
                    @waspie tried that, still same errors...
                    What should be the entries in the org.eclipse.smarthome.mqtt.cfg file ?
                    W J 2 Replies Last reply
                    • R Rene Mullie
                      W
                      W
                      waspie
                      @rene-mullie delete it
                      • R Rene Mullie
                        J
                        J
                        jimmy loyens
                        @rene-mullie if im not mistaken that file is to configure mqtt v1 and your using mqtt v2
                        • R
                          R
                          Rene Mullie
                          Thx4 your support! I gave up on fixing the old install and started over with brand new install of OH2.4: All was up&running in 45mins!! MQTT2.4 with embedded broker works like a charm. On top the Mysensors MQTT GW Ting was online with 1-click! All my MYsensor nodes where recognized immediately! What a relief!
                          Hope someone will update Mysensors docu so others will be spared the pain...
