  3. OpenHAB
  4. Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable)
60 Posts 19 Posters 24.2k Views 23 Watching
  • jogantJ jogant
    @timo unfortunately this also does not work for me. I followed your manual very well but I always get errors. It starts after installing feature:install esh-io-transport-mqtt and mysensors binding:
    16:59:57.772 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - Reason unknown
    16:59:57.806 [INFO ] [o.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.96.8' with clientid paho1135997459230242 and file store '/var/lib/openhab2/mqtt/192.168.96.8'
    16:59:57.867 [ERROR] [protocol.mqtt.MySensorsMqttConnection] - MQTT connection offline - {}
    org.eclipse.paho.client.mqttv3.MqttException: MqttException
            at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) [229:org.eclipse.paho.client.mqttv3:1.0.2]
            at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:604) [229:org.eclipse.paho.client.mqttv3:1.0.2]
            at java.lang.Thread.run(Thread.java:748) [?:?]
    Caused by: java.net.SocketException: Connection reset
            at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
            at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
            at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
            at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
            at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:983) ~[?:?]
            at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
            at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
            at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:89) ~[?:?]
            at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:590) ~[?:?]
            ... 1 more
    and reconection starts every 10 seconds.
    It must be interference with mqtt1 bindung that I use for eventbus.
    The mqtt-bridge remains Offline.
    What is wrong?
    TimO
    @jogant Indeed this looks like an error in your configuration. I suspect the MQTT configuration. Did you change the MQTT configuration according my posting above? I've also added a text to the Wiki. The name and content of the MQTT configuration differs between OpenHAB 2.2 and 2.3.
    jogantJ 2 Replies Last reply
    • T TimO
      jogantJ
      jogantJ
      jogant
      @timo with 2.2 I had two configurations which were very similar.
      I have one mosquitto mqtt broker on localhost, version 1.5.
      The mqtt1 binding is for my mqtt-eventbus connection is called mosquitto and the config file (mqtt.cfg) is as follows:
      mosquitto.url=tcp://192.168.96.8:1883
      mosquitto.retain=false
      mosquitto.clientId=openhab
      mosquitto.user=user
      mosquitto.pwd=pwd
      With OH2.2 this configuration works. It also works with 2.3 as I can see all openhab events on my mosquitto.
      My mysonsors binding is configured by org.eclipse.smarthome.mqttbroker.cfg config file which looks as follows:
      name=mosquittomys
      host=192.168.96.8
      port=1883
      retain=false
      username=username
      password=password
      clientId=openhabMys
      I also tried without authentication and also without clientId, all to no succuess.
      I cleaned /var/lib/openhab2/cache/ folder and /var/lib/openhab2/tmp/ folder.
      I looked at /var/lib/openhab2/config folder for resulting runtime configuration, but all looks fine. Do you have any further idea?
      • T TimO
        jogantJ
        jogantJ
        jogant
        @timo I found the fault in my configuration: it was the missing secure=false config flag in the org.eclipse.smarthome.mqttbroker.cfg config file. I have no idea what happens when the flag is missing but without it one doesn't achieve a valid connection.
        name=mosquittomys
        host=192.168.96.8
        port=1883
        secure=false  <-- important !
        So now I have a working 2.3 installation! Thanks alot for your support.
        • jogantJ jogant
          name=mosquittomys
          host=192.168.96.8
          port=1883
          TimO
          @jogant Good catch! I'm glad it's working now! :-)
          • MasMatM
            MasMatM
            MasMat
            I'm still unsuccesful.
            Do I need to reinstall all the files as well? I didn't find a new set of instructions.
            In my /etc/openhab2/services-folder I have:
            mqtt-eventbus.cfg containing just
            broker=mosquitto
            and org.eclipse.smarthome.mqttbroker.cfg:
            name=mosquitto
            host=127.0.0.1
            secure=false
            port=1883
            secure=false
            username=XXXX
            password=YYYYY
            retain=false
            clientId=openhabMys
            openhab.log everything mysensors related:
            2018-07-09 06:40:36.782 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho175068223000 and file store '/var/lib/openhab2/mqtt/127.0.0.1'
            2018-07-09 06:40:37.050 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTING - org.openhab.binding.mysensors
            2018-07-09 06:40:37.075 [DEBUG] [org.openhab.binding.mysensors       ] - BundleEvent STARTED - org.openhab.binding.mysensors
            2018-07-09 06:40:37.206 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.thing.binding.ThingHandlerFactory}={service.id=119, service.bundleid=13, service.scope=bundle, component.name=org.openhab.binding.mysensors.factory.MySensorsHandlerFactory, component.id=17} - org.openhab.binding.mysensors
            2018-07-09 06:42:36.466 [WARN ] [lipse.smarthome.io.net.exec.ExecUtil] - Execution failed (Exit value: -559038737. Caused by java.io.IOException: Cannot run program "arping" (in directory "."): error=2, Tiedostoa tai hakemistoa ei ole)
            2018-07-09 06:42:36.685 [INFO ] [ternal.dhcp.DHCPPacketListenerServer] - DHCP request packet listener online
            2018-07-09 06:42:37.484 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
            2018-07-09 06:42:38.136 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
            2018-07-09 06:42:38.178 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0, 1, 99, 4, 5]
            2018-07-09 06:42:38.608 [DEBUG] [rotocol.mqtt.MySensorsMqttConnection] - Enabling connection watchdog
            2018-07-09 06:42:38.830 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=281, service.bundleid=13, service.scope=singleton} - org.openhab.binding.mysensors
            2018-07-09 06:42:38.897 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
            2018-07-09 06:42:38.926 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
            Anyone spot what's still wrong?
            P.S. I remember seeing someone got MyS gateway to log to a different file. Does anyone know how to implement that in the ./configure -command? Or how can I do that?
            jogantJ 1 Reply Last reply
            • MasMatM MasMat
              broker=mosquitto
              name=mosquitto
              host=127.0.0.1
              secure=false
              port=1883
              secure=false
              username=XXXX
              password=YYYYY
              retain=false
              clientId=openhabMys
              jogantJ
              jogantJ
              jogant
              @masmat two things come to my mind: I have two different broker-names for eventbus connection and mysensors connection. For eventbus binding you need classic mqtt1 binding with its own configuration like this:
              mosquitto.url=tcp://127.0.0.1:1883
              mosquitto.user=user
              mosquitto.pwd=pwd
              And second: can you show your mysensors bridge configuration? Not shure but debug log looks like an ethernet bridge and not a mqtt bridge.
              • MasMatM
                MasMatM
                MasMat
                Not sure how to answer some of your questions...but here goes.
                configuration:
                sudo ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --my-signing-debug --my-signing=password --my-signing-password=XXXXXXXX --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-user=YYYY --my-mqtt-password=ZZZZZ --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18
                I'm not sure what "eventbus"-binding is. Something I need to install in Paper UI?
                Is the configuration file mqtt-eventbus.cfg or something else? Should I try to install it? I have not installed the MQTT binding in OpenHab because at least originally the instructions said not to.
                • MasMatM MasMat
                  configuration:
                  jogantJ
                  jogantJ
                  jogant
                  @masmat I just wanted to understand your configuration. So I read through whole thread and saw your problems began with upgrade to OH2.3.
                  I mentioned eventbus as you wrote something about eventbus.cfg.
                  You need eventbus only if you want to send all oh events to mqtt broker.
                  I wanted to see your mqtt bridge configuration. You can either configure dynamicly via paper ui or you set it up via things file. The later is what I did. So here is my things file with bridge configuration.
                  Bridge mysensors:bridge-mqtt:gateway [  brokerName="mosquittomys",
                                                          topicPublish="mysensors1/in",
                                                          topicSubscribe="mysensors1/out",
                                                          startupCheckEnabled=true ] {
                  Here the brokername has to be the same as in mqttbroker.cfg. Fix topic names to match your mysensors gateway.
                  Hope this is of any help.
                  MasMatM 1 Reply Last reply
                    shadowbreed
                    • jogantJ jogant
                      MasMatM
                      MasMatM
                      MasMat
                      wrote on last edited by MasMat
                      #28
                      @jogant Finally had time to double check this:
                      Paper UI:
                      Broker Name
                      mosquitto
                      Subscription Topic
                      mygateway1-out
                      Publish Topic
                      mygateway1-in
                      Send Delay 100
                      Startup check enabled
                      Metric answer enabled
                      Network sanity check enabled
                      Interval to launch network sanity check 3
                      Attempts before disconnecting the bridge 3
                      Heartbeat disabled
                      Attempts before disconnecting nodes 10
                      EDIT: I noticed I have different topics in MQTT, corrected AND I did:
                      cd /usr/share/openhab2/addons/
                      wget http://www.oberfoell.com/openhab2/org.openhab.binding.mysensors-2.4.0-SNAPSHOT.jar   <== THIS probably  fixed it!
                      chown for the same file
                      rm org.openhab.binding.mysensors-2.3.0-SNAPSHOT.jar
                      Now my MQTT Gw is ONLINE, in Paper UI I just selected the bridge for every individual Thing and now it works.
                      Hope this helps people strugling with this.
                      G 1 Reply Last reply
                      • EuromirE
                        EuromirE
                        Euromir
                        Hi
                        I want to set this up, but have openHAB already setup and running MQTT using the binding installed in paperui, whereas you say dont use that?
                        Suggestions? With devices already working well on MQTT currently i want to follow this great, but dont wish to break what i have already working?
                        • I
                          I
                          itbeyond
                          @TimO Thanks for the excellent work with the binding.
                          I have just got this all running on OH2.3 using mosquito and mqtt mysensors using a Mega 2560. I am migration from a Vera to openHab and have around 20+ mysensors nodes from 1 to 8 devices on each. So this is a significant task. Anyway I am also newish to OH so have a few questions if I may.
                          • Is it better to go via MQTT or Ethernet Bridge - on Vera I am using Ethernet my new Gateway using the Mega (as pro mini not enough ram to run security) can be either so is there a preference for either of these?
                          • Is it worth using PaperUI vs Items files for configuration. I am leaning to items files as I am working with Persistance and some complex rules for device control. I have the binding learning nodes during a reboot in PaperUI these are working but I am confused how to build everything outside of the json DB files or even if I should?
                          • Can MYSController be used somehow in this configuration either MQTT or Ethernet for OTA. At the moment I run this on a PC and connect to the Ethernet gateway do my updates and then let Vera have the gateway back. Is there a better way to link this using openHab?
                          Sorry for the questions but if you never ask you never learn - thanks.
                          David
                          F 1 Reply Last reply
                          • I itbeyond
                            David
                            F
                            F
                            fredswed
                            @itbeyond As always your mileage will vary depending on experience and goals.
                            Disclaimer: I only have a couple of MYS-sensors and a small OpenHAB installation for sensing and remote light control. OpenHAB is a complex system so it takes time to master. Fortunately it also has great support and I really like it for its flexiblity, power and structure.
                            • MQTT or ethernet bridge? I've tried both but never got MQTT to work. Based on the questions in the MYS forums I believe it is easier to use the ethernet connection. I find it easier to troubleshoot. You can start with the ethernet bridge to ensure everything works. Then you can easily switch to the MQTT setup if there are advantages for you. But unless you have other applications that also listen to the MYS messages, I can't really see any obvious reasons to use MQTT. (Of course, it may give you a warm, fuzzy feeling of having an all-MQTT sensor network.)
                            • Definitely go for config files. Autodiscovery is neat but there are many things you can't do in PaperUI or that are very difficult to do there. In config files you can also add comments to explain to your future self why you did something.
                              You can try autodiscovery and PaperUI first if you like and then move to config files. Then you may want to check out the OpenHAB forums on how to manually clear the cache. Sometimes the OH cache is a bit too clever for itself.
                            • As I understand it, OTA is not supported by any MQTT controller. It is also not supported by OpenHAB. If you use the ethernet bridge you can keep your current ways of working - sensing and control in OpenHAB and update OTA via MYSController. If I'm not mistaken you only have to configure the MYS gw to accept at least two connections.
                            You seem to know your way around OH already, but I will add a few general comments for beginners, based on my own experience with OpenHAB (as a non-developer):
                            • First step is to set up backup and restore. Then test that it really works the way you intended.
                            • Use the production release of OpenHAB unless you really need the bleeding edge. It can be very time consuming to revert from a beta/snapshot release to the production release.
                            • Spend some time setting up OpenHAB and software around it so you can easily edit the config files. I use Openhabian which automatically shares all interesting files using Samba. It is then trivial to connect from my desktop and edit with my favourite editor. (MS Code has great support for OpenHAB config files.)
                            • Spend some time on how to properly backup and restore OpenHAB so you can experiment freely and still easily revert if it crashes.
                            • The OH forum is your friend. It is even more true than for MYS.
                              E.g. check out the advice on how to name (and not name) your config files, things and items.
                              and the OH patterns that provides beatiful solutions for many "impossible" problems.
                            • Did I mention backup and restore? At least archive your config directory regularely.
                            /Fredrik
                            I 1 Reply Last reply
                            • F fredswed
                              /Fredrik
                              I
                              I
                              itbeyond
                              @fredswed thanks for your comments. I have gone with Ethernet gateway as it works well and at this stage I do not need MQTT - maybe if I play with node-red or something down the track but for the moment happy with Ethernet - it just works. I did have MQTT working but the MYSController connection is a possible problem.
                              I have also gone to the config files directly and have worked out the bridge setup in the things file and have a few test items running.
                              Yes backups - done that and have my system backing up to a local NAS box.
                              Cheers David
                              • MasMatM
                                MasMatM
                                MasMat
                                #33
                                I need a fresh set of eyes on my problem.
                                Gateway is online, but things are not discovered. I have tried adding them manually (my syntax could be wrong), but it doesn't help.
                                There are no errors in mysgw.log-file.
                                Mosquitto mysensors-out:
                                mysensors-out/1/14/1/0/23 35
                                mysensors-out/1/15/1/0/0 49
                                mysgw.things:
                                Bridge mysensors:bridge-mqtt:mygateway1 [brokerName="mosquitto",
        topicPublish="mysensors-in",
        topicSubscribe="mysensors-out",
                                  temperature BoilerTemp [nodeID=1, childId=15]
                                  motion PukuhLiike [nodeID=1, childId=3]
                                default.items:
                                Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:temperature_1_15:temp"}
                                Contact PukuhLiike "Pukuhuone Liike" <motion> {channel="mysensors:motion:mygateway1:motion_1_3:tripped"}
                                OpenHab2 frontail:
                                2018-08-13 22:34:03.284 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid paho111686078117 and file store '/var/lib/openhab2/mqtt/127.0.0.1'
                                2018-08-13 22:34:05.499 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
                                2018-08-13 22:34:11.928 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Helsinki'.
                                2018-08-13 22:34:11.999 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'fi'.
                                2018-08-13 22:34:20.211 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.51:8080
                                2018-08-13 22:34:20.317 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.51:8443
                                2018-08-13 22:35:16.502 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
                                2018-08-13 22:35:34.984 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
                                2018-08-13 22:35:38.657 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mys.things'
                                2018-08-13 22:35:39.245 [.ItemChannelLinkAddedEvent] - Link 'PukuhLiike-mysensors:motion:mygateway1:motion_1_3:tripped' has been added.
                                2018-08-13 22:35:39.309 [.ItemChannelLinkAddedEvent] - Link 'BoilerTemp-mysensors:temperature:mygateway1:temperature_1_15:temp' has been added.
                                2018-08-13 22:36:14.848 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
                                2018-08-13 22:36:18.741 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
                                2018-08-13 22:36:22.407 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
                                2018-08-13 22:36:25.610 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from UNINITIALIZED to INITIALIZING
                                2018-08-13 22:36:26.660 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                                2018-08-13 22:36:26.861 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED to UNINITIALIZED (BRIDGE_UNINITIALIZED)
                                2018-08-13 22:36:27.453 [hingStatusInfoChangedEvent] - 'mysensors:bridge-mqtt:mygateway1' changed from INITIALIZING to ONLINE
                                2018-08-13 22:36:27.546 [INFO ] [rotocol.mqtt.MySensorsMqttConnection] - Successfully connected to MySensors Bridge.
                                2018-08-13 22:36:28.075 [hingStatusInfoChangedEvent] - 'mysensors:temperature:mygateway1:BoilerTemp' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
                                2018-08-13 22:36:28.120 [hingStatusInfoChangedEvent] - 'mysensors:motion:mygateway1:PukuhLiike' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to UNINITIALIZED (HANDLER_CONFIGURATION_PENDING)
                                In my addons I have the 2.4.0 Snapshot.
                                name=mosquitto
                                host=127.0.0.1
                                secure=false
                                port=1883
                                username=XXXX
                                password=YYYYY
                                retain=false
                                clientId=openhabian
                                EDIT: After a week of trying things. This worked: https://forum.mysensors.org/post/73600
                                No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up :( ), but it's not updating the values.
                                • MasMatM MasMat
                                  mysgw.things:
                                  default.items:
                                  OpenHab2 frontail:
                                  name=mosquitto
                                  host=127.0.0.1
                                  secure=false
                                  port=1883
                                  username=XXXX
                                  password=YYYYY
                                  retain=false
                                  clientId=openhabian
                                  TimO
                                  @masmat said in Getting MySensors MQTT Gateway working on OpenHAB 2.2 (Stable):
                                  No autodiscovery, but this switches my sensors ONLINE (even ones that are not powered up ), but it's not updating the values.
                                  Autodiscovery should work. :confused:
                                  Does the temperature thing in OH2 get updates? Is it working?
                                  The sensors will show up ONLINE if the connection to the broker is established, because the sensors are just a topic. There is at the moment no implementation to check if the sensors/things are really available. This could be done, but it is not implemented yet.
                                  • T TimO
                                    MasMatM
                                    MasMatM
                                    MasMat
                                    #35
                                    @timo Before I did the re-install of everything autodiscovery was working, but now it isn't. Current sys: RpiZeroW, Openhabian 2.3.0-1release, mosquitto.
                                    The temperature is not updating in OH2. But the mysensors-out topic does show the gateway sending the values out. OH2 is not listening for some reason...
                                    Re-install some (which?) parts or bindings? Openhab2 mqtt-binding?
                                    Permissions?
                                    • T
                                      TimO
                                      Needs to be changed to:
                                      Number BoilerTemp "Lämminvesivaraaja [%.1f °C]" <heating> {channel="mysensors:temperature:mygateway1:BoilerTemp:temp"}
                                      But there is something additionally amiss, because discovery is not working.
                                      Please enable debug in the OH2 console and post the output of the initialization.
                                      Don't spend time reinstalling, this looks like a configuration issue.
                                      • T TimO
                                        MasMatM
                                        MasMatM
                                        MasMat
                                        @timo Firstly, I am very thankful for your help.
                                        I changed that item and it started receiving values! I think there's something wrong with my light-level sensor's syntax too.
                                        In console I did: log:set DEBUG.
                                        That prints out hundreds and hundreds of lines....should I narrow the search somehow?
                                        • MasMatM MasMat
                                          TimO
                                          @masmat I'm glad the first sensor is updating now. Please post the the thing and item definition of the light sensor and I'll look at it.
                                          I only need the debug output from the binding so please use:
                                          log:set DEBUG org.openhab.binding.mysensors
