  3. DHT12 + 2Relay + 2Button - Combining Problem
14 Posts 3 Posters 3.1k Views 4 Watching
  • rejoe2R
    rejoe2R
    rejoe2
    Question: First all worked well, until you added the code for the DHT?
    IMO, the
      wait(UPDATE_INTERVAL);
    part blocks the entire code for most of the time. You should instead use a non-blocking loop structure using millis(). See the https://www.mysensors.org/build/pulse_power example (follow the path, when "#define SLEEP_MODE true" is used).
    michlb1982M 1 Reply Last reply
    • rejoe2R rejoe2
      IMO, the
      michlb1982M
      michlb1982M
      michlb1982
      @rejoe2
      thanks for the link.. i will try... and report if it worked..
      • michlb1982M
        michlb1982M
        michlb1982
        Hello again.. long time ago.. but still here. ;-)
        well thankss for the tip... but now i have a other problem...
        the relay will work when the order comes from the gateway ... but when i press the button, nothing happens...
        any ideas?
        here the code:
        #define MY_REPEATER_FEATURE
        // Define Node ID
        #define MY_NODE_ID 101
        #define RELAY_ON 1
        #define RELAY_OFF 0
        #define SSR_A_ID 1   // Id of the sensor child
        #define SSR_B_ID 2   // Id of the sensor child
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 0//1
        #define SENSOR_TEMP_OFFSET 0
        #include <DHT12.h>
        const int buttonPinA = 7;
        const int buttonPinB = 8;
        const int relayPinA = 6;
        const int relayPinB = 5;
        int oldValueA = 0;
        int oldValueB = 0;
        bool stateA = false;
        bool stateB = false;
        float lastTemp;
        float lastHum;
        uint8_t nNoUpdatesTemp;
        uint8_t nNoUpdatesHum;
        bool metric = true;
        static const uint8_t FORCE_UPDATE_N_READS = 10;//10
        static const uint64_t UPDATE_INTERVAL = 30000;//30000
        Bounce debouncerA = Bounce();
        Bounce debouncerB = Bounce();
        MyMessage msgA(SSR_A_ID, V_STATUS);
        MyMessage msgB(SSR_B_ID, V_STATUS);
        DHT12 dht12;
          //Serial.begin(115200);
          Wire.begin();
          pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
          pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
          // After setting up the buttons, setup debouncer
          debouncerA.attach(buttonPinA);
          debouncerA.interval(5); //5
          debouncerB.attach(buttonPinB);
          debouncerB.interval(5);//5
          digitalWrite(relayPinA, RELAY_OFF);
          digitalWrite(relayPinB, RELAY_OFF);
          pinMode(relayPinA, OUTPUT);
          pinMode(relayPinB, OUTPUT);
        void presentation()  {
          sendSketchInfo("2xRelais,2xButton,DHT12", "1.2");
          present(SSR_A_ID, S_LIGHT);
          present(SSR_B_ID, S_LIGHT);
          present(CHILD_ID_HUM, S_HUM);
          debouncerA.update();
          // Get the update value
          int valueA = debouncerA.read();
          if (valueA != oldValueA) {
            send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
          oldValueA = valueA;
          debouncerB.update();
          int valueB = debouncerB.read();
          if (valueB != oldValueB) {
            send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
          oldValueB = valueB;
        //  dht12.readSensor(true);
          float temperature = dht12.readTemperature();
          if (isnan(temperature)) {
            lastTemp = temperature;
            // apply the offset before converting to something different than Celsius degrees
            if (!metric) {
            // Reset no updates counter
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
            Serial.print("T: ");
            nNoUpdatesTemp++;
          float humidity = dht12.readHumidity();
          if (isnan(humidity)) {
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
            Serial.print("H: ");
            Serial.println(humidity);
            nNoUpdatesHum++;
            switch (message.sensor) {
              case 1:
                stateA = message.getBool();
                digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
              case 2:
                stateB = message.getBool();
                digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
            //Serial.print("from node:");
            //Serial.println(message.sender);
            //Serial.print(", New status: ");
        • michlb1982M michlb1982
          any ideas?
          here the code:
          // Define Node ID
          #define RELAY_ON 1
          #define RELAY_OFF 0
          #include <DHT12.h>
          int oldValueA = 0;
          int oldValueB = 0;
          float lastTemp;
          float lastHum;
          bool metric = true;
          DHT12 dht12;
            Wire.begin();
            oldValueA = valueA;
            oldValueB = valueB;
              if (!metric) {
              nNoUpdatesTemp = 0;
              #ifdef MY_DEBUG
              nNoUpdatesTemp++;
              lastHum = humidity;
              nNoUpdatesHum = 0;
              #ifdef MY_DEBUG
              nNoUpdatesHum++;
                case 1:
                case 2:
          @michlb1982 there are no digitalWrite commands in the loop. Withiut digitalWrite, there will be no changes to the relay.
          • michlb1982M
            michlb1982M
            michlb1982
            @mfalkvidd you are right, but in the original Relay-Scetch there is also no digitalWrite command in the loop-section... https://www.mysensors.org/build/relay
            only in the viod receive message section is a digitalwrite command....
            there is also another problmem...sometimes (i can't say when) there is the RElay not working or works lately.. .maybe it is when the DHT is measuring? i can't explain...
              @michlb1982 yes you are right, sorry for the confusion. The relay will be switched when the node receives ack for the outgoing message.
              Looking at the debug logs (from node and gateway) will probably be the quickest way to figure out what is wrong.
              • michlb1982M
                michlb1982M
                michlb1982
                well i can't find anything strange in the node debug messages..
                90243 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:35.541 -> Incoming change for sensor:2
                08:25:35.541 -> 1
                92163 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:37.478 -> Incoming change for sensor:1
                08:25:37.478 -> 0
                92843 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:38.139 -> Incoming change for sensor:2
                08:25:38.139 -> 0
                93059 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:38.375 -> Incoming change for sensor:2
                08:25:38.375 -> 1
                93458 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:38.769 -> Incoming change for sensor:2
                08:25:38.769 -> 0
                93674 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:38.963 -> Incoming change for sensor:2
                08:25:39.003 -> 1
                94012 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:39.315 -> Incoming change for sensor:2
                08:25:39.315 -> 0
                94229 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:39.524 -> Incoming change for sensor:2
                08:25:39.557 -> 1
                94721 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:40.049 -> Incoming change for sensor:2
                08:25:40.049 -> 0
                94893 TSF:MSG:SEND,101-101-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:23.5
                08:25:40.213 -> T: 23.50
                94973 TSF:MSG:SEND,101-101-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:40.6
                08:25:40.284 -> H: 40.60
                08:25:40.284 -> 94981 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:40.284 -> Incoming change for sensor:2
                08:25:40.284 -> 1
                95182 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                08:25:40.495 -> Incoming change for sensor:2
                08:25:40.495 -> 0
                95396 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:40.702 -> Incoming change for sensor:2
                08:25:40.702 -> 1
                97184 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:42.505 -> Incoming change for sensor:1
                08:25:42.505 -> 1
                97225 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                08:25:42.547 -> Incoming change for sensor:1
                08:25:42.547 -> 1
                and the acting time delay is only sometimes... i don't know jet how to reproduce it....
                ok with the time delay i can live... but the buttons would be great if the could work...
                any ideas left?
                  08:25:35.541 -> 1
                  08:25:37.478 -> 0
                  08:25:38.139 -> 0
                  08:25:38.375 -> 1
                  08:25:38.769 -> 0
                  08:25:39.003 -> 1
                  08:25:39.315 -> 0
                  08:25:39.557 -> 1
                  08:25:40.049 -> 0
                  08:25:40.284 -> 1
                  08:25:40.495 -> 0
                  08:25:40.702 -> 1
                  08:25:42.505 -> 1
                  08:25:42.547 -> 1
                  any ideas left?
                  @michlb1982 when/how many times did you press the button?
                  There are no send commands in the log, so the button press was never registered.
                  • mfalkviddM
                    Now I see. During the 30 second wait, no button presses will be registered. You’ll need to use interrupts, or modify the code to not use wait/sleep in the loop.
                    This is what rejoe2 mentioned in https://forum.mysensors.org/post/93454
                    • michlb1982M
                      michlb1982M
                      michlb1982
                      @mfalkvidd you are so right!!! the "wait" is the problem... i changed the script.. i use a if to check if the update-interval is over and then i go through the dht loop....
                      now the bounce are also working..!
                      here my code...
                      //#define MY_REPEATER_FEATURE
                      // Define Node ID
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      #include <DHT12.h>
                      int oldValueA = 0;
                      int oldValueB = 0;
                      unsigned long startMillis;
                      unsigned long currentMillis;
                      float lastTemp;
                      float lastHum;
                      bool metric = true;
                      DHT12 dht12;
                        Wire.begin();
                        digitalWrite(relayPinA, RELAY_ON);
                        digitalWrite(relayPinB, RELAY_ON);
                        sendSketchInfo("2xRelais,2xButton,DHT12", "1.2a");
                        currentMillis = millis();
                        oldValueA = valueA;
                        oldValueB = valueB;
                        if (currentMillis - startMillis >= UPDATE_INTERVAL)
                          if (!metric) {
                          nNoUpdatesTemp = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesTemp++;
                          lastHum = humidity;
                          nNoUpdatesHum = 0;
                          #ifdef MY_DEBUG
                          nNoUpdatesHum++;
                        startMillis = currentMillis;
                        Serial.print("Startzeit: ");
                        Serial.println(startMillis);
                        //wait(UPDATE_INTERVAL);
                            case 1:
                            case 2:
                        here my code...
                        // Define Node ID
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        #include <DHT12.h>
                        int oldValueA = 0;
                        int oldValueB = 0;
                        float lastTemp;
                        float lastHum;
                        bool metric = true;
                        DHT12 dht12;
                          Wire.begin();
                          oldValueA = valueA;
                          oldValueB = valueB;
                            if (!metric) {
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                            nNoUpdatesHum++;
                              case 1:
                              case 2:
                        @michlb1982 great work, thanks for reporting back
                        • rejoe2R
                          rejoe2R
                          rejoe2
                          @michlb1982 Congratulations also from my side :smile: !
                          One additional remark: In case you want to use more relays and buttons, you may hav a closer look to the use of array functions. Good, but rather complex example: https://forum.mysensors.org/post/51488
