  3. DHT12 + 2Relay + 2Button - Combining Problem
14 Posts 3 Posters 2.9k Views 4 Watching
  • M Offline
    M Offline
    michlb1982
    wrote on last edited by michlb1982
    Hello
    I tried to combine a DHT12 + 2 Relay incl. Buttons.
    ![alt text](0_1536489069705_SENS-DHT-12.JPG image url)
    Well it works (somtimes longer.. sometimes not..), i combined the Scetches of both but often i have the problme, that the Relays don't act anymore and the buttons didn't either since the beginning...
    i found something on google that i have to change the sleep to wait command so it works little better but after some time it also even quits working.
    what is my mistake???
    #define MY_REPEATER_FEATURE
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 0//1
    #define SENSOR_TEMP_OFFSET 0
    #include <DHT12.h>
    const int buttonPinA = 7;
    const int buttonPinB = 8;
    const int relayPinA = 6;
    const int relayPinB = 5;
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    static const uint8_t FORCE_UPDATE_N_READS = 10;//10
    static const uint64_t UPDATE_INTERVAL = 30000;//30000
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage msgB(SSR_B_ID, V_STATUS);
    DHT12 dht12;
      //Serial.begin(115200);
      Wire.begin();
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5); //5
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);//5
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
    void presentation()  {
      sendSketchInfo("2xRelais,2xButton,DHT12", "1.2");
      present(SSR_A_ID, S_LIGHT);
      present(SSR_B_ID, S_LIGHT);
      present(CHILD_ID_HUM, S_HUM);
      debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA) {
        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
      oldValueA = valueA;
      debouncerB.update();
      int valueB = debouncerB.read();
      if (valueB != oldValueB) {
        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
      oldValueB = valueB;
    //  dht12.readSensor(true);
      float temperature = dht12.readTemperature();
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        nNoUpdatesTemp++;
      float humidity = dht12.readHumidity();
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
        nNoUpdatesHum++;
      wait(UPDATE_INTERVAL);
        switch (message.sensor) {
          case 1:
            stateA = message.getBool();
            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
          case 2:
            stateB = message.getBool();
            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
        //Serial.print("from node:");
        //Serial.println(message.sender);
        //Serial.print(", New status: ");
    Thanks for help!
    • M michlb1982
      Hello
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #include <DHT12.h>
      int oldValueA = 0;
      int oldValueB = 0;
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT12 dht12;
        Wire.begin();
        oldValueA = valueA;
        oldValueB = valueB;
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
          nNoUpdatesHum++;
            case 1:
            case 2:
      Thanks for help!
      mfalkviddM Online
      mfalkviddM Online
      @michlb1982 what does the debug log say?
      • rejoe2R Offline
        rejoe2R Offline
        rejoe2
        Question: First all worked well, until you added the code for the DHT?
        IMO, the
        part blocks the entire code for most of the time. You should instead use a non-blocking loop structure using millis(). See the https://www.mysensors.org/build/pulse_power example (follow the path, when "#define SLEEP_MODE true" is used).
        • rejoe2R rejoe2
          IMO, the
          M Offline
          M Offline
          michlb1982
          @rejoe2
          thanks for the link.. i will try... and report if it worked..
          • M Offline
            M Offline
            michlb1982
            Hello again.. long time ago.. but still here. ;-)
            well thankss for the tip... but now i have a other problem...
            the relay will work when the order comes from the gateway ... but when i press the button, nothing happens...
            any ideas?
            here the code:
            // Define Node ID
            #define MY_NODE_ID 101
            #define RELAY_ON 1
            #define RELAY_OFF 0
            #include <DHT12.h>
            int oldValueA = 0;
            int oldValueB = 0;
            float lastTemp;
            float lastHum;
            bool metric = true;
            DHT12 dht12;
              Wire.begin();
              oldValueA = valueA;
              oldValueB = valueB;
                if (!metric) {
                nNoUpdatesTemp = 0;
                #ifdef MY_DEBUG
                nNoUpdatesTemp++;
                lastHum = humidity;
                nNoUpdatesHum = 0;
                #ifdef MY_DEBUG
                nNoUpdatesHum++;
                  case 1:
                  case 2:
            • M michlb1982
              any ideas?
              here the code:
              // Define Node ID
              #define RELAY_ON 1
              #define RELAY_OFF 0
              #include <DHT12.h>
              int oldValueA = 0;
              int oldValueB = 0;
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT12 dht12;
                Wire.begin();
                oldValueA = valueA;
                oldValueB = valueB;
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                  nNoUpdatesHum++;
                    case 1:
                    case 2:
              mfalkviddM Online
              mfalkviddM Online
              @michlb1982 there are no digitalWrite commands in the loop. Withiut digitalWrite, there will be no changes to the relay.
              • M Offline
                M Offline
                michlb1982
                @mfalkvidd you are right, but in the original Relay-Scetch there is also no digitalWrite command in the loop-section... https://www.mysensors.org/build/relay
                only in the viod receive message section is a digitalwrite command....
                there is also another problmem...sometimes (i can't say when) there is the RElay not working or works lately.. .maybe it is when the DHT is measuring? i can't explain...
                • M michlb1982
                  mfalkviddM Online
                  mfalkviddM Online
                  @michlb1982 yes you are right, sorry for the confusion. The relay will be switched when the node receives ack for the outgoing message.
                  Looking at the debug logs (from node and gateway) will probably be the quickest way to figure out what is wrong.
                  • M Offline
                    M Offline
                    michlb1982
                    well i can't find anything strange in the node debug messages..
                    90243 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:35.541 -> Incoming change for sensor:2
                    08:25:35.541 -> 1
                    92163 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:37.478 -> Incoming change for sensor:1
                    08:25:37.478 -> 0
                    92843 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:38.139 -> Incoming change for sensor:2
                    08:25:38.139 -> 0
                    93059 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:38.375 -> Incoming change for sensor:2
                    08:25:38.375 -> 1
                    93458 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:38.769 -> Incoming change for sensor:2
                    08:25:38.769 -> 0
                    93674 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:38.963 -> Incoming change for sensor:2
                    08:25:39.003 -> 1
                    94012 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:39.315 -> Incoming change for sensor:2
                    08:25:39.315 -> 0
                    94229 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:39.524 -> Incoming change for sensor:2
                    08:25:39.557 -> 1
                    94721 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:40.049 -> Incoming change for sensor:2
                    08:25:40.049 -> 0
                    94893 TSF:MSG:SEND,101-101-0-0,s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:23.5
                    08:25:40.213 -> T: 23.50
                    94973 TSF:MSG:SEND,101-101-0-0,s=0,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=OK:40.6
                    08:25:40.284 -> H: 40.60
                    08:25:40.284 -> 94981 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:40.284 -> Incoming change for sensor:2
                    08:25:40.284 -> 1
                    95182 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:0
                    08:25:40.495 -> Incoming change for sensor:2
                    08:25:40.495 -> 0
                    95396 TSF:MSG:READ,0-0-101,s=2,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:40.702 -> Incoming change for sensor:2
                    08:25:40.702 -> 1
                    97184 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:42.505 -> Incoming change for sensor:1
                    08:25:42.505 -> 1
                    97225 TSF:MSG:READ,0-0-101,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                    08:25:42.547 -> Incoming change for sensor:1
                    08:25:42.547 -> 1
                    and the acting time delay is only sometimes... i don't know jet how to reproduce it....
                    ok with the time delay i can live... but the buttons would be great if the could work...
                    any ideas left?
                    • M michlb1982
                      08:25:35.541 -> 1
                      08:25:37.478 -> 0
                      08:25:38.139 -> 0
                      08:25:38.375 -> 1
                      08:25:38.769 -> 0
                      08:25:39.003 -> 1
                      08:25:39.315 -> 0
                      08:25:39.557 -> 1
                      08:25:40.049 -> 0
                      08:25:40.284 -> 1
                      08:25:40.495 -> 0
                      08:25:40.702 -> 1
                      08:25:42.505 -> 1
                      08:25:42.547 -> 1
                      any ideas left?
                      mfalkviddM Online
                      mfalkviddM Online
                      @michlb1982 when/how many times did you press the button?
                      There are no send commands in the log, so the button press was never registered.
                      • mfalkviddM Online
                        mfalkviddM Online
                        Now I see. During the 30 second wait, no button presses will be registered. You’ll need to use interrupts, or modify the code to not use wait/sleep in the loop.
                        This is what rejoe2 mentioned in https://forum.mysensors.org/post/93454
                        • M Offline
                          M Offline
                          michlb1982
                          @mfalkvidd you are so right!!! the "wait" is the problem... i changed the script.. i use a if to check if the update-interval is over and then i go through the dht loop....
                          now the bounce are also working..!
                          here my code...
                          //#define MY_REPEATER_FEATURE
                          // Define Node ID
                          #define RELAY_ON 1
                          #define RELAY_OFF 0
                          #include <DHT12.h>
                          int oldValueA = 0;
                          int oldValueB = 0;
                          unsigned long startMillis;
                          unsigned long currentMillis;
                          float lastTemp;
                          float lastHum;
                          bool metric = true;
                          DHT12 dht12;
                            Wire.begin();
                            digitalWrite(relayPinA, RELAY_ON);
                            digitalWrite(relayPinB, RELAY_ON);
                            sendSketchInfo("2xRelais,2xButton,DHT12", "1.2a");
                            currentMillis = millis();
                            oldValueA = valueA;
                            oldValueB = valueB;
                            if (currentMillis - startMillis >= UPDATE_INTERVAL)
                              if (!metric) {
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                              nNoUpdatesHum++;
                            startMillis = currentMillis;
                            Serial.print("Startzeit: ");
                            Serial.println(startMillis);
                            //wait(UPDATE_INTERVAL);
                                case 1:
                                case 2:
                          • M michlb1982
                            here my code...
                            // Define Node ID
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            #include <DHT12.h>
                            int oldValueA = 0;
                            int oldValueB = 0;
                            float lastTemp;
                            float lastHum;
                            bool metric = true;
                            DHT12 dht12;
                              Wire.begin();
                              oldValueA = valueA;
                              oldValueB = valueB;
                                if (!metric) {
                                nNoUpdatesTemp = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesTemp++;
                                lastHum = humidity;
                                nNoUpdatesHum = 0;
                                #ifdef MY_DEBUG
                                nNoUpdatesHum++;
                                  case 1:
                                  case 2:
                            mfalkviddM Online
                            mfalkviddM Online
                            @michlb1982 great work, thanks for reporting back
                            • rejoe2R Offline
                              rejoe2R Offline
                              rejoe2
                              @michlb1982 Congratulations also from my side :smile: !
                              One additional remark: In case you want to use more relays and buttons, you may hav a closer look to the use of array functions. Good, but rather complex example: https://forum.mysensors.org/post/51488
                              12.1k
