  2. Announcements
  • K kted
    Has the issue with RFM automatic transmission control been addressed?
    R
    R
    Rolo6442u
    wrote on last edited by Rolo6442u
    #982
    @kted Can you give me a pointer to the details of this issue? I'm willing to do some tests and report back my findings. Some info about my configuration, I have 5 nodes at this moment, all battery feeded, they are sending only nodes. They all work but they have a interval of several minutes between sending. The gateway is connected to Domoticz running on another Raspberry PI.
    K 1 Reply Last reply
    • R Rolo6442u
      K
      K
      kted
      wrote on last edited by kted
      #983
      @rolo6442u I built an Raspberry gateway using an RFM69 radio, to replace one built around a NodeMCU.
      All nodes are transmit only, and using the latest stable API.
      I noticed that all sensors were using max TX power after the first couple of transmissions, although they were respecting the ATC setting before, and were using minimum power most of the time.
      Now I am concerned about battery life, so I switched back to the NodeMCU gateway, waiting for a fix.
      I'll put together a temporary net, with a RPi0 gateway and a single node later, to show some real data, if you need any more information.
      R mfalkviddM 2 Replies Last reply
      • K kted
        R
        R
        Rolo6442u
        #984
        @kted I wil do some tests to check if I see this behavior. Just build a simple test node with a pushbutton, on 2 AA batteries. This node has the low power W radio module. How did you discover/measure that the max TX power was used?
        • K kted
          @kted could be the same problem as discussed in https://forum.mysensors.org/topic/9796/rfm69-atc-not-working/
          • R Rolo6442u
            K
            K
            kted
            @rolo6442u From what the node itself reports from transportGetSignalReport(SR_TX_POWER_PERCENT). It starts from say 50%, and after a coule of transmissions it goes up to 100%, when the nodes are 1m apart. When using a stand alone ESP8266 gateway, it drops to 0%.
            I'll have the nodes ready in a couple of hours, after I come home from work...
            • R
              R
              Rolo6442u
              Did some tests and I do see the TX power climbing to 100% after a few transmits :
              -42 :transportGetReceivingRSSI()
              127 :transportGetSendingRSSI()
              -256 :transportGetReceivingSNR()
              -256 :transportGetSendingSNR()
              6 :transportGetTxPowerLevel()
              77 :transportGetTxPowerPercent()
              0 :transportInternalToRSSI(_transportSM.uplinkQualityRSSI)
              -46 :transportGetReceivingRSSI()
              -102 :transportGetSendingRSSI()
              7 :transportGetTxPowerLevel()
              80 :transportGetTxPowerPercent()
              -47 :transportGetReceivingRSSI()
              10 :transportGetTxPowerLevel()
              90 :transportGetTxPowerPercent()
              -105 :transportGetSendingRSSI()
              11 :transportGetTxPowerLevel()
              93 :transportGetTxPowerPercent()
              -103 :transportGetSendingRSSI()
              13 :transportGetTxPowerLevel()
              100 :transportGetTxPowerPercent()
              -106 :transportGetSendingRSSI()
              Not sure if this has a great impact on battery life, depends on how often the node sends a message. Al my nodes have an interval of about 10 minutes. I leave the gateway running for now. Having it running on this PI is a great advantage for me. Will try to do some current measurement on this node and calculate what the impact is on battery life.
              • B barrydou
                Hello
                Is it possible to redefine pin used for DI00 with rfm69 (with configure option for example) ?
                Indeed, DI00 is on pin 22 on raspberry, and pin 2 on arduino.
                But with NRF, pin 2 on arduino is for IRQ, which is connected to pin 15 on raspberry.
                So if it was possible to force pin 15 for DI00, we could use adaptator card like this one https://www.mysensors.org/hardware/nrf2rfm69.
                @barrydou I gave a double gateway running on my raspberry both nrf24 and rfm69, still on v. 2.2
                  K
                  K
                  kted
                  @gohan Nice. I was thinking to do that same at some time, but I wasn't sure if the Raspberry could handle the load, since I also run domoticz on it, along with pi-hole.
                  How many devices do you have on each gateway?
                    I got the same, domoticz and pi hole, but the load of the gateway is minimal
                      K
                      K
                      kted
                      @gohan I meant multiple gateways on the same raspberry.
                      Right now, I have an NRF24L01 gateway, Domoticz, pi-hole, and a VPN server running, with 2 more gateways connected, one local and one remote RFM69 on ESP8266.
                      It would be nice if I could combine the two local gateways, the RFM and the NRF on the same Raspberry's GPIO...
                        Yes, I have both radios on the same raspberry.
                        • MasMatM
                          MasMatM
                          MasMat
                          wrote on last edited by MasMat
                          #993
                          More problems when I try to "make" after configuring. Tried with and without sudo...
                          dietpi@Domoticz:~/MySensors$ sudo make
                          gcc -MT build/hal/architecture/Linux/drivers/core/log.o -MMD -MP -march=armv6zk -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard -DMY_SIGNING_SIMPLE_PASSWD=\"ZZZZZZZ\" -DMY_RADIO_RF24 -DMY_GATEWAY_LINUX -DMY_GATEWAY_MQTT_CLIENT -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_LINUX_CONFIG_FILE=\"/etc/mysensors.conf\" -DMY_DEFAULT_TX_LED_PIN=18 -DMY_DEFAULT_RX_LED_PIN=16 -DMY_DEFAULT_ERR_LED_PIN=12 -DMY_MQTT_CLIENT_ID=\"mygateway1\" -DMY_MQTT_SUBSCRIBE_TOPIC_PREFIX=\"mysensors-in\" -DMY_MQTT_PUBLISH_TOPIC_PREFIX=\"mysensors-out\" -DMY_MQTT_PASSWORD=\"YYYYY\" -DMY_MQTT_USER=\"XXXX\" -DMY_CONTROLLER_IP_ADDRESS=127,0,0,1 -DMY_DEBUG_VERBOSE_SIGNING -DMY_RX_MESSAGE_BUFFER_FEATURE -DMY_RF24_IRQ_PIN=15  -Ofast -g -Wall -Wextra  -I. -I./core -I./hal/architecture/Linux/drivers/core -I./hal/architecture/Linux/drivers/BCM -c hal/architecture/Linux/drivers/core/log.c -o build/hal/architecture/Linux/drivers/core/log.o
                          In file included from hal/architecture/Linux/drivers/core/log.c:20:0:
                          hal/architecture/Linux/drivers/core/log.h:24:19: fatal error: stdio.h: File not found
                           #include <stdio.h>
                          compilation terminated.
                          Makefile:102: recipe for target 'build/hal/architecture/Linux/drivers/core/log.o' failed
                          make: *** [build/hal/architecture/Linux/drivers/core/log.o] Error 1
                          EDIT: ...and here's the fix: "sudo apt-get install g++" (I'm using DietPi now to make it lighter for Pi Zero W).
                          • cozaC
                            cozaC
                            coza
                            wrote on last edited by coza
                            #994
                            Running Version 2.3.2-beta just cloned today. On a raspberry pi B rev2.
                            A little bug/problem I have discovered with the MQTT gateway.
                            When you run the gateway with command and switch:-
                            mysgw -c /etc/mysensors.conf
                            It segfaults.
                            When its run with the command and switch :-
                            mysgw --config-file /etc/mysensors.conf
                            It works fine
                            I was playing with the ethernet gateway compile and the -c worked fine.
                            • cozaC
                              cozaC
                              coza
                              #995
                              Another thing I have found is I cannot get any logging working with the mqqt gateway compile.
                              It worked fine (named pipe) with the ethernet gateway compile.
                              Edit
                              It seems logging with the mqtt is not instant. It seem to dump the log out of memory periodically, is this expected? Makes it a bit hard to debug real-time.
                                Just use mqtt client
                                • cozaC coza
                                  Edit
                                  #997
                                  @coza I have experienced that the raspberry pigateway does not flush the logs immediately when logging to file. Syslog logs immediately though. See if switching to syslog helps.
                                  • B
                                    B
                                    barrydou
                                    wrote on last edited by barrydou
                                    #998
                                    @gohan Sorry I miss your answer a few days ago
                                    I don't want to a gateway with both rfm69 and nrf24..
                                    I'm planning to change my nrf24 sensors with rfm69, to have a better transmission distance. My two nodes are outside, and i have communication trouble if i put them where i wanted, specially for my rain gauge.
                                    So I wanted to use those adaptors https://www.openhardware.io/view/16/NRF2RFM69.
                                    I received them, and I'm still waiting RFM69 board to test it.
                                    But as the pinout is not the same between nrf24 and rfm69 on raspberry gateway, I could not use the adaptor on the gateway. So before making a new board for my raspberry, I wanted to know if it's possible to change the default pin configuration, to have exactly the same as nrf24, and use an adaptor on the gateway too.
                                    For that, I "just" need to redefine DIO0 on pin 15 (default is 22). So I wonder if it's possible to do it.
                                    And "bonus question", I'd like to know why pin configuration is not the same between arduino and raspberry. Why pin 15 is not used for DIO0 on raspberry (equivalent to pin 2 on arduino). I'm telling myself it should be a good reason, but I don't get it.
                                    • B barrydou
                                      #999
                                      @barrydou is this what you need (from the documentation and ./configure--help)
                                      For the bonus question: I wasn't aware that there was a mapping between Raspberry Pi gpio and Arduino pins. Could you share he rest of the list?
                                      • B
                                        B
                                        barrydou
                                        #1000
                                        @mfalkvidd I don't know what DI00 is, and if it's equivalent to IRQ ? If Yes, it's exactly what I need ! Thank you !!! :) I will test it as soon as I get my RFM69
                                        Here is the pin mapping between RFM69W/NRF24 and Arduino/Raspberry
                                        Arduino mini - NRF24  - RFM69 - Raspberry GW NRF - Raspberry GW RFM
                                        9            - CE     - N/A   - 22               - N/A
                                        10           - CSN/CS - NSS   - 24               - 24
                                        13           - SCK    - SCK   - 23               - 23
                                        11           - MOSI   - MOSI  - 19               - 19
                                        12           - MISO   - MISO  - 21               - 21
                                        2            - IRQ    - DI00  - 15               - 22
                                        So, the only mismatch breaking pin compatibility (and preventing to use adaptors on the raspberry pi gateway) is on IRQ/DI00. Adaptors wire RFM69 DI00 on NRF24 IRQ pin, but they don't use, by default, the same pin on raspberry, depending the radio type.
                                        • B barrydou
                                          #1001
                                          @barrydou I don't know what dio0 is either, but https://learn.sparkfun.com/tutorials/rfm69hcw-hookup-guide/all describes it like this:
                                          Digital I/O 0
                                          RX interrupt Received data ready interrupt signal from RFM69HCW to microcontroller
                                          which sounds like it could be interrupt. It might be worth a try at least.
