  3. WS2811 RGB strip lights up in groups of three
11 Posts 5 Posters 10.0k Views 4 Watching
  • Daniel OliveiraD
    Daniel OliveiraD
    Daniel Oliveira
    Looking at the product picture indeed there is only one WS2811 IC per each 3 LEDs. So... I'm afraid the behaviour that you describe is that LED strip can do...
    I have around here some WS2801 LED strips and there's one IC per LED.
    MySensors rules my home :)
    • Daniel OliveiraD
      Daniel OliveiraD
      Daniel Oliveira
      Just found this in the product description : "LED Type: 1 WS2811 IC control 3 LED Chip,"
      • Daniel OliveiraD Daniel Oliveira
        Thanks @Daniel-Oliveira. I read the part about 3 leds but thought that one IC controlled three leds individually. But since WS2811 can only control one address per chip, it makes sense that they light up in groups of 3.
        Oh well, you always learn something :)
        • Daniel OliveiraD
          Daniel OliveiraD
          Daniel Oliveira
          Well... I'm sorry for you, but at least now everyone that reads this thread will be aware.
            @Daniel-Oliveira yup. For me, electronics is all about learning new stuff. Either from other people's mistakes, or by my own mistakes :)
            Thanks for the quick answer.
            • TetnobicT
              TetnobicT
              Tetnobic
              @mfalkvidd So where you buy the right led strip ?
              Thanks for your reponse
              • TetnobicT Tetnobic
                @Tetnobic https://www.aliexpress.com/item/1m-2m-3m-4m-5m-ws2812b-ws2812-led-strip-individually-addressable-smart-led-strip-black-white/32682015405.html
                I bought 5m 30 black pcb ip30
                N 1 Reply Last reply
                  N
                  N
                  Nicklas Starkel
                  @mfalkvidd , quite OT, but how do you power these?
                  I have them as well and when I calculate how much amp they should draw it is quite much!
                  However, when I check what they actually draw is quite low. Around 3-4A on full bright white.
                  Do not really know what I should aim for because you can find nice 5A or less quite easily while above this you would have to go with big ugly power supplys.
                  And it's a shame they work in 5V only as 12V would be much better for me (and get more A out of as well from smaller power supplys)
                  • N Nicklas Starkel
                    @Nicklas-Starkel yep, that is a problem, at least in theory.
                    However, I have been powering my arcade game screen from a 2.1A USB powerpack without problems. So maybe they don't use as much power as they are specified for.
                    I am considering buying a good 230VAC->12VDC adapter and use one or a few of these to get 5V: https://www.aliexpress.com/item/5A-XL4015-DC-DC-4-38V-to-1-25-36V-24V-12V-9V-5V-Step-Down/32713638689.html
                    If you find anything nice, please let me know.
                    • J
                      J
                      jack.historia
                      You guys had the wrong LED type in the arduino setup:
                      //   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
                      //   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
                      //   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
                      I have the 12V GRB option - one controller connected to 3 leds but it runs smooth as a cat. With RGB and RGBW it doesn't work that well and I see only 3 led chunks. ali express link 12V2811 5m |1 50 leds | White PCB
                      That is the setup line that works for the WS2811 RGB strip (GRB strip):
                      Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
                      I went on this by accident and I thought I should let you know even after 2 years :-) Hope that helps
