  3. Home Assistant
  4. Node 2 is unknown warning in Homeassistant.
3 Posts 2 Posters 1.2k Views 3 Watching
  • B Offline
    B Offline
    badisensors
    Hi everybody.
    I am running homeassistant on raspberrypi and i have serial gateway on raspberry. I have made 2 nodes with temp hum sensor and they are working fine but i see this warning everytime i reboot homeassistant ''Node 2 is unknown'' the same also for node3. What that means and should i just ignore it?
    Also i see this warning ''child_id 1 already exists in children of node 3, cannot add child''
    Thank you.
    W 2 Replies Last reply
    • B badisensors
      Hi everybody.
      Thank you.
      W Offline
      W Offline
      wint0178
      @badisensors I am also working on this. Have you figured it out? I can see my serial data from the node coming into my sensebender, but my system log says that the node is unknown and can't add it.
      • B badisensors
        Hi everybody.
        Thank you.
        W Offline
        W Offline
        wint0178
        @badisensors I have this same issue and am struggling to find a consice answer to the question. Have you figured it out?
        I would love to see a bit more detail about the important naming and numbering protocals for Gateways, Nodes, Sensors, and their output values within the MySensors architecture. So far, I am not finding much and progress is slow when I simply need to try different iterations and make conclusions/adjustments.
