  3. rboard - Cheap relay/radio/arduino board ~$10
57 Posts 15 Posters 34.9k Views 7 Watching
  • gaduG gadu
    Cool, this one is also interesting!
    http://imall.iteadstudio.com/im120618001.html
    Dean
    I agree... I placed an order with them last and it arrived yesterday. I bought a few items including a couple more Mini Rboards, but I also bought what you linked. Not sure what I will do with it, but at that price I couldn't say no. :-)
    • greglG
      greglG
      gregl
      ive had an rboard in production with mysensors for 6 months or so.... it hasnt missed a beat and caused me absolutely no issues!!!
      • epierreE
        epierreE
        epierre
        #49
        @gregl I wanted to try mine, but it seems it doesn't commute, have you a test script ?
        When I send the order:
        echo "9;0;1;1;2;1" >> /dev/ttyUSB0
        I see on the debug:
        read: 0-0-9 s=0,c=1,t=2,pt=0,l=1:1
        send: 9-9-0-0 s=0,c=1,t=2,pt=0,l=1,st=ok:1
        Incoming change for sensor:0, New status: 1
        But I don't hear the relay commute nor mesure a conductivity on the relay limits.
        any hint ?
        z-wave - Vera -> Domoticz
        • greglG
          greglG
          gregl
          You may not have enough power to drive the relay...five it at least 6v
          . ...or the Wong pin in your sketch.
          • epierreE
            epierreE
            epierre
            @gregl right this was linked to a powering issue.
            :~$ echo "9;1;1;1;2;1" >> /dev/ttyUSB0
            :~$ echo "9;1;1;1;2;0" >> /dev/ttyUSB0
            what is strange is that it is the sensor 1 and not the 0, but the way the demo code is you have to do that...
            digitalWrite(message.sensor-1+RELAY_1,
            @hek sending a message would be good in http://www.mysensors.org/download/serial_api_14 in § serial communication example, it is missing...
            • HomerH
              HomerH
              Homer
              Sorry about bumping an old thread...
              I am using one of these boards to make a relay and temp sensor. I am trying to use Gregl's example that is linked here and stored on Codebender. For the record, here it is:
              //This is Motion/Door & Temp Sensor with Relay
              //Hardware is Mini RBoard ftp://imall.iteadstudio.com/Mainboard/IM140704001_mini_Rboard/SCH_IM140704001_MiniRboard.pdf
              #include <OneWire.h>
              char sketch_name[] = "Multi Sensor";
              char sketch_ver[]  = "2014.11.15r1";
              #define MySensorTESTBED 0
              #if MySensorTESTBED == 1
              #define CLIENT_ID 9  // Sets MYSensors client id
              #define RADIO_CH 96  // Sets MYSensors to use Radio Channel 96
              #define RELAY 4   // Set 4 for mini rboard
              #define TRIGGER	3	// On Mini Rboard there is D3 (Interupt 1) available on the RX Module pins
              #if MySensorTESTBED == 0
              #define CLIENT_ID AUTO  // Sets MYSensors client id
              #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
              //Temp Sensor bits
              #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected - on Rboard this is A0(D14)
              DallasTemperature DallasSensors(&oneWire);
              float lastTemperature ;
              #define CHILD_ID_T1 3 //CHILD ID for relay
              //Relay Output bits
              #define CHILD_ID_R1 1 //CHILD ID for relay
              //Trigger Sensor Bits
              #define CHILD_ID_S1 2 //CHILD ID for Reed/Motion sensor
              boolean lastTripped = 0;
              MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
              MyMessage relayMsg(CHILD_ID_R1,V_LIGHT);
              MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
              	// Startup OneWire Temp Sensors
              	DallasSensors.begin();
              	gw.begin(incomingMessage, CLIENT_ID , false,AUTO,RF24_PA_MAX,RADIO_CH,RF24_250KBPS);
              	gw.sendSketchInfo(sketch_name, sketch_ver);
              	gw.present(CHILD_ID_R1, S_LIGHT);
              	gw.present(CHILD_ID_T1, S_TEMP);
              	gw.present(CHILD_ID_S1, S_MOTION);
              	pinMode(RELAY, OUTPUT);
              	pinMode(TRIGGER,INPUT_PULLUP);
              	//Ensure relay is off
              	digitalWrite(RELAY,RELAY_OFF); //turn relay off
              	// Check for motion change value
              		boolean tripped = digitalRead(TRIGGER) == HIGH;
              		if (lastTripped != tripped ) {
              			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
              			Serial.println("Tripped");
              			lastTripped=tripped;
              		DallasSensors.requestTemperatures();
              		float tempC = DallasSensors.getTempCByIndex(1);
              		if (lastTemperature != tempC && tempC != -127.00) {
              			gw.send(tempMsg.set(tempC,1));
              			lastTemperature=tempC;
              	if (message.type==V_LIGHT && !(message.isAck()) ) { // look for messages for the relay and that are not ACK messages
              		// Change relay state
              		digitalWrite(RELAY, message.getBool()?RELAY_ON:RELAY_OFF);
              Just as the code stands, when I try to compile it, I get an error. First I got one because the Mysensors library had the last letter 's' missing, but even after I make that correction I can't get it to compile. This is the error that I get:
              Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328P"
              In file included from C:\Users\Dean\Documents\Arduino\testingagain\testingagain.ino:7:0:
              C:\Users\Dean\Documents\Arduino\libraries\MySensors/MySensors.h:405:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
              Multiple libraries were found for "MySensors.h"
              Used: C:\Users\Dean\Documents\Arduino\libraries\MySensors
              Not used: C:\Users\Dean\Documents\Arduino\libraries\MySensors-2.3.1
              Multiple libraries were found for "DallasTemperature.h"
              Used: C:\Users\Dean\Documents\Arduino\libraries\DallasTemperature
              Not used: C:\Users\Dean\Documents\Arduino\libraries\MAX31850_DallasTemp
              exit status 1
              Error compiling for board Arduino Duemilanove or Diecimila.
              I really don't know where to go to from here, because all I have done is tried to compile a working sketch so it should work, shouldn't it?
              Keen to hear back from someone who knows a lot more about this stuff than me! Thanks
              • HomerH Homer
                //Temp Sensor bits
                //Relay Output bits
                exit status 1
                @homer that sketch was made for MySensors 1.x and needs to be converted to work for MySensors 2.x.
                Followthe guide at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x to convert it.
                Alternatively, remove MySensors 2 and install MySensors 1 instead.
                HomerH 1 Reply Last reply
                  HomerH
                  HomerH
                  Homer
                  @mfalkvidd said in rboard - Cheap relay/radio/arduino board ~$10:
                  Thanks mate! I was thinking something like that might be the case, but I didn't know for sure.
                  Thank you so much for pointing me in the right direction!!
                  • HomerH
                    HomerH
                    Homer
                    I just wanted to say that I managed to upload a sketch and I have it working!
                    I attempted to change the code so it was compatible but I gave that up and decided to merge two sketches. It was good fun, and I enjoyed learning!
                    • alowhumA
                      alowhumA
                      alowhum
                      Could you share the sketch? Perhaps others will learn from it too?
                      • alowhumA alowhum
                        HomerH
                        HomerH
                        Homer
                        #57
                        @alowhum said in rboard - Cheap relay/radio/arduino board ~$10:
                        Great idea! :relaxed:
                        Here it is
                        // Setup Relay bits
                        #define RELAY_PIN 4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                        // Setup Temperature bits
                        #define ONE_WIRE_BUS 14 // Pin where dallase sensor is connected
                        int numSensors = 0;
                        bool receivedConfig = false;
                        bool metric = true;
                        MyMessage tempMsg(0, V_TEMP);
                        void before()
                          for (int sensor = 1, pin = RELAY_PIN; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                            pinMode(pin, OUTPUT);
                            digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
                          sensors.begin();
                          sendSketchInfo("Temp and Relay", "1.0");
                          for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                            present(i, S_TEMP);
                              present(sensor, S_BINARY);
                          wait(conversionTime);
                            float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                        #if COMPARE_TEMP == 1
                              send(tempMsg.setSensor(i).set(temperature, 1));
                              lastTemperature[i] = temperature;
                          wait(SLEEP_TIME);
                            digitalWrite(message.sensor - 1 + RELAY_PIN, message.getBool() ? RELAY_ON : RELAY_OFF);
                            // Store state in eeprom
