  3. Particle Powered Air Quality Sensor Logging to Google Docs
si7021air qualitypm2.5particlehpma115s0ccs811
69 Posts 6 Posters 17.3k Views 8 Watching
  • J jaredwolff
    @FotoFieber if you check out my tvoc_test branch, I implemented the CCS811 update routine. I'm interested to see how it compares to the SPG30 and BME680..
    FotoFieberF
    FotoFieberF
    FotoFieber
    @jaredwolff
    The update has brought a big improvement.
    I think one could derive airquality from the measurements, but the CO2 ppm value is still way off.
    J 1 Reply Last reply
    • FotoFieberF FotoFieber
      @jaredwolff
      J
      J
      jaredwolff
      wrote on last edited by jaredwolff
      #29
      @fotofieber that's great news! Pretty much what I've seen. I've stopped eC02 all together because it correlates 1:1 with TVOC on that part. Plus I don't know how actionable the C02 reading is. Does it indicate stale air? C02 is a byproduct of the VOCs? Maybe it's more useful for more industrial environments..
      Are you logging anything other than C02?
      • J jaredwolff
        FotoFieberF
        FotoFieberF
        FotoFieber
        wrote on last edited by FotoFieber
        #30
        @jaredwolff
        CO2 is an indicator of air quality. I use it since years mainly with consumer devices from Netatmo. In my graphs you can see, when people are in the rooms consume the air, when they leave, when I open the windows...
        The CO2 measurement with NDIR-sensors seems much more reliable than what I see here from CCS811. They usually show quite good results just plugged in without calibration. They are easier to handle, because you don''t need to bother with handling basline (save and restore). And they don't need a temp/hum measurement to correct their values.
        Yesterday arrived another NDIR-Sensor (Senseair S8) and a SGP30. I am curious, how they perform. Hope I have the first results in two days.
        In general I have much more values I log (radioactivity, luminosity, window open/close, motion...)
        In this setup I log what I can get from the sensors.
        FotoFieberF 2 Replies Last reply
          @jaredwolff
          FotoFieberF
          FotoFieberF
          FotoFieber
          This night was a complete fail for the CCS811 I have here:
          Fresh air at 20:00
          Sleep till 6:15 with closed windows
          -> NDIR sensors show, how air quality gets worse
          -> CCS811 shows, how the air quality gets better during sleep with closed window!
          Fresh air at 06:15
          WTF.... :)
            @jaredwolff
            FotoFieberF
            FotoFieberF
            FotoFieber
            S8 readings seem quite goot. (NDIR)
            SGP30 :( Will try with the adafruit library instead of the sparktech.
              J
              J
              jaredwolff
              @fotofieber said in Particle Powered Air Quality Sensor Logging to Google Docs:
              SGP30 Will try with the adafruit library instead of the sparktech.
              I have that one in the same branch I mentioned before if you need a working reference.
              I followed your lead on the Grafana + InfluxDB stuff. It was dead simple to setup.
              I just want to get HTTPS/SSL working. Pretty nifty little piece of software. :)
              • J jaredwolff
                FotoFieberF
                FotoFieberF
                FotoFieber
                @jaredwolff said in Particle Powered Air Quality Sensor Logging to Google Docs:
                Yes, really simple. I use docker for grafana and influxdb.
                Your SGP30 CO2 ppm graph looks like mine... :(
                I use an nginx-setup here for https.
                Yepp! They are real software gems.
                J 2 Replies Last reply
                  J
                  J
                  jaredwolff
                  #35
                  @fotofieber also, I compiled my conclusions about some of the smaller form factor TVOC/C02 sensors. It was inspired by everything we talked about here. Our back and forth conversation has been awesome. So I wanted to say thanks for the inspiration :)
                  The above is a screenshot from the side-by-side data of the BME680, CCS811 and SGP30.
                  The BME680 seemed impressive at first but I'm seeing a big difference in temperature and humidity. My thinking it's likely due to the heating elements inside keeping it a little less humid and a little more hot. (These are the compensated values by the way. The non-compensated values are even lower humidity and a hotter.)
                  The SGP30 is a bit of a power hog but the TVOC readings seemed to align well with the response from the BME680.
                  The CCS811, like we've seen throughout this thread, had some wacky responses using the 1.0.0 firmware. I haven't seen that since all of my CCS811 are up to date.
                  It's a toss up between all three but I'd shy away from the CCS811. If anyone here plans on building a production device, the stock is not reliable enough. (Digikey and Mouser have been out of stock lately) I'm not sure if you'd have the same problem in the EU or how things are in Asia.
                  Anyway my TLDR conclusions are here if anyone is interested. They include software implementation factors, hardware factors, availability factors and data output factors all rolled into one.
                    J
                    J
                    jaredwolff
                    Also, Is your SGP30 plot the dark red one? Definitely not what I'd expect from this sensor. At first I thought it was the CCS811 as that one appears to be less reactive (at least in my testing)
                    • J jaredwolff
                      FotoFieberF
                      FotoFieberF
                      FotoFieber
                      I have tested several temperature sensors in the same setup and will use seperate HTU21D in my production devices anyway. So temperature and humidity would be no problem for me.
                      Yes, it's is the dark red one. :(
                      Yesterday another CCS811 arrived. I will add it to my setup.
                      My final setup drifts to:
                      • HTU21D temp/hum
                      • MHZ19B CO2
                      • HC-SR501 (modified for 3.3V) motion
                      • WS 2812B led stripes
                        • HTU21D temp/hum
                        • MHZ19B CO2
                        J
                        J
                        jaredwolff
                        #38
                        After someone on a different forum suggested, I actually switched it from continuous to low power mode and the temperature and humidity readings look better.
                        (Red line is in the middle between before and after the change.)
                        Nice, curious to see your results!
                        • J jaredwolff
                          FotoFieberF
                          FotoFieberF
                          FotoFieber
                          BME680 sensor mith MCU arrived. Hope I can read the chinese specification of the module.... :) (What stand PS for?)
                            J
                            J
                            jaredwolff
                            @fotofieber hmm I'm not sure. Can you send me more info about the board you got?
                            • J jaredwolff
                              FotoFieberF
                              FotoFieberF
                              FotoFieber
                              @jaredwolff
                              Found something on https://de.aliexpress.com/item/GY-MCU680V1-BME680-Sensor-Module-Temperature-and-Humidity-Air-Pressure-Air-Quality-IAQ-MCU680-Module/32902672818.html?spm=a2g0x.10010108.1000016.1.3bc92080ZxA8fs&isOrigTitle=true
                              When soldering the PS solder joint, the module is in the chip's own IIC mode, at which point the MCU does not participate in the operation and does not consume current. Can be used as a simple BME680 module.
                              And in serial mode:
                              https://playground.cmmakerclub.com/2018/12/esp32/วิธีการใช้งาน-gy-mcu680-กับ-esp32/
                              I will try the I2C mode first.
                                @jaredwolff
                                And in serial mode:
                                J
                                J
                                jaredwolff
                                @fotofieber I'm using I2C over here with great success. Let me know how it goes!
                                • J jaredwolff
                                  FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  #43
                                  @jaredwolff
                                  Seems like I only get an IAQ value for the BME680 and no (e)CO2. Is this correct?
                                    @jaredwolff
                                    J
                                    J
                                    jaredwolff
                                    @fotofieber correct! No C02. There's also temp, humidity and pressure. Here's a little code to get up and running with their C++ library.
                                    • J jaredwolff
                                      FotoFieberF
                                      FotoFieberF
                                      FotoFieber
                                      @jaredwolff
                                      Managed to compile Bosch arduino demo code on ESP32 on platformio after 3 hours. :sunglasses:
                                      But then....
                                      BSEC library version 1.4.7.3
                                      Timestamp [ms], raw temperature [°C], pressure [hPa], raw relative humidity [%], gas [Ohm], IAQ, IAQ accuracy, temperature [°C], relative humidity [%], Static IAQ, CO2 equivalent, breath VOC equivalent
                                      BSEC error code : -2
                                      Maybe I give up here, as I really don't like to use binary code in my sensors....
                                        @jaredwolff
                                        But then....
                                        J
                                        J
                                        jaredwolff
                                        @fotofieber integrating their static library is a PITA.
                                        What processor are you using exactly? That wold dictate which version of the BSEC you'd integrate.
                                        For Arduino, the library should handle the import of the .a file. If you're in any other environment you'll have to add a few lines:
                                        LIB_DEPS += $(USER_LIB_DIR)/libalgobsec.a
                                        LDFLAGS += -Wl,--whole-archive $(USER_LIB_DIR)/libalgobsec.a -Wl,--no-whole-archive
                                        I had to add these to the makefile in .particle/toolchains/deviceOS/1.2.0-beta.1/firmware-1.2.0-beta.1/modules/xenon/user-part for the Particle stuff to work.
                                        • J jaredwolff
                                          FotoFieberF
                                          FotoFieberF
                                          FotoFieber
                                          @jaredwolff
                                          ESP32 is the platform I use.
                                          Linking is no problem (after trial and error of two hours :) ).
                                          I seem to have made a call to the lib:
                                          Now adding DEBUG-Messages to the BSEC arduino library.
