  3. Monitor a DIY solarpanel with ASC712 - HELP
5 Posts 3 Posters 2.9k Views 1 Watching
  • H Offline
    H Offline
    Hausner
    wrote on last edited by Hausner
    Has anyone gotten a ASC712 to work with a actuator node?
    I'm trying to monitor my diy solar panel, so that I can see what it is producing(if).
    I've tried with the code below, but I can't get the node to send the readings to the gateway. I'm using a 30A ASC712 to do the readings. (Don't mind the motion sensor part).
    My last code:
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
    const int analogIn = A0;
    int mVperAmp = 66; // use 100 for 20A Module and 66 for 30A Module
    int RawValue= 0;
    int ACSoffset = 2500;
    double Voltage = 0;
    double Amps = 0;
    double Voltage_new = 0;
    double Amps_new = 0;
    #define RELAY_1 6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays
    // Motion sensor defs
    unsigned long SLEEP_TIME = 10000; // Sleep time between reports (in milliseconds)
    #define DIGITAL_INPUT_SENSOR 3   // The digital input you attached your motionsensor.  (Only 2 and 3 generates interrupt!)
    #define CHILD_ID 3   // Id of the sensor child
    volatile int state = LOW;
    boolean lockLow = true;
    boolean lastTripped = 0;
    MyMessage msgMotion(CHILD_ID, V_TRIPPED);
    MyMessage msgvolt(4, V_VOLTAGE);
    MyMessage msgcur(5, V_CURRENT);
      gw.sendSketchInfo("Relay/Motion Sensor", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      pinMode(DIGITAL_INPUT_SENSOR, INPUT);      // sets the motion sensor digital pin as  input
      gw.present(CHILD_ID, S_MOTION);
      // attachInterrupt(DIGITAL_INPUT_SENSOR, ON, CHANGE);
      //delay(30000);
      gw.present(4, V_VOLTAGE);
      gw.present(5, V_CURRENT);
      //boolean tripped = (digitalRead(DIGITAL_INPUT_SENSOR) == HIGH);
      //  if (lastTripped != tripped ) {
    //	gw.send(msgMotion.set(tripped?"1":"0")); // Send new state
    //	lastTripped=tripped;
      //Serial.print("Raw Value = " ); // shows pre-scaled value
      //Serial.print(RawValue);
      //gw.send(msgvolt);
      //Serial.print("\t mV = "); // shows the voltage measured
      //Serial.print(Voltage,3); // the '3' after voltage allows you to display 3 digits after decimal point
      //Serial.print("\t Amps = "); // shows the voltage measured
      for ( int i=0; i<=20; i++ ){
        RawValue += analogRead(analogIn);
        delay(50);
      Voltage = (RawValue / 1023.0) * 5000; // Gets you mV
      Amps = ((Voltage - ACSoffset) / mVperAmp);
      //gw.send(msgcur);
      Serial.print("mV = "); // shows the voltage measured
      Serial.println(Voltage);
      //Serial.println(Amps,3); // the '3' after voltage allows you to display 3 digits after             decimal point
      //delay(2500);
     if (message.type==V_LIGHT) {
     // Change relay state
     // Store state in eeprom
    Any help would be appreciated :)
    PS: Att HEK - why isn't there a "insert code" button, just like the "insert link" button?
    hekH R 2 Replies Last reply
    • H Hausner
      My last code:
      int RawValue= 0;
      double Voltage = 0;
      double Amps = 0;
        //delay(30000);
        //gw.send(msgvolt);
          delay(50);
        //gw.send(msgcur);
        //delay(2500);
      hekH Offline
      hekH Offline
      Sorry. Haven't found any nodebb-plugin which add this in the composer. So you have to surround code with 4 backticks ```` in the meantime.
      • H Hausner
        My last code:
        int RawValue= 0;
        double Voltage = 0;
        double Amps = 0;
          //delay(30000);
          //gw.send(msgvolt);
            delay(50);
          //gw.send(msgcur);
          //delay(2500);
        R Offline
        R Offline
        RJ_Make
        @Hausner Serial Monitor output OK?
        RJ_Make
        • H Offline
          H Offline
          Hausner
          No, serial monitor was just for testing. I would like to push it to mqtt.
          I found the V_VOLTAGE and V_CURRENT, and the serial monotir showed up correctly as 38/39.
          R 1 Reply Last reply
          • H Hausner
            R Offline
            R Offline
            RJ_Make
            @Hausner So the problem is with the node transmitting anything to the gateway?
            Post the radio messages from the serial monitor and hopefully someone can tell you what's going on..
            RJ_Make
