  3. How to know the node ids assigned by the mqtt gateway to the sensors?
11 Posts 5 Posters 6.8k Views 2 Watching
  • A Offline
    A Offline
    amitach
    I have a mqtt gateway running on arduino from mysensors library. I also have an openhab controller running on a raspberry pi connected to the arduino uno through the ethernet shield. I am trying to create my first item on openhab and I understand that the format required is
    MyMQTT/20/0/V_TEMP where 20 and 0 are node id and sensor id respectively.
    I can see following message on the serial monitor
    Started!
    0;0;3;0;9;read: 20-20-0 s=1,c=1,t=16,pt=0,l=1:1
    1. How do I configure the node id and the sensor id?
    2. Is it assigned automatically or do I assign it statically?
    3. How do I understand the above output on the serial monitor?
    X A D 3 Replies Last reply
    • A amitach
      Started!
      X Offline
      X Offline
      Xander
      @amitach I have the same setup and I use a MQTT-Client for testing: http://www.jensd.de/wordpress/
      You have to stop OpenHAB, because only one connection to the gateway is possible.
      Usage:
      • start client
      • create a profile: Extras / Connection Profiles
      • connect with this profile
      • click button "Subscribe"
      • choose "Topic" : # (see wildcards: http://mosquitto.org/man/mqtt-7.html )
      • click button "Subscribe" (on the right from field "Topic"
      Now you see all messages from your sensor.
      • ? Offline
        ? Offline
        A Former User
        If you have any questions or comments regarding MQTT.fx please don't hesitate to get in touch with me!
        A 1 Reply Last reply
        • ? A Former User
          A Offline
          A Offline
          Anthony Straw
          @Jerady works with older verions of MQTT.fx 0.0.12 on win 7 32 bit .. the newer one is only for 64 bit machine.. cheers
          ? 1 Reply Last reply
          • A amitach
            Started!
            A Offline
            A Offline
            Anthony Straw
            @amitach im able see on mqttfx on windows with incoming msg of arduino senting temp and hum (MyMQTT/21/0/v_HUM with 41.0 below.. appear to be working on this machine while the openhab is running as server on this pc for testing .... ive check the openhab test.items
            i rename the line...
            String sketch20 "Cupboard Temp [%s °C]" (sketch,all) {mqtt="<[MyMQTT/21/0/V_TEMP:state:default]"}
            nothing is updating....
            • A Anthony Straw
              A Offline
              A Offline
              Anthony Straw
              • A Offline
                A Offline
                Anthony Straw
                on the arduino serial monitor showing..
                0;0;3;0;9;read: 21-21-0 s=1,c=1,t=0,pt=7,l=5:21.0
                MyMQTT/21/1/V_TEMP
                30 18 00 12 4D 79 4D 51 54 54 2F 32 31 2F 31 2F 56 5F 54 45 4D 50 32 31 2E 30
                0;0;3;0;9;read: 21-21-0 s=0,c=1,t=1,pt=7,l=5:41.0
                MyMQTT/21/0/V_HUM
                30 17 00 11 4D 79 4D 51 54 54 2F 32 31 2F 30 2F 56 5F 48 55 4D 34 31 2E 30
                0;0;3;0;9;read: 21-21-0 s=0,c=1,t=1,pt=7,l=5:42.0
                • A Anthony Straw
                  ? Offline
                  ? Offline
                  A Former User
                  @Anthony-Straw Going to provide a 32 Bit version of MQTT.fx 0.0.14.3 for windows.
                  • ? A Former User
                    ? Offline
                    ? Offline
                    A Former User
                    wrote on last edited by A Former User
                    @Anthony-Straw have a look here: http://www.jensd.de/apps/mqttfx/0.0.14.3/
                    • A Offline
                      A Offline
                      Anthony Straw
                      thanks ;-)
                      • A amitach
                        Started!
                        darazs
                        Started!
                        You can let the gateway autoassign node IDs or take it in your own hands.
                        What I found useful is to not rely on the automatic assignment but give my nodes a static ID, you can do that by replacing the gw.begin function call by this:
                        gw.begin(NULL, NODE_ID, false);
                        where NODE_ID is your chosen ID (you can use "#define NODE_ID 12" for example to specify it before).
                        The sensor ID is specified by you. So in each example you see a line something like this:
                        MyMessage msgMotion(CHILD_ID_MOTION, V_TRIPPED);
                        where the first argument (here CHILD_ID_MOTION) specifies the sensor ID that will be sent along your message. You can, again, use #define to define a number in the top of your sketch.
                        The serial output was a mystery to me as well until I looked up the printout in the libraries/MySensors/MySensors.cpp file. It's constructed like this:
                        debug(PSTR("read: %d-%d-%d s=%d,c=%d,t=%d,pt=%d,l=%d:%s\n"),
                        			msg.sender, msg.last, msg.destination,  msg.sensor, mGetCommand(msg), msg.type, mGetPayloadType(msg), mGetLength(msg), msg.getString(convBuf));
                        So it's the sender's node ID, then probably the next hop's node ID, then the destination's node ID, then s=sensor ID, command type?, the message type (like V_TRIPPED, but as a number), payload type, length of the message, the message itself.
                        12.1k
