  3. Using only two digital pins for a button? (no GND, no VCC)
7 Posts 4 Posters 1.2k Views 3 Watching
  • alowhumA Offline
    alowhumA Offline
    alowhum
    If I only have two digital pins left, could they be used to support a button? Online searches have proven fruitless.
    For example:
    - D4 functions as output, set to permanently high.
    [ button ]
    - D5 functions as input, with pullup resistor enabled.
    Would this work? Or would this fry the Arduino/pin?
    Y 1 Reply Last reply
    • alowhumA alowhum
      For example:
      [ button ]
      Y Offline
      Y Offline
      @alowhum almost, if you set D4 permanently LOW.
      Then you button on D5 toggles between HIGH (when open, due to pullup) and LOW (when closed, shorted to D4).
      • alowhumA Offline
        alowhumA Offline
        alowhum
        @Yveaux Thanks!
        // It works!
        For anyone finding this:
        In the Setup / Before function:
          // BUTTON
          pinMode(BUTTON_OUTPUT_PIN, OUTPUT);                          // Set a digital pin as power output
          digitalWrite(BUTTON_OUTPUT_PIN, LOW);
          pinMode(BUTTON_INPUT_PIN, INPUT_PULLUP);                     // Set another digital pin as power input
        In the loop:
          wait(20);
          // ON DEVICE TOGGLE BUTTON
          if (digitalRead(BUTTON_INPUT_PIN) == LOW) {
            button_pressed = true;
            Serial.print(F("."));
        • D Offline
          Out of curiosity, would there be any practical reason for doing it this way? Maybe there is an advantage that I am not thinking of. It just seems though that it is a waste of a pin, not to mention that it is more code to get it working.
          • alowhumA Offline
            alowhumA Offline
            alowhum
            @dbemowsk The Nano only has so many GND and VCC pins. This allows me to connect a relay, an LED and this button directly with dupont wires. No breadboard/expansion board/soldering required.
            • alowhumA alowhum
              zboblamontZ Offline
              zboblamontZ Offline
              zboblamont
              @alowhum Seems a bit wasteful of Nano pins for the sake of 2 lines of Veroboard and some header pins though, but if it works for you... ;)
              alowhumA 1 Reply Last reply
              • zboblamontZ zboblamont
                alowhumA Offline
                alowhumA Offline
                alowhum
                @zboblamont It's not very wasteful if you're not using them for anything else anyway. I'd rather use some extra code than extra hardware.
                12.1k
