  3. not working Ethernet Gateway (sensebender and/or nano gateway)
32 Posts 9 Posters 6.0k Views 8 Watching
  • R
    R
    rafael156
    Okay, thanks for the clarification.
    i changed the processor because the USB interface was not recognized under windows and i couldn't program the board anymore. leds were lit but, so i thought that the samd must be broken.
    the new one shows the same behavior after flashing with mysensors 2.3.1 ... so it must be somewhere due to the software.
    can you please initiate the change to the "platform.txt" (see https://forum.mysensors.org/post/96909)?
    tbowmoT 1 Reply Last reply
    • R rafael156
      tbowmoT
      tbowmoT
      tbowmo
      @rafael156
      Is it the standard gateway sketch, that you use for the SAMD? If not, could you post it here? Then I could try programming a spare samd21 board at some point in time (I do not know if I get around to it this weekend, as I have lots of projects running through my head at the moment)
      R 1 Reply Last reply
      • tbowmoT tbowmo
        @rafael156
        R
        R
        rafael156
        @tbowmo yes, it is the standard "SensebenderGatewaySerial" sketch.
        i try to reinstall the arduino ide completely on the weekend and use older versions. it is worth a try...
        • R
          R
          rafael156
          wrote on last edited by rafael156
          #24
          ok, the weekend has brought a lot of information... both problems have been solved:
          To the Arduino Nano+W5100+NRF24:
          • Note versions:
            Clean Install (delete Dirs: ".../Documents/Arduino", "AppData", "Arduino IDE") before compiling:
            Arduino IDE 1.6.13
            Arduino AVR 1.6.18
            Arduino SAMD 1.6.12
            MySensors SAMD 1.0.5
            MySensors Lib 2.3.1
          • if no W5100 is attached, then 0.0.0.0 comes in the log
          • Both GNDs of the W5100 must be connected!
          • Voltage with +5V, if voltage transformer present
          • optional: fix bug of W5100: https://arduinodiy.wordpress.com/2017/04/12/the-w5100-bug/
          • successful log Nano_5V_16Mhz+W5100+NRF24:
            0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
            4 TSM:INIT
            5 TSF:WUR:MS=5000
            11 TSM:INIT:TSP OK
            13 TSM:INIT:GW MODE
            15 TSM:READY:ID=0,PAR=0,DIS=0
            17 MCO:REG:NOT NEEDED
            320 GWT:TIN:IP=128.168.1.38
            1323 MCO:BGN:STP
            1325 MCO:SLP:MS=250,SMS=0,I1=255,M1=255,I2=255,M2=255,M2=255
            1330 !MCO:SLP:REP
            1332 TSM:READY:NWD REQ
            1369 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            1581 MCO:BGN:INIT OK,TSP=1
          • power consumption Nano_5V_16Mhz+W5100+NRF24: 250mA
          • operate the W5100 with its own +5V power supply!
          With 2kB SRAM, the Arduino Nano meets the minimum requirements for an ETHERNET(!) gateway (serial gateway is no problem). It can happen from time to time that the W5100 is not responsive for a short time because the nano does not follow. It is best to deactivate MY_DEBUG or use a mega with 8kB memory.
          My working Nano+W5100+NRF24 Sketch:
           * Version 1.0 - Henrik EKblad
           * Contribution by Tomas Hozza <thozza@gmail.com>
           * LED purposes:
           * - To use the feature, uncomment MY_DEFAULT_xxx_LED_PIN in the sketch below
           * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
           * - ERR (red) - fast blink on error during transmission error or receive crc error
          //#define MY_DEBUG
          #define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          #define MY_GATEWAY_W5100
          #define MY_GATEWAY_MAX_CLIENTS  3
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
          #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
          #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
          #define MY_RF24_CS_PIN 6
          // Enable UDP communication
          //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
          #define MY_IP_ADDRESS 192,168,1,38
          #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
          #define MY_PORT 5003
          //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
          // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
          //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
          //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
          #if defined(MY_USE_UDP)
          #include <EthernetUdp.h>
          #include <Ethernet.h>
           sleep(250);    // Optional, if W5100 is rebooting
          • R
            R
            rafael156
            #25
            To the Sensebender Board with W5100+NRF24:
            • Sensebender can be flashed via Arduino IDE: Bootloader and Sketch
            • Note versions (work):
              Arduino IDE 1.6.13
              Arduino AVR 1.6.18
              Arduino SAMD 1.6.12
              MySensors Lib 2.3.1
            • Installed is an Atmel "ATSAMD21J18A-AU".
            • Windows 10 does not recognize the serial port after a few flashes (native USB ATSAMD21J18A-AU). Then the PC must be restarted.
            • the bootloader has to be flashed via SWD interface (e.g. with Atmel JtagICE3):
              -> install Atmel Studio 7 (for JtagICE3 drivers) and erase chip
              -> Connect the pins of the JTAGICE3 to Sensebender:
              JTAGICE3: ARM SWD Pin:
              Pin 1 (TCK) SWDCLK
              Pin 2 (GND) GND
              Pin 4 (VTG) VCC
              Pin 5 (TMS) SWDIO
              Pin 6 (nSRST) nRESET
              -> bootloader about Ardunio IDE flash: Programmer "Atmel EDBG or Atmel Sam ICE"
              -> usb port should now be found automatically (windows 10 has drivers already integrated, install win7.8 driver from MySensors)
            • sketch normal about arduino ide and port selection flashes
            My working Sensebender W5100+NRF24 sketch:
             * LED purposes:
            //@riss
            // Define sketch version
            #define SKETCH_VERSION "0.4"
            //@riss
            #define MY_SOFTSPI
            //@riss
            #include <SD.h>
            #include <drivers/ATSHA204/ATSHA204.cpp>
            Sd2Card card;
            #define EEPROM_VERIFICATION_ADDRESS 0x01
            static uint8_t num_of_leds = 5;
            static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
            //@riss
             sleep(250);      // wait for the W5100
            //@riss
            void preHwInit()
              pinMode(MY_SWC1, INPUT_PULLUP);
              pinMode(MY_SWC2, INPUT_PULLUP);
              if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
                return;
              uint8_t tests = 0;
              for (int i=0; i< num_of_leds; i++) {
                pinMode(leds[i], OUTPUT);
              if (digitalRead(MY_SWC1)) {
                uint8_t led_state = 0;
                while (!Serial) {
                  digitalWrite(LED_BLUE, led_state);
                  led_state ^= 0x01;
                  delay(500);
                } // Wait for USB to be connected, before spewing out data.
              digitalWrite(LED_BLUE, LOW);
              if (Serial) {
                Serial.println("Sensebender GateWay test routine");
                Serial.print("MySensors core version : ");
                Serial.println(MYSENSORS_LIBRARY_VERSION);
                Serial.print("GateWay sketch version : ");
                Serial.println(SKETCH_VERSION);
                Serial.println("----------------------------------");
                Serial.println();
              if (testSha204()) {
                digitalWrite(LED_GREEN, HIGH);
                tests++;
              if (testSDCard()) {
                digitalWrite(LED_YELLOW, HIGH);
                tests++;
              if (testEEProm()) {
                digitalWrite(LED_ORANGE, HIGH);
                tests++;
              if (testAnalog()) {
                digitalWrite(LED_BLUE, HIGH);
                tests++;
              if (tests == 4) {
                while(1) {
                  for (int i=0; i<num_of_leds; i++) {
                    digitalWrite(leds[i], HIGH);
                    delay(200);
                    digitalWrite(leds[i], LOW);
              } else {
                while (1) {
                  digitalWrite(LED_RED, HIGH);
                  delay(200);
                  digitalWrite(LED_RED, LOW);
                  delay(200);
            bool testSha204()
              uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
              uint8_t ret_code;
              if (Serial) {
                Serial.print("- > SHA204 ");
              atsha204_init(MY_SIGNING_ATSHA204_PIN);
              ret_code = atsha204_wakeup(rx_buffer);
              if (ret_code == SHA204_SUCCESS) {
                ret_code = atsha204_getSerialNumber(rx_buffer);
                if (ret_code != SHA204_SUCCESS) {
                  if (Serial) {
                    Serial.println(F("Failed to obtain device serial number. Response: "));
                  Serial.println(ret_code, HEX);
                } else {
                  if (Serial) {
                    Serial.print(F("Ok (serial : "));
                    for (int i=0; i<9; i++) {
                      if (rx_buffer[i] < 0x10) {
                        Serial.print('0'); // Because Serial.print does not 0-pad HEX
                      Serial.print(rx_buffer[i], HEX);
                    Serial.println(")");
                  return true;
              } else {
                if (Serial) {
                  Serial.println(F("Failed to wakeup SHA204"));
              return false;
            bool testSDCard()
              if (Serial) {
                Serial.print("- > SD CARD ");
              if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                if (Serial) {
                  Serial.println("SD CARD did not initialize!");
              } else {
                if (Serial) {
                  Serial.print("SD Card initialized correct! - ");
                  Serial.print("type detected : ");
                  switch(card.type()) {
                  case SD_CARD_TYPE_SD1:
                    Serial.println("SD1");
                    break;
                  case SD_CARD_TYPE_SD2:
                    Serial.println("SD2");
                    break;
                  case SD_CARD_TYPE_SDHC:
                    Serial.println("SDHC");
                    break;
                  default:
                    Serial.println("Unknown");
                return true;
              return false;
            bool testEEProm()
              uint8_t eeprom_d1, eeprom_d2;
              SerialUSB.print(" -> EEPROM ");
              eeprom_d1 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
              delay(500);
              eeprom_d1 = ~eeprom_d1; // invert the bits
              hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
              delay(500);
              eeprom_d2 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
              if (eeprom_d1 == eeprom_d2) {
                SerialUSB.println("PASSED");
                hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
                return true;
              SerialUSB.println("FAILED!");
              return false;
            bool testAnalog()
              int bat_detect = analogRead(MY_BAT_DETECT);
              Serial.print("-> analog : ");
              Serial.print(bat_detect);
              if (bat_detect < 400 || bat_detect > 650) {
                Serial.println(" Failed");
                return false;
              Serial.println(" Passed");
              return true;
            //@riss
            JCLBJ 1 Reply Last reply
            • R
              R
              rafael156
              Thanks to everyone who helped! now it would be interesting again, if it also works with the latest SAMD and arduino ide versions...?! has somebody already tested it/ been running?
              • tbowmoT
                tbowmoT
                tbowmo
                it should not be necessary to use atmel studio to erase the SAMD21, before you reflash with arduino. The erase cycle is included in the flashing process..
                I haven't updated any of my SAMD21 boards the last year, so don't know if the latest arduino breaks something.
                alexsh1A 1 Reply Last reply
                • tbowmoT tbowmo
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @tbowmo said in not working Ethernet Gateway (sensebender and/or nano gateway):
                  I updated SAMD21 (Sensebender) with the latest Arduino and nothing has been broken.
                  I have not tested it extensively though.
                  • R
                    R
                    rollin
                    the pinout of the jtagice 3 is not compatible with the cortex m0 debug port pinout. So check the pinout of both devices first to be sure that they match.
                    • R rollin
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @rollin said in not working Ethernet Gateway (sensebender and/or nano gateway):
                      Yes, they do not match.. I created https://www.openhardware.io/view/192/Jtag-ICE3-breakout to make them compatible :)
                      • R rafael156
                          Arduino IDE 1.6.13
                          Arduino AVR 1.6.18
                          Arduino SAMD 1.6.12
                          MySensors Lib 2.3.1
                          Pin 1 (TCK) SWDCLK
                          Pin 2 (GND) GND
                          Pin 4 (VTG) VCC
                          Pin 5 (TMS) SWDIO
                         * LED purposes:
                        //@riss
                        //@riss
                        #define MY_SOFTSPI
                        //@riss
                        #include <SD.h>
                        Sd2Card card;
                        //@riss
                        //@riss
                        void preHwInit()
                            return;
                          uint8_t tests = 0;
                            while (!Serial) {
                              led_state ^= 0x01;
                              delay(500);
                          if (Serial) {
                            Serial.println();
                          if (testSha204()) {
                            tests++;
                          if (testSDCard()) {
                            tests++;
                          if (testEEProm()) {
                            tests++;
                          if (testAnalog()) {
                            tests++;
                          if (tests == 4) {
                            while(1) {
                                delay(200);
                          } else {
                            while (1) {
                              delay(200);
                              delay(200);
                        bool testSha204()
                          uint8_t ret_code;
                          if (Serial) {
                              if (Serial) {
                            } else {
                              if (Serial) {
                              return true;
                          } else {
                            if (Serial) {
                          return false;
                        bool testSDCard()
                          if (Serial) {
                            if (Serial) {
                          } else {
                            if (Serial) {
                                break;
                                break;
                                break;
                              default:
                            return true;
                          return false;
                        bool testEEProm()
                          delay(500);
                          delay(500);
                            return true;
                          return false;
                        bool testAnalog()
                            return false;
                          return true;
                        //@riss
                        JCLBJ
                        JCLBJ
                        JCLB
                        @rafael156 said in not working Ethernet Gateway (sensebender and/or nano gateway):
                          Arduino IDE 1.6.13
                          Arduino AVR 1.6.18
                          Arduino SAMD 1.6.12
                          MySensors Lib 2.3.1
                        Thanks a lot ! ! !
                        I've lost 2 days trying to understand why it was not working anymore while uploading the exact same sketch as before !
                        Last release are not that stable finally.
                        • JenniferTJ
                          JenniferTJ
                          JenniferT
                          Banned
                          This post is deleted!
