  3. not working Ethernet Gateway (sensebender and/or nano gateway)
32 Posts 9 Posters 6.2k Views 8 Watching
  • R
    R
    rafael156
    ok, I have now flashed the sensebender gateway with previously compiled SensebenderGatewayW5100.ino.hex, but no LEDs flash.
    can someone send me the factory hex?
    or do I have to change the fuses?
    my factory fuses are:
    NVMCTRL_NVM_LOCK = 0x00
    NVMCTRL_PSZ = 0x03
    NVMCTRL_NVMP = 0x1000
    ADC_LINEARITY_0 = 0x08
    ADC_LINEARITY_1 = 0x04
    ADC_BIASCAL = 0x03
    OSC32K_CAL = 0x42
    USB_TRANSN = 0x05
    USB_TRANSP = 0x1D
    USB_TRIM = 0x03
    DFLL48M_COARSE_CAL = 0x23
    DFLL48M_FINE_CAL = 0x200
    ROOM_TEMP_VAL_INT = 0x1D
    ROOM_TEMP_VAL_DEC = 0x08
    HOT_TEMP_VAL_INT = 0x7D
    HOT_TEMP_VAL_DEC = 0x00
    ROOM_INT1V_VAL = 0x00
    HOT_INT1V_VAL = 0xF9
    ROOM_ADC_VAL = 0xB38
    HOT_ADC_VAL = 0xEC1
    NVMCTRL_BOOTPROT = 0x07
    NVMCTRL_EEPROM_SIZE = 0x07
    BOD33USERLEVEL = 0x07
    BOD33_EN = [ ]
    BOD33_ACTION = 0x01
    WDT_ENABLE = [X]
    WDT_ALWAYSON = [X]
    WDT_PER = 0x0B
    WDT_WINDOW_0 = [ ]
    WDT_WINDOW_1 = 0x05
    WDT_EWOFFSET = 0x0B
    WDT_WEN = [X]
    BOD33_HYST = [X]
    NVMCTRL_REGION_LOCKS = 0xFFFF
    OTP1_WORD_0 = 0x10000300 (valid)
    OTP4_WORD_0 = 0x40004007 (valid)
    OTP4_WORD_1 = 0x8DF4B09C (valid)
    OTP4_WORD_2 = 0xFFFFFE00 (valid)
    TEMP_LOG_WORD_0 = 0x7D81D (valid)
    TEMP_LOG_WORD_1 = 0xEC1B38F9 (valid)
    USER_WORD_0 = 0xD8E0C7FF (valid)
    USER_WORD_1 = 0xFFFFFC5D (valid)
    • tbowmoT
      tbowmoT
      tbowmo
      @rafael156
      You probably need to have the bootloader as well.. I might be able to find the binary/hex file that is used for production at itead in one of my old emails.. If interested, I can send it in an email (PM me if interested)
      • R rafael156
        for a short moment I was able to connect to the myscontroller and got the following log:
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?^a?
        21.01.2019 22:24:41	RX	B?$?]?}?L?*+2a??MQt҆Ÿ?Go?I??
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=B?$?]?}?L?*+2a??MQt҆Ÿ?Go?I??
        21.01.2019 22:24:41	RX	??z??xQG&F⎙(݄???¢
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??z??xQG&F⎙(݄???¢
        21.01.2019 22:24:41	RX	??`???i?Ŀ?^a?Hf????wHH?h?Gb؛??W?U��Y??
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??`???i?Ŀ?^a?Hf????wHH?h?Gb؛??W?U��Y??
        21.01.2019 22:24:41	RX	Ⱥ?x)ل?c??
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=Ⱥ?x)ل?c??
        21.01.2019 22:24:41	RX	?R]hgGR?r7"?JOS?-&?{??%?~?s??ɋ5??.Ejj?7?er?8?P?1@T?s{?\G$
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?R]hgGR?r7"?JOS?-&?{??%?~?s??ɋ5??.Ejj?7?er?8?P?1@T?s{?\G$
        21.01.2019 22:24:41	RX	"'??
        ?12???9?7˩/9[u?u?[?6Z
        ???{#|X|M??4!?GB?8??b̨??۽?x?v??Ar?/?m'!n"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg='??
        21.01.2019 22:24:41	RX	?c?b?-
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?c?b?-
        21.01.2019 22:24:41	RX	eH{??J6
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=eH{??J6
        21.01.2019 22:24:41	RX	5[?4??*?j????ql??5
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=5[?4??*?j????ql??5
        21.01.2019 22:24:41	RX	">?/??]J?v@;jL!F?????>???TX?B#	?n??	?O?}?8?ǀ???
        T?0y1?U??/?H?Lj?*ߋ8t??#7pY??""&O??r? ?p?7??ļ_^??>?+*??ҖPR???Cz?!f?:&~z?Hӑ"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=>?/??]J?v@;jL!F?????>???TX?B#	?n??	?O?}?8?ǀ???
        21.01.2019 22:24:41	RX	?:?E??I????
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?:?E??I????
        21.01.2019 22:24:41	RX	"?,T?$?f8\?׺^?o
        ?݈s??P)?F??W	?Z':?`q??y?<??\F駐???<??0?DȅΠ?BZ_?!gB??"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=?,T?$?f8\?׺^?o
        21.01.2019 22:24:41	RX	"??""
        ??i32٫+?m??{p?<H?^>'bl?\?\?h???ځ{?C"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=??""
        21.01.2019 22:24:41	RX	??4??(3AX?Hb?[k?؊??iT?6
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=??4??(3AX?Hb?[k?؊??iT?6
        21.01.2019 22:24:41	RX	"??A??,??*??ab!?^3l=???[M3??lay?f9B??J?8G?C?}JOU?%
        Tǽ?I/h???\
        4b%<??!AH??kw??^؁?"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=??A??,??*??ab!?^3l=???[M3??lay?f9B??J?8G?C?}JOU?%
        Tǽ?I/h???\
        4b%<??!AH??kw??^؁?"
        21.01.2019 22:24:41	RX	?9??H ?Y0?*?aͧ?Z.!?p2P??
        21.01.2019 22:24:41	ERROR	ErrorFlag=255, Msg=?9??H ?Y0?*?aͧ?Z.!?p2P??
        21.01.2019 22:24:41	RX	"f?>;???0f??iB*}?/?J*1?~?S6WjH.?w?	?K#?29?(?kq8-O?V??U?n\"
        21.01.2019 22:24:41	ERROR	"ErrorFlag=255, Msg=f?>;???0f??iB*}?/?J*1?~?S6WjH.?w?	?K#?29?(?kq8-O?V??U?n\"
        21.01.2019 22:24:41	RX	?^a?
        Tǽ?I/h???\
        4b%<??!AH??kw??^؁?"
        Tǽ?I/h???\
        4b%<??!AH??kw??^؁?"
        can it be that the nano has too little power (+5V) for the NRF and W5100 when I feed it via USB?
        @rafael156 said in not working Ethernet Gateway (sensebender and/or nano gateway):
        There is a large variety of cloned Nano's around, and most of them use crappy voltage regulators, so yes this could be the case.
        What regulator is on the Nano? Or picture if you don't know...
        You could try powering from USB using a separate regulator, or using a separate supply.
        Do the standard ethernet examples that come with the Arduino IDE work correctly?
          Stephen205
          For the W5100 does "MO"=MOSI and "MI"=MISO?
          Yes.
          I have just built a gateway with funduino w5100, I have it connected over usb (for power) to a RPI for now, it works well.
            Stephen205
            did you add a decoupling capacitor to the radio?
            • R
              R
              rafael156
              Yes, on every radio.
              tomorrow I'll try different tests and then report back
                Stephen205
                / Enable MY_IP_ADDRESS here if you want a static ip address (no DHCP)
                #define MY_IP_ADDRESS 192,168,1,110
                change #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
                to MY_IP_GATEWAY 192,168,1,110
                and see if that works.
                • R
                  R
                  rafael156
                  wrote on last edited by rafael156
                  can anyone tell me how to flash the sensebender board (Atmel ATSAMD21J18A) with openocd and an Atmel JtagIce3 running on windows? i have a batch file, but it returns an error.
                  Batch file:
                  openocd\bin\openocd --debug 4 --log_output log.txt -d0 -s openocd/share/openocd/scripts/ -f arduino_zero.cfg -c "telnet_port disabled; init; halt; at91samd bootloader 0; program {{%1}} verify reset;shutdown"
                  log_file:
                  Debug: 17 12 command.c:145 script_debug(): command - ocd_command ocd_command type ocd_debug_level 0
                  Debug: 18 12 command.c:145 script_debug(): command - debug_level ocd_debug_level 0
                  debug_level: 0
                  adapter speed: 500 kHz
                  adapter_nsrst_delay: 100
                  target state: halted
                  xPSR: 0x81000000 pc: 0x00005460 msp: 0x20007fb8
                  xPSR: 0x81000000 pc: 0x000005e8 msp: 0x20007ffc
                  ** Programming Started **
                  auto erase enabled
                  Runtime Error: embedded:startup.tcl:454: ** Programming Failed **
                  in procedure 'program'
                  in procedure 'program_error' called at file "embedded:startup.tcl", line 510
                  • R
                    R
                    rafael156
                    ok, I flashed the bootloader and now LED5 (D5) is lit permanently. A new USB port is also not recognized.
                    the fuse settings were probably not set either. do I still have to set them or don't I need them at sensebender gw?
                    but i need the USB port, otherwise i can't transfer sketches.
                    if I transfer sketches via SWD nothing happens after the upload.
                    • R
                      R
                      rafael156
                      i just found out that the platform.txt is not correct/outdated. The file "...\Arduino15\packages\MySensors\hardware\samd\1.0.5\platform.txt"
                      Line 148 should be changed from
                      openocd-0.9.0-arduino5-static.path
                      to
                      openocd-0.9.0-arduino6-static.path
                      can one of the mysensors samd board 1.0.5 please change that?
                      • R
                        R
                        rafael156
                        has anyone managed to get an arduino nano running with NRF and W5100 as ethernet gateway? mine won't even accept the IP address (should be 192.168.1.110) after a successful sketch:
                         MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1<\n>
                        4 TSM:INIT<\n>
                        5 TSF:WUR:MS=0<\n>
                        11 TSM:INIT:TSP OK<\n>
                        13 TSM:INIT:GW MODE<\n>
                        15 TSM:READY:ID=0,PAR=0,DIS=0<\n>
                        17 MCO:REG:NOT NEEDED<\n>
                        580 GWT:TIN:IP=0.0.0.0<\n>
                        1582 MCO:BGN:STP<\n>
                        1584 MCO:BGN:INIT OK,TSP=1<\n>
                        1586 TSM:READY:NWD REQ<\n>
                        1624 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:<\n>
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          The SAMD21 doesn't use fuses in the same way that the atmega328 does. For example, the clock source is set by the running program, and not the fuses. The only fuses awailable is BOD, WDT and bootprotection. (See page 43 in the datasheet)
                          So it should not be needed to set any fuses in the SAMD21 in order to get it working.
                          btw. why did you replace the atsamd21 in the first place?
                          • R
                            R
                            rafael156
                            Okay, thanks for the clarification.
                            i changed the processor because the USB interface was not recognized under windows and i couldn't program the board anymore. leds were lit but, so i thought that the samd must be broken.
                            the new one shows the same behavior after flashing with mysensors 2.3.1 ... so it must be somewhere due to the software.
                            can you please initiate the change to the "platform.txt" (see https://forum.mysensors.org/post/96909)?
                            tbowmoT 1 Reply Last reply
                            • R rafael156
                              tbowmoT
                              tbowmoT
                              tbowmo
                              @rafael156
                              Is it the standard gateway sketch, that you use for the SAMD? If not, could you post it here? Then I could try programming a spare samd21 board at some point in time (I do not know if I get around to it this weekend, as I have lots of projects running through my head at the moment)
                              R 1 Reply Last reply
                              • tbowmoT tbowmo
                                @rafael156
                                R
                                R
                                rafael156
                                @tbowmo yes, it is the standard "SensebenderGatewaySerial" sketch.
                                i try to reinstall the arduino ide completely on the weekend and use older versions. it is worth a try...
                                • R
                                  R
                                  rafael156
                                  #24
                                  ok, the weekend has brought a lot of information... both problems have been solved:
                                  To the Arduino Nano+W5100+NRF24:
                                  • Note versions:
                                    Clean Install (delete Dirs: ".../Documents/Arduino", "AppData", "Arduino IDE") before compiling:
                                    Arduino IDE 1.6.13
                                    Arduino AVR 1.6.18
                                    Arduino SAMD 1.6.12
                                    MySensors SAMD 1.0.5
                                    MySensors Lib 2.3.1
                                  • if no W5100 is attached, then 0.0.0.0 comes in the log
                                  • Both GNDs of the W5100 must be connected!
                                  • Voltage with +5V, if voltage transformer present
                                  • optional: fix bug of W5100: https://arduinodiy.wordpress.com/2017/04/12/the-w5100-bug/
                                  • successful log Nano_5V_16Mhz+W5100+NRF24:
                                    0 MCO:BGN:INIT GW,CP=RNNGA---,REL=255,VER=2.3.1
                                    4 TSM:INIT
                                    5 TSF:WUR:MS=5000
                                    11 TSM:INIT:TSP OK
                                    13 TSM:INIT:GW MODE
                                    320 GWT:TIN:IP=128.168.1.38
                                    1323 MCO:BGN:STP
                                    1325 MCO:SLP:MS=250,SMS=0,I1=255,M1=255,I2=255,M2=255,M2=255
                                    1330 !MCO:SLP:REP
                                    1332 TSM:READY:NWD REQ
                                    1369 TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                    1581 MCO:BGN:INIT OK,TSP=1
                                  • power consumption Nano_5V_16Mhz+W5100+NRF24: 250mA
                                  • operate the W5100 with its own +5V power supply!
                                  With 2kB SRAM, the Arduino Nano meets the minimum requirements for an ETHERNET(!) gateway (serial gateway is no problem). It can happen from time to time that the W5100 is not responsive for a short time because the nano does not follow. It is best to deactivate MY_DEBUG or use a mega with 8kB memory.
                                  My working Nano+W5100+NRF24 Sketch:
                                   * Copyright (C) 2013-2018 Sensnology AB
                                   * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                                   * Version 1.0 - Henrik EKblad
                                   * LED purposes:
                                   * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                                   * - ERR (red) - fast blink on error during transmission error or receive crc error
                                  #define MY_RADIO_RF24
                                  //#define MY_RADIO_NRF5_ESB
                                  //#define MY_RADIO_RFM95
                                  #define MY_GATEWAY_W5100
                                  #define MY_GATEWAY_MAX_CLIENTS  3
                                  //#define MY_W5100_SPI_EN 4
                                  // radio on the same spi bus.
                                  #define MY_SOFTSPI
                                  #ifndef MY_RF24_CE_PIN
                                  #define MY_RF24_CE_PIN 5
                                  #ifndef MY_RF24_CS_PIN
                                  #define MY_RF24_CS_PIN 6
                                  // Enable UDP communication
                                  //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                                  #define MY_IP_ADDRESS 192,168,1,38
                                  #define MY_PORT 5003
                                  // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
                                  // Enable inclusion mode
                                  // Set blinking period
                                  // Flash leds on rx/tx/err
                                  #if defined(MY_USE_UDP)
                                  #include <EthernetUdp.h>
                                  #include <Ethernet.h>
                                   sleep(250);    // Optional, if W5100 is rebooting
                                  • R
                                    R
                                    rafael156
                                    #25
                                    To the Sensebender Board with W5100+NRF24:
                                    • Sensebender can be flashed via Arduino IDE: Bootloader and Sketch
                                    • Note versions (work):
                                      Arduino IDE 1.6.13
                                      Arduino AVR 1.6.18
                                      Arduino SAMD 1.6.12
                                      MySensors Lib 2.3.1
                                    • Installed is an Atmel "ATSAMD21J18A-AU".
                                    • Windows 10 does not recognize the serial port after a few flashes (native USB ATSAMD21J18A-AU). Then the PC must be restarted.
                                    • the bootloader has to be flashed via SWD interface (e.g. with Atmel JtagICE3):
                                      -> install Atmel Studio 7 (for JtagICE3 drivers) and erase chip
                                      -> Connect the pins of the JTAGICE3 to Sensebender:
                                      JTAGICE3: ARM SWD Pin:
                                      Pin 1 (TCK) SWDCLK
                                      Pin 2 (GND) GND
                                      Pin 4 (VTG) VCC
                                      Pin 5 (TMS) SWDIO
                                      Pin 6 (nSRST) nRESET
                                      -> bootloader about Ardunio IDE flash: Programmer "Atmel EDBG or Atmel Sam ICE"
                                      -> usb port should now be found automatically (windows 10 has drivers already integrated, install win7.8 driver from MySensors)
                                    • sketch normal about arduino ide and port selection flashes
                                    My working Sensebender W5100+NRF24 sketch:
                                     * LED purposes:
                                    //@riss
                                    // Define sketch version
                                    #define SKETCH_VERSION "0.4"
                                    //@riss
                                    #define MY_SOFTSPI
                                    //@riss
                                    #include <SD.h>
                                    #include <drivers/ATSHA204/ATSHA204.cpp>
                                    Sd2Card card;
                                    #define EEPROM_VERIFICATION_ADDRESS 0x01
                                    static uint8_t num_of_leds = 5;
                                    static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
                                    //@riss
                                     sleep(250);      // wait for the W5100
                                    //@riss
                                    void preHwInit()
                                      pinMode(MY_SWC1, INPUT_PULLUP);
                                      pinMode(MY_SWC2, INPUT_PULLUP);
                                      if (digitalRead(MY_SWC1) && digitalRead(MY_SWC2)) {
                                        return;
                                      uint8_t tests = 0;
                                      for (int i=0; i< num_of_leds; i++) {
                                        pinMode(leds[i], OUTPUT);
                                      if (digitalRead(MY_SWC1)) {
                                        uint8_t led_state = 0;
                                        while (!Serial) {
                                          digitalWrite(LED_BLUE, led_state);
                                          led_state ^= 0x01;
                                          delay(500);
                                        } // Wait for USB to be connected, before spewing out data.
                                      digitalWrite(LED_BLUE, LOW);
                                      if (Serial) {
                                        Serial.println("Sensebender GateWay test routine");
                                        Serial.print("MySensors core version : ");
                                        Serial.println(MYSENSORS_LIBRARY_VERSION);
                                        Serial.print("GateWay sketch version : ");
                                        Serial.println("----------------------------------");
                                        Serial.println();
                                      if (testSha204()) {
                                        digitalWrite(LED_GREEN, HIGH);
                                        tests++;
                                      if (testSDCard()) {
                                        digitalWrite(LED_YELLOW, HIGH);
                                        tests++;
                                      if (testEEProm()) {
                                        digitalWrite(LED_ORANGE, HIGH);
                                        tests++;
                                      if (testAnalog()) {
                                        digitalWrite(LED_BLUE, HIGH);
                                        tests++;
                                      if (tests == 4) {
                                        while(1) {
                                          for (int i=0; i<num_of_leds; i++) {
                                            digitalWrite(leds[i], HIGH);
                                            delay(200);
                                            digitalWrite(leds[i], LOW);
                                        while (1) {
                                          digitalWrite(LED_RED, HIGH);
                                          delay(200);
                                          digitalWrite(LED_RED, LOW);
                                          delay(200);
                                    bool testSha204()
                                      uint8_t ret_code;
                                      if (Serial) {
                                        Serial.print("- > SHA204 ");
                                      atsha204_init(MY_SIGNING_ATSHA204_PIN);
                                      ret_code = atsha204_wakeup(rx_buffer);
                                      if (ret_code == SHA204_SUCCESS) {
                                        ret_code = atsha204_getSerialNumber(rx_buffer);
                                          if (Serial) {
                                            Serial.println(F("Failed to obtain device serial number. Response: "));
                                          if (Serial) {
                                            Serial.print(F("Ok (serial : "));
                                            for (int i=0; i<9; i++) {
                                              if (rx_buffer[i] < 0x10) {
                                              Serial.print(rx_buffer[i], HEX);
                                            Serial.println(")");
                                          return true;
                                        if (Serial) {
                                          Serial.println(F("Failed to wakeup SHA204"));
                                      return false;
                                    bool testSDCard()
                                      if (Serial) {
                                        Serial.print("- > SD CARD ");
                                      if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
                                        if (Serial) {
                                          Serial.println("SD CARD did not initialize!");
                                        if (Serial) {
                                          Serial.print("SD Card initialized correct! - ");
                                          Serial.print("type detected : ");
                                          switch(card.type()) {
                                          case SD_CARD_TYPE_SD1:
                                            Serial.println("SD1");
                                          case SD_CARD_TYPE_SD2:
                                            Serial.println("SD2");
                                          case SD_CARD_TYPE_SDHC:
                                            Serial.println("SDHC");
                                          default:
                                            Serial.println("Unknown");
                                        return true;
                                      return false;
                                    bool testEEProm()
                                      uint8_t eeprom_d1, eeprom_d2;
                                      SerialUSB.print(" -> EEPROM ");
                                      eeprom_d1 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
                                      delay(500);
                                      eeprom_d1 = ~eeprom_d1; // invert the bits
                                      hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
                                      delay(500);
                                      eeprom_d2 = hwReadConfig(EEPROM_VERIFICATION_ADDRESS);
                                      if (eeprom_d1 == eeprom_d2) {
                                        SerialUSB.println("PASSED");
                                        hwWriteConfig(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
                                        return true;
                                      SerialUSB.println("FAILED!");
                                      return false;
                                    bool testAnalog()
                                      int bat_detect = analogRead(MY_BAT_DETECT);
                                      Serial.print("-> analog : ");
                                      Serial.print(bat_detect);
                                      if (bat_detect < 400 || bat_detect > 650) {
                                        Serial.println(" Failed");
                                        return false;
                                      Serial.println(" Passed");
                                      return true;
                                    //@riss
                                    JCLBJ 1 Reply Last reply
                                    • R
                                      R
                                      rafael156
                                      Thanks to everyone who helped! now it would be interesting again, if it also works with the latest SAMD and arduino ide versions...?! has somebody already tested it/ been running?
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        it should not be necessary to use atmel studio to erase the SAMD21, before you reflash with arduino. The erase cycle is included in the flashing process..
                                        I haven't updated any of my SAMD21 boards the last year, so don't know if the latest arduino breaks something.
                                        alexsh1A 1 Reply Last reply
                                        • tbowmoT tbowmo
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @tbowmo said in not working Ethernet Gateway (sensebender and/or nano gateway):
                                          I updated SAMD21 (Sensebender) with the latest Arduino and nothing has been broken.
                                          I have not tested it extensively though.
