  3. Rocketscream Mini Ultra Pro V3 as gateway
10 Posts 2 Posters 2.4k Views 2 Watching
  • R
    R
    robbie deloose
    Is anyone using a Mini Ultra Pro v3 as a gateway? I have a few of them lying around and I want to use one as a gsm gateway
    I tried getting the nRF24 radio up and running before adding other components, but I seem unable to get it working.
    20128 TSM:FAIL:DIS
    20138 TSF:TDI:TSL
    30149 TSM:FAIL:RE-INIT
    30159 TSM:INIT
    30174 !TSM:INIT:TSP FAIL
    30184 TSM:FAIL:CNT=4
    I found a post about the Arduino Zero, which uses the same chip, as wel as the sensebender gateway.
    I tried using the spi pins (22-23-24), defined soft spi pins and tried using the pins used by sensebender gateway (found in the schematic).
    Also used 2 different radios, used both vbus pin, as wel as bat pin with li-ion battery connected. radio has cap soldered to it and is working on pro mini and nano.
    alexsh1A 1 Reply Last reply
    • R robbie deloose
      20128 TSM:FAIL:DIS
      20138 TSF:TDI:TSL
      30159 TSM:INIT
      alexsh1A
      alexsh1A
      alexsh1
      @robbie-deloose I have rocketscream mini ultra pro v3, but it has got rfm95 module, which I'd like to use as a gateway. I have not tried to connect it yet. I'll let you know, but I think your problem is soft spi or pins definition.
      • R
        R
        robbie deloose
        thx! I'm thinking along the same lines, as the chip is in use for the sensebender gateways. I give it another try today, but still no luck.
        schematic for mini ultra: https://github.com/rocketscream/MiniUltraPro/raw/master/MINI-ULTRA-PRO.pdf
        schematic for arduino zero: https://www.arduino.cc/en/uploads/Main/ArduinoZero-schematic.pdf
        schematic for sensebenderGW: https://www.openhardware.io/dl/5691595329c41a296a5d0fd3/design/MysensorsGW.pdf
        I've tried using pins 19,20,21 and 11,12,13
        I tried using softSPI, but this seems to give errors when used on arm:
        Compiling .pioenvs\zeroUSB\src\main.cpp.o
        Compiling .pioenvs\zeroUSB\libf5a\SPI\SPI.cpp.o
        In file included from C:\Users\robbi\.platformio\lib\MySensors_ID548/hal/architecture/AVR/drivers/DigitalIO/DigitalIO.h:31:0,
        from C:\Users\robbi\.platformio\lib\MySensors_ID548/MySensors.h:341,
        from src\main.cpp:130:
        C:\Users\robbi\.platformio\lib\MySensors_ID548/hal/architecture/AVR/drivers/DigitalIO/DigitalPin.h:32:25: fatal error: util/atomic.h: No such file or directory
        #include <util/atomic.h>
        compilation terminated.
        *** [.pioenvs\zeroUSB\src\main.cpp.o] Error 1
        compelete code:
        #include "arduino.h"
         * Version 1.0 - Rait Lotamõis
         * The TinyGSM MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker using a GSM modem or optionally an ESP8266 as a WiFi modem.
         * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
         * LED purposes:
        #define MY_RADIO_RF24
        //#define MY_RADIO_RFM95
        #define MY_RF24_CHANNEL 120
        #define MY_RF24_CE_PIN 5
        #define MY_RF24_CS_PIN 6
        #define MY_SOFTSPI
        // Enable GSM modem support
        #define MY_GATEWAY_TINYGSM
        // Define your modem
        #define TINY_GSM_MODEM_SIM800
        // #define TINY_GSM_MODEM_SIM808
        // #define TINY_GSM_MODEM_SIM900
        // #define TINY_GSM_MODEM_A6
        // #define TINY_GSM_MODEM_A7
        // #define TINY_GSM_MODEM_M590
        // #define TINY_GSM_ESP8266
        // leave empty anything that does not apply
        #define MY_GSM_APN	"hologram"
        //#define MY_GSM_PIN	"1234"
        #define MY_GSM_USR	""
        //If using a GSM modem, this stands for your GSM connection password. If using WiFi, it's your wireless password.
        #define MY_GSM_PSW	""
        //#define MY_GSM_SSID ""
        // Use Hardware Serial on Mega, Leonardo, Micro
        #define SerialAT Serial1
        // or Software Serial on Uno, Nano
        //#include <SoftwareSerial.h>
        //#define MY_GSM_RX 4
        //#define MY_GSM_TX 5
        // If your Mosquitto is old fashioned and does not support 3.1.1
        //#define MQTT_VERSION MQTT_VERSION_3_1
        #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
        // Set MQTT client id
        #define MY_MQTT_CLIENT_ID "mygateway2"
        // Enable these if your MQTT broker requires username/password
        #define MY_MQTT_USER ""
        #define MY_MQTT_PASSWORD ""
        //#define MY_IP_ADDRESS 192,168,32,220
        //#define MY_IP_GATEWAY_ADDRESS 192,168,32,1
        // MQTT broker if using URL instead of ip address.
        #define MY_CONTROLLER_URL_ADDRESS "-----"
        #define MY_PORT ----
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        alexsh1A 3 Replies Last reply
        • R robbie deloose
          compelete code:
           * LED purposes:
          #define MY_SOFTSPI
          alexsh1A
          alexsh1A
          alexsh1
          @robbie-deloose I cannot compile your sketch under any board. There is a problem somewhere, perhaps MY_PORT and MY_CONTROLLER_URL_ADDRESS are not defined?
          Try to compile and upload this sketch:
          #define MY_SOFTSPI
          #define MY_GSM_APN	"internet"
          //#define SerialAT Serial1
          #define MY_GSM_RX 4
          #define MY_GSM_TX 5
          //#define MY_CONTROLLER_URL_ADDRESS "mymqttbroker.com"
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
          #define MY_PORT 1883
          It does compile for mega2560, but does not for Arduino Zero. There is a problem with
          Please see this -> https://forum.arduino.cc/index.php?topic=371122.0
          • R robbie deloose
            compelete code:
             * LED purposes:
            #define MY_SOFTSPI
            alexsh1A
            alexsh1A
            alexsh1
            @robbie-deloose For whatever season, the compiler does not see the following directory:
            C:\Program Files (x86)\Arduino\hardware\tools\avr\avr\include\util
            Very strange. @hek - any ideas please?
            I am talking about this
            ...Arduino\libraries\MySensors/drivers/AVR/DigitalIO/DigitalPin.h
            There are several references to atomic.h, but the above location cannot be seen.
            • R robbie deloose
              compelete code:
               * LED purposes:
              #define MY_SOFTSPI
              alexsh1A
              alexsh1A
              alexsh1
              @robbie-deloose OK, success! I did not notice it, but before you define softSPI in SAMD, you have to have a line
              Otherwise, it does not compile.
              This sketch works fine for Arduino Zero (Native USB port):
               * LED purposes:
              #define MY_SOFTSPI
              • R
                R
                robbie deloose
                @alexsh1 , Thx for checking!
                Code does compile, but i'm still getting
                !TSM:INIT:TSP FAIL
                Tried different pins as well, but no luck. Did you managed to get the radio to initialise?
                alexsh1A 2 Replies Last reply
                • R robbie deloose
                  !TSM:INIT:TSP FAIL
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @robbie-deloose Most likely you have a wiring or pin number issue.
                  I have RFM95 hooked up to Mini Ultra Pro V3 and use the following setting:
                  #define MY_DEBUG_VERBOSE_RFM95
                  #define MY_RFM95_FREQUENCY RFM95_868MHZ
                  #define MY_RFM95_CS_PIN 5
                  #define MY_RFM95_ATC_MODE_DISABLED
                  #define MY_SOFTSPI
                  #define MY_SOFT_SPI_SCK_PIN 24
                  #define MY_SOFT_SPI_MISO_PIN 22
                  #define MY_SOFT_SPI_MOSI_PIN 23
                  It works like a charm. And this is from my log:
                  0;255;3;0;9;20890 MCO:BGN:INIT GW,CP=RLNGS---,VER=2.3.0
                  0;255;3;0;9;20900 TSF:LRT:OK
                  0;255;3;0;9;20910 TSM:INIT
                  0;255;3;0;9;20920 TSF:WUR:MS=0
                  0;255;3;0;9;20930 RFM95:INIT
                  0;255;3;0;9;20940 RFM95:INIT:PIN,CS=5,IQP=2,IQN=2
                  0;255;3;0;9;20960 RFM95:PTX:LEVEL=13
                  0;255;3;0;9;20970 TSM:INIT:TSP OK
                  0;255;3;0;9;20980 TSM:INIT:GW MODE
                  0;255;3;0;9;20990 TSM:READY:ID=0,PAR=0,DIS=0
                  0;255;3;0;9;21000 MCO:REG:NOT NEEDED
                  0;255;0;0;18;2.3.0
                  0;255;3;0;9;21010 MCO:BGN:STP
                  0;255;3;0;9;21020 MCO:BGN:INIT OK,TSP=1
                  • R robbie deloose
                    !TSM:INIT:TSP FAIL
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @robbie-deloose BTW, it works even with the following minimum settings:
                    given that SCK, MOSI, MISO are wired to standard pins for ATSAMD21
                    • R
                      R
                      robbie deloose
                      @alexsh1 I've put this aside for a few days to clear my head. Changed to another breadboard started froms cratch and reconnected all the wiring. Now it does works! probably a bad connection or a miswiring.
                      Thx for the help!
