  3. Home Assistant
  4. V_LEVEL light sensor not working
2 Posts 1 Posters 870 Views 1 Watching
  • KorYiK
    KorYiK
    KorYi
    I tried making a motion/light/door sensor and everything seems to work fine, except the light sensor doesn't show up in home assistant. The problem seems to be me using V_LEVEL to pass exact lux amount. As I understand it, this should work fine? I can seen in gw log that lux value and "custom_lux" prefix get transferred as expected. Any help would be appreciated as I seem to be lost at this point....
    2019-03-07 19:29:57 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 1 child 3
    2019-03-07 19:29:57 DEBUG (MainThread) [homeassistant.components.mysensors.helpers] Invalid values: {37: '1'}: sensor platform: node 1 child 3: S_LIGHT_LEVEL requires value_type V_LIGHT_LEVEL @ data[23]
    Relevant code:
    #define MY_RADIO_RF24
    #include <Bounce2.h>
    #include <Wire.h>
    #include <BH1750.h>
    #define CHILD_ID_LIGHT 3    //ID of light sensor
    uint16_t lastlux=0;         //light sensor
    BH1750 LightSensor;       //declaration of light sensor
    MyMessage msg_light(CHILD_ID_LIGHT, V_LEVEL);   //light sensor message
    MyMessage msgPrefix(CHILD_ID_LIGHT, V_UNIT_PREFIX);  //custom unit for light sensor
      LightSensor.begin();
      send(msgPrefix.set("custom_lux"));        //light sensor setup for hassio
      send(msg_light.set(lastlux));
      request(CHILD_ID_LIGHT, V_LEVEL);
      wait(2000, C_SET, V_LEVEL);
      sendSketchInfo("Motion/Door/Lux sensor", "1.0");    //info about the sensor
        uint16_t lux = LightSensor.readLightLevel();                //only send light info if the motion sensor was triggered
        if (lux != lastlux) {
          send(msg_light.set(lux));
          lastlux = lux;
    KorYiK 1 Reply Last reply
    • KorYiK KorYi
      Relevant code:
      #include <Wire.h>
      #include <BH1750.h>
            lastlux = lux;
      KorYiK
      KorYiK
      KorYi
      I was so occupied checking everything related to MySensors that I completely forgot to check the home-assistant part.
      I didn't specify the MySensors version in configuration.yaml, which defaults to 1.4 which doesn't support V_LEVEL...
      Oh well, problem solved ^^
