  3. Sensor board w/ liPo charger and fuel gauge +BMP180 +HTU21
37 Posts 10 Posters 26.9k Views 5 Watching
  • AWIA AWI
    @Anticimex Switching the Arduino is probably not a good idea :) but powering up the voltage sensitive sensors with a mosfet switched step-up converter is an option?
    AnticimexA
    AnticimexA
    Anticimex
    @AWI yes, but why bother with a mosfet for enabling the regulator (if it already have an enable signal)?
    • C
      C
      ceech
      wrote on last edited by ceech
      #22
      The main reason why I was dragged to the LTC4067 is the fact that it has so called Power path technology. It only uses the battery if there is no other available source of power. The benefit is much longer battery lifetime. It also has a proper 2A Lithium charger. Last but not least is the current monitoring, which can be translated into battery state of charge, which is another thing that interests me.
      I chose the voltage regulator for the fact that is fairly efficient and powerful even for ESP8266 modules and as simple as possible to implement. It only uses 35uA, which is as low as I ever saw. And the LTC4067 has Suspend mode that only uses a couple of uA as well.
      @tbowmo Prices for the HTU21 are lower, for me at least. And since the pinout is the same it is all for the better.
      I'll put some thought into the separate power options. The first thing that can be fairly simply done is to power the Atmega328 from the battery, and the sensors from the regulator.
      • C
        C
        ceech
        Which is more useful - an EEPROM or Flash memory chip?
        • AWIA
          AWIA
          AWI
          My vote is for flash memory, but no deal breaker
          • C
            C
            ceech
            #25
            Finally managed to put all things together and made the first two test boards. They look like this:
            Main new features are LTC4067 lithium battery charger and XC6210, a low consumption voltage regulator.
            The board comes with a Torex XC6210 3.3V voltage regulator . It has low power consumption of 35μA, while delivering at least 700mA. Voltage drop is 50mV @ 100mA.
            LTC4067 battery charger with Automatic Battery Charging/Load Switchover
            It provides power for the circuit and charges the backup single-cell lithium battery while greatly extends battery life. You can monitor the voltages and currents. It has suspend mode, which reduces current consumption to around 40μA. The power source is a small, 5V solar cell. Connections:
            analog input A1 on ATmega 328 is FAULT signal from LTC4067
            analog input A0 on ATmega328 is battery voltage
            analog input A2 is solar cell voltage
            analog input A6 is input current ( I=V/R x 1000 )
            analog input A7 is battery charge current ( I=V/R x 1000 )
            digital output A9 - drive it high to put LTC4067 in SUSPEND mode
            The two trimmer potentiometers are used to determine the current for both the input side - to better match the internal resistance of the solar cell - and for the battery charge current. At shipping they are both set to about 2.5kOhm, which set both currents to about 75mA. Please refer to technical data sheet of LTC4067 for more information. It is available here:
            Official web page for LTC4067
            Or, ask me.
            This is the back side of the board with place for BMP180, HTU21 and EEPROM chip:
            SparkmanS 1 Reply Last reply
            • L
              L
              lafleur
              It need an RFM69 radio on the board....??
              C 1 Reply Last reply
              • H
                H
                hawk_2050
                @ceech , I recently bought one of the predecessor boards to this new design. I was wondering if you had a better feel yet on likely end user pricing for this new one? Do you plan on populating all active parts, or providing them for users to place themselves? Really looking forward to this board becoming available.
                • C ceech
                  Or, ask me.
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @ceech Looks great! When do you expect to have them available for sale?
                  Cheers
                  Al
                  • sj44kS
                    sj44kS
                    sj44k
                    @ceech Some impressive work you are pulling off here! I am also interested so keep us posted when you have it available !
                    • L lafleur
                      C
                      C
                      ceech
                      @lafleur The board is meant to be used with either NRF24l01+, or ESP8266 radio modules. @hawk_2050 The price will be around 14EUR for the version without sensors, and 19EUR for the fully populated one. @Sparkman and @sj44k some boards will be available as soon as next week. Those are the test ones and since everything seem to work excellent, I'll make them available for purchase.
                      • C
                        C
                        ceech
                        #31
                        For those interested, here is a link with more detailed description of this board:
                        http://www.ebay.com/itm/331641400414?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
                        We will probably offer a bit less complex version here, on mysensors.org.
                        Enjoy.
                          MikeF
                          I've just built a version of this, using the solar cell from the Solar Motion Light identified in this project: Solar Powered Mini-Weather Station. I'm using Domoticz as the controller.
                          I'm trying to understand what the solar and battery currents represent (I had to scale these by 1000, as Domoticz will only display currents in amps). Also, at what battery voltage level will the battery start to charge? and what level of solar voltage is required? I'm also concerned that the solar cell voltage can exceed 6V in bright sunlight - is there a need for overvoltage protection on the LTC4067?
                          (I'll post details and pics in My Projects shortly.)
                          • M MikeF
                            C
                            C
                            ceech
                            #33
                            Here:
                            float readVcc()
                              signed long resultVcc;
                              float resultVccFloat;
                              delay(10);                           // Wait for Vref to settle
                              ADCSRA |= _BV(ADSC);                 // Convert
                              while (bit_is_set(ADCSRA,ADSC));
                              resultVcc = ADCL;
                              resultVcc |= ADCH<<8;
                              resultVcc = 1126400L / resultVcc;    // Back-calculate AVcc in mV
                              resultVccFloat = (float) resultVcc / 1000.0; // Convert to Float
                              return resultVccFloat;
                            int current = A6;
                            int chrg = A1;
                            int cell = A2;
                            int lipo = A0;
                            int batterycurrent = A7;
                              Serial.begin(9600);
                              float napetost = readVcc();
                              float tok = ((analogRead(current) * napetost / 1024 ) / 2500) * 1000000; // convert the ADC value to miliamps
                              float tokbaterija = ((analogRead(batterycurrent) * napetost / 1024 ) / 2500) * 1000000; // convert the ADC value to miliamps
                              float panel = ( analogRead(cell) * napetost / 1024 ) * 2; // measuring input voltage
                              float baterija = ( analogRead(lipo) * napetost / 1024 ) * 2; // measuring battery voltage
                              int polnjenje = analogRead(chrg);
                              Serial.print("Vcc = ");
                              Serial.print(napetost);
                              Serial.println("V");
                              delay(400);
                              Serial.print("Input current = ");
                              Serial.print(tok);
                              Serial.println("mA");
                              delay(400);
                              Serial.print("Charge current = ");
                              Serial.print(tokbaterija);
                              delay(400);
                              Serial.print("Solar cell voltage = ");
                              Serial.print(panel);
                              delay(400);
                              Serial.print("Battery voltage = ");
                              Serial.print(baterija);
                              delay(400);
                              Serial.print("CHRG = ");
                              Serial.println(polnjenje);
                              Serial.println("----------------------------");
                              delay(2000);
                            Improving accuracy:
                            To do so, simply measure your Vcc with a voltmeter and with our readVcc() function. Then, replace the constant 1107035L with a new constant:
                            scale_constant = internal1.1Ref * 1024 * 1000
                            where
                            internal1.1Ref = 1,1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                            Example:
                            For instance, I measure 3,43V from my FTDI, the calculated value of Vref is 1,081V.
                            So (1,081 x 1000 x 1024) = 1107034,95 or 1107035L rounded up.
                            Source: http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                            and
                            https://code.google.com/p/tinkerit/wiki/SecretVoltmeter
                              MikeF
                              @Ceech Thanks, I'll give this a try; I need to make some hardware mods first - I'm thinking of including a MOSFET in series with IN, as per datasheet.
                              • M MikeF
                                C
                                C
                                ceech
                                #35
                                @MikeF Sure, if you think it's necessary. OVI pin on the PCB is already connected to input power source. How do you plan to connect the gate of the mosfet to the OVP pin?
                                  MikeF
                                  @Ceech I guess I'm concerned that the solar cell voltage Vin might exceed 7V - which the datasheet says is the absolute max. (and the max. overvoltage threshold Vovth is 6.2V). I've been getting >6.5V, with the solar cell not pointing directly at the sun (i.e., not due south / azimuth). I'll take some measurements with the solar cell disconnected. I can see that it would be very difficult to interrupt the IN connection (pin 12); is there another way of limiting the solar cell voltage?
                                  • M MikeF
                                    C
                                    C
                                    ceech
                                    #37
                                    @MikeF Well not limiting, but reducing. Connect one or two ordinary diodes in series with the input, and you will reduce the voltage for 0.7V for every diode.
