  3. Help please.
Help please.
9 Posts 4 Posters 1.5k Views 3 Watching
  • R Offline
    R Offline
    Rado Mori
    I need sample 2560 scene controller schematic.
    I'm new in mysensors and total noob. My idea is building a simple weather station for monitoring just out/in temp, humidity and pressure (for begining). I buy mega kit for scene controller but don't know how to connect together with nrf24l01 and dht22.
    Thear is no schematic or wiring diagram.
    Please help.
    mfalkviddM D 2 Replies Last reply
    • R Rado Mori
      Please help.
      Hi @rado-mori, welcome to the MySensors community!
      Have you looked at these examples?
      https://www.mysensors.org/build/connect_radio#nrf24l01+-&-arduino for NRF24 wiring
      https://www.mysensors.org/build/humidity for DHT (wiring and code)
      https://www.mysensors.org/build/scene_controller (wiring and code)
      • R Rado Mori
        Please help.
        @rado-mori Welcome to MySensors. Does it have to be a 2560? That seems a bit overkill for what you are trying to do. A 328P should handle those few things.
        R 1 Reply Last reply
        • D dbemowsk
          R Offline
          R Offline
          Rado Mori
          @dbemowsk
          Thank's for replay. I'm just start with MySensors and planing to expand the system later.
          I finding that cheap kombination (2560, shield and 3.2" ILI3941 TFT) but cannot find any schematic (wiring, pinouts, working example ,..).
          First I wish make simple weather station, later wish to add Rpi as Gateway and more Automation sensors and actuators,...
          skywatchS 1 Reply Last reply
          • R Rado Mori
            @dbemowsk
            skywatchS Offline
            skywatchS Offline
            skywatch
            @rado-mori Whilst you can do what you initally want with just arduino pro-mini + nrf24l01 to arduino pro-mini + nrf24l01, it will have to be reprogrammed to use with mysensors as in this case there is no gateway or controller present.
            Mysensors requires a gateway (a place all data is sent to and from). This is beacuse all remote sensors are 'nodes' that communicate via this gateway back to a controller (a controler is a thing that displays values. stores values, takes actions etc...).
            So, if you want to later add other items you should get a gateway and controller working first with a test node. Another tip is to do things a little at a time. Get one sensor working properly, then add another, then add the screen. Often I will have several arduinos testing code for different sensors and get it working that way before combining into a single code for one node.
            The 'Build' at the top of this page will give you a lot of help, after that it is hours and hours of searching the forums here and looking online as well...
            • skywatchS skywatch
              R Offline
              R Offline
              Rado Mori
              @skywatch
              Thank's for replay
              If I corect understend:
              • first build the gateway (Rpi with Nrf24l01)
              • then controller (Openhab or Homeassistant)
              • next The nodes
                Is not posible to turn the flow?
              -first nodes (one)
              -next monitoring one by one
              -then connecting all together ??
              And What is the easyest way to build a home monitoring (and automating) system?
              Sorry , I'm noob with this. I'm just making a cnc kit and 3d printer.
              • skywatchS Offline
                skywatchS Offline
                skywatch
                @Rado-Mori It will be best to do the first option, believe me I have been through this! ;) Build a gateway, connect to a controller and get them working. Then add nodes one at a time (you can have over 200 sensors/actuators per node.....).
                The easiest way will depend on what skills you already have and a detailed idea of what you want to achieve. Best to go slowly and learn. It's a hassle, but worth it in the end.
                The controller is the central brains, without it you will have many more problems. For nodes to send data to the controller they need a gateway. There are many controllers out there. I use mycontroller (not myscontroller which is different).
                3d printing is very addictive.....I hope you have lots of spare time! :)
                  R Offline
                  R Offline
                  Rado Mori
                  @skywatch
                  Thank's for your answer.
                  I'm steel confused.
                  I'm build some DHT nodes and 2004 monitor for it. Now, I will connect all together.
                  Rpi with nrf24 as gateway wish to bi a database, but trying with Openhab is unsucsesible (Not work). For start will make a easy upgradable system mostly with nrf24.
                  If that, with My Sensors, not posible, then must build with WiFi (It's power hungry).
                  Is any oder system? Or technic?
                  Time is a relative.
                  • R Rado Mori
                    @skywatch
                    I'm steel confused.
                    Time is a relative.
                    skywatchS Offline
                    skywatchS Offline
                    skywatch
                    @rado-mori Please see this for answer of how mysensors work.....
                    https://www.mysensors.org/about/network
                    If you can make this so what you want then you are in luck. But you will be wasting time to make a system that is not mysensors enabled if you want it to be in the future.
                    As for controller may I suggest you try https://mycontroller.org/#/home
                    12.1k
