  3. Home Assistant
  4. HA not seeing sensors.
7 Posts 3 Posters 2.4k Views 3 Watching
  • el tigroE
    el tigroE
    el tigro
    I'm going crazy, any help appreciated.
    My setup.
    Pi 3 controller on ethernet.
    HASSOS recently installed.
    MQTT.
    NodeMCU 09 wifi gateway.
    My sensors switch / lamp.
    Nodes and gateway talking fine. Controller and gateway register with MQTT server on HA (mosquitto).
    Nodes are registering with gateway but not getting 'initial value' back from HA and repeats request.
    This happened after I updated HA. Any help appreciated.
    monteM 1 Reply Last reply
    • el tigroE el tigro
      My setup.
      MQTT.
      monteM
      monteM
      monte
      @el-tigro do you send initial values after presentation? HA won't recognize your sensor if it doesn't send values. You can check what exactly it needs to be sent here: https://www.home-assistant.io/components/mysensors/. There are separate pages for each sensor type with sketch examples.
      el tigroE 1 Reply Last reply
      • monteM monte
        el tigroE
        el tigroE
        el tigro
        @monte
        Node debug. Appears to register but then no response to initial value request.
        3 TSM:INIT
        4 TSF:WUR:MS=0
        11 TSM:INIT:TSP OK
        12 TSM:INIT:STATID=66
        15 TSF:SID:OK,ID=66
        16 TSM:FPAR
        53 TSF:MSG:SEND,66-66-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        192 TSF:MSG:READ,0-0-66,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        197 TSF:MSG:FPAR OK,ID=0,D=1
        2060 TSM:FPAR:OK
        2061 TSM:ID
        2062 TSM:ID:OK
        2064 TSM:UPL
        2069 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        2082 TSF:MSG:READ,0-0-66,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        2086 TSF:MSG:PONG RECV,HP=1
        2089 TSM:UPL:OK
        2092 TSM:READY:ID=66,PAR=0,DIS=1
        2096 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        2103 TSF:MSG:READ,0-0-66,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        2110 TSF:MSG:SEND,66-66-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
        2118 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
        4127 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Grey Lamp
        4135 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        4144 TSF:MSG:SEND,66-66-0-0,s=2,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
        4150 MCO:REG:REQ
        4153 TSF:MSG:SEND,66-66-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
        4176 TSF:MSG:READ,0-0-66,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        4182 MCO:PIM:NODE REG=1
        4184 MCO:BGN:STP
        4185 MCO:BGN:INIT OK,TSP=1
        Sending initial value
        4190 TSF:MSG:SEND,66-66-0-0,s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
        Requesting initial value from controller
        4198 TSF:MSG:SEND,66-66-0-0,s=2,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=OK:
        6207 TSF:MSG:SEND,66-66-0-0,s=2,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
          @monte
          3 TSM:INIT
          4 TSF:WUR:MS=0
          11 TSM:INIT:TSP OK
          15 TSF:SID:OK,ID=66
          16 TSM:FPAR
          2060 TSM:FPAR:OK
          2061 TSM:ID
          2062 TSM:ID:OK
          2064 TSM:UPL
          2089 TSM:UPL:OK
          4150 MCO:REG:REQ
          4184 MCO:BGN:STP
          el tigroE
          el tigroE
          el tigro
          wrote on last edited by el tigro
          @el-tigro
          I have other nodes / devices and they all do the same.
          HA config
          mysensors:
          gateways:
          - device: '/dev/ttyUSB0'
          persistence_file: '/config/myhouse/mysensors.json'
          - device: mqtt
          persistence_file: '/config/myhouse/mysensors4.json'
          topic_in_prefix: 'mygateway1-out'
          topic_out_prefix: 'mygateway1-in'
          optimistic: false
          persistence: true
          retain: true
          version: '2.0'
          mqtt:
          broker: 192.168.1.***
          port: 1883
          client_id: home-assistant-1
          keepalive: 60
          Gateway code
          #define MY_BAUD_RATE 115200
          #define MY_GATEWAY_ESP8266
          #define MY_MQTT_CLIENT_ID "Gateway"
          #define MY_ESP8266_SSID "BTHub6-36PM"
          #define MY_ESP8266_PASSWORD "88888888"
          #define MY_ESP8266_HOSTNAME "Gateway node"
          #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1,***
          #define MY_IP_GATEWAY_ADDRESS 192,168,1,***
          #define MY_PORT 1883
          #include <ESP8266WiFi.h>
          void presentation() {
          // Send locally attech sensors data here
            @el-tigro
            HA config
            mysensors:
            gateways:
            - device: mqtt
            optimistic: false
            persistence: true
            retain: true
            version: '2.0'
            mqtt:
            port: 1883
            keepalive: 60
            Gateway code
            el tigroE
            el tigroE
            el tigro
            NODE CODE
            #define MY_NODE_ID 66
            #include <Bounce2.h>
            #define RELAY_PIN 7
            #define BUTTON_PIN 6
            #define CHILD_ID 2
            #define RELAY_ON 1
            #define RELAY_OFF 0
            #include <avr/wdt.h>
            #include <Wire.h>
            #define RESETWATCHDOG
            Bounce debouncer = Bounce();
            bool state = false;
            bool initialValueSent = false;
            MyMessage msg(CHILD_ID, V_STATUS);
            Serial.begin(115200);
            pinMode(BUTTON_PIN, INPUT_PULLUP);
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(10);
            digitalWrite(RELAY_PIN, RELAY_ON);
            pinMode(RELAY_PIN, OUTPUT);
            sendSketchInfo("Grey Lamp", "1.0");
            present(CHILD_ID, S_BINARY);
            wdt_reset();
            if (!initialValueSent) {
            send(msg.set(state ? RELAY_ON : RELAY_OFF));
            Serial.println("Requesting initial value from controller");
            request(CHILD_ID, V_STATUS);
            wait(2000, C_SET, V_STATUS);
            if (debouncer.update()) {
            if (debouncer.read() == LOW) {
            state = !state;
            send(msg.set(state ? RELAY_ON : RELAY_OFF), true);
            if (message.isAck()) {
            Serial.println("Receiving initial value from controller");
            initialValueSent = true;
            state = (bool)message.getInt();
            digitalWrite(RELAY_PIN, !state ? RELAY_ON : RELAY_OFF);
              Michał Szura
              Hi
              I have different question doesn't this line give you errors?
              • el tigroE
                el tigroE
                el tigro
                SOLVED..... Such a mug, such a small error. One character missing in wireless key.
