  3. Home Assistant
  4. How to send custom data to mysensors node?
2 Posts 1 Posters 966 Views 1 Watching
  • E
    E
    eMdzeJ
    I need set some parameters in Home Assistant and send it to mysensors node. I far I know I can do it by S_CUSTOM sensor type and V_VARx values.
    But how to set it in Home Assistant? I want to have input text/number field in Home Assistant to store parameters.
    For example:
    I've temperature sensor and want to switch relay (starts fan) when temperature reach parameter set in Home Assistant input number field.
    • E
      E
      eMdzeJ
      V_VARx not working because HA saves states/data from mysensors to file. When you update sensor data from HA that file doesn't change.
      I can send data to node by V_TEXT messages using notify service. It works :)
